Manufacturing Industry News
EGA Spectro Alloys Receives Aluminum Melting, Homogenizing Equipment
EGA Spectro Alloys has received key thermal processing equipment for the second phase of its aluminum billet recycling expansion in Rosemount, ...
Groundbreaking Marks Next Phase of Arkansas DRI Project
U.S. Steel has broke ground on a $1.9 billion direct reduced iron (DRI) production facility in Osceola, Arkansas, marking the next ...
Aluminum Heat Exchanger Manufacturer Orders Second CAB Line
An aluminum heat exchanger manufacturer has ordered a semi-continuous controlled atmosphere brazing (CAB) line to increase production capacity for tube-and-bar heat ...
Hadrian Plans Pennsylvania Foundry Modernization for Naval Steel Casting Capacity
Hadrian has acquired a Pennsylvania foundry and plans to increase domestic production capacity for naval-grade steel castings. The project is intended ...
Graphite Electrode Business for EAF Steelmaking to Change Ownership
A global graphite electrode manufacturing and electric arc furnace (EAF) optimization business is set to change ownership in a transaction involving ...
Amaero Begins PM-HIP Production for US Submarine Components
Amaero has moved its powder metallurgy-hot isostatic pressing (PM-HIP) operations into low-rate initial production for the U.S. submarine industrial base. The ...
Deacero Casts First Steel Billet at New Mini-Mill
Deacero has cast its first steel billet at a new mini-mill in Ramos Arizpe, Mexico, marking a milestone in the facility's ...
Toptech Brings Vacuum Heat Treatment In-House
Toptech Polska, a precision metal components manufacturer, is bringing vacuum heat treatment in-house with a new furnace capable of high-pressure gas ...
Titanium Sintering Capacity Moves Into Production
A Virginia titanium manufacturer has commissioned additional hydrogen sintering and phase transformation (HSPT) capacity and begun production sintering of titanium components ...
Algoma Steel Produces First Heat from Second EAF
Algoma Steel has produced the first heat of liquid steel from its second electric arc furnace, advancing the Canadian steelmaker's transition ...
New Sinter Plant Supports Integrated Steel Production
A new traveling-grate sinter plant with an annual production capacity of approximately 5.75 million tons is planned as part of a ...
US Steel Greenlights New Hot Strip Mill
A new hot strip mill at U.S. Steel's Mon Valley Works will incorporate walking beam furnaces for slab reheating as part ...
Sintered Magnet Production Capacity Set for Tenfold Increase
A U.S.-based critical materials manufacturer has begun receiving additional vacuum sintering and magnet production equipment that is expected to increase annual ...
Amaero Plans Capital Equipment Investment Following IPO Pricing
Amaero Inc., a Tennessee-based producer of refractory and titanium alloy metal powders and near-net-shape components using powder metallurgy-hot isostatic pressing (PM-HIP), ...
New Heat Treatment Cell Designed for Nitriding
A new modular heat treatment cell has been developed to handle nitriding, nitrocarburizing, carbonitriding, and dry oxidation, giving manufacturers the ability ...
Partnership Strengthens Regional Access to Nitriding Technologies
A new sales representation agreement will provide regional support for plasma nitriding, gas nitriding, and plasma coating technologies across six U.S. ...
Heat Treat Tooling Manufacturer Adds Melting, Casting Capacity
A North American manufacturer of high-temperature heat treatment tooling and high-alloy components is adding melting, fabrication, and casting capacity through the ...
Solcoa Plans Vacuum Induction Rare Earth Production
Solcoa Industries is planning a 500-ton-per-year rare earth metalmaking facility in Nevada that will use vacuum induction heating as part of ...
Two CAB Furnaces Boost Aluminum Brazing
AKG Group, a manufacturer of heat exchangers and cooling systems has ordered two controlled atmosphere brazing (CAB) furnace lines to add ...
New American Steel Complex Integrates DRI, EAF Production
Mesabi Metallics plans to invest $18 billion to integrate its Minnesota iron ore operations with a new Iowa steelmaking complex using ...
Blast Furnace Reline Returns Furnace to Service
U.S. Steel has completed a $350 million blast furnace reline at its Gary Works operation in Indiana, returning more than 2 ...
Induction Smelting Project Targets Low-Grade Ores for Steelmaking
A nearly $3 million federally funded project will develop an induction smelting process to produce pig iron from low-cost, low-grade ores, ...
U.S. Manufacturer Brings Aluminum Brazing In-House
A U.S.-based cooling systems manufacturer is adding in-house aluminum brazing capabilities for the production of large heat exchangers, a move designed ...
New Austenitizing Furnace To Process Heavy-Duty Wear Components
A new high-temperature austenitizing furnace system will support the production of large, heavy wear components used in ground-engaging equipment. Designed for ...
Electric Arc Furnace Steelmaking Resumes After Power Outage
Electric arc furnace (EAF) steel production has resumed at Algoma Steel following a temporary suspension caused by an unplanned power generation ...
Army Task Order Scales Titanium Sintering Capacity for Defense Components
IperionX has received a second U.S. Army task order to expand domestic titanium component manufacturing through hydrogen sintering and phase transformation ...
Nitriding Furnace to Treat Aluminum Extrusion Dies
An aluminum profile manufacturer has ordered a gas nitriding furnace to treat extrusion dies, improving their wear resistance and extending service ...
New Aluminum Remelting Facility Begins Billet Production
RevoCast Aluminum Billets Ltd., a manufacturer of recycled aluminum billets, has begun production at a new aluminum remelting facility in British ...
Arkansas Steelmaker Adds Second Electric Steelmaking Mill
Hybar LLC, a U.S. steel producer, is adding a second continuous minimill at its Osceola, Arkansas, operation that will integrate electric ...
Acquisition Expands Industrial Burner Systems Portfolio
An acquisition is expanding an industrial combustion technology portfolio to include complete burner systems for thermal processing applications, bringing combustion controls, ...
ERP Task Force Addresses Changing Software Landscape
A new industry task force will provide heat treating companies with educational resources and peer guidance as they evaluate enterprise resource ...
New DRI Plant Planned for US Pig Iron Production
NEMO Industries is planning a new direct reduction iron (DRI) plant in Louisiana to strengthen domestic pig iron production by supplying ...
Steelhead Acquires Visual Shop, Bluestreak
Steelhead Technologies, a software provider serving the heat treating and metal finishing industries, has acquired Visual Shop and Bluestreak, bringing together ...
Aluminum T6 System Boosts Production
An advanced aluminum T6 heat treatment system has been selected to replace an existing line that no longer meets increasing production ...
Commercial Heat Treater Launches Vacuum Hardening Operation
Kalírna Desire is opening a new commercial heat treat facility in a region that has so far lacked local infrastructure for ...
Vacuum Heat Treat Capacity Grows in Northeast
Solar Atmospheres, a commercial heat treater, is preparing to expand vacuum heat treating capacity in the Northeastern United States as construction ...
Stainless Steel Producer Upgrades Ladle Furnace Capacity
Outokumpu Stainless USA will upgrade its secondary metallurgy operations with a new 180-ton twin ladle furnace at its Calvert, Alabama, facility. ...
Steelmaker to Double Rebar Production Capacity
Hybar LLC has secured financing to support construction of a second electric rebar mini mill, a project that will expand domestic ...
Vacuum Degassing Plant to Boost Steel Quality
A new vacuum degassing plant is expected to increase meltshop performance and capacity while enabling the production of a larger volume ...
Vacuum Heat Treat Capacity Grows for Metal AM
AGF DEFCOM, a metal additive manufacturing company, has expanded its vacuum heat treating capacity with the addition of a second furnace, ...
New Vacuum Furnace Serves Turbine Production
A commercial heat treater is expanding its vacuum heat treating capabilities for gas turbine components with the addition of a high-performance ...
Electric Arc Furnace Upgrade Advances Steel Production
A Pennsylvania steel mill will undergo an electric arc furnace (EAF) modernization project designed to improve productivity, operational reliability, and process ...
Fringe Friday: New Program Supports Specialty Alloy Development Initiatives
We’re celebrating getting to the “fringe” of the weekend with a Heat Treat Fringe Friday installment: a new specialty alloy development ...
Intalus Enhances Metal AM Capacity with New Machine Order
Intalus, a U.S.-based manufacturer, is expanding its metal additive manufacturing capabilities through the acquisition of two electron beam powder bed fusion ...
Arkansas DRI Plant Bolsters Steel Supply Chain
A new direct reduced iron (DRI) facility planned for U.S. Steel's Arkansas-based steelmaking facility, Big River Steel Works, in Osceola, Arkansas, ...
Debinding, Sintering Operations Consolidated in North Carolina
DSH Technologies, a provider of debinding and sintering services for metal injection molding (MIM) and additive manufacturing (AM) applications, has relocated ...
Controls Upgrade Modernizes Steel Mill Operations
Steel Dynamics Inc. (SDI) is modernizing automation systems at its Butler, Indiana, hot strip mill through a controls upgrade that supports ...
AP60 Upgrade Increases Aluminum Smelting Capacity
Rio Tinto has begun commissioning a major expansion of its AP60 aluminum smelter technology in Quebec, increasing primary aluminum production capacity ...
12-Foot Vacuum Furnace Expands Titanium Processing Capacity
Solar Atmospheres, a North American commercial heat treating company, has expanded its vacuum heat treating and titanium processing capabilities with the ...
Strip Casting Systems Support Magnet Production
New strip casting systems for rare-earth magnet manufacturing are expected to support thermal processing operations tied to neodymium-iron-boron (NdFeB) magnet production ...
Mega-HIP Expands Precious Metals Capacity
ITP Co. Ltd. has installed a new hot isostatic pressing (HIP) system to strengthen production capabilities for precious metal equipment used ...
Vacuum Furnace Builder Goes from Kitchen Startup to Employee Ownership
Signature Vacuum Systems, a small manufacturer of vacuum furnace equipment, recently implemented an Employee Ownership Trust (EOT), placing partial ownership of ...
Andis Company, a U.S.-based manufacturer of grooming tools, has completed a controls upgrade on a vacuum heat treat furnace used for ...
Fringe Friday: US Lab Selects PGA Platform for New Materials Initiative
We’re celebrating getting to the “fringe” of the weekend with a Heat Treat Fringe Friday installment: a plasma gas atomization (PGA) platform selected by ...
Vacuum Furnace Boosts Tool Steel Processing
Treatnorte, a commercial heat treatment company, will add a new vacuum furnace to support vacuum heat treatment of tool steel, improving ...
Groundbreaking Marks Heat Treat Furnace Expansion In Iowa
Advanced Heat Treat Corp. (AHT), a global provider of commercial heat treat services and metallurgical solutions, is expanding its Waterloo, Iowa, ...
Vacuum Furnace Consolidates Multiple Heat Treat Processes
A manufacturer has placed an order for a vacuum furnace system designed to replace multiple heat treating processes, consolidating operations into ...
Bodycote Improves Heat Treat Efficiency with On-Site Hydrogen Production
Bodycote, a global provider of advanced heat treatment and specialist thermal processing services, is improving heat treat efficiency and reducing process ...
Fringe Friday: Custom Split Tube Furnace Designed for High-Temperature Materials Testing
We’re celebrating getting to the “fringe” of the weekend with a Heat Treat Fringe Friday installment: a custom split tube furnace engineered for elevated-temperature ...
New US Service Center Strengthens High-Temperature Electrification Capabilities
A new service center in Concord, North Carolina, is now fully operational. Kanthal, an Alleima company, added U.S.-based production and service ...
California Facility Adds 10-Bar Vacuum Furnace
Solar Atmospheres has announced the installation and full commissioning of a new 10-bar vacuum furnace at its Fontana, California, further expanding ...
Strategic Acquisition in High-Temp Insulation Segment
NUTEC Inc., a manufacturer of industrial insulation and fire protection products, has acquired ETS Schaefer LLC, a provider of monolithic ceramic ...
Refractory Production Facility Opens in Missouri
A new production facility for lightweight refractory materials has opened in Missouri, increasing supply for furnace-lined industrial processes that operate at ...
Sintering Furnace Enhances Powder Metal Production
Metco Industries has added a new seven-zone continuous belt sintering furnace to improve process control and consistency in the production of ...
Custom Box Furnace Designed for Strict Operational Constraints
A specialized U.S. government manufacturing facility will install a custom thermal processing system to support expanded high-temperature operations. The new box ...
New Diffusion Hardening Vessel Expands Stainless Steel Processing in North America
Bodycote has installed a new treatment vessel at its Mooresville, North Carolina facility, expanding its capability to process larger stainless steel ...
Induction Hardening and Gas Nitriding Capacity Added at Alabama Plant
Advanced Heat Treat Corp. (AHT) has expanded induction hardening and gas nitriding capacity at its Cullman, Alabama facility, increasing throughput and ...
Firearm Manufacturer Increases Carburizing Heat Treat
A defense sector manufacturer has selected a vacuum furnace solution to support carburizing and heat treatment of steels used in firearm ...
A new downstream aluminum fabrication facility is being planned in Inola, Oklahoma, to convert molten primary aluminum into value-added products. The ...
JISCO Carbon Steel, a global steel producer serving international markets including North America, has commissioned a new integrated CSP®-HSM line at ...
Mold Manufacturer Moves Heat Treatment In-House
BTOMEC Ferramentaria e Usinagem de Precisão Ltda. has invested in a vacuum furnace to establish its own in-house hardening capability. The ...
Urschel Furnace Upgrade Reinforces Food Processing Industry
Urschel Laboratories, a global manufacturer of precision food-cutting equipment based in Chesterton, Indiana, has placed an order for a new high-capacity ...
