Automotive Heat Treating
The automotive heat treat market is diverse, large, and continually growing. Heat treating demands are evolving with the advent of electric cars, but heat treatment of conventional automotive parts remains strong. Parts that are heat treated include: power transmission gears, braking systems, engine components, fasteners and stampings. These parts are made from a variety of heat treatable materials, including mild steel, aluminum, magnesium, and high strength and low alloy steels. The components are made from materials produced by powder metallurgy and wrought metal, including castings and forgings. Processes vary widely, a few examples being annealing, brazing (e.g., processing automotive heat exchangers), case hardening (e.g., carburizing, carbonitriding, ferritic and austenitic nitrocarburizing, nitriding), hardening (e.g., through hardening, selective surface hardening), normalizing, sintering, and solution heat treating (e.g., aluminum). Below is a collection of automotive news and technical articles.
Automotive Technical Content
Reliable Induction for Heat Treating Automotive Components
Reliable induction heat treating depends on more than metallurgy — it requires precise, repeatable performance from every part of the induction ...
Tratamiento térmico por inducción confiable para componentes automotrices
Un tratamiento térmico por inducción fiable depende de algo más que la metalurgia: requiere un desempeño preciso y repetible de cada ...
The Jominy Rapid Quench, Part 2: Automotive Applications
In the second of the two-part series, the Advanced Rapid Quench Jominy Tester application for automotive underbody parts is examined. In ...
Customize To Build Better Furnaces
Custom furnace design isn't just about performance upgrades — it's about process reliability. Vacuum furnaces built for general use, however, often ...
A Case Study in Brake Rotor Innovation at GM
Ferritic nitrocarburizing (FNC) has emerged as a powerful, low-distortion heat treatment solution for automotive components, especially brake rotors, thanks to its ...
At a Crossroads: Smart Thermal Processing Technologies for Auto
In this Technical Tuesday installment Christoph Bollgen, industry manager for Thermal Processing Technology, JUMO GmbH & Co. describes how global industries ...
Heat Treatment of Giga Dies for Aluminum Die Casting: Challenges and Advancements
Thomas Wingens, Founder & President, WINGENS CONSULTANTS  The increasing adoption of large-scale aluminum die casting, often termed Giga casting, in the ...
Heat Treat Radio #117: How GM Started & Grew FNC for Brake Rotors
In this Heat Treat Radio episode, host Doug Glenn converses with Mike Holly on his extensive experience in ferritic nitrocarburizing (FNC). Listen as ...
Automotive Industry News
Louisiana EAF Steel Mill Launches $5.8B Project
A $5.8 billion electric arc furnace (EAF)-based integrated steel mill project has launched in Louisiana, establishing a new domestic source of ...
Cleveland-Cliffs Invests $1B in Steelmaking Modernization
Cleveland-Cliffs is investing $1 billion to modernize its Middletown Works steelmaking facility in Ohio, including upgrades and a planned rebuild of ...
Major Steel Plant Shifts to Electric Steelmaking
A major steel plant is replacing its existing blast furnace route with electric steelmaking as part of a transition to lower-emission ...
AI Inspection for Forging Quality Control
Hirschvogel is implementing automated inspection of closed-die forgings to replace manual visual checks, enabling faster detection of surface defects and dimensional ...
GM Invests in Casting Capacity Expansion
General Motors announced plans to invest more than $150 million in its Saginaw Metal Casting Operations facility in Michigan to support ...
Bodycote announced plans to open a new heat treatment facility in Apodaca, Mexico, expanding regional capacity for case hardening and nitriding ...
Linamar Boosts Gear, Forging Capabilities with Acquisition
Linamar Corporation, a North American manufacturer with in-house heat treating capabilities, has acquired select assets of Winning BLW, strengthening its capabilities ...
Global Automotive Supplier Acquisition Expands Operations
Dauch Corporation has completed its acquisition of Dowlais Group plc, combining two global automotive manufacturers in a move that expands driveline, ...
PSW Group Opens New Semi-Solid Casting Center in Ohio
PSW Group announced the launch of its High Integrity Diecasting Center (HIDC) at the Magretech plant in Bellevue, Ohio, a new ...
Automotive Supplier Expands Brazing Capacity
An automotive manufacturer is expanding stainless steel brazing capacity at its Midwest manufacturing facility, adding a new 24-inch belt, four-zone brazing ...
Jupiter Aluminum Industries (JUPALCO), part of the Jupiter Group, has ordered two aluminum coil annealing furnaces to support production at its ...
Tier 1 Automotive Supplier Expands Burst Capacity
A Tier 1 automotive supplier maintained uninterrupted production during a planned maintenance shutdown by leveraging outsourced burst heat treating capacity from ...
ArcelorMittal is advancing a major expansion in electrical steel production that includes a preparation line, a continuous annealing and varnishing line, ...
An international, multi-billion-dollar corporation at the forefront of drivetrain technologies has commissioned a complete isothermal annealing line, due to be delivered ...
2 CAB Furnaces Commissioned for Auto Manufacturer
Two EV/CAB lines will be installed for a major manufacturer of heat exchangers for trucks, passenger cars, and new energy technologies. ...
Aluminum Brazing Furnace Supports Automotive Industry
Weifang Hengtong Radiator is increasing their efficiency and quality of their aluminum plate and bar heat exchangers with a semi-continuous controlled atmosphere ...
2 Large Scale Furnaces for Automotive and Marine Propulsion
Two intensive furnace projects are poised to bring heat treating to the automotive brake rotor and marine propulsion systems industries. An ...
Busch Group Adds 60,000 sqft US Facility
Busch Vacuum Solutions, part of the Busch Group, a global company in vacuum and overpressure technology, has announced the development of ...
