MANUFACTURING HEAT TREAT
Heat Treat Grab Bag of 10 Tips to Keep Your Costs Down
OCWant a free tip? Check out this read of some of the top 101 Heat Treat Tips that heat treating professionals submitted over the last three years. These handy technical words of wisdom will keep your furnaces in optimum operation and keep you in compliance. If you want more, search for “101 heat treat tips” on the website! This grab bag of 10 tips focuses on how to keep your heat treating costs down, either by maintenance strategies or product and process decisions.
By the way, Heat Treat Today introduced Heat Treat Resources this year; this is a feature you can use when you’re at the plant or on the road. Check out the digital edition of the September Tradeshow magazine to check it out yourself!
(Super Systems, Inc.)
New Diffusion Pump Technology Increases Production Output
Gain immediate positive net cash flow with a lease to own finance option by upgrading your diffusion pumps with the new immersion heater technology. The new style heater will extend oil life and reduce energy consumption. New heater technology can increase production by eliminating the need of dropping your pump every time you change oil for faster maintenance turn around. Drop in place pump design with improved performance.
(Leybold Vacuum USA)
(Grammer Vacuum Technologies)
How Much Lost Money Flows Through the Walls of Your Furnace
In a strict sense, heat flows through the insulating lining of your furnace wall: the lower the outside temperature in the furnace shell, the less heat is lost and, consequently, less money.
For example, an outside temperature on the oven shell of 160°F (71°C) equals a heat loss of approximately 190 BTU/hr ft2, just multiply this number by the square footage of the entire outside surface of the oven. A well-designed and well-maintained insulation can reduce the outside temperature of the shell, say 120°F (49°C), and heat losses would be close to 100 BTU/hr ft2, that’s 90% more heat lost and therefore fuel.
So, my Tip for today is: “Let’s go for the basics that don’t change, and it will always give good results.” By the way, how many furnaces are there in your plant and how many square feet do their surfaces add up to?
(Carrasco Hornos)
There are 2 things in life you should never go cheap on: Toilet paper and combustion equipment! When upgrading or looking at new systems, spend the money to do it right. Designing on the cheap will only lead to operational and maintenance headaches. And trying to reuse the ancient artifacts when upgrading just to save a buck will cost you 10x that down the road. You don’t have to break your budget to do a quality job!
(Bloom Engineering Co., Inc.)
(Combustion Innovations)
  1. It can cost you money: Operating with more air than needed will reduce your furnaces efficiency and require you to burn more fuel. Conversely, operating air deficient, unless necessary for the process, results in unburned fuel being released with the exhaust gasses. In most cases the unburned fuel going up your stack is energy that you paid for.
  2. It can decrease product quality and yield:  For many ferrous metals too much excess air will result in excess scale formation at high processing temperatures. On the contrary other materials such as titanium need to be processed with excess air to prevent Hydrogen pickup.
  3.  It can reduce your furnace’s reliability:  The burners on your direct fired furnace will have a defined range of acceptable air to fuel ratios for proper operation. If your system wanders outside of this range, which can be fairly tight with today’s ultra-low NOx burners, you could start to see flame failures that result in unplanned shutdowns.
  4. It can be a safety hazard: Apart from the possibility of causing burner instability, running with too little air will increase CO emissions. Unless your furnace is designed to safety exhaust CO you could end up exposing personnel working near your furnace to this deadly gas.
Inspection Mistakes That Cost
  • A certified Rc 54.3 +/- 1 test block was tested three times and the average of the readings was Rc 54 utilizing a flat anvil.  Water was put on the anvil under the test block and the next three readings averaged Rc 52.1.
  • Why is it so important that samples are clean, dry, and properly prepared?
  • If your process test samples are actually one point above the high spec limit but you are reading two points lower, you will ship hard parts that your customer can reject.
  • If your process test samples are one point above the low spec limit but you are reading two points lower, you may reprocess parts that are actually within specification.
  • It is imperative that your personnel are trained in proper sample preparation and hardness testing procedures to maximize your quality results and minimize reprocessing.
(Debbie Aliya)
The Right Furnace Atmospheres Will Pay Dividends
Save money on your furnace atmospheres by employing the driest and leanest furnace atmosphere blends possible. Furnace atmospheres are a compromise between keeping it simple and supplying exactly the atmosphere to meet the unique requirements of each material processed. Organizations have different priorities when it comes to atmospheres—heat treat specialists may want to be able to run as many different materials as possible using a limited array of atmosphere types, while captive heat treating operations often want exactly the atmosphere approach to maximize the benefits for their specific processes/products.
The dewpoint (water content) of the atmosphere in the furnace is a key factor in its performance. At high temperatures, water in the atmosphere can break down, releasing oxygen that can cause oxidation. You must maintain a high degree of reducing potential to achieve the surface finish and processing results desired. If the furnace atmosphere gas is wet, you’ll need a gas blend richer with hydrogen than you would if your atmosphere blend had a lower dewpoint (less water vapor content). Since hydrogen costs 10 times more than nitrogen, it is more economical to run a leaner atmosphere than a richer atmosphere. By running the driest atmosphere blend possible, you may find that you can lean down your atmosphere (consistent with the metallurgical needs of your product/process) by reducing the proportion of hydrogen and increasing the nitrogen. In doing so, you may recognize meaningful savings.
Check your furnace atmosphere raw materials and process and obtain the driest atmosphere possible. Control your atmosphere dewpoint by adding humidity as needed to the driest starting blend possible rather than accepting a wet atmosphere and trying to process your parts. You’ll achieve the best compromise of excellent results at the lowest cost.
(Nel Hydrogen)
Heat Treat Grab Bag of 10 Tips to Keep Your Costs Down Read More »
Fringe Friday: Manufacturing for the Future
Source: IndustryWeek
Sometimes our editors find items that are not exactly "heat treat" but do deal with interesting developments in one of our key markets: aerospace, automotive, medical, energy, or general manufacturing. To celebrate getting to the "fringe" of the weekend, Heat Treat Today presents today’s Heat Treat Fringe Friday best of the web article evaluating how your jobs may look a little different as general manufacturing adopts Industry 4.0 trends.
A question this article asks -- and you should, too -- is "What talent and skills do manufacturers need in order to succeed in the factory of the future?" With interconnected digital and physical developments through internet technology, heat treaters may fear that a "robot" will replace them. Armed with this article, you'll be able to identify what skills are needed for the future of five manufacturing roles: production planner, industrial engineer, operator, line leader, and quality engineer.