Continuous CAB Line Production Boosts Capacity
A manufacturer specializing in advanced thermal management solutions has expanded its production capabilities with the delivery of a new continuous controlled ...
New Acquisition in North America Boosts Refractory Support
TFL Incorporated, a Houston-based provider of refractory materials and precast shapes, has been acquired in a move that strengthens resources and ...
Jupiter Aluminum Industries (JUPALCO), part of the Jupiter Group, has ordered two aluminum coil annealing furnaces to support production at its ...
Century Aluminum Company has emphasized that next-generation EX smelting technology will be critical to the development of its new primary aluminum ...
Atlantic Fire Brick Acquisition Strengthens Refractory Services
Atlantic Fire Brick & Supply has been acquired in a move that strengthens refractory solutions for industrial thermal processing operations across ...
IperionX To Produce Titanium Components for Military Vehicles
IperionX has received a prototype order for lightweight titanium components intended for U.S. Army heavy ground combat systems. The order directly ...
Exclusive License Brings Bell Furnace Quenching Systems to North America
Gasbarre Thermal Processing Systems announced the expansion of its modular furnace offerings for the North American market through an exclusive licensing ...
JSA/Metalline Acquired, Increased Finishing Equipment Technical Support for Midwest
A business transition is expanding sales coverage, technical support, and response times for manufacturers serving the plating and general metal finishing ...
IperionX continues to advance domestic titanium manufacturing and thermal processing capabilities in a recent commitment to reduce long lead times for ...
Bhuj Polymers Advances Production Capabilities with New Vacuum Furnace
Bhuj Polymers, an established precision components manufacturer, is expanding its manufacturing capabilities through the acquisition of a state-of-the-art vacuum furnace. This ...
Southwest Metal Treating Corp Expands Capabilities with New Cryogenic System
Southwest Metal Treating Corp (SWMT), an AS9100D/ISP 9001:2015 and Nadcap-accredited facility specializing in providing precision heat treating services, announces the addition ...
3 Furnace Upgrades for Environmental Impact
Three aluminum melting furnaces at a Novelis site have been updated to achieve a more than 40% reduction in carbon footprint ...
Solar Atmospheres has commissioned and installed a new 10-bar vacuum furnace at its Greenville, SC facility. The horizontal furnace can process ...
Heat Treater Expands Furnace Operations and Nadcap Readiness
A metal heat treater is expanding their operations with a new vacuum furnace. The high-pressure quench vacuum furnace will be used ...
IperionX Receives $25M to Accelerate Titanium Production
Iperion X has received $25 million from the U.S. Department of War to support the build-out of a resilient, fully integrated, ...
Fringe Friday: Woodward To Build $200 Million Aerospace Manufacturing Facility
We’re celebrating getting to the “fringe” of the weekend with a Heat Treat Fringe Friday installment: Woodward, Inc, a manufacturer with in-house heat treat ...
Fringe Friday: Riverspan Partners Acquires United Titanium
We’re celebrating getting to the “fringe” of the weekend with a Heat Treat Fringe Friday installment: Riverspan Partners has acquired United Titanium, a leading ...
2 Large Scale Furnaces for Automotive and Marine Propulsion
Two intensive furnace projects are poised to bring heat treating to the automotive brake rotor and marine propulsion systems industries. An ...
Fringe Friday: New Green Steel Technology Transforms Domestic Iron Ore
We’re celebrating getting to the “fringe” of the weekend with a Heat Treat Fringe Friday installment: a project that revolutionizes domestic steel making. Learn ...
IperionX To Receive $12.5 Million for Primary Titanium & Components
IperionX Limited will receive $12.5 million from the U.S. Department of Defense (DoD) to accelerate the scale-up of a resilient, low-cost, ...
Step Back from the Fire, Caveman, and Think
Heat treatment is a hands-on science and it can be easy to forget about continuing education. In today's edition of Combustion ...
Busch Group Adds 60,000 sqft US Facility
Busch Vacuum Solutions, part of the Busch Group, a global company in vacuum and overpressure technology, has announced the development of ...
News from Abroad: Electric Expansions
In today's News from Abroad installment, we highlight an electrically heated aging furnace for aluminum production, an electric arc furnace as ...
Dual-Chamber Vacuum Furnace for Increased Hardening Capacity
A plant is expanding its heat treatment capacities with a dual-chamber vacuum furnace equipped with an oil quenching system and an ...
Atlas Acquires EVRAZ North America; Forms Orion Steel
Atlas Holdings has announced the formation of Orion Steel following the completion of the acquisition of EVRAZ Inc. North America and ...
Gas-Fired Car Bottom Furnace for Heat Treatment
A heat treater in the U.S. Midwest anticipates greater heat treat abilities of ingots with a new gas-fired car bottom furnace. ...
Wieland Grows In-House Heat Treat With New Furnace
A new reheating walking hearth furnace has been commissioned for Wieland Rolled Products North America. The new furnace has a processing ...
Furnace Expansion for Portland Heat Treater
Stack Metallurgical Services has added a new furnace to their Portland facility. The furnace adds significant capacity for stress relieving, sub-annealing, ...
$74 Million Heat Treat Expansion for Alabama Facility
SSAB is investing approximately $74 million to expand its heat treat capacity at its Axis, Alabama facility. The expansion will support ...
Industrial Ceramic Products Acquired by Allied Mineral Products
Industrial Ceramic Products, Inc. (ICP) has been acquired by Allied Mineral Products, LLC (Allied). The acquisition includes all ICP’s product lines, ...
Michigan Heat Treater Increases Gas Nitriding Capacity
Advanced Heat Treat Corp. (AHT) has increased operations at their Monroe, Michigan facility with additional gas nitriding equipment. Chad ClarkPlant ManagerAdvanced ...
Walking Beam Furnace On The Way for Steel Casting
A walking beam furnace has been ordered for the in-house operations of the largest steel subsidiary of the Salzgitter Group. The ...
Tariffs, Supply Chains, & Heat Treating
Heat Treat Today publishes twelve print magazines annually and included in each is a letter from the publisher, Doug Glenn. This letter is from ...
New Strip Casting Furnace Commissioned in U.S. Collaboration
A vacuum induction melting strip casting furnace (VIM-SC) was commissioned for a manufacturer in North Carolina. Consarc Corporation and Vulcan Elements announced ...
U.S. Steel: An Uncertain Future Turned $4 Billion Steel Mill
In today's editor's page, Heat Treat Today's Daily Editor, Tiffany Ward, provides a history of U.S. Steel and the recent Nippon ...
28,000-Square-Foot Facility Acquired for U.S. Heat Treat Company
The largest family-owned heat treating company in the United States announced the opening of its seventh U.S. heat treat operation. Jamie ...
Deal For First U.S. Smelter in 45 Years
A site in Oklahoma is the planned future home of a $4-billion dollar smelting operation. The plant would have a capacity ...
Low-Carbon Aluminum Casting Products for the Automotive Industry
Hanne SimensenExecutive Vice PresidentHydro Aluminium Metal Two companies have signed a letter of intent (LOI) to develop low-carbon aluminum casting products ...
Vacuum Furnaces for Dies for Automotive Industry
A company in the automotive industry is expanding its hardening plant and has ordered a new vacuum furnace. The furnace introduces ...
ECM Mexico Now Operating As MEXVAC ECM, S.A. DE C.V.
The Mexico heat treatment industry has a new vacuum furnace supplier entity – ECM Mexico, doing business as MEXVAC ECM, S.A. ...
15th CAB Line Ventures to Mexico
After 15 years of collaboration, a new CAB furnace designed for production of heat exchangers for delivery vehicles, trucks, and cars ...
Major Auto Maker Pledges $20 Billion for US
A major automaker announced a $20 billion investment in United States-based manufacturing. Hyundai's investment, which the automaker described as a pledge ...
News from Abroad:
In today's News from Abroad installment, we highlight processing and initiatives that aim to improve operations and improve sustainability. Read more ...
Modernized Walking Beam Furnace at thyssenkrupp Steel
thyssenkrupp Steel, a supplier of high-grade flat steel, recently upgraded with the modernization of a walking beam furnace installed at the ...
High-Purity Alumina Calcining Processes Support Expansion
One of North America's leading producers of ultra-high-purity alumina and associated products recently boosted its advanced manufacturing operations with a 50m-long ...
Railway Supplier voestalpine To Expand with Hardening Line
voestalpine Fastening Systems, a supplier to the railway industry, is bolstering its hardening processes of steel parts with a technological line ...
Chiz Bros. Acquires Advanced Material Science
Chiz Bros., which provides solutions for refractory and high temperature applications in the metals industries, recently completed the acquisition of Advanced ...
CMMC 2.0: Why Waiting Is a Costly Mistake
The Cybersecurity Maturity Model Certification (CMMC) 2.0 compliance process is detailed and complicated, and businesses in the defense industrial base (DIB) ...
Conticon Boosts Copper Rod Production with Heat Treat Capabilities
Conticon, a steel-wire manufacturer, is expanding production capabilities at its North American plant by installing a CONTIROD® CR3700 line to address the ...
News From Abroad: Initiatives, Processing for a Better World
Fringe Friday: Sustainable Long Steel Production in Texas
We're celebrating getting to the "fringe" of the weekend with a Heat Treat Fringe Friday covering news about a Texas steelmaker making ...
US DOE Industrial Decarbonization Initiative Update: January 2025, the Trump Effect
The heat treating industry is under pressure to reduce its greenhouse gas emissions (GHGE), and the response has been a noble ...
CAB Capabilities Expanded for Heat Exchanger Manufacturer
An aluminum heat exchanger manufacturer specializing in the production of heat exchangers recently expanded its production capabilities with a semi-continuous furnace for ...
Manufacturer Expands Aluminum Heat Treat Capabilities
A provider in the power solutions industry has enhanced its operations with a heat treat drop-bottom furnace for the solution heat ...
22 News Chatter To Keep You Current
Heat Treat Today offers News Chatter, a feature highlighting representative moves, transactions, and kudos from around the industry. Enjoy these 22 news ...
Case Study: Adapting a Continuous Rotary Hearth Furnace to an Existing ‘Brownfield’
Are you looking to expand in-house heat treat operations on a brownfield industrial site? These sites can bring complications due to ...
News From Abroad: Launches and Strategic Steps
In today’s News from Abroad installment, we highlight changes in personnel, production lines, and facilities throughout the industry, including the launch ...
US Heat Treater Adds Furnaces, Marquenching Capabilities
A commercial heat treating company recently added new furnaces and process improvements to its operations in order to serve manufacturers in ...
Fringe Friday: Atomizer Enhances Capabilities at Metals Company
We're celebrating getting to the "fringe" of the weekend with a Heat Treat Fringe Friday covering news about a metals company enhancing ...
Loy Instrument Partners To Expand Capabilities
Loy Instrument, Inc., which supplies process control and combustion solutions for heat treaters in multiple industries, has been acquired by Relevant Industrial, ...
Agriculture Solutions Manufacturer Bolsters Furnace Line
A manufacturer which supplies agricultural ground engaging solutions has improved its production efficiency with two roller hearth furnace systems. The furnaces ...
Leak Detection Seminar Highlights Best Practices
Retech Systems LLC welcomed participants to its Buffalo, NY, facility for a leak testing seminar last month, unveiling best practices and ...
AHT Expands Footprint and Nitriding Capacity
A North American nitriding company recently announced a building expansion to accommodate more equipment and services. The new production space at ...
Heat Treater Expands Capacity and Footprint
Solar Atmospheres in Souderton, PA, has commissioned two additional 2-bar vacuum furnaces, expanding its capabilities to meet demand in the aerospace ...
Retech Expands with ReMelt Scientific
Retech, which provides advanced technologies for melting and refining reactive and refractory metals, has acquired ReMelt Scientific, broadening the capabilities for ...
18 News Chatter To Keep You Current
Heat Treat Today offers News Chatter, a feature highlighting representative moves, transactions, and kudos from around the industry. Enjoy these 18 news ...
News from Abroad: Mergers & Partnerships Ring in the New Year
Today’s News from Abroad installment highlights a new year ringing in acquisitions, partnerships and mergers resulting in increased production and expanded ...
ECM Group Expands with Acquisition in Italy
The ECM Group, a provider of solutions and services for industrial heat treatment companies with a subsidiary based in North America, recently acquired Vacuum Service & Maintenance ...
Pittsburgh-based Providers Merge, Strengthen Heat Treatment Capabilities
A global supplier of equipment, systems, and digital solutions for several manufacturing sectors recently announced that it has acquired Bloom Engineering, ...
US Defense Contractor Upgrades with Vacuum Retort Furnace
A U.S. military firearms manufacturer announced its plan to update its in-house stress relieving operation with a new vacuum retort furnace. ...
The Holiday Edition of This Week in Heat Treat Social Media
Welcome to the first installment of Heat Treat Today's This Week in Heat Treat Social Media of 2025, and today we ...
News from Abroad: Growth Via Innovation
The growth we're reporting on in today’s News from Abroad installment is not just about expansions but also modernization and innovation. ...
Naval Ship Builder Expands 3D Parts Annealing Capabilites
A major ship builder has acquired a vacuum furnace for the Additive Manufacturing Division at the company's new Manufacturing Center of ...
Fringe Friday: Decarbonizing the Bright Annealing Process
We're celebrating getting to the "fringe" of the weekend with a Heat Treat Fringe Friday installment: a project that targets reducing the ...
CG Thermal Adds Second Facility To Expand Production Capacity
A provider of process technology for harsh and corrosive process streams has expanded its operations with an additional 13,000 square foot, ...
