Aluminum Heat Exchanger Manufacturer Orders Second CAB Line
An aluminum heat exchanger manufacturer has ordered a semi-continuous controlled atmosphere brazing (CAB) line to increase production capacity for tube-and-bar heat exchangers used in industrial and automotive applications. The new system will accommodate products with thicker cores and varied geometries while maintaining consistent thermal profiles during brazing.
The Chinese manufacturer has selected a Universal Batch CAB system from SECO/WARWICK Group, a global heat treatment equipment supplier with North American operations headquartered in Meadville, Pennsylvania. The order marks the manufacturer’s second order from the supplier, following a CAB line delivered in 2016 that remains in operation. A significant share of the manufacturer’s production is exported to clients in North America, Europe, Asia, Australia, South America, and Africa.
Image Credit: SECO/WARWICK Group
The new semi-continuous line will feature a 600 mm (24 in.) wide conveyor belt and include a drying furnace, vacuum purge chamber, convection preheating furnace, convection CAB brazing furnace, vacuum purge cooling chamber, and air cooling chamber. The order also includes a control system, installation, and on-site commissioning.
Piotr Skarbiński
SECO/WARWICK
“CAB technology is a process in which the precision of the entire sequence matters: load prepataion, nitrogen atmosphere quality, heating, brazing and cooling,” said Piotr Skarbiński, vice president of the Aluminum and CAB Products Segment at SECO/WARWICK Group.
The Universal Batch CAB system will allow heat exchangers to be brazed vertically or horizontally, depending on product design and process requirements. Its semi-continuous configuration accommodates different product sizes, shorter production batches, and varied geometries while maintaining process repeatability.
The new installation will incorporate configuration updates compared with the manufacturer’s existing CAB line. It will increase production capacity for aluminum heat exchangers serving industrial and automotive clients and marks the first project carried out jointly by SECO/WARWICK Group and its Chinese team for this facility.