[blockquote author="" style="1"]The smart factory of the future will perfectly blend human capabilities with technology. Manufacturers can get ahead now by understanding how critical manufacturing roles will evolve and how to hire, train and upskill for these roles. Getting it right in talent development will ultimately separate the leaders from the laggards.[/blockquote]
Read more at "5 Manufacturing Roles that Will Soon Look Very Different"
"State of Industry 4.0 in the North American Heat Treat Market"
If you are interested in how the heat treating industry is affected by artificial intelligence (AI), the industrial internet of things (IIoT), and other subjects related to Industry 4.0, check out this article. Here's an excerpt:
"According to Aymeric Goldsteinas, project development manager at Ipsen, customers are becoming more willing to implement Ipsen’s Industry 4.0 endeavors, even cloud-based solutions, a willingness that was not present just one decade ago. So how is the heat treat market responding? We asked suppliers how they implemented Industry 4.0. . ."
Fringe Friday: Manufacturing for the Future Read More »
Looking to a Future with FNC or Nitriding?
OCWhat's the future of ferritic nitrocarburizing and how does it compare to other hardening processes? When it comes to metal hardening, there are many variations on central processes, including recent innovations in how to apply hardening processes.
This Technical Tuesday brings you a quick overview of how hardness technologies differ, specifically nitriding and FNC, and how certain heat treaters have developed these specific hardness technologies.
Understanding the Various Hardening Processes
If you want to know the future, the best you can do is understand the past and present. Let’s begin with looking at the most common hardening processing methods. Here are a few excerpts from “Elevate Your Knowledge: 5 Need-to-Know Case Hardening Processes” by Mike Harrison, engineering manager of Industrial Furnace Systems Division at Gasbarre Thermal Processing Systems:
Read more about these 5 processes in Mike Harrison's article. Click to read.
Carburizing: “Gas carburizing is a process where carbon is added to the material’s surface. The process is typically performed between 1550-1750°F, with carburizing times commonly between 2-8 hours [this spec is disputed, and times may run up to 24 hours]; of course, these values can vary depending on the material, process, and equipment. The most common atmosphere used for atmosphere gas carburizing is endothermic gas with additions of either natural gas or propane to increase the carbon potential of the furnace atmosphere.”
Nitriding: “Gas nitriding is a process where nitrogen is added to the material surface. The process is typically performed between 925-1050°F; cycle times can be quite long as the diffusion of the nitrogen is slow at these temperatures, with nitriding times typically ranging from 16 – 96 hours or more depending on the material and case depth required. Nitriding can be performed in either a single or two-stage process and has the potential to produce two types of case, the first being a nitrogen-rich compound layer (or “white layer”) at the surface that is extremely hard and wear-resistant but also very brittle.”
Carbonitriding: “Despite its name, carbonitriding is more closely related to carburizing than it is to nitriding. Carbonitriding is a process where both carbon and nitrogen are added to the material surface. This process is typically performed in a range of 1450-1600°F [this spec is disputed, and temperatures may go up to 1650°F] and generally produces a shallower case depth than carburizing.”
Ferritic Nitrocarburizing (FNC): “In the author’s opinion, just like with carbonitriding, ferritic nitrocarburizing (FNC) is named incorrectly as it is more closely related to nitriding than it is with carburizing. FNC is a process that is still mostly nitrogen-based but with a slight carbon addition as well. The added carbon helps promote compound layer formation, particularly in plain carbon and low alloy steels that do not contain significant nitride-forming alloys. This process is typically performed in a range of 1025-1125°F with cycle times much shorter than nitriding, typically 1-4 hours.”
Low Pressure Carburizing (LPC): “Low-pressure carburizing (LPC), or vacuum carburizing, is a variation of carburizing performed in a vacuum furnace. Instead of the atmospheres mentioned previously, a partial pressure of hydrocarbon gas (such as acetylene or propane) is used that directly dissociates at the part surface to provide carbon for diffusion. After LPC, the workload is transferred to a quench system that could use oil or high-pressure gas, typically nitrogen.”
Nitriding
Learn more about the basics of hardening at Heat Treat Radio. Click to listen,
Gas nitriding, a process over 100 years old, is a hardening process that involves diffusing nitrogen into the surface of steel to create a hard, wear-resistant case. Among many benefits, the part will have enhanced fatigue properties, anti-galling properties under load, and a resistance to softening at elevated temperature. This makes it an excellent choice for the aerospace industry.
There is some recent history regarding problems related to the “white layer”. In a typical microstructure, the “white layer” is a nitrogen-rich surface layer and the diffusion layer exists beneath it.1 It is essential that the surface layer be controlled to avoid an overly brittle part. Mark Hemsath the vice president of Sales – Americas for Nitrex Heat Treating Services, elaborated on this in a Heat Treat Radio episode:
"Doug Glenn: I assume, with all the modern day technology and whatnot, we're able to control that white layer and/or depth of nitriding layer through your process controls and things of that sort."
"Mark Hemsath: Yes. Nitriding has been around a long time, but one of the problems that they had was controlling the white layer. Because they basically would just subject it to ammonia and you kind of got what you got. Then they learned that if you diluted it, you could control it. That's with gas nitriding. Then plasma nitriding came around and plasma nitriding is a low nitriding potential process. What that means is it does not tend to want to create white layer as much. It's much easier to control when the process itself is not prone to creating a lot of white layer, unlike gas. Now, in the last 10 – 15 years, people have gotten really good at controlling ammonia concentrations. They've really learned to understand that."
Recently, SECO/WARWICK shared their nitriding technological developments in their product, ZeroFlow.
"ZeroFlow nitriding is ammonia-based gas nitriding," commented Dr. Maciej Korecki, PhD Eng., vice president of the Vacuum Furnace Segment at SECO/WARWICK Group. "It is distinguished by the fact that the nitrogen potential is controlled by introducing the right portion of ammonia at the right time and only ammonia, instead of a continuous flow of a mixture of ammonia and diluent gas."
"Consequently, the ZeroFlow method uses the minimum amount of ammonia needed to achieve the required nitrogen potential and replenish the nitrogen in the atmosphere, taking into account the situation where no ammonia is supplied to the furnace at all, no flow, hence the suggestive name of the solution," he continued. "Using ammonia alone in the nitriding process, we are dealing with a stoichiometric reaction (as opposed to some traditional methods), that is, one that is uniquely defined and predictable based on the monitoring of a single component of the atmosphere. Therefore, the ZeroFlow process controls very precisely through the analyzer only one gas, obtaining an improvement in the quality and repeatability of the results compared to various traditional methods."