News from Abroad: Growth from Mergers, Alliances, and Broadened Capabilities
Today’s News from Abroad installment is all about growth in the global heat treating market. A heat treater expands its contract ...
Heat Treater Expands Hardening Plant Capabilities
A heat treater with surface hardening capabilities recently expanded its operational line with a vacuum furnace. The new equipment offers a ...
Furnace Manufacturers Form Partnership To Bolster Processing in North America
AFC-Holcroft (AFCH), an industrial furnace manufacturer based in Wixom, MI, recently announced a strategic partnership with Tokai Konetsu Kogyo Co., Ltd. ...
Steel Industry Acquisitions: Updates Following US Election
As U.S. election results were announced last week, several steel industry players are in the midst of acquisitions that could mean ...
West Coast Semiconductor Supplier Bolsters In-House Heat Treat
A semiconductor industry supplier recently ordered an extra-large 2-bar vacuum furnace specific to the company's high-temperature process. The new addition will ...
Sandia National Laboratories Expands Production Capabilities with 2 Vacuum Furnaces
Sandia National Laboratories has acquired two horizontal vacuum furnaces for one of its production labs in Albuquerque, NM. The furnaces will ...
Special Springs Enhances Production Capabilities with Nitriding System
Springs and gas cylinders manufacturer Special Springs has bolstered its heat treating capacity with a new nitriding turnkey system. By adding ...
Commercial Heat Treater Expands Capabilities with 12th Vacuum Furnace
HART-TECH has expanded its capabilities with a vacuum furnace that will allow for the heat treatment of multiple steel types and ...
News from Abroad: New Technologies and Sustainability Initiatives Result in Industry Growths and Closures
Today’s News from Abroad installment highlights some of the ups and downs in the global heat treating market which are largely ...
MIHEU Expands with 4th Vacuum Furnace
MIHEU, a commercial heat treater for the steel processing industry, recently expanded its vacuum furnace line for processing large dies at ...
FNA Week in Heat Treat Social Media
Welcome to a special edition of Heat Treat Today's This Week in Heat Treat Social Media. We've discovered a furnace-full collection ...
Plibrico Opens New Refractory Production Facility
Plibrico, a manufacturer and installer of superior aluminosilicate and high alumina monolithic refractories, has expanded its footprint with the grand opening ...
Lukasiewicz– IMN Enhances R&D with Vacuum Furnace
Łukasiewicz – the Institute of Non-Ferrous Metals (Łukasiewicz – IMN) recently expanded its heat treating operations with a VIM furnace for ...
News from Abroad: Cutting Edge Processes, First-in-Industry Achievements, and State-of-the-Art Upgrades
Today’s News from Abroad installment highlights global accomplishments from pilot programs in gas recovery and a successful trial run of biomass ...
Sanbao Group Boosts Heat Treatment Capabilities with 3 Annealing and Coating Lines
Steelmaker Sanbao Group has expanded its heat treatment operations with three annealing and coating lines for non-grain oriented (NGO) silicon steel. ...
Volkan Steels Expands Production Capabilities With Nitriding/Nitrocarburizing System
A tool supplier has boosted its production capabilities with the installation of a new nitriding/nitrocarburizing system, expanding its heat treatment services ...
Furniss & White Broadens Production at Heat Treat Facility With High-Performance Alloy Series
Furniss & White has partnered with a stainless steel technology company to produce its castings at its heat treatment facility using ...
News From Abroad: Looking Forward to Production Efficiency, Sustainability
Today’s News from Abroad installment examines strategies global manufacturers are investigating and enacting to move the industry toward the next generation ...
Defense Industry Manufacturer Expands Heat Treating Capabilities
A defense industry manufacturer has purchased an inert atmosphere batch oven for processing stainless steel parts in a reduced oxygen environment ...
IperionX Delivers First Titanium Furnace Production Run
IperionX, a U.S. titanium metal and critical materials company, recently delivered its first successful titanium furnace production run at the company's ...
East Coast Manufacturer To Replace Aging Fleet of Vacuum Sintering Furnaces
An East Coast manufacturer has purchased six new vacuum sintering furnaces to replace the 1980s-era sintering furnaces it has used for ...
Heat Treater’s Michigan Expansion Progressing
The Michigan expansion of a furnace manufacturer and heat treating company has advanced with the erection of the entire steel structure ...
Inductotherm Group Announces Leadership Transition
Inductotherm Group, which provides thermal processing technologies, has announced a significant leadership transition as part of a planned succession strategy of ...
SECO/WARWICK Group Expands US Footprint
The SECO/WARWICK Group, the parent company of SECO/VACUUM Technologies and SECO/WARWICK USA, has announced plans to bolster its production capacity in ...
Piston Rings Manufacturer Bolsters Production with 3rd Nitriding System
Asimco Shuanghuan Piston Ring Co., Ltd. has added a third nitriding system to its heat treating operations, enhancing piston ring production ...
Heat Treater Launches Expanded HIP Capacity Production at South Carolina Facility
A U.K.-based thermal processing service provider announced it has begun production at its facility in Greenville, SC, where it recently expanded ...
Aluminum Parts Manufacturer Increases Capacity with Melting Furnace
A melting and holding furnace with a preheat hearth and a maximum temperature rating of 1,450°F (788°C) has been shipped to ...
Furnace Manufacturer Consolidates Operations With $4M Facility, Creates 25 new jobs
A Missouri-based furnace manufacturer for the foundry, die casting and metal forming industries recently announced plans to expand its footprint in ...
$2.5B Acquisition Expands Steelmaker’s North American Reach
Cleveland-Cliffs Inc, a major supplier of steel to the automotive industry with heat treat capabilities, has announced its acquisition of Stelco ...
US DOE Strategy: Why the Heat Treating Industry?
News From Abroad: Globally, Eyes Turn to the Future
Today’s News from Abroad installment investigates the influence AI is bearing on the global field of heat treating, as well as ...
10 News chatter To Keep You Current
Heat Treat Today offers News Chatter, a feature highlighting representative moves, transactions, and kudos from around the industry. Enjoy these 10 ...
Gas Equipment Provider’s Acquisition Increases Reach to Heat Treaters
A Georgia-based provider of natural gas measurement and control products and solutions has announced the acquisition of a distribution and service ...
Two Manufacturers Expand Operations With Nitriding Systems
Nitriding systems have expanded the operations at two global companies: a gear manufacturer for the automotive industry and a fuel injection ...
Heat Treater Breaks Ground in Michigan Expansion
Robert (Bob) Hill, FASM President Solar Atmospheres of Michigan Source: Solar Atmospheres After successfully relocating and commissioning ten vacuum furnaces into ...
groundbreaking ceremony for Toyota Material Handling, banner in background, 4 men with shovels in the fg
Toyota Material Handling Expands, Adds 85 Manufacturing Jobs
Toyota Material Handling is investing nearly $100M for a new 295,000-square-foot facility at its Columbus, Indiana, headquarters, adding 85 manufacturing jobs ...
Welcome to Heat Treat Today's This Week in Heat Treat Social Media. We're looking at hot summer events, hot summertime activities, ...
5 digital screens and devices, one with a hand and finger touching a screen; background faded silver/gray design
Thermal Loop Solutions, Part 2: A Path to a Sustainable Future in Heat Treatment
What is the path forward for thermal loop systems, and how is “sustainability” at the forefront of this technology? The following ...
Digital Technology Powers Green Heat Treat
"Communication is key." As heat treating equipment and processes evolve, it becomes critical that the accompanying control systems also develop to ...
overhead view of Pittsburgh point with US Steel and Nippon Steel logos
U. S. Steel-Nippon Steel Merger Will Expand Pittsburgh Steelmaker’s Technical Base
David Burritt president and CEO U.S. Steel Source: U.S. Steel Access to technology and expertise in integrated mills are among the ...
All 21 News Chatter To Keep You Current
Heat Treat Today offers News Chatter, a feature highlighting representative moves, transactions, and kudos from around the industry. Enjoy these 21 ...
man and women right of image, bg: EBNER Group text with colorful image; left image of furnace
EBNER Group Extends Heat Treatment Reach with Stake in Furnace Manufacturer
EBNER Group, a global provider of heat treatment solutions, melting, and casting for the aluminum industry has increased its stake in ...
rectangular promo of HTR, smiling bearded man, blue background, HTR banner
Heat Treat Radio #110: Isolated Heat, the Future of Vacuum Furnaces
Heat Treat Radio host, Doug Glenn, and guest Bryan Stern from Gasbarre Thermal Processing Systems discuss the shift from single chamber ...
2024 06 News from Abroad June
News from Abroad: Furnace Efficiency and Climate Neutrality
Today’s News from Abroad installment brings us news of a climate-neutral metallurgical thermal process center in Germany, a twin-ladle furnace station ...
Allied Mineral Products Jobs
Refractory Manufacturer’s $23.5M Expansion To Create Jobs in Alabama
Thirteen new manufacturing jobs will open up with the $23.5 million expansion of an Alabama heat containment refractory production facility. The ...
Heat Treater Overhauls Aging System To Upgrade Carburizing Processes
An Italian heat treater enhanced its operations with the installation of control cabinets, allowing for real-time data analysis and more efficient management ...
Heat Treat Operations Modernize with 9 Hardening Furnaces
Nine heat treat furnaces are set to modernize the operations of a manufacturer's heat treat facilities. This move is intended to ...
Heat Treater To Receive 2 Furnaces
François Studer SA, a Swiss commercial heat treater with 45 years of experience, will advance their hardening capabilities with the order ...
In-House Heat Treat Innovates To Improve Aluminum Extrusion
Nitrex batch-type nitriding/nitrocarburizing furnaceSource: Nitrex Beymetal Alüminyum, a manufacturer in the aluminum extrusion industry and based in Türkiye, is overcoming limitations ...
2 Al Billet Homogenizers & 2 Coolers Headed Coast to Coast
Two aluminum homogenizers and two coolers are set to enhance U.S. operations for an aluminum manufacturer with locations across America. One ...
News from Abroad: Casting Metal and Forging a Venture
Today’s News from Abroad installment brings us news of casting equipment supplied in China, heat treat supplier joint venture forged in ...
Fringe Friday: Additive Manufacturing Brings Metal Processing to New Heights
We’re celebrating getting to the “fringe” of the weekend with a Heat Treat Fringe Friday a press release detailing how additive manufacturing ...
All 11 News Chatter To Keep You Current
Heat Treat Today offers News Chatter, a feature highlighting representative moves, transactions, and kudos from around the industry. Enjoy these 11 news items. ...
News from Abroad: Safer Technologies and Carbon Cutting
Today’s News from Abroad installment highlights more carbon-cutting trends from the steel industry, ranging from robots in the cast house to ...
A custom-built vacuum induction melting (VIM) equipment is set to expand thermal processing for a manufacturer, whose operations already has two VIM ...
HIP Adds Abilities to R&D Manufacturing Hub
A hot isostatic press will add a new capability to the research infrastructure already in place at the Sydney Manufacturing Hub ...
Heat Treater Completes Michigan Move
Robert (Bob) Hill, FASM President Solar Atmospheres of Western PA Source: Solar Atmospheres Solar Atmospheres of Michigan has successfully relocated from ...
US DOE Strategy Affects Heat Treaters
As heat treaters strive for a sustainable future, pressure mounts to make the right choices while running commercially viable operations. This ...
Welcome to Heat Treat Today's This Week in Heat Treat Social Media. We're looking at some compelling developments in aviation manufacturing, ...
Motorcycle Manufacturer Embarks on Sustainable Heat Treat Future
Guangdong Tayo Motorcycle Technology Co. Ltd., a Chinese manufacturer of motorcycles and bicycles, has invested in a nitriding/nitrocarburizing system, increasing sustainability ...
All 13 News Chatter To Keep You Current
Heat Treat Today offers News Chatter, a feature highlighting representative moves, transactions, and kudos from around the industry. Enjoy these 13 news items. ...
News from Abroad: Shifts for Sustainability in Steel
Today’s News from Abroad installment shares exciting news from the steelmaking world that is of international importance.   Heat Treat Today partners with ...
Manufacturer To Receive EB Furnace for Large-Ingot Casting
A North America-based company is set to receive a four-gun electron beam hearth melting furnace from their industry partner of 3 ...
Car Bottom Furnace Increases Large Component Heat Treat for Solar Atmospheres
Solar Atmospheres of Western PA recently commissioned their third car bottom air furnace. This Class 2 air furnace has a maximum ...
Fringe Friday: “So, I gave you the apple…”
We're celebrating getting to the "fringe" of the weekend with a Heat Treat Fringe Friday installment: a video unveiling the learning progress ...
Aluminum Extrusion Operations Bring Nitriding In-House
Extral SP. Z o.o., a Polish company specializing in aluminum extrusions, has bolstered its manufacturing capabilities to better serve the construction, ...
Increased HIP on the Horizon: Kittyhawk Expands with Stack HIP Acquisition
Kittyhawk, Inc., backed by the Dallas-based private equity firm Trive Capital, has acquired Stack HIP, LLC from Stack Metallurgical Group (SMG). ...
US Army Enlists Metallus for Munitions Expansion
Metallus, formerly known as TimkenSteel and a leader in high-quality specialty metals, manufactured components, and supply chain solutions, announced that the ...
Innovative Engineering Partnership To Serve North American Lithium-Ion Battery Market
EVERGREEN KILN TECHNOLOGIES, LLC, located in Niagara Falls, U.S.A., and SUZHOU KILNPARTNER Mechanical Technology Co., Ltd., located in China, officially announced ...
Vacuum Furnace for Global Wire Mesh Products Supplier in Auto Industry
A U.S.-based engineered knitted wire mesh solutions company and global supplier for the automotive, food service, and janitorial industries will receive ...