According to Dr. Korecki, the process is about going back to the basics of nitriding: "The inventor of the method is Prof. Leszek Maldzinski of the Poznan University of Technology, who developed the theoretical basis and confirmed it with research. Then, more than 10 years ago, a partnership between SECO/WARWICK and the Poznan University of Technology initiated a project to develop and build the first industrial furnace designed to perform the ZeroFlow nitriding processes. The furnace was launched at SECO/WARWICK's research and development department (SECO/LAB®), where the method has been implemented and validated on dozens of industrial-scale processes."
This nitrogen-based process can produce a deeper compound layer than nitriding, which is great for industrial machinery applications where this deep layer is needed for increased wear resistance and the critical strengthening of a deep case depth is not essential.
FNC has gone through a technical evolution with different heat treaters in the industry developing their own unique applications with method in mind. We'll look at two recent examples: AHT's Super Ultra Ox and Bodycote's Corr-I-Dur.
Edward Rolinski
Senior Scientist
Advanced Heat Treat, Corp.
(Source: https://www.ahtcorp.com/)
According to experts at Advanced Heat Treat Corp. (AHT), Edward Rolinski (Dr. "Glow"), Jeff Machcinski, Vasko Popovski and Mikel Woods, "Thermochemical surface engineering of ferrous alloys has become a very important part of manufacturing. Specifically, nitriding and nitrocarburizing (FNC) processes are used since their low temperature allows for treatment of finished components. They are applied to enhance the tribological and corrosion properties of component surfaces.2 In many situations, nitriding replaces carburizing even if the nitrided layer is not as thick.3 A post-oxidizing step, applied at the end of FNC, leads to significant enhancement of corrosion properties by formation of a magnetite layer (Fe3O4).
"AHT’s newly developed process, UltraOx® Hyper, results in superior wear and corrosion resistance and allows for good control of the parts’ blackness. The latter is very important when the treatment is used for firearms. While the parts’ corrosion resistance improves with nitriding alone, the additional steps in UltraOx® Hyper significantly extend corrosion resistance. AHT is committed to achieving its customers’ desired metallurgical and cosmetic results through R&D and investing in state-of-the-art equipment. These innovations allow for flexibility in these areas."
In recent news, wave energy pioneer CorPower Ocean will be using Bodycote's thermochemical treatment, Corr-I-Dur®, for CorPower’s high-efficiency WECs.
Image Source: www.waterpowermagazine.com
From Bodycote, they say that their proprietary Bodycote thermochemical treatment “Corr-I-Dur® is a combination of various low temperature thermochemical process steps, mainly gaseous nitrocarburising and oxidising.”
They explain, "In the process, a boundary layer consisting of three zones is produced. The diffusion layer forms the transition to the substrate and consists of interstitially dissolved nitrogen and nitride precipitations which increase the hardness and the fatigue strength of the component. Towards the surface it is followed by the compound layer, a carbonitride mainly of the hexagonal epsilon phase. The Fe3O4 iron oxide (magnetite) in the outer zone takes the effect of a passive layer comparable to the chromium-oxides on corrosion resistant steels.
"Due to the less metallic character of oxide and compound layer and the high hardness abrasion, adhesion and seizing wear can be distinctly reduced. Corr-I-Dur® has very little effect on distortion and dimensional changes of components compared to higher temperature case hardening processes."
How to Implement?
We’ve seen a lot of development in way of nitriding and ferritic nitrocarburizing (FNC), but for many heat treaters, you inherit specific processes and traditions of accomplishing heat treatment and do not have the chance to understand how to implement each process. Read the full 21 point comparative resource at FNC vs. Nitriding
The more informed you are, the better decisions you can make. For example, knowing these recent developments in metal treating and hardening is sure to help you decide whether to shift directions in how you company process parts for electric vehicles, or if you are ready to expand your offerings for your aerospace clients. It is clear that each of these processes have a future all-their-own. It’s up to you to decide whether that future should be yours, too.
For more information on the basics of hardness, listen to the what, why, and how of hardening with Mark Hemsath, an expert on metal hardness and vice president of Sales – Americas for Nitrex Heat Treating Services, on this Heat Treat Radio episode with Doug Glenn, publisher of Heat Treat Today. You can also review the resources below that were referenced in today’s article.
1 Daniel H. Herring, “The Heat Treat Doctor”, “Case Hardening of Steel, Part Three: Gas Nitriding,” PowerPoint Presentation, © 2004 – 2010 The HERRING GROUP, Inc.
2 “Thermochemical Surface Engineering of Steels”, Woodhead Publishing Series in Metals and Surface Engineering: Number 62, Ed. Eric J. Mittemeijer and Marcel A. J. Somers, Elsevier, 2015, pp.1-769.
3 J. Senatorski, et. al, Tribology of Nitrided and Nitrocarburized Steels”, ASM Handbook Vol 18, Friction, Lubrication and Wear Technology, ed. G. Totten ASM International, 2017, pp. 638-652.
Resources
  1. Herring, “Case Hardening of Steel, Part Three: Gas Nitriding,” PowerPoint Presentation, © 2004 – 2010 The HERRING GROUP, Inc.
  2. Harrison, “Elevate Your Knowledge: 5 Need-to-Know Case Hardening Processes,” Heat Treat Today, https://www.heattreattoday.com/processes/hardening/hardening-technical-content/comparative-study-of-5-case-hardening-processes/.
  3. Hemsath and D. Glenn, “Heat Treat Radio: Metal Hardening 101, Part 2 of 3,” Podcast and Transcript, Heat Treat Today, https://www.heattreattoday.com/media-category/heat-treat-radio/heat-treat-radio-metal-hardening-101-with-mark-hemsath-part-2-of-3/.
  4. Orosz, T. Wingens, and D. Herring, “Nitriding vs. FNC,” Heat Treat Today, https://www.heattreattoday.com/processes/nitrocarburizing/nitrocarburizing-technical-content/integrated-nitriding-and-fnc/.
  5. Senatorski, J. Tacikowski, E. Rolinski and S. Lampman, “Tribology of Nitrided and Nitrocarburized Steels”, ASM Handbook Vol 18, Friction, Lubrication and Wear Technology, ed. G. Totten ASM International, 2017.
  6. “Thermochemical Surface Engineering of Steels”, Woodhead Publishing Series in Metals and Surface Engineering: Number 62, Ed. Eric J. Mittemeijer and Marcel A. J. Somers, Elsevier, 2015, pp.1-769.
Looking to a Future with FNC or Nitriding? Read More »
Welcome to Heat Treat Today's This Week in Heat Treat Social Media. As you know, there is so much content available on the web that it’s next to impossible to sift through all of the articles and posts that flood our inboxes and notifications on a daily basis. So, Heat Treat Today is here to bring you the latest in compelling, inspiring, and entertaining heat treat news from the different social media venues that you’ve just got to see and read!
This week, we check out what's going on in the heat treat community (in person and afar), watch a robot video (it may look familiar, but this time the robot might be at your plant), and read a not-so-heat-treat-but-certainly-funny T-shirt.
1. "Spot What You've Been Missing"?
Spot, the dancing robot from the previous TWIHTSM, can perform manufacturing site inspections. Using Fluke imaging technology, the robot can monitor site problem areas. What do you think? Does this change the game of manufacturing? Is it a good solution to safety concerns on the shop floor?
2. Water Cooler Talk
What have you been talking about while we were away? Online chatter "around the cooler" yields some interesting insights. Let us know about some interesting fact or episode in your world by tagging @HeatTreatToday on your next post!
Chattin' About Furnaces
Influences on Furnace Pumping Time?
Too Basic?
3. Heat Treat Community
In person or online, we can't get enough of the comradery. Let's show you what we're talking about. . .
@Women in Manufacturing!
To China and Beyond!
Luncheons in the Air (kind of)
4. Reading and Podcast Corner
You can't read everything, we get it. So how's about you listen/watch/read this ONE epic podcast? Yes? Perfect.
5. Outstanding 40 Under 40 Leaders of 2021
Check out some of the stellar Heat Treat Today 40 Under 40 Class of 2021 that have been popping up on the interwebs:
6. I know it's not heat treat. . . but I laughed
Have a great weekend!
Heat Treat Radio #64: Thermocouple 101 with John Niggle, Pelican Wire (Part 3 of 3)
Heat Treat Today publisher Doug Glenn wraps up this three-part series with Pelican Wire experts by talking with John Niggle from Pelican Wire about thermocouple insulation types and considerations.
The first two episodes cover the history, types, vocabulary, standards, and other basics of understanding how thermocouples work. Listen to the previous episodes of the series here.
Doug Glenn (DG):  Welcome to Heat Treat Radio!
John Niggle (JN):  Yes, it's good to see you again, Doug.  I know we've run into each other a couple of times out there in the field.  I'm looking forward to having the opportunity to do all of this stuff in person again.
DG:  It will be nice.  Before we hit the record button, we were talking about shows this fall and hoping that they happen because you, like I, are ready to get out and go.
You are the business development manager for Pelican Wire.  If you don't mind, give us just a little bit of background about you and about your experience in the whole thermocouple world.
Pelican Wire headquarters
JN:  Sure, absolutely.  As you said, I am the business development manager at Pelican Wire.  I've been at Pelican since 2013 so we're working out my eighth year here.  I'm a career industrial sales representative.  I do have previous experience also, actually, in the process instrumentation industry.  Way back when, before I even knew how to spell thermocouples, I was selling that stuff when I first got out of college.  My career has, sort of, gone full circle, let's say.
DG:  Very nice.  Well, you've got plenty of years of experience, which is great.  We've had two previous episodes with your colleague, Ed Valykeo, and we covered a good bit of stuff.  We covered a lot of basics in the first episode.  We covered standardization, and things of that sort, in the second episode.  I want to encourage any listeners who haven't listened to those episodes, feel free to go back, Google “Heat Treat Radio” and search for “Pelican Wire” and listen to episodes 1 and 2.
John, you and I want to move forward.  I'm always kind of curious about this question:  From your perspective, with your experience, why do we use thermocouples?  Let's talk about what they are and why we use them.
JN:  First of all, we have to assume that somebody is trying to measure the temperature of some sort of a process- a process or an event of some kind.  That's basically what they're trying to do.  Compared to other devices like RTDs, bimetal thermometers, liquid expansion state change devices and so forth, thermocouples are robust, they're inexpensive; they're repeatability, they're ease of use and size  -- all of those factors lead them to be more widely used than another sort of thermal measurement device of any kind.  It is the preferred method.
On top of that, I mentioned the expense part.  Because they're relatively inexpensive, there are certain industries, the heat treat industry and smelting industry, for example, consider these as, actually, consumable or disposable.  So, the cost factors in significantly in the industry that we're talking about here.
DG:  I live in western Pennsylvania and the town where my wife grew up, there was an old Leeds and Northrup manufacturing plant.  I believe they made the consumable thermocouples for melt shops.  You would, basically, throw the thermocouple in and it would melt quickly but it would give you a response during that time.
CLICK to Listen!
JN:  Right.  And, as I mentioned earlier, the response factor is important, or that's one of the factors considered, when people are looking at thermocouple wire.  And, you're correct, Ed Valykeo, as you mentioned, has 40 years of experience in the industry and has seen exactly the same sort of thing that you're talking about where people will just tack weld it onto something that gets thrown into a furnace or it gets thrown into a melting pot or something like that, and they're looking for that instantaneous temperature.
If you don't mind, I'll tell you that we've done some work, actually, in the aerospace industry and we had a customer that we sold significant, literally miles, of thermocouple wire to (when I say aerospace, it was specifically for space exploration) and this was because of whatever we had done with the insulation.  I can't tell you, because it was before my time, but this is what was relayed to me- they were able to get another 3 - 4 seconds of temperature measurement out of that wire.  That critical, extra data for them made all the difference in the world.
DG:  We're going to get to the insulation part which should be interesting.  You won't have to tell us any trade secrets, but we are headed in that direction anyhow.
So, different types of thermocouples.  Again, just a review question for us.  Why use them?  Why the different types and why are we using different types?
JN:  Forgive me, Doug, and the rest of the audience, for that matter, if I end of repeating some of the things that came out in the previous episode.  Basically, when you're talking about thermocouples, there are the two chemistries; for lack of a better term, you have “base” and “noble” metals.  The base metals are really the metals that we focus on at Pelican.  The noble metals are the more expensive ones- rare earth metals, tungsten, titanium, platinum and all those sorts of things that people spend exorbitant amounts of money on.  There are purposes for those, but, typically, what you're going to see in the heat treat industry, in particular, you're going to see a lot of the base metals.