Heat Treater Adds Austempering Capabilities for U.S. Markets
Aalberts surface technologies, a global provider of specialized thermal processing, surface treatment, and material coating solutions, announced on Wednesday, February 14, ...
Supplier Expansion Anticipates Growth and Innovation for Manufacturers with Heat Treat
Lee Sobocinski President Thermal Care Inc PiovanGroup is launching a new strategic division for industrial and process refrigeration, the result of ...
Box Furnace Increases Tempering Capabilities for Castings Company
Tom Schulz Sales Manager L&L Special Furnace Source: L&L An investment castings manufacturer's heat treat department received a large floor-standing box ...
IperionX Grows with New Virginia Titanium Facility
IperionX, a producer of high-quality titanium alloys, has commissioned a titanium production facility in Virginia. Anastasios (Taso) Arima, CEO of IperionX, ...
An Overview of Cemented Carbide Sintering
Source: TAV Vacuum Furnaces Cemented carbide is often used interchangeably with other terms in the industry to describe a popular material ...
Welcome to Heat Treat Today's This Week in Heat Treat Social Media. As you know, there is so much content available ...
Second HIP Contracted For Wallwork
Bringing forward plans by two years, Wallwork Group have signed for a second hot isostatic press. Following hot on the heels ...
ECOACERO Expands Rebar Potential with New Mill
ECOACERO, an ESTRELLA Group company, has placed an order for a new rebar mill with a heat treater with North American ...
thyssenkrupp Hohenlimburg GmbH Expands Sustainable Operations with Bell-Type Annealing Plant
An Ultra Low NOx HPH®-flameless bell-type annealing plant at thyssenkrupp Hohenlimburg has achieved CO2-neutral heat treatment of precision strip. Tenova LOI ...
Cybersecurity Desk: Artificial Intelligence and Heat Treating
Artificial intelligence remains a hot topic for every industry, not least heat treating. Understanding the how and why of AI's potential ...
Fringe Friday: 5G Network Introduced for Metallurgical Industry
Sometimes our editors find items that are not exactly “heat treat” but do deal with interesting developments in one of our ...
News From Abroad: A Glimpse Into the International Market
Heat Treat Today is partnering with two international publications: heat processing, a Vulkan-Verlag GmbH publication that serves mostly the European and ...
North American Heat Treater Welcomes New Ownership
Effective November 30, 2023, Joe A. Powell has sold his remaining shares in Akron Steel Treating Company, his family's commercial heat ...
Foundry Expands 3D Printing Capabilities
A Louisiana-based foundry — a supplier of iron, stainless, and specialty alloy castings for paper/pulp, energy, mining, and petrochemical customers — ...
Fringe Friday: Nippon Steel Corporation To Acquire U. S. Steel
News from Abroad: Furnace Updates and Lowered Emissions
Aluminum Rolling Company Expands Operations with Heat Treat Software
The aluminum rolling division of ElvalHalcor S.A., Elval, has placed an order for a sustainability suite with a heat treat supplier with North ...
Double Reduction Mill Offers Sustainable Solutions for Tinplate Company
A tinplate company will receive a new order for a tinplate coating line (TCL) and tinplate double reduction mill (TDRM) from ...
Heat Treat Radio #103: US Army Veteran MG T.J. Wright — From Vietnam to Heat Treat
MG Timothy J. Wright (T.J. Wright) understands the heat from a heat treat furnace as well as the heat of engagement ...
The Canary in the Furnace: Ceramic Disks Give Early Alerts of Temperature Changes
The question in many heat treaters' minds is, "Why would I want more documentation on my furnaces?" TempTABs can act as ...
The Technology that Is Turning North America Green
Due to the Inflation Reduction Act (IRA), United States investment in the energy and transportation sectors is increasing - by some ...
Sustainability Insights: Process Heating and the Energy-Carbon Connection
"Plan, do, check, act." When it comes to caring about carbon footprint, a path forward to may seem too out-of-reach. But ...
At ASM Heat Treat? Curated Picks for Technical Sessions
Scrambling to stay up to date on all the publications that Heat Treat Today's experts have been releasing? If you are ...
From the Archives: Heat Treat Veterans
Today is a little-known holiday: National Veterans BBQ day, on which Americans are encouraged to treat veterans to a cookout as ...
Hydrogen Combustion for Silicon Strip Line at Waelzholz
A long-term test of high-efficiency and ultra-low-emission burner technology from WS Wärmeprozesstechnik at Waelzholz demonstrated that hydrogen can be used as ...
Sustainability Insights: Reducing the Carbon Footprint of Your Heat Treating Operations
Renewable fuels or hydrogen have entered the scene as these are fuels that contain little or no carbon. So, no carbon ...
The Layers of Low-Temperature Combustion Systems
The primary advantage of pre-mix burners is the reduction of comparative emissions. But converting a nozzle mix to a pre-mix burner ...
GeniCore Partners To Expand SPS Offerings in North America
Earl GoodManaging Director at Retech Systems, LLCSource: Retech Spark plasma sintering technology innovator, GeniCore, will be expanding their North American influence in ...
Feel the Heat This Valentine’s Day!
No better time to turn up the heat than Valentine's Day! Of course, we at Heat Treat Today are talking about ...
MTI Prepares for Nadcap with Rigorous Special Meeting
The Metal Treating Institute (MTI) hosted a special meeting for members at the Embassy Suites by Hilton in Downtown Pittsburgh, PA, ...
Heat Treat Radio #83: Lunch & Learn with Heat Treat Today — Austempering
Today's episode delves into the term "austempering". What is it? Why do heat treaters need to use it? For what applications ...
Manufacturing Plant Adds In-House Nitriding for Power Generation Parts
A manufacturer in Poland turns to in-house heat treating capabilities rather than outsourcing its nitriding for stainless steel power generation parts. ...
Sintering and Binder Jetting With Vacuum Furnaces
Source: TAV Vacuum Furnaces Ever heard of binder jetting (BJT)? It's an evolving technology that is quickly catching up to metal ...
Don’t Be Unique! 10 Temperature Uniformity Tips
We've assembled some of the top 101 Heat Treat Tips that heat treating professionals submitted over the last three years into todays original content. If ...
Furnace Diagnostics for Validation, Preventative Maintenance, and R&M
One of the most important advances in batch integral quench (BIQ) furnace systems has been the development of innovative control systems. ...
U.S. Defense Contractor Expands Heat Treat Capabilities
Vacuum Sintering Furnace from Signature Vacuum Systems, Inc. Source: Signature Vacuum Systems, Inc. A United States defense contractor will expand their ...
Heat Treating With Salts
Jerry Dwyer Market Manager Hubbard-Hall "Successful heat treating begins by understanding the make-up of the steel that is to be treated." Heat ...
Heat Treat Case Study: The Installation of 17 Ovens and Kilns
Time for a solid case study. In this Heat Treat Today Technical Tuesday feature, José P. Sanchez, part of Ceramics Business Unit in Nutec Bickley, ...
Liberty Wire Johnstown Upgrades Controls for Continuous Furnace Lines
A Pennsylvania producer and provider of steel wire and rod products, Liberty Wire in Johnstown, PA, underwent an intensive nitrogen-methanol controls ...
New Nitriding Furnace Installed at Solar Atmospheres
Solar Atmospheres of Souderton, PA, has received a new, state-of-the-art vacuum gas nitriding furnace to support an increasing demand for high-value ...
IHEA Monthly Economic Report: No Surprises Here
"It is the time to dare and endure." Winston Churchill made that statement in 1940, and it is apropos today, as ...
Heat Treat Radio #28: Heat Treat Modeling With Justin Sims
Welcome to another episode of Heat Treat Radio, a periodic podcast where Heat Treat Radio host, Doug Glenn, discusses cutting-edge topics ...
Choosing the Right Vacuum Furnace
Source: TAV, the Vacuum Furnaces Blog It pays to carefully consider the key factors to buying a vacuum furnace (source: TAV, ...
Thermal Processing Manufacturer Helps Sterilize PPE Masks
A global manufacturer of thermal-processing and sterilizing equipment announced they are working with hospitals to prove the efficacy of their Gruenberg ...
Tips for a Healthy Vacuum Furnace System
Source: Ipsen, the Harold blog Vacuum Furnace (source: Ipsen, the Harold) A strong and healthy vacuum furnace system is essential for ...
Pros and Cons Of Remote Monitoring In Heat Treatment
Gerry McWeenyPresidentHeat Treatment Solutions Is new technology always an advantage? Do companies need to update everything or a few things? The ...
Marc Glasser on The Tools and Trade Secrets of Heat Resistant Alloy Welding
Heat resistant alloys used for heat treating fixtures, muffles, retorts, radiant tubes, and other parts are typically stainless steel or nickel ...
Machine Tool Manufacturer Streamlines with In-House Heat Treat
A machine tool manufacturer has decided to create their own "captive" heat treat department.  The company has consequently invested in two ...
  Welcome to the inaugural column of Heat Treat Today's first offering of This Week in Heat Treat Social Media. As you ...
Heat Treat Radio #27: Women in Heat Treat
High-Temp Differential-Expansion Problem and How to Solve It
    Source: Vac Aero International Inc.         If you've ever tried to braze together materials that have ...
Simulation Software and 3D Printers Improve Copper Coils
This informative feature was contributed by CENOS, a simulation software developer. Read on to learn about how 3D printing is revolutionizing ...
Global Automotive Supplier, Precious Metals Producer Purchases Continuous Belt Furnaces
Brazing Furnace for Automotive Supplier (Image Source: Abbott Furnace Co.) A diversified global automotive supplier, focused on metal forming, aluminum casting, ...
Tool and Die Industry Receives Vacuum Furnace
Dan Insogna,Southeast Regional Sales Manager for Solar Manufacturing A vacuum furnace was recently shipped to a customer servicing the tool and ...
Heat Treat Today’s Coronavirus Survey
Heat Treat Today conducted a very unscientific and highly-fluid study on the impact of COVID-19 (coronavirus) on the North American heat ...
Preventing or Controlling Compressed Air Safety Hazards
Compressed air is an essential component for most construction jobsites and production lines. For thermal operations and processing companies, compressed air ...
Medical, Additive Manufacturing Industries Acquire Two All-Metal Hot Zone Furnaces
Two all-metal hot zone furnaces were recently shipped to the medical and additive manufacturing industries. Solar Manufacturing created and shipped the ...
Buehler Marks 100 Year Anniversary of Wilson Hardness Brand
ITW Company Buehler recently celebrated the 100-year anniversary of its Wilson® hardness brand, which was originally known as the Wilson Mechanical ...
Powder Metallurgy Leader to Receive Lifetime Achievement Award
Dr. Randall (Rand) German, FAPMI, founder of German Materials Technology, will receive the Kempton H. Roll Powder Metallurgy (PM) Lifetime Achievement ...
Nickel-Titanium SMA Introduced for Elastocaloric Cooling
Scientists from the Alliance for the Development of Additive Processing Technologies (ADAPT) at Colorado School of Mines who took part in ...
Heat Treat Radio #25: A Discussion with David Wolff, Nel Hydrogen, Part 2
Hauck Heat Treatment Receives High Vacuum Furnace from Parent Company of North American Furnace Manufacturer
A Hauck HT plant located in the Netherlands recently received a unique high vacuum furnace. The all-metal high vacuum furnace from ...
Heat Treat Radio #24: A Discussion with David Wolff, Nel Hydrogen, Part 1
Nitrex Acquires Furnace Manufacturer G-M Enterprises of California
Nitrex, a global provider of fully integrated heat-treating solutions and technologies based in Montreal, Canada, acquired G-M Enterprises, a manufacturer of ...
High-Strength Al-Based Alloys Being Developed for Aerospace and Automotive
A global technology group, an industrial gases company, an additive and design company, and an engineering university in Germany have entered ...
Global Materials Engineering Group Tests Hardfacing Alloy Applications
A global materials engineering group explored alternative methods of applying a hard surfacing alloy at the ITSC conference in Japan. Engineers ...
Steel Dynamics Expands Rolling Mill, Includes 3-MW Induction Furnace
A steel producer based in Fort Wayne, Indiana, recently announced the expansion of their rolling mill, which will include a 3-MW ...
PA Heat Treater Completes Brazing/Assembly Room
A western Pennsylvania heat treat provider recently completed construction of a new brazing and assembly room, built primarily to accommodate a ...
Dr. Valery Rudnev on Equipment Selection for Induction Hardening: Single-Shot Hardening, Part 3
This article continues the ongoing discussion on Equipment Selection for Induction Hardening by Dr. Valery Rudnev, FASM, IFHTSE Fellow. Six previous installments in Dr. ...
Carburizing vs Nitriding Engineering Components
  Source: Advanced Heat Treat Corp.   Extensive wear or fatigue from friction and contact stress cause many engineering components made ...
Cooperative Research and Development Agreement Targets Improving EBM Process Reliability, Expanding Technology to SuperAlloys
A cooperative research and development agreement (CRADA) has recently been reached that has as its objective improving the process reliability of ...
Heat Treat Tips: Where You Measure Matters
Texas Aluminum Company Invests, Restarts Rolling Mill
  Source: Light Metal Age   A Texas-based aluminum company recently launched operations of its previously idled aluminum rolling mill with ...
Heat Treating, Additive Manufacturing, and Serialization
Ron Beltz, Bluestreak | Bright AM's™ Director of Strategic Accounts Additive Manufacturing (AM) is a disruptive technology trend that is continuing ...
Aluminum Producer Awarded Department of Defense Grant to Optimize Armor Plate Production
A global aluminum manufacturer of products for multiple applications, including aerospace, automotive and packaging, recently announced that its Ravenwood, West Virginia, ...
Solar Manufacturing and Bucks County PA Officials Participate in Ribbon Cutting Ceremony
Three generations of the Jones family. This picture taken just moments before the Ribbon Cutting Ceremony shows (l-r) Trevor Jones, CEO ...
Palladium Disappears Down SC River in Daring Chemical Plant Heist
      Earlier this year, four 100-pound drums filled with palladium—which is comparable in value to gold—were stolen from a ...
Vacuum Furnace Manufacturer Relocates Pennsylvania Operations
Jim Nagy, President of Solar Manufacturing A Pennsylvania vacuum furnace manufacturing company has recently relocated its operations to provide more space ...
Seasonal Cooling Water Adjustments for Induction Power Supplies
Heat Treat Today recently released the latest round of 101 Heat Treat Tips in the fall 2019 issue of Heat Treat ...
Michigan Heat Treat Equipment Manufacturer Completes Building Expansion
Premier Furnaces new 40,000 sq. ft. facility in Farmington Hills, MI. A Michigan-based heat treat equipment manufacturer recently announced a major ...
Future-proofing Melting Operations
Sven-Olaf Sauke, head of R&D at ZPF GmbH, is responsible for research and development at ZPF GmbH and works on innovative ...
Heat Treat Provider Expands Capacity with New Facility, Equipment
New building opens for ThermTech of Waukesha, Wisconsin. A heat treating services provider based in Waukesha, Wisconsin, recently completed an 11,000 ...
10 Heat Treat Tips to Whet Your Appetite
Heat Treat 2019 is coming, and one of the great benefits of gathering with a community of heat treaters is the opportunity ...
Gary Burdardt, market development manager with Frigel North America There’s only one constant about technology. It’s always evolving—revealing new innovations and ...
Metal AM Technology Developer Plans to Open First U.S. Facility
  Source: Chatham Star-Tribune   A German developer and provider of 3DMP metal 3D printers and technology recently announced that the ...
Simulation of Induction Heating of Steel Billets for Forging
This article was written by Dr. Vadims Geza, chief scientist at CENOS. More information on CENOS Platform can be found here. ...
Steel Product Manufacturer Announces Ohio Expansion
A global steel product company recently reported plans to expand its successful Delta, Ohio, steel plant. BlueScope Steel, a leading manufacturer ...
Indiana Furnaces Manufacturer Breaks Ground on Expansion
  Source: The Journal-Gazette   A rendering of McLaughlin Furnace Group’s new facility in Avilla A heat treating equipment manufacturer in ...
Dr. Valery Rudnev on Equipment Selection for Induction Hardening: Single-Shot Hardening, Part 2
Texas Chiller Manufacturer Commissions CAB Furnace for In-House Brazing
A manufacturer of custom industrial chillers based in Houston, Texas, recently purchased a controlled atmosphere brazing (CAB) furnace line to conduct ...
Ohio Manufacturer Receives Upgrades to Plant’s Heat Treatment Equipment
An Ohio manufacturer of processing equipment recently received heat treating upgrades to its facility from a heat treat controls system manufacturer, ...
U.S. Army Research Lab Invests to Develop Powerful Metal Powder 3D Printer
The Combat Capabilities Development Command Army Research Laboratory, also known as ARL, recently awarded a 3D engineering and manufacturing company a $15 ...
Refractory Supplier Celebrates Manufacturing Facility Expansion
A supplier of refractory products and services in North America recently celebrated the completion of its phase one facility expansion plan. ...
Domestic Steel Producer & Recycler Selects New Flat Roll Mill Site
A domestic steel producer and metals recycler chose Sinton, Texas, as the site for the company's new electric-arc-furnace (EAF) flat roll ...
Vacuum Furnace Manufacturer Adds Advanced Firing Capabilities
A high-temperature vacuum and controlled atmosphere furnace manufacturer recently invested in new equipment for advanced firing capabilities. Centorr Vacuum Industries recently ...
Heat Treat Tips: Testing & Compliance
Heat Treat Company Donates Vacuum & Brazing Furnace to Lehigh University
A thermal processing company donated a $300,000 commercial-grade vacuum heat treating and brazing furnace to Lehigh University's materials science program to ...
Induction Heat Treat: Considerations for Inductor Design
  Source: Fluxtrol.com Induction heat treaters know that proper coil design is crucial to increasing longevity, improving production quality, and cutting ...
Heat Treat Equipment Manufacturer Partners with Tech Giant, Develops Augmented Reality System
A major provider of innovative heat processing solutions recently developed an augmented reality (AR) system in conjunction with a global technological ...
10 Heat Treat Tips: Vacuum Furnaces
Heat Treat 2019 is coming, and one of the great benefits of gathering with a community of heat treaters is the opportunity to ...
Powder Metal Alloys Facility Expansion to Support A.M. Demand
A North American manufacturer of powder metal products recently announced plans to expand its Pennsylvania facility, adding new production capabilities to ...
Dr. Valery Rudnev on . . . Equipment Selection for Induction Hardening: Single-Shot Hardening, Part 1
This article continues the ongoing discussion on Equipment Selection for Induction Hardening by Dr. Valery Rudnev, FASM, IFHTSE Fellow. Six previous installments in Dr. Rudnev’s ...
International Demographic of Bright World of Metals Factor in Success
Friedrich-Georg Kehrer, the Global Portfolio Director for Metals and Flow Technologies at Messe Düsseldorf GmbH After five eventful days at the ...
Cleaning Workpieces: Vacuum Vapor Degreasing
Source: VAC AERO International   In order to maintain the cleanliness of workpieces and baskets or fixtures in the vacuum heat ...
Heat Treater Expands Nitriding, Induction Hardening Capacity
A heat treat and metallurgical services company recently unveiled plans to expand two of their four facilities this summer to better ...
Manufacturer Buys Extrusion Equipment, Expands Facility
A Minnesota company recently added an aluminum extrusion press and plans to expand its facility to accommodate the new purchase. Tom ...
Roller Chain Company Joins Bearing, Power Transmission Producer
A large Ohio manufacturer of bearings and power transmissions recently purchased an established roller chain company to enhance their distribution and ...
Steel Manufacturer Holds Grand Opening for Spooler Expansion
    Source: Independent News Media Inc.   A steel manufacturer recently opened an addition to its Mesa, Arizona, facility featuring ...
Induction Heating System Improves Motor Production
The parent company of a U.S.-based induction heating equipment manufacturer was selected to supply an induction heating system to an international ...
Induction Heat Treatment & the Role of Simulation Software
Dr. Mihails Scepanskis is the CEO and co-founder of CENOS LLC. Induction heating is an efficient way to quickly heat electrically ...
Dr. Valery Rudnev, FASM, IFHTSE Fellow, Honored To Deliver Heat Treat Lecture
Dr. Valery Rudnev, FASM, IFHTSE Fellow, was selected to be the Woodside lecturer at the most recent ASM Detroit Chapter meeting. ...
Heat Treat Furnace Manufacturer Contracts with Defense Materials Manufacturer
The parent company of a western Pennsylvania-base heat treat furnace manufacturer recently announced a partnership with a Serbian defense materials manufacturer ...
Plans for “Largest Continuous ERW Tube Mill”
A Chicago-based manufacturer recently announced the construction of  "the world’s largest continuous ERW tube mill," according to the project's supplier. Capable ...
Heat Treat Expansion for HPH Bell-Type Furnace Plant
Source : Strategic Research Institute, SteelGuru Image Source: Tenova A Magnitogorsk, Chelyabinsk (Russia) company has placed a new contract for the ...
Heat Treat Tips: Industrial Gases & Combustion
Dr. Valery Rudnev on … Equipment Selection for Induction Hardening: Continuous and Progressive Hardening, Part 3
This article continues the ongoing discussion on Equipment Selection for Induction Hardening by Dr. Valery Rudnev, FASM, IFHTSE Fellow. Dr. Rudnev previously reviewed equipment selection ...
HRL Laboratories Registers New 3D-Printed Aluminum Alloy
Aluminum Association Creates Registration System for Additive Alloys Beginning with HRL’s First-Ever 3D-Printed High-Strength Aluminum HRL Laboratories, LLC, is commercializing its ...
Heat Treat Equipment Upgrades Part of Industrial Solutions Plant Investment
  Source: PharosTribune.com   Heat treat equipment upgrades were included in the investments made at a global industrial solutions company that ...
SDB Furnaces Shipped to Metal Treating Facility
Mark Schahczinski, Sales Engineer, Wisconsin Oven Corporation A metal treating company based in Raleigh, North Carolina, recently purchased five electrically heated ...
Major U.S. Steelmaker to Invest in Endless Casting & Rolling Technology
A U.S. integrated steel producer headquartered in Pittsburgh, Pennsylvania, recently announced that it will invest more than $1 billion to construct ...
Prevent Catastrophic Fuel-Delivery Accidents: On Valve Safety Trains in Heat Treating Equipment
Robert Sanderson, PE, Rockford Systems, LLC This article on the critical role of valve safety trains in the prevention of catastrophic ...
DC53 “Only as Good as the Heat Treatment It Receives”
. Source: International Mold Steel, Inc. . DC53 Steel, a general purpose cold work mold and die steel with exceptional strength and ...
Heat Treatment of FDM Parts to Determine Effect on 3D Printing: UT-Arlington Study
  Source: 3DPrint.com   A University of Texas at Arlington thesis student recently investigated thermal annealing to determine how to increase ...
Heat Treat Tips: Safety and Cost-Saving Hacks
Heat Treated Steel to be Produced at Ohio River Plate Mill
A steel manufacturer recently announced that it will build its new state of the art steel plate mill in Brandenburg, Kentucky, producing ...
Dr. Valery Rudnev on . . . Equipment Selection for Induction Hardening: Continuous and Progressive Hardening, Part 2
Heat Treat Line Expanded at Ontario Facility
A family-owned commercial heat treating company recently expanded the capabilities of its Ontario-based facility with the purchase of two batch furnaces. Cambridge Heat ...
Heat Treat Control Panel: Best Practices in Digital Data Collection, Storage, Validation
When processing critical components, heat treaters value and demand precision in every step of the process — from the recipe to ...
Heat Treat Tips: How to Install an Ammonia System
UBQ Furnace Installation Expands Production Capacity
Several universal batch quench (UBQ) furnaces were purchased and installed over the course of 2018 to support the growth in business ...
Heat Treat Tips: Alloy Fabrications
Dr. Valery Rudnev on . . . Equipment Selection for Induction Hardening: Continuous & Progressive Hardening, Part 1
This article continues the ongoing discussion on Equipment Selection for Induction Hardening by Dr. Valery Rudnev, FASM, IFHTSE Fellow. Previously, Dr. Rudnev ...
Construction Advances at PA Vacuum Furnace Manufacturing Facility
William Jones, owner, Solar Atmospheres The new facility of an eastern Pennsylvania vacuum furnace manufacturing company is beginning to take shape ...
Meet the Consultants: Madhu Chatterjee
Heat Treat Today recently unveiled its Heat Treat Consultants page in the October 2018 print edition (available in digital format here) and at FNA in Indianapolis, Indiana. We offer ...
United States Steel to Restart Construction of Electric Arc Furnace
David B. Burritt, U.S. Steel President & CEO United States Steel Corporation announced recently the restart of construction on a technologically ...
Heat Treat Tips: Make and Stick to a Clear Preventative Maintenance Program
Common Sense Guidelines for Loading Parts in Vacuum Furnaces
  Source: VAC AERO International   From minuscule medical implants to massive aerospace engine parts, vacuum furnaces process components that come in ...
Salt Bath Nitriding Process Monitored by Data Logger
A distributor of data loggers, paperless recorders and data acquisition equipment recently supplied a surface treatment company with runtime data collection ...
Registration Open for IHEA’s Online Learning Course
Jack Marino Registration is open for IHEA’s Fundamentals of Industrial Process Heating Online Learning Course that begins on April 15, 2019. ...
Registration Open for Forge Fair 2019 in Cleveland
In May 2019, the forging industry will come together to showcase their products and services at Forge Fair, North America’s largest ...
“Metallic Wood”: Strong as Titanium
  Source: Medium.com   The study was led by James Pikul, Assistant Professor in the Department of Mechanical Engineering and Applied ...
40 Under 40 Highlight: Christina Somogye
In 2018, Heat Treat Today introduced one of its most popular features, the 40 Under 40 Awards for young, up-and-coming talent in the North American heat treat ...
UK Heat Treater Invests in N. American Facility
The world’s largest provider of heat treatment and specialist thermal processing services based in Macclesfield, United Kingdom, is pleased to announce plans ...
“Sign” Leads Firearms Maker to New Manufacturing Location
  Source: Times-Enterprise   A firearms maker from New York looking for a more spacious location for its business recently announced ...
Carbon Science Center to Pioneer Research for Multiple Applications
A global leader in materials science recently celebrated the grand opening of its new multi-million dollar development center which will pioneer ...
EAF Mill Returns to Life After Almost 10 Years Idle
A Texas-based steel distributor recently restarted its facility in Mingo Junction, Ohio, after being idle for 3,545 days. The JSW USA ...
Acquisition of EAF Mill Expands Industrial Group’s U.S. Operations
A Texas-based steel products manufacturer with EAF capacity that produces a diverse line of high-quality value-added steel products was recently acquired ...
Dr. Valery Rudnev on Equipment Selection for Scan Hardening, Part 3
Dr. Valery Rudnev on . . .  Induction Hardening Tips: Equipment Selection for Scan Hardening, Part 3 This is the third installment of ...