I like to say that, truly, the 20 gauge K, in particular, is the 800 pound gorilla in the room.  It's almost considered, and I think it would be by people in the industry, a commodity.  There are untold miles of that wire that are used in the heat treating and smelting industry.  K is used, really, because of the temperature range.  It fits in well with what people do in the heat treating industry.  It is good for temperatures from zero up to around 1260 C.  It's inexpensive, it covers the ranges that those people are looking for, and, again, it's the 800 pound gorilla in the room when it comes to temperature measurement in the heat treating industry.
Click to read the Heat Treat Today Original Content article on thermocouples.
The other types such as J comes up periodically, particularly if you're looking at lower temperature ranges.  You won't see it quite as often in the heat treating industry.  You will see it somewhat, but not to the degree that you would K.  The J thermocouple wire has an iron leg so it does oxidize and you need to be careful about that sort of thing.  Type T thermocouple wire has a narrower range.  It has very good response times in cryogenic and cold temperature applications.  The higher, upper end of type T thermocouple wire, typically, wouldn't be of terrible interest to the audience that we're involved with here, for the most part, because the upper ends around 370 to 400 C degrees, in lab environments; that's where it's going to be the most popular.
There is also type E.  It's a higher temperature, as well.  Response time.  Broader range is a little bit better than K at lower temperature ranges.  An interesting one is type N that you will see fairly often in the heat treating industry.  For those people not familiar with type N, it is different alloys than type K.  It covers virtually the same temperature range that type K does and will, actually, have less drift than type K.  It is more expensive because of the alloys that it is made of, but, again, if you're interested in less drift, then type N is worth looking at.  It hasn't quite caught on in the US the way it has in, say, Europe, in particular, and that really has to do with the infrastructure of the instrumentation.  People have instrumentation that is either calibrated for K or J or something like that.  Now, there is instrumentation out there, now, that would use K and N both, so we may see more, particularly, in the aerospace industry I would think it would become more and more popular.
DG:  That's helpful.  It's always good to hear those things over again.
How about the parameters and/or the factors that need to be considered when you're constructing the wire to start with?  What do we need to be worried about in that area?
JN:  I don't know if I like the word “worried” exactly, Doug.  It's more, what do we need to think about?  What do we need to be concerned about?  Besides the metallurgy that we just talked about, we need to think in terms of what the sensor is actually going to look like.  Is it just the wire?  Thermocouple wire, by itself, can be a thermocouple; that's it, without any protection or anything like that.
As I mentioned earlier, you can tack weld it to an ingot, or something like that, and there you go.  You don't have any probe, there is no thermal well to protect it or anything like that.  But, what we do need to think about, then, is the process that it's going to be involved in.  Where is it going to be used?  Is it going to see an environment where there is a flow.  Is it going to see an environment where somehow the thermocouple wire can become damaged?  In that case, then, we're headed in the direction of talking about what our customers are interested in.  And for a customer for Pelican Wire, we're mainly talking about people who actually assemble thermocouples – they make the connections, they have the molds and all that sort of thing.
To be clear, Pelican Wire just makes wire.  And, again, the thermocouple wire can be used as a thermocouple, but a tremendous amount of wire is actually connected to some sort of a sensor or a probe, as I said, and is protected in a thermal well or something along those lines.
"But, what we do need to think about, then, is the process that it's going to be involved in.  Where is it going to be used?  Is it going to see an environment where there is a flow.  Is it going to see an environment where somehow the thermocouple wire can become damaged?  In that case, then, we're headed in the direction of talking about what our customers are interested in."
John Niggle
DG:  Do we also have to be concerned with oxidizing, carburizing atmospheres, corrosive atmospheres?  Is that, also, something that we need to be aware of?
JN:  Absolutely.  And that is one of the reasons you will see a probe thermocouple is because the wire is protected from that atmosphere.  Nearly all of the wires that we talked about would be affected, particularly, in say, like a sulfurous environment; it would be subject to corrosion, oxidation and something along those lines.
Other factors, of course, are the accuracy and how much space we have.  Believe it or not, if it's going to go into a small orifice, then we need to think about what the age size is going to look like.  And then the environment:  Is it going to be abrasive?  Is there movement?  Is there some sort of braiding motion that could wear a hole in the wire in the insulation and so forth?  There are a lot of things to think about.
DG:  And, it would probably be a good idea, especially if our heat treat people are running anything outside of the norm, regardless of what it is, whether it be atmosphere, configuration, fixturing, if there is anything outside the norm, they would probably be wise to mention it to the thermocouple wire and/or thermocouple probe manufacturer and make sure that they know so that you guys can get help get the right thing on there in their furnace.
JN:  Yes, absolutely.  At the end of the day, we work with this every day.  We have design engineers on staff who can assist with technical questions and so forth and, of course, our customers, and the actual thermal wire assembly people, this is what they do every day of the week.
“I'll tell you that we've done some work, actually, in the aerospace industry and we had a customer that we sold significant, literally miles, of thermocouple wire to (when I say aerospace, it was specifically for space exploration) and this was because of whatever we had done with the insulation.”
DG:  Let's talk about something a little bit new, I guess, to our conversation here in this 3-part series, and that is the insulation that's going to go around these wires.  Can you tell us what are the different types of insulations and what are the advantages and/or disadvantages of each, and why would we be using them?
JN:  I'll break it down into, what I would call, the four basic categories.  That would be an extruded insulation, insulations that are tapes, fiberglass insulations that are routinely worked with and then, of course, high temp textiles.  High temp textiles, in particular, would be of interest to the audience here in the heat treat metallurgy world.
Extruded insulations can be a variety of thermoplastics.  A term that, I think, Ed has probably mentioned before and we've talked about before is extension grade wire.  That typically has a PVC insulation on it and the reason PVC works for that is that it's cheap and extension grade wire, typically, does not see the sorts of high temp environments that you're going to see in processes.  It's really a signal wire that takes the signal from the probe or from the sensor to the process control device.
DG:  So what kind of temperature tolerances can the extruded wire handle?  Are we talking 300, 400 degrees?  I guess you talk C, I talk F.
Teflon frying pan
JN:  We talk whatever language our customer likes to talk, but we do talk C quite a bit.  So, PVC is quite low, it's in the 200s F.  But, when you're looking at fluoropolymer insulations (and Pelican is really a high temp house, so we focus on the higher temp insulations) you have FEP and PFA, those are in the 200s.  PFA actually goes up to 260.  So, you can see, it's probably not suitable for heat treating applications, smelting and that sort of thing.  The advantages to those compounds would be that you're going to have abrasion resistance.  Think about your Teflon frying pan: it's slick, it's smooth.  So, if you're in an environment where there is some movement, it will be good for that.  And, of course, it will have excellent moisture resistance and chemical resistance.  Those would be the advantages to the extruded wire.  The other advantage would be, because you'll have a thinner wall than you will with the other insulations, you'll have some more flexibility.  So, if you have a type N radius, you can go around a corner easily.