BIQ Furnace Repeat Order Expands Line at North Carolina Heat Treat Facility
A thermal processing equipment manufacturer based in Maumee, Ohio, recently supplied a batch integral quench furnace for a metal treating company ...
Heat Treat Today Contributor to Present Webinar on Induction Heating Challenges
Heat Treat Today Technical Tuesday contributor, Dr. Valery Rudnev, FASM, IFHTSE Fellow, "Professor Induction", and Director of Science and Technology at Inductoheat, ...
Planned Steel Plate Mill to Include Heat Treat Processing
A North American steel and steel products manufacturer recently announced plans to build a state-of-the-art plate mill with heat treating included ...
Steelmakers Announce Investments of $5.6B in U.S. Steel Mills
  Source: NWI Times Two major international steel corporations recently announced plans to invest in existing steel mills in along the ...
Heat Treat Tips: Quenching
3D-Printed, Robot-Built Bridge Traversed by Pedestrians in Test, Next Stop: Spanning a Canal in Amsterdam
  Source: ThomasNet.com   At 41 feet long and 21 feet wide, weighing in at nearly 10,000 pounds, the world's first ...
Applying PID to Temperature Variances in Vacuum Furnaces
  Source: Solar Manufacturing   Controlling process temperature with accuracy and without extensive operator involvement is a crucial task in the ...
Ohio Heat Treat Provider Acquired, Joins Holdings Group
John Hubbard, chairman of Thermal Process Holdings Following the acquisition of a Wisconsin heat treat company, finalized last week, an industry ...
The Workhorses of Industry: High-Strength, Heat-Treated Bolts & Fasteners
  Source: Bayou City Bolt   A comparison of minimum tensile strength of heat-treated and non-heat-treated fasteners One would be hard-pressed ...
Acquisition of Wisconsin Heat Treat Company to Expand Value-Added Services
John Hubbard, Chairman of TPH A Wisconsin heat treating company has been acquired by an industry holdings group in a bid ...
Heat Treat Tips: Induction Heating — Stuff You Should Know
Steelmaker Invests in Q&T Production at Alabama Plant
A Swedish steelmaker is responding to the increase in demand for quenched and tempered (Q&T) steels in the U.S. by investing the ...
Sacrificial Lambs: Hardness Testing and Heat Treating
  Source: Gear Technology   Charles D. Schultz, president of Beyta Gear Service In a recent blog post at Gear Technology, Charles ...
Nevada, Wisconsin Construction Equipment Manufacturer Expansion Includes Heat Treat
A manufacturer and supplier of earth-moving equipment recently announced expansion plans that include two of its brands building new facilities in ...
Steelmaker Completes Acquisition of Rebar Facilities
A steel and metal manufacturer based in Irving, Texas, which includes heat treating in the processes it provides recently announced the ...
Recognizing the U.S. Veterans Within the Heat Treat Industry
Although Veteran's Day, set aside to honor military veterans -- those who served in the United States Armed Forces -- is November 11, ...
Heat Treat Today’s Meet the Consultants: Adeel Karim
Heat Treat Today recently unveiled its Heat Treat Consultants page in the October 2018 print edition (available in digital format here) and ...
Specialty Alloys Firm Enhances AM Capabilities with Powder Lifecycle Technology Acquisition
A Pennsylvania producer and distributor of premium specialty alloys recently announced it has acquired a leader in the development and supply of ...
Steel Rail Producer Looks to Invest in Mill Expansion
A leading North American steel rail producer is looking to invest at least $200 million into the expansion of its footprint ...
CNC Machined Components Manufacturer Acquires Like Company
An industry leader in the production of CNC machined components recently announced the completion of the acquisition of a Summerville, South ...
The Heart of a Vacuum Furnace System
  Source: VAC AERO International   Heat treaters know that the heart of a vacuum furnace system is the pumping system. ...
Passenger Pod Unveiled as Race to Hyperloop Technology Speeds Up
  Source: ThomasNet.com   A company which has been moving hyperloop transport technology closer to reality is Hyperloop Transportation Technologies, which ...
Industrial-Scale Metal Alloy Powder Plant Launched in U.K.
A U.K.-headquartered company with a solid-state alloy powder technology recently announced its launch of the world's first industrial-scale metal alloy powder ...
SBQ Alloy Manufacturer Acquired by Steel Producer
A U.S. steel producer recently announced the completion of the acquisition of substantially all of the assets of a manufacturer of special ...
Marc Glasser on Heat Resistant Alloys — RA330®
This is the second of three articles by metallurgist Marc Glasser on three individual heat resistant alloys. This article will feature ...
News Chatter Follow Up: Heat Treat Facility Groundbreaking to Accommodate Equipment
  As we reported last week in the News Chatter edition of September 21, 2018, a Wisconsin-based, heat treating company recently ...
Women-Owned Metal Stamping Co Launches with Range of Services, Including Heat Treating
  A woman-owned metal stamping company with heat treating capabilities serving a broad range of industries, including automotive, aerospace, energy, medical ...
Cooling the Vacuum Furnace: 5 Tips for Prevention, Maintenance
    Source: TAV: The Vacuum Furnaces Blog   Andrew Alborghetti of TAV Vacuum Furnaces It's frustrating enough for furnace operators ...
Tubing Order Largest Yet for Virginia Metals Producer
  A corporation based in Richmond, Virginia, that produces metals equipment for a broad range of manufacturing applications recently announced that ...
Corrosion-Free Heat Treatment and Hardface Coating Systems
    Source: TechBriefs   From an article provided by the Office of Technology Commercialization and Partnerships and published at Tech Briefs, ...
Canadian Heat Treater Expands Production Capability with UBQ, UBT Furnaces
  A Canadian commercial heat treater has expanded their heat treatment production capability with the purchase of two furnaces, installed at the ...
Annealing Furnace Contracted for Belgium Plant
A Belgian stainless steel producer recently contracted with a plant supplier to the metallurgical industry to provide an annealing and pickling ...
Burners 101 for Heat Treating Efficiency and Safety
    Source: Control Engineering   Running a heat treat shop is more than just firing up a furnace to treat ...
Perfecting “Launch and Land” Systems Part of Aircraft Carrier’s Next Development Phase
    Source: Navy Times   The next phase in development has begun in the construction of the nation’s newest aircraft ...
Automated Machine Manufacturer Breaks Ground for Ohio Expansion
    Source: Times-Reporter   A Dover, Ohio, engineering consultant group and manufacturer of custom automated machine equipment recently broke ground on a ...
This is the first of three articles by metallurgist Marc Glasser on three individual heat resistant alloys. This article will feature ...
Strengthen Your “Metal Matrix” with Precipitation Hardening
  Titanium nitride precipitates in a precipitation hardened HSLA steel. Image copyright: University of Nevada, Reno via The Balance Source: Multiple ...
Heat Treat Radio #11: Laser Heat Treating with Laser Hard
Welcome to another episode of Heat Treat Radio, a periodic podcast where Heat Treat Radio host, Doug Glenn, discusses cutting-edge topics with industry-leading personalities. Below, you can ...
Family-owned Pittsburgh Metals Manufacturer Acquired by Global Metals Supplier
An international technology group recently signed a contract to acquire a Pittsburgh-area family-owned company that manufactures a wide range of shear ...
Lightweight Rocket Launchers Contracted by U.S. Army
  With a recent contract to produce its lightweight High Mobility Artillery Rocket System (HIMARS) launchers and associated hardware, a global ...
Steel Fabricator Plans Light Gauge Plant for Construction Industry
    Source: Area Development   A steel fabricator based in Lansing, Illinois, recently announced plans to launch a new manufacturing ...
Irish Mfg Group Purchases 2 Heat Treatment Lines for Mining, Drilling
  An Irish engineering group specializing in the design, manufacture, and servicing of hard-rock drilling consumables has added two separate state-of-the-art ...
Alum Supplier Breaks Ground for New Press Line
    Source: FDL Reporter A supplier for aluminum extrusions based in Fond-du-Lac, Wisconsin, recently broke ground on an expansion which will include ...
Leading Construction Steel Provider Restarts Illinois Blast Furnace
The leading supplier of steel sheet products to the diverse construction industry announced recently that it will restart the second of ...
Demanding Loads on Joints Call for Heat Treating Bolts & Fasteners
    Source: IEEE GlobalSpec   When tensile, shear or combination loads place a demand on bolted joints, heat treatment is ...
Ship Builder Acquires Tech Developer of Aluminum Probe Device
  An advanced ship manufacturer recently announced today it has acquired a technology leader in developing and deploying non-destructive, portable probe ...
Special Steel Plant in Kapfenberg, Austria, to Boast Fully Automated Melting System
  Franz Rotter, head of the High Performance Metals Division Since the official groundbreaking ceremony in April 2018, preparations for the ...
Selecting the Right Vacuum Pump Oil Starts with Knowing Your Pump
    Source: VAC AERO International   Vacuum furnace heat treaters know that one of the most critical parts of their ...
Dan Kay on Brazing Stop-Off Materials
Heat Treat Today will soon be launching Heat Treat Consultants, a resource that offers the most comprehensive listing of heat treat industry ...
Rail Systems Provider Expands Heat Treatment Capacity
Tracy Dougherty, sales manager at AFC-Holcroft   A global leader in fully integrated freight car systems for the heavy haul rail ...
John Deere to Heat Treat Execs: “Keep Innovating”
Doug Glenn, Publisher, Heat Treat Today A special report from Heat Treat Today publisher, Doug Glenn.         Mr. ...
High-tech Heat Treatment Facility Launched in Russia
A leading global iron ore and HBI producer and supplier, as well as a producer of high-quality steel, recently launched heat ...
Troubleshooting Thermocouples: Detecting Small Issues Before They Become Big Problems
    Source: GeoCorp, Inc.   Heat treating thermocouples are thermal processing sensors that allow equipment operators to accurately measure and ...
Controls, Software Upgrade at Bearings Plant to Improve Efficiency
  Bob Fincken, Super Systems National Sales Manager A Cincinnati-based heat treat technology solutions provider recently completed a controls and software upgrade ...
How to Know Which Softening Process to Use in Your Heat Treatment
    Source: Metlab Heat Treat   When steel needs to be softened to alter ductility, toughness, or properties, or to ...
California Heat Treater Expands with New Furnaces, Endo Generator
  A California-based, full-service brazing and heat treating company recently installed several pieces of equipment, including an indirect temper furnace as well ...
Heat Treat Radio #10: John Vanas on SX Oil Lifters
New Vacuum Furnace to Stress Test Defense Vessel Parts
  A new vacuum furnace will be tasked to stress test parts for the LM2500 turbine, which is used by the ...
What’s Going on Inside Your Heat Treated Part?
  Source: Gear Technology   It's no secret to heat treaters that not all methods work well on all parts and ...
Industrial Knife Manufacturer Transitions to Vacuum Heat Treating at Vietnam Facility
A manufacturing company based in Loves Park, Illinois, recently purchased a vacuum furnace with 2 bar gas quenching that will be ...
The Great Chain of the Hudson River: When Heat Treating Assisted Revolutionary Victory
  Source: RecordOnline.com Map of West Point fortifications from 1775–1783 To join the United States in the celebration of Independence Day, ...
Heat Treat Radio #9: Tom Morrison on Why Manufacturers Should Send Their Entire Heat Treat Team to FNA 2018
Tool Steel Potential Dependent Upon Heat Treating
  Source: L&L Special Furnace   With its unique ability to be used in the shaping of other materials, tool steel, ...
Restarting Blast Furnace, Steel Producer Focuses on Demand
With the restart of the second of its two blast furnaces, a major U.S. steel producer expects to step up its ...
Clarity and Accuracy in Heat Treat Specifications Ensures Quality Processing
  Source: Paulo Learning Center   Heat treaters strive to deliver parts that meet industry and manufacturers' specifications with precision, but too ...
Induction Heating Manufacturer Doubles Facility Space to Meet Demand
Tony Mazzullo, president of Ambrell An induction heating manufacturer has moved its operations to a facility twice the size of the ...
Heat Treat Today’s Induction Expert Dr. Valery Rudnev Recognized at TPiM 2018
Dr. Valery Rudnev, who writes Heat Treat Today's column, "Dr Valery Rudnev On . . . ", was recognized during the ...
Binder Removal in Vacuum Sintering
  Source: TAV: The Vacuum Furnaces Blog   Andrea Alborghetti, Technical Manager of TAV Vacuum Furnaces Heat Treat Today previously posted Parts 1 ...
Indiana Steel Operations Changing Hands, Includes Galvanizing Line
An Indiana steelmaker recently acquired the flat roll operations of steel producer of hot roll coils, located in Terre Haute, Indiana, ...
Gyro Stabilizer Finished with Heat Treating at Texas Forge
Seakeeper Gyro Stabilizer A closed die forging company, headquartered in Ellwood City, Pennsylvania, recently launched a new marine product line for ...
The Pros and Cons of Gas and Ion (Plasma) Nitriding
  Source: AHTcorp.com   The compound zone acts as a ceramic skin protecting the metal underneath from corrosion. (Photo credit: Advanced ...
PA Heat Treater Expands Production Capability with UBQ, UBT Furnaces
A precision parts heat treating company based in western Pennsylvania recently invested in a universal batch quench (UBQ) integral quench furnace ...
World’s First Carbon-free Aluminum Smelting Process Developed in Joint Venture
An Australian-British metals and mining corporation based in London in conjunction with a Pittsburgh-based aluminum producer recently announced an innovative process to ...
Heat Treatment Included in JV to Inaugurate Swiss Precision & Assembly Plant in India
  Source: Udaipurkiran   Our "Best of the Web" feature today brings you a story about an initiative in India to ...