The next step up, in terms of temperature resistance, would be the tapes.  Basically, in that area, you're looking at PTFE tape, mica take and capped-on tape or polyamide tape.  Those will give you slightly higher heat resistances.  The mica, in particular, would give you more.  (Mica, as a matter of fact, is used as a supplement to the PTFE to give it even higher heat resistance.)  Mica will go up to 500 C, PTFE and the polyamides match, in terms of heat resistance, the extruder products around 260.  What they do give you, again if you use the tapes, is the heat resistance you're looking for, some abrasion resistance and the moisture resistance.  You'll have less flexibility because those products are stiffer, but they're also going to be a little bit lighter weight unless you incorporate the mica into it.  Then, when you do that, you're going to end up with an even stiffer wire and it will be a little bit heavier, and all those will be larger in diameter than an extruded wire.  If you look at an environment where you need to poke the wire through a hole and that hole is an eighth of an inch, you need to think really hard if what you're doing is going to work.
DG:  So you've got extruded and you've got tapes.
JN:  The next step after that would be fiberglass.  In the case of fiberglass, you have E glass and S glass.  Of the two, E glass would  have the lower temperature resistance and you're looking at 482 C on the high end.  For S glass, you're up to 704 C.  Now you're starting to talk about insulations that you will see in the heat treat environment; it's quite common, especially on the S glass side where you're looking at the 704, you'll see a lot of people that need 500 C for whatever reason.  The advantage, obviously, to the glass, as I mentioned, is the higher heat resistance.
There are disadvantages.  Think about fiberglass for a minute.  We actually have to saturate the wire to keep it from fraying without it ever really experiencing any abuse.  If we don't saturate it, then the wire can fray, and you can get fiberglass in your fingers even, which is unpleasant.  So, fiberglass has some disadvantages like that.  If you put it in an environment where there is some movement, abrasion, vibration or something like that, it can be problematic.  Also, it's going to be stiffer because it's saturated, typically.  Sometimes you'll even see those saturants even cause problems in a heat treat environment where, if it gets too hot, the saturant can leave an ash behind.  You're going to lose flexibility, as I said.  You're not going to have the abrasion resistance, the chemical resistance or the moisture resistance that you're going to get from an extruded product.
The other one that we see, again, literally miles and miles and miles of, in the heat treat world would be what's called Refrosil and Nextel, (those are both, actually, trade names).  We're talking about vitreous silica and ceramic.  Again, those are, what we call, high temp textiles.  Now, you're looking at products that are in the 1200 C range.  Ceramic goes up to 1204, vitreous silica is in the 870's.  Again, there are some of the same disadvantages with those that you're going to have with glass.  It's going to be somewhat fragile.  We don't saturate those because the saturants are not going to hold up in the environments that they're going to be placed into, so you would have that ash residue left.
Again, it will be stiff, it will be even larger in diameter than the fiberglass, which is larger than tape which is larger than the extruder products.  Of course, you're not going to have the abrasion resistance, the moisture resistance or the chemical resistance.  But it does protect the wire in those elevated temperature environments that are critical for the heat treating industry.
DG:  Let's back up a bit.  I want to understand something you said.  You said, in the fiberglass, it is saturated and in the textiles it's not.  I want to know what you mean by saturated.
JN:  It's either a solvent-based or a water-based saturant that is applied to the wire to protect it.  Think in terms of a varnish.  It would be like a protective coating.  Again, it just keeps the exterior of the wire, the bare wire, from being exposed.  It's a coating, but we call it a saturant.
DG:  High temperature textiles tend to be the stuff we're using, in the heat treat industry, probably most.
JN:  Yes.  Again, when I mentioned the 800 pound gorilla in the room, the 20-gauge K with the vitreous silica or the Refrosil would be an extremely popular product in the heat treating industry, absolutely.
DG:  Let me ask you a very, very fundamental question.  I'm curious of your answer to this.  Why do we insulate wires at all?  Is it done to protect from temperature or is it done simply to protect them from crossing with each other and grounding or shorting out?  Why do we insulate?
"I'll go back to something that I know Ed talked about: the Seebeck effect. You have this loop; if you don't have that loop, then you don't have anything. You don't have the EMF, the electromotive force, that you're looking for."
John Niggle
JN:  It is the second part.  When you look at any wire construction, the two singles have to be insulated from each other.  I'll go back to something that I know Ed talked about: the Seebeck effect.  You have this loop; if you don't have that loop, then you don't have anything.  You don't have the EMF, the electromotive force, that you're looking for.  We do make a wire that is not duplex, but, typically, what you're going to see is a wire that has two singles and then it's duplexed with an insulation over the top.  We do make a wire that the two singles are jacketed in parallel and then no jacket is placed over the top but that is for an application that wouldn't be suitable for the heat treat industry.
DG:  I asked that question, because for those who are unbaptized in this conversation, it's kind of interesting.  So, we're talking about insulation and we're doing a lot of conversation about temperature ranges and, for someone who wouldn't think so, they would say, "Well, that means you're insulating because of temperature."  But, really, the reason you're insulating wire is for electrical.  It's to keep them apart.  It's just how high of temperatures those insulations can handle, not that you're insulating the wire to keep them cool.  Right?
JN:  Absolutely not.
DG:  That may sound very basic, but there may be people that think that, so I want to get that on the table.
JN:  Most of the people in the audience are probably familiar with this already.  Typically, what happens is the wire is stripped so we have exposed ends.  And then those ends, as we mentioned earlier, can be tack welded onto something or they can just be out there.  The thermocouple world, by the way, is an incestuous world where we have customers, we kind of compete with those customers, some of our customers compete with others of our customers but then they buy supplies from each other.  You probably already know that from talking with other people in this industry.  At any rate, the wire is stripped and then it's either tack welded or it's connected to some sort of sensor or probe of some kind.
DG:  It's a tangled web, the whole thermocouple world.  You've got customers, yet you sell to certain suppliers who also sell to those customers.  It can be complicated!  But that's OK, we'll let you guys worry about that; we just want to make sure the thermocouples are good and we'll be in good shape.
Another question for you:  We talked about the process and a lot of different environments about what type of thermocouple you should use, but does the process being monitored influence the type of insulation that should be used?  Obviously, temperature is going to have an impact, but is there anything else?