Metals Manufacturer Marks Growth with Second Micro Mill in Oklahoma
A steel and metals manufacturer based in Irving, Texas, which processes materials and services through a network of facilities that includes ...
Buffalo-based Heat Treatment Provider Building Multiple Carbon Fiber Production Lines
Dr. Bill Stry, senior process technology engineer at Harper International A global leader in complete thermal processing solutions recently extended the ...
Sintering Si3N4 Powder-to-Part Process Launched
  Source: Superior Technical Ceramics   A Vermont-based ceramics solutions specialist and manufacturer recently announced in a white paper the introduction ...
Steel Producer Implements HD Spray Technology
A new HD (high definition) spray technology was implemented and successfully commissioned in the two-strand slab caster of a global steel ...
Russian Hydraulic Cutting Tool Manufacturer Launches Commercial Heat Treatment
A Russian manufacturer of hydraulic cutting tools and rescue and emergency equipment recently extended its range of services by offering commercial ...
Precision Heat Treat, Aftermarket Suppliers Announce Cooperation
A German heat treat aftermarket supplier recently reached a cooperation with a European heat treating manufacturer for the production and distribution ...
Heat Treating Mold Base Materials for Optimal Conditions
  Source: ETMM-online   Heat treating plays a critical role in the making of a mold base, notes an Austrian manufacturer ...
Heating Capacity Increased with Reopening of Swedish Mill
With the recent reopening of its drawing mill in Hallstahammar, Sweden, a leading supplier of industrial heating technology and resistance materials ...
Aluminum Extrusion Producer Increases No. American Coverage with Acquisition, New Facilities
A North American extrusion and forging grade billet producer recently announced plans to proceed with new aluminum remelt facilities for billet ...
Good Design Practices Lengthen Induction Tooling Life
  Source: Fluxtrol.com   Induction heat treaters know that proper coil design is crucial to increasing longevity, improving production quality, and ...
Auto Components Manufacturer to Restart Heat Treating Facility
A refractory materials provider in Newark, New York, recently announced its acquisition of the assets of a refractory sales and service ...
Heat Treating Enables Handgun Conversions
Adam Devine, CEO, co-founder, and head of R&D, Ranger Point Precision A Texas-based manufacturer of custom-built, match-grade rifles and performance parts ...
Gas Supplier, Process Controls Group Launch Heat Treatment Collaboration
A global provider of industrial furnace controls and process automation solutions announced a new collaboration with a leading industrial gas company ...
Rebar Micro Mill Planned in Florida
John Ferriola, Nucor chairman, CEO & president The largest U.S. steel producer and "mini-mill" steelmaker recently announced plans to build a ...
Endothermic Gas Generator Added to Brazilian Fastener Heat Treatment System
A major fastener manufacturer in South America recently received delivery of an endothermic gas generator intended for heat treatment operations at ...
The Vacuum Sintering Furnace Examined
Andrea Alborghetti, Technical Manager of TAV Vacuum Furnaces   Source: TAV: The Vacuum Furnaces Blog Following up on the first installment of ...
Four Vacuum Heat Treat Systems Shipped to Casting Company
Four vacuum furnaces were recently shipped to a major casting company in Arizona, three with a free work area of 54" W ...
TPIM 2018 Promises Heat Treaters Technical Presentations and Keynotes from Industry Leaders
The ASM Heat Treating Society and IFHTSE are joining together to present “Thermal Processing in Motion, including the 4th International Conference ...
How Aging Heat Treatment of AF 1410 Steel Affects Impact Energy, Strength
  Source: ASM International   ASM International recently posted an instructive article on the effect of aging temperature on impact energy ...
Austempering Heat Treatment Expands into Arkansas
Steve Metz, Vice President of Sales and Marketing for Applied Products, Inc. A Michigan-based company that specializes in austempering heat treatment ...
Heat Treat Basics: Scale Removal or Prevention?
Source: Paulo   Leading commercial heat treat company, Paulo, provides an excellent primer on heat treat scale, what causes it, and what ...
Presidents’ Day Quiz: What Do Honest Abe and Heat Treating Have in Common?
  Source: Total Materia   In honor of Presidents' Day, Heat Treat Today takes a cue from the U.S. penny, where we ...
Heat Treating Services Show Upward Trend in Activity
  Source: Thomasnet.com   Aluminum sheets and heat treating services are among the categories of upwardly trending activity that Tony Uphoff ...
IHEA Report Shows Industrial Capacity Utilization at Peak Levels
The monthly heat treat industry report released by the Industrial Heating Equipment Association (IHEA) showed year-high industrial capacity utilization coming in ...
Advanced Heat Treating SP-700 Techniques Result in Better Hit Performance
  Source: Golf Digest   David Llewellyn, Mizuno’s director of research and development for golf In the quest for more opportunities ...
Tubing Manufacturer Purchases Annealing Line for Stainless Steel, Nickel Alloy Tubes
  Source: ExpoMetals.net   A supplier of plasma-based heat and surface treatment solutions to the metals industry has delivered a high-speed ...
Matching Gases with Vacuum Heat Treatment Operations
  Source: VAC AERO International   Relative Gas Supply Cost Notes: [a] Based on a minimum usage of 2830 cubic meters ...
PA, Wash to See Increased Titanium Heat Treat Activity
Rich Harshman, ATI’s chairman, president, and CEO A Pennsylvania-based manufacturer of specialty materials and complex components predominantly for aerospace & defense industries ...
Ellwood Forge Heat Treat Location to Expand Office Facilities
  Source: EllwoodCity.org   Ellwood City Forge (ECF), a steel and heavy metals manufacturing group in Ellwood City, Pennsylvania, with heat ...
Scissors Maker Goes for the Gold with Titanium Coating
William Whiteley & Sons, the oldest scissor-makers in the western world, has chosen a UK-based company that specializes in hard coatings, ...
PA-Based Heat Treater Expands with New Vacuum Bay
Johnathan Rex, General Manager of Rex Heat Treat A heat treater with facilities in Pennsylvania and Alabama was recently given the ...
Achieving Perfect Vacuum Sintering
  Source: TAV: The Vacuum Furnaces Blog Andrea Alborghetti, Technical Manager of TAV Vacuum Furnaces     Andrea Alborghetti, technical manager ...
Texas Steelmaker Acquires Rebar and EAF Mills from Gerdau
Barbara Smith, president and CEO of Commercial Metals Co. Four electric arc furnace (EAF) steel mills in Knoxville, Tennessee; Jacksonville, Florida; ...
Alcoa Closes Rockdale, Italian Smelting Sites Sold
Global manufacturer of bauxite, alumina and aluminum products Alcoa Corporation recently announced its decision to close its Rockdale Operations facility in Texas, ...
Comparing Carburizing Technology and Furnace Features
  Source: ECM-USA   Pierre Rousset and Vincent Lelong from ECM USA compare the significant differences between a conventional furnace and a ...
Certified Heat Treating Acquired by Baltimore Investment Group
John Hubbard, chairman of Thermal Process Holdings An Ohio-based company providing heat treatment for the general manufacturing market, Certified Heat Treating, ...
Arconic Divests, Hydro Acquires Latin American Extrusions Plants
Svein Richard Brandtzæg, president and CEO Lightweight metals engineering and manufacturing firm Arconic, headquartered in Pittsburgh, Pennsylvania, recently announced that a global ...
Tenova To Supply TimkenSteel’s Analysis System, EAF Technology
TimkenSteel, a leading producer of carbon and alloyed steel including large diameter SBQ bars and seamless mechanical tubing, recently ordered a ...
PA-Based Heat Treater Contracts with Zhongwang
A forged and cast rolls producer for steel and aluminum manufacturers was recently selected by a Chinese manufacturer of high-end aluminum flat-rolled ...
Novelis Invests $4.5M in NE Ohio Facility, Pretreatment Applications
Global aluminum rolling producer Novelis Inc. recently announced a $4.5 million manufacturing investment at its facility in Warren, Ohio. The state-of-the-art ...
Titanium Producer Boosts Melt Capabilities with New Furnaces
Frank Perryman, president and chief executive officer of Perryman Company Perryman Company, a metal fabricator headquartered in Houston, Pennsylvania, recently announced it will ...
Laser Sintering vs. Bulk Sintering in a Furnace: Both Have a Place in 3D Metal Printing Industry
  Source: 3DPrint.com Matt Sand, president of 3DEO Matt Sand, president of 3DEO, discusses the pros and cons of laser sintering ...
Kentucky Steel Facility Inaugurates Bright Annealing Line, Cold Rolling Mill
  Source: Kentucky I-71 Connected.com Left to Right: Cristóbal Fuentes, CEO of North American Stainless; Bernardo Velázquez, CEO of Acerinox; Matt ...
No. American Steel Producer Announces Plans for Merchant Bar Mill, Rebar Micro Mill
A North American manufacturer of steel products recently announced that construction will begin on two new projects that will boost its ...
3D Printed Marine Grade Stainless Steel “Better Than Traditional Manufacturing”
Scientists at several research institutions recently reported a breakthrough in 3D printing a marine grade stainless steel -- a low-carbon type ...
High-Speed Rail, Aerospace and Defense Industries Eyed by Hindalco
Source: The Economic Times In addition to organic expansion in the U.S. and Asia automotive and construction sectors, Hindalco Industries recently ...
Mexico-Based Furnace Manufacturer Acquires PA Heat Treat Equipment Supplier
An international manufacturer of industrial furnaces, ovens, ceramic kilns, and combustion systems, based in Monterrey, Mexico, recently announced the key asset ...
New Technical Resource for Induction Heating and Heat Treating Professionals
Handbook of Induction Heating (2nd Ed.) by Dr. Valery Rudnev, FASM Heating by means of electromagnetic induction is a topic of ...
U.S. Army Arsenal Upgrade Includes Heat Treat Facilities, Boosts Readiness
Arsenal Commander Col. Joseph Morrow The U.S. Army upgrade at its manufacturing center at Watervliet, New York, will include heat treatment ...
What Do Fashion Watches and Aerospace Components Have in Common? 3D Metal Printing
A Swedish producer of metal powders announced recently that it has launched commercial production of the industry's first high precision binder ...
Refractory Products Manufacturer Expands with Purchase of Southern Supplier
A producer of monolithic refractory products, an employee-owned company headquartered in Columbus, Ohio, has expanded its manufacturing presence in the southeast through ...
Aerospace, Auto, AM Industries Expand Heat Treat Capabilities
Fourteen vacuum furnaces have recently been shipped to various clients in the additive manufacturing, aerospace, automotive, and commercial heat treating industries, ...
University Purchases 1500°C Box Furnace
A 1500°C box furnace was recently shipped to a university, designed for testing, research and development, and laboratory applications and with ...
Kazakhstan Steel Producer Orders 290-Ton Ladle Furnace
Steelmaker ArcelorMittal recently ordered a 290-ton ladle furnace to control chemical composition and temperature of liquid steel and slag for its ...
Firearms Parts Manufacturer Utilizes Precision Heat Treating for .308 Match Bolt Assembly
A U.S.-based aerospace and firearms parts company, which has been manufacturing bolt carrier groups for the AR-15 and M16 rifles since 1991, ...
Fastener Manufacturer Expands Heat Treatment in Response to Growth
Global industrial fastener manufacturer Trifast PLC has announced the expansion of its heat treatment capabilities as part of the company's response to ...
New Isofrax® 1400 Fiber Launched for Higher Temp Processes
Enhanced fiberization techniques combined with proprietary processing technology is behind the manufacturing of a recently unveiled low bio-persistent (LBP) fiber that ...
More Accessible Design-to-Launch Services Unveiled with IT, AM Technologies Partnership
Sudip Singh, Global Head, Engineering Service at Infosys Ltd An end-to-end product development service using metal additive manufacturing (AM) technology was ...
Sophisticated All-Metal Hot Zone Delivered
A uniquely engineered, high-temperature refractory metal hot zone has been delivered by the furnace division of an international supplier of refractory ...
U.S.-Produced Aluminum Cladding Adorns Façade of South African Mall
  Source: AlCircle   To achieve a distinctive look that can be seen from a distance, a shopping mall in the ...
Heat Treat Equipment Purchases — Recent Activity
Lindberg/MPH ships immersion lead melting furnace Among the many transactions involving the contracting, purchasing, selling, shipment and delivery of heat treat systems, ...
Tool and Die Failure, Heat Treatment Causes and Corrections
George Vander Voort has a background in physical, process and mechanical metallurgy and has been performing metallographic studies for nearly 50 years. ...
Hoa Phat Orders 4 Blast Furnaces to Increase Production at Dung Quat Complex
Vietnamese steel producer Hoa Phat Steel has awarded a contract to an Italian steel production technology specialist for the design, supply, ...
Paulo Announces New Plant in Monterrey, Mexico
Heat treatment service provider Paulo has begun construction on a greenfield facility in Monterrey, Mexico.  The new plant will be completed ...
SSAB Modernizes Hot-Dip Galvanizing Line No. 3 at Finnish Facility
Swedish specialty steel producer SSAB will modernize its continuous hot-dip galvanizing line No. 3 in Hämeenlinna, Finland. The upgrade essentially involves switching ...
Italian Manufacturers Order Annealing Furnaces from Austrian Heat Treatment Supplier
Two major Italian manufacturers have ordered bell annealer furnaces to expand their existing lines. Leading bolt manufacturer, Fontana Luigi S.p.A., based ...
Joe Powell Comments on Marquenching and Austempering
Last week, we ran a news release about ThermoFusion in California expanding their heat treat capabilities to include marquenching and austempering ...
UPC Energizes Aging Carburizing Cell for Axle Gears Manufacturer
A U.S.-based axle gears manufacturer recently commissioned hardware and software enhancements to add to their existing heat treat cell and automation. ...
Heat Treating Keeps Costs Down for German Tool Manufacturer
  Source:  ETMM The Meusburger alignment process is shown here. Heat treatment of standard parts allows a Bamberg-based contract manufacturer to provide ...
No Cal Heat Treat Services Supplier Adds Austempering, Marquenching Capabilities
A brazing and heat treating services supplier based in Northern California has announced the expansion of process services to their heat ...
European Drilling Tools Manufacturer Commissions Furnace System
A European manufacturer of hard rock drilling tools recently contracted to purchase a gas nitro carburizing turnkey installation, complete with furnace, ...
Bearing Manufacturer Commissions Electrically Heated Furnace Line
An electrically heated furnace line has recently been commissioned by a leading bearing manufacturer for its existing production line. Responsible for ...
Voestalpine Expands 3D Metal Printing Activities to Asia and North America
In April 2017, a new research center for 3D printing of highly complex metal components launched operations in Singapore, as part ...
EJ Americas Begins Construction on New Iron Foundry
  EJ Americas, a global organization producing and distributing iron castings for municipal and infrastructure programs, broke ground in July for ...
Tracked Vehicle Rollers Get Controlled Heat Treatment Using Movicon SCADA
Source: Process and Control Today   The accuracy and energy efficiency of the heat treatment for rollers used in heavy duty ...
TMK IPSCO restarts operations at Tulsa Port of Catoosa
Source:  Tulsa World Keith Marquart leads a tour of the control room of the TMK IPSCO facility at the Tulsa Port ...
CHTE Distinguished Service Award Goes to Cummins Inc. Employee
Dr. Rick Sisson of Worcester Polytechnic Institute (WPI) in Worcester, Mass. (L) presents the Distinguished Service Award to Cummins Inc. employee ...
Nucor Steel Gallatin Orders Hot Strip Galvanizing Line with “Heat-to-Coat” Technology
Nucor Steel Gallatin, based in Ghent, Kentucky, recently ordered a “heat-to-coat” pickling and galvanizing line with an annual capacity of 500,000 ...
NLMK Lipetsk Upgrades Hot-Rolling Operations
NLMK Group, an international steelmaking company with operations in Russia, the US, and the European Union, is upgrading hot-rolled steel production ...
BAE Systems Begins Production on First Royal Navy Type 26 Global Combat Ship
Production on the first of the new Type 26 Global Combat Ships for the UK Royal Navy began with the push of a ...
Dana to Supply Driveshaft Assemblies, Motion Systems for New York Wheel
Dana Incorporated, based in Maumee, Ohio, recently announced that it is providing driveshaft assemblies and gearboxes for the New York Wheel–which ...
Austal Delivers Aluminum EPF Catamaran to U.S. Navy
  Source: Light Metal Age Austal USA recently delivered the USNS Yuma, the eighth Expeditionary Fast Transport (EPF) vessel, an aluminum catamaran, ...
Atmosphere Box Furnace Shipped to the Steel and Mining Industry
Lindberg/MPH announced the shipment of an electrically heated, rod over-bend atmosphere box furnace to the steel and mining industry. This is ...
Electro-Spec Expansion to Include Heat Treating Services
Source: SC Department of Commerce Electro-Spec, Inc., a specialty plating manufacturer headquartered in Franklin, Indiana, announced plans to locate a new ...
Using Heat Treatment and Thermal Shape Memory to Tailor Nitinol to Industry Applications
  Source: AZO Materials Nitinol’s shape memory and superelastic properties allow it to be used in a wide range of applications ...
Novelis, Kobe Steel Join Forces with South Korea Heat-Treat Facility
Novelis Inc. announced in May that it has entered into a joint venture agreement with Kobe Steel, Ltd., a producer of aluminum ...
Suit of Armor Receives Heat Treatment
  Source: Metlab Combining the ancient craft of blacksmithing with heat treating processes, artisan Robert (Mac) McPherson obtained the finish he ...
Melting Furnaces and Twin Chamber Furnace to be Installed
Significant milestones have been obtained with the construction and installation of two 70 mt melting furnaces and the installation of a ...
Heat Treat Radio #7: Former Bodycote CEO Re-Enters Heat Treat Market
SCHMOLZ + BICKENBACH and TSINGSHAN to Form Joint Venture
Clemens Iller - CEO SCHMOLZ + BICKENBACH SCHMOLZ + BICKENBACH, a global leader in special long steel, and TSINGSHAN GROUP, a ...
Allied Mineral Products, Inc. to Acquire Pryor Giggey Co.
Allied Mineral Products, Inc. announces the intent to purchase Alabama-based Pryor-Giggey Co., a monolithic refractory and precast shapes company with plants ...
Just Throw Some Heat at It
Source:  Flame Treating Systems Since a blog is usually some way for the author to try and educate readers about some ...
Surface Engineering & Heat Treatment Industry Conference/Exhibition
The Surface Engineering Association is proud to partner with the Contract Heat Treatment Association (CHTA) and Wolfson Heat Treatment Centre as ...
Bharat Forge Expands in U.S. with Tennessee Acquisition
  Source:  Forging Directors of Bharat Forge Ltd., in Pune, India, approved the company’s acquisition of 100% of the shares of ...
Jorgensen Forge Acquired
Source:  Forging Jorgensen Forge, a Tukwila, WA, open-die forger and ring-rolling operation, has emerged from Chapter 11 bankruptcy as one of ...
3T RPD Opens Metal Additive Manufacturing Site
  Source:  TCT Mag The new 10,000 square foot facility triples 3T RPD’s space for metal AM production. Read more to ...
Heat Treat Basics: Optimizing Process Heating Systems
  Source:  Reliable Plant Dr. Arvind Thekdi, an Energy Expert for the U.S. Department of Energy, routinely conducts energy assessments to ...
Aluminum Demand Grows for 6th Consecutive Year Since 2009
  Source:  The Aluminum Association This year’s Review shows continued growth in demand for the metal and positive trend lines in ...
Heat Treat Basics: Metal Urgency – Carburizing
  Source:  Thermal Processing Magazine "While some heat treatments are used to soften the material or improve its machinability, most are ...
Heat Treat Basics (Video): Steel Metallurgy from MetallurgyData.com #2
Guest post by www.MetallurgyData.com MetallurgyData.com has produced a video series entitled Steel Metallurgy. Preview this episode at –http://www.metallurgydata.com/index.php/metallurgy-for-non-metallurgists-2/steel-metallurgy/. The preview runs ...
Federal Firearms License Secured by AHT Corp.
WATERLOO, IA—Advanced Heat Treat Corp. (AHT) recently announced that it has received a Federal Firearms License (FFL) issued by the U.S. ...
Liberty House Group Creating Steel Sector in the UK
  Source:  Recycling Today The London-based metals trading and manufacturing company Liberty House Group (LHG) has launched a metal recycling business called ...
IHEA’s Fundamentals of Industrial Process Heating Online Learning Course is scheduled to begin on Oct. 17, 2016.   This course is ideal ...
Schafer Gear Works Transfers its Fort Wayne, Ind., Commercial Aviation Shafts and Small Gear Capabilities to South Bend, Ind.
To meet Schafer Gear Works’ growing demand for high-precision commercial aviation shafts and gears, the company recently moved its Fort Wayne, ...
Aftermarket Partnerships Help Extend Equipment Life and Efficiency
  Source:  AZO Materials Total lifecycle cost of running a piece of equipment can be significantly reduced if the right end-user/OEM ...
Case Study: Laser Hardening
  Source:  Thermal Processing for Gear Solutions "The hardening of materials by laser is a specialized and fast-growing field as it ...
An Iron Giant’s Big Plans
  Source:  Global Casting Magazine With annual sales approaching $2 billion, Waupaca Foundry is one of the largest metalcasting groups in ...
Industry 4.0 + IIoT = Smart Industrial Ovens & Furnaces
  Source:  Eurotherm by Schneider Electric "Effective process control and automation technologies link thermal processing equipment such as ovens and furnaces ...
StrikoWestofen Opens Heat-Treatment Business Unit
As of immediately, StrikoWestofen covers another step in the production chain of the light metal casting industry. From now on, heat ...
Heat Treatment and Wicked Problems
  Source:  Linked In - Peter Sherwin "I am wide awake on a late night flight from Kolkata to Delhi (India) ...
Vacuum Heat Treatment’s Role in Additive Manufacturing (AM) 3D Printing
  Source:  Global Heat Treatment Network "Vacuum heat treatment tasks for AM manufactured parts is the same process as  traditional subtractive ...
Quality Counts: Gas Nitriding
  Source:  Thermal Processing for Gear Solutions In general, nitriding of parts involves a thermal process that provides a tough, corrosion-resistant, ...
Heat Treating Involved in Production of Speakers
  Source:  ETMM The Website "One look at the back of the part told me it was filled with one sub-gate ...
Walking Beam Furnace Energy Savings: New Skid Pipe Insulation Concept
  Source:  Heat Processing On-Line This paper discusses how energy consumption and energy loss can be reduced in reheating furnaces of ...
Heat Treatment Used in Building Conformal Cooling Inserts
  Source:  MoldMaking Technology "The process of building conformal cooling inserts can be generally broken up into four steps: 1) simulating ...
PVD Coatings and Tool Steel Selection
  Moldmaking Technology - July 2016 "When it comes to steel selection, the standard grades and heat-treat cycles might need to ...
Stainless Steel Can Be Heat -Treated to 50 – 53 HRC
International Mold Steel will introduce S-Star-A, a 420 stainless steel in the annealed condition that can be heat-treated to hardness of ...
Integrated Heat Treating Used in Making Steinway Pianos
  Source:  Modern Machine Shop "The company wanted to develop a more streamlined machining method, including integrating a heat-treat process that ...
Proper Heat Treating Integral to Producing Quality Stainless Steel Parts
  Source:  Modern Machine Shop "DON’T forget that an attack can occur in a passivating bath if parts are improperly heat ...
Direct-Chill Casting
  Source:  Total Materia Direct-chill (DC) casting is currently the most common semi-continuous casting practice in non-ferrous metallurgy. The process is ...
Making Metal Wires – No Heating Required
  Source:  Materials Today "A team of engineers from North Carolina State University looked to eutectic gallium indium (EGaIn) – a ...
New Boride Material Forms Own Protective Coating
  Source:  Materials Today "This resistance to oxidation is possible because of the presence of aluminum in layers between molybdenum and ...
The FINEX Process
  Source:  Total Materia Molten Iron is produced directly using iron ore fines and non-coking coal rather than processing through a ...
Analysis of Heat Treat on Carburized Ring Gear and Multivariate Regression Model Development
  Source:  Thermal Processing for Gear Solutions Like most other heat treatments, the carburizing and hardening process is known to introduce ...
Vermont Precision Tools Selects Lucifer Furnaces
Vermont Custom Gage LLC. a subsidiary of Vermont Precision Tools Inc., Swanton VT, selected Lucifer Furnaces to create manufacturing capability with ...
UPS Launching On-Demand 3D Printing Manufacturing Network
UPS will launch a distributed, on-demand manufacturing network that links its global logistics network with 3D printers at The UPS Store in ...
Saudi Aramco Signs to Set Up High-End Forging & Casting Manufacturing Facility
Saudi Aramco has signed a Memorandum of Understanding (MoU) with GE (NYSE: GE) and Cividale SpA of Italy to build the ...
NASA Releases Dozens of Patents into the Public Domain
Washington – NASA has released 56 formerly-patented agency technologies into the public domain, making its government-developed technologies freely available for unrestricted ...
Record Gas Quenching Speeds Achieved in Ipsen’s ARGOS Heat Treating System
KLEVE, GERMANY – Ipsen's Global Development Team recently celebrated the first build and testing of the ARGOS heat-treating system. The ARGOS uses ...
Improved Materials and Enhanced Fatigue Resistance for Gear Components
Source:  Thermal Processing for Gear Solutions "When trying to improve fatigue properties, two important areas need to be addressed: improvements of ...
2200°F Conveyor Oven Supplied for Aquatic Heating Systems
Baker Furnace, Inc. shipped a custom-built, high-temperature conveyor oven designed to heat treat rods used to manufacture commercial heating elements.  The ...
Commercial Metals Company Celebrates the Groundbreaking of New Micro Mill
On April 29, 2016, Commercial Metals Company (NYSE: CMC), state, federal and local officials and their honored guests gathered for a ...
Solar Manufacturing’s Vacuum Furnace Reference Series
    Source:  Solar Manufacturing's Vacuum Furnace Reference Series This series includes eight releases with the following titles. Release 1:  Critical ...
Heat Treating Involved in 3D Printing Technique
Source:  Today's Medical Developments - March 2016 3D printing technique using liquid inks and common furnaces is less expensive, faster, and ...
Heat Treating Oven Part of Norsk Titanium’s Ultra Lean Manufacturing Line
Norsk Titanium AS, the world’s leading provider of aerospace-grade, titanium additive manufacturing technology, today announced the groundbreaking of a new European ...
Economist: Manufacturing Revives in 2016’s Second Half
Source:  SME Manufacturing Engineering “We’re about out of the woods,” Alan Beaulieu, president of ITR Economics, said during a presentation at ...
Slovenia commercial heat treater, MIHEU, is expanding their production capacity with the addition of a new Vector™ High Pressure Gas Quench ...
Apple’s Patent Pending 7000 Series Aluminum Invention Used in the New iPhone 6s Comes to Light
[Best of the Web] Source: PatentlyApple.com When Apple introduced the iPhone 6s on September 9, 2015 they pointed out in their ...