JN:  Yes.  Let's circle back to what we talked about earlier just a little bit.  When you look at the process, you need to think of what is going to happen to that wire?  Is it going to see, first of all as you mentioned, the temperatures?  That is certainly important so that comes into play with the insulation.  But, we need to think about, Is there movement?  Is there going to be some abrasion?  Is there some sort of activity that could damage the wire somehow?  Then, we need to look at the chemicals, like we talked about.  Do we need some chemical resistance?  Do we need water resistance?  Is it going to be submersed in something?  Those things all need to be considered.
Again, as I mentioned earlier, the actual placement of the wire.  Does it need to be inserted in a hole?  At Pelican, we produce wire down to 40 and actually 44 gauge which, I think, will probably be stunning to most of the people in your audience because, again, 20-gauge K is what these people think about.  In the heat treating industry, what you see is they need a robust wire, something that's going to be able to handle those temperatures and a large conductor like that.
Another thing to think about, actually, is a bend radius.  Are you going to put the wire somewhere where it needs to go around a corner, around a bend?  Then, are you better off using a stranded wire?  A stranded wire is going to have more flexibility.  You can buy a 20-gauge stranded wire, you can buy 24-gauge, 28-gauge, 36-gauge.
DG:  Now, what do you mean by stranded?
JN:  Stranded wire would be instead of just one solid 20-gauge conductor, you have multiple strands that make up that 20-gauge.  But, if you think about it, multiple strands of wire will actually be more flexible.  You'll still get the same results, but it will be more flexible if you need to go around a corner or if you need to insert it into something.
DG:  It's almost like a braided wire as opposed to a solid.
JN:  Yes.  Now braiding is a little bit of a different process.  When we're talking about stranded wire, it's, basically, just spiral.  Braided is more crossed into each other, which, coincidentally, is the way that the fiberglass and the high temp textile insulations are made – those are actually braided.  And, by the way, I'll just toss this out, it's made on equipment that really hasn't changed since the ‘20s.  I'm not talking about the 2020s, I'm talking about the 1920s!  Rumor has it, some of that braiding equipment was, actually, designed by Thomas Edison.  I'm not sure if that's really true.  But that is the process used to apply the fiberglass and high temp textiles.
DG:  So, anything else as far as any other considerations we need to take into consideration when we're talking about choosing insulation?  If not, that's fine.
JN:  I think I covered them, Doug.
DG:  At Pelican Wire, your company, I know you guys deal with a broad number of markets, I'm sure, one of them being heat treat.  What do you see as any special demands or special concerns that are, maybe, unique or, at least, inherent in the heat treat market?
". . . what you see is insulations that are higher in temperature resistance, as well. In some cases, as I mentioned earlier, in ovens where there is a saturant involved, we could see ash. Some people ask that saturant not be applied to the fiberglass and that's certainly something that can be done."
John Niggle
JN:  For the heat treat market, again, I'll go back to what I said earlier, we see a lot of 20-gauge K used.  It's because of the higher heat requirements, the higher heat that is involved with the processes of heat treating.  Secondly, what you see is insulations that are higher in temperature resistance, as well.  In some cases, as I mentioned earlier, in ovens where there is a saturant involved, we could see ash.  Some people ask that saturant not be applied to the fiberglass and that's certainly something that can be done.
Sometimes we're even asked to not put tracers.  We go back to what we talked about earlier with the metallurgy- you have two legs, a positive and a negative leg.  Well, how do those end users tell those legs apart if they look similar, if they're an alloy of some kind?  So, we put a tracer wire in there so you have a red leg and a yellow leg, in the case of type K, or sometimes you just have a red leg depending on what they ask for.  Those tracers can, actually, cause problems, too, if the ovens are hot enough and they are in there for long enough times.  We even have customers who ask us not to put tracers in their wire, for that matter.
Accuracy, of course, is extremely important.  I know that Ed, in a previous episode, talked about standard limits, special limits and all that sort of thing.  Typically, you're going to see special limits used in the heat treat industry and, in some cases, we're asked even for special calibration points.  In previous podcasts, I've heard you talk with other people about AMS2750 and how that comes into play.  It is extremely critical for the folks in the heat treating industry and something that clearly a thermocouple wire producer has to understand.
DG:  Let's say you've got a customer that calls you and wants to talk about their thermocouple needs, let's say there is some sort of special need.  What would you suggest they have, in hand, when they call you?  What do you need to know from them to help you do a better job with their thermocouple needs?
JN:  Honestly, the first question we do ask is:  What temperature are you going to be running this at?  How hot are we going to be?  We, absolutely, need to know that.  That helps us narrow down the alloy that we might be looking at, whether it's type K, type J, type E, or whatever.  And then, of course, it's a natural thing to dial in the insulation after that.  Quite honestly, one of the things that frustrates me is when people say, "I need Teflon."  Well, OK.  Do you need FEP or do you need PFA?  Those are both fluoropolymers like Teflon is.  We need to talk about temperature resistance, so don't tell me you just need Teflon.  We do need some specifics when it comes to that sort of thing.  Again, we talked earlier about stranding and stranded wire.  Do you need some flexibility?  What gauge size do you think you need?  How robust does this wire need to be?  Those are some of the key factors we need to know about.
DG:  Let's say, for example, somebody does want to get a hold of you or Ed, your colleague who was on the first two episodes, how is best to do that?  How can we get a hold of Pelican Wire?
JN:  Our web address is www.pelicanwire.com, about a simple as it possibly gets.  Our email addresses are, actually, quite simple, as well.  If anybody wants to email me, it's jniggle@pelicanwire.com.  You can contact me directly, if you want to, or we have a sales inbox and that is simply sales@pelicanwire.com.  We do have a phone number, but it seems a lot of people don't care about phone numbers as much these days.  But the number is 239-597-8555.
DG:  I have one, unrelated, question for you that I know the world is wanting to know:  How is it having a company in Naples, Florida, that's what I want to know?
JN:  I'll tell you what, Doug, the answer today will be different than the answer in October or December.  It's actually quite nice.  We moved down here 8 years ago in 2013.  I moved from the Midwest and didn't really feature myself owning palm trees, but I own palm trees, which is pretty darn cool.  We are, as the crow flies, about 3 miles from the water, where I live anyhow, 20 minutes by car.  Our office and manufacturing facility are, actually, on the very edge of the everglades.  You can see the picture in the background behind me.  That's our building.  That's actually facing east.  That is a sunrise over the everglades.  We're on the very edge of the everglades.  There is a lake right next to our building and then, after that, it's everglades all the way over to Miami.  And, real quick, our weather pattern comes from the east.  It doesn't come from the Gulf.  This time of year, in the summer at about 3:00 in the afternoon, about the time that we're doing this call right now, a thunderstorm blows up and it comes from the east over the everglades and it moves to the west.  The trees blow that direction, you can see it coming.  It's interesting.  During the wintertime, I have to tell everyone, you'd probably be jealous, but it is truly paradise.
DG:  Yes!  I've been to Naples, ate at a nice restaurant down there, years ago, but it was very nice.
You guys are also employee-owned, right?
JN:  That's correct, yes.  The company is over 50 years old.  The founder of the company passed away in 2008 and, before he passed away, he converted the company to an employee-owned operation.  So, we've been employee-owned since 2008.  We've purchased a couple other companies since then that folded into, what we call, the Wire Experts Group.  Pelican Wire is part of that.  We have a sister company out in Colorado.  We bought another facility in Chicago and folded that into our company in Colorado.  So, yes, we're employee-owned and it works out really well for the employee owners, I'll tell you that much.
DG:  That's great.  John, it's been a pleasure talking with you.  Thanks for taking the time.  I appreciate your expertise.  Hopefully, we will see you out on the pavement somewhere in the real world.
JN:  I'll, actually, be seeing you at the heat treat show in about 3 weeks.
DG:  That's about right, yes.
JN:  Hopefully, some of the people that are listening we will see, as well.
Publisher
Heat Treat Radio #64: Thermocouple 101 with John Niggle, Pelican Wire (Part 3 of 3) Read More »
OCYour parts need heat treated to herculean surface hardness but with a soft, ductile core. That is to say, you are looking at case hardening processes, most likely one of these: gas carburizing, low-pressure carburizing, carbonitriding, gas nitriding, and ferritic nitrocarburizing.
Mike Harrison at Gasbarre Thermal Processing Systems brings us a Technical Tuesday article about what case hardening is and how five of the most common processes vary by (1) comparing the specific guidelines for each temp and time, (2) identifying equipment used to perform each process, and (3) providing a chart (at the end!) to understand different process considerations.
Mike Harrison
Engineering Manager of Industrial Furnace Systems Division
Atmosphere Gas Carburizing
Fig. 1 – Integral quench furnace: "The atmosphere gas carburizing process can be performed both in batch and continuous equipment."
Fig. 2 – Endothermic gas generator: "To achieve a carburizing atmosphere endothermic gas is typically used, which is produced by an endothermic gas generator that heats a combination of natural gas and air to create a mixture that is approximately 40% hydrogen, 40% nitrogen, and 20% carbon monoxide."
Low-Pressure Carburizing
Fig. 3 – Vacuum furnace with oil quench
Fig. 4 – Continuous vacuum furnace
Carbonitriding
Diffusion Only Processes
Gas Nitriding
Fig. 5 – Horizontal retort nitriding furnace: "Traditionally, pit furnaces have been used for nitriding as they can accommodate larger load sizes and can be easier to seal as gravity helps keep the lid sealed; however, horizontal designs have gained in popularity in recent years."
Considerations
Screenshot 2023-12-27 at 1.19.41 PM
Elevate Your Knowledge: 5 Need-to-Know Case Hardening Processes Read More »
Tecnovacum to Heat Treat with New Vacuum Furnace
HTD Size-PR LogoBrazilian commercial heat treater Tecnovacum recently received a vacuum furnace, produced in cooperation between a Polish-based furnace suppler and a Brazilian-based furnace manufacturer.
For the first time in the history of the SECO/WARWICK Group, parent company to North American SECO/VACUUM Technologies, the order was executed in a 50/50 cooperation system – Tecnovacum’s financing plan with an industry development bank stipulated that at least 50% of the equipment production would be in Brazil with Combustol Fornos Ind Com. Ltda, who was the partner for this project.
Maciej Korecki
Vice President of the Vacuum Furnace Segment
SECO/WARWICK
(source: SECO/WARWICK)
The Vector vacuum furnace is the first product that the supplier has provided to Tecnovacum. To implement the government subsidy program, the equipment must have 50% of the production in the territory of Brazil. The furnace was developed in close cooperation with the Brazilian partner – Combustol Fornos Ind Com. Ltda. Cooperation between the two companies has been ongoing for six years in terms of sales, supplies and start-ups of furnaces in Brazil.
"This is an exceptional situation, the first one, but certainly not the last," commented Maciej Korecki, vice-president of the Vacuum Segment of the SECO/WARWICK Group. "Under our supervision and in close cooperation, the Brazilian partner made the casing and the control cabinet in Brazil, and the company was also responsible for the equipment assembly and start-up [. . .] We are glad that we have a partner who is not only able to carry out the assembly, start-up and service of our equipment on site, but also build the entire vacuum furnace in cooperation with us."
Tecnovacum to Heat Treat with New Vacuum Furnace Read More »
Ovako’s Transformational Heat Treat Benefits with Electric Retrofit
HTD Size-PR LogoFor Ovako, a centuries old manufacturer of engineering steel, innovative approaches to producing their product has taken the form of electrifying their roller hearth furnaces over the course of the past decade.
The process of converting to electric heating began in 2014, each furnace installed with up to 86 Tubothal® metallic heating elements from Kanthal. Now, 14 roller hearth furnaces are electrified. The estimated CO2 savings is around 1,400 to 2,000 tons per year per furnace.
“[In] our heat treatment shop in Hofors,” shares Anders Lugnet, a furnace technology specialist at Ovako (pictured above), “we originally had around 450 gas burners, and there was always a problem somewhere in one of them. Since replacing them with 300-odd Tubothal® elements, the daily maintenance is simply not there. Occasionally, an element needs to be replaced, but it is nothing compared to the way it was.”
He continues that, previously, NOx and CO2 emissions were problematic. But with green electricity, emissions are zero, and with no flue-gas losses, total efficiency has improved significantly.
You can read more about this gas burner to electrification retrofit piece of news here: “Clean and Simple: How Electric Heating Transformed Ovako’s Heat Treatment Furnaces”
Ovako’s Transformational Heat Treat Benefits with Electric Retrofit Read More »
Where is Aluminum Headed?
Source: heatprocessing
Today's shared content is provided by the global information partnership between leading European heat treat news provider heatprocessing and the team at Heat Treat Today.
It may be starting in Europe, but through "free and fair-trade", increasing aluminum use may find its way around the world. On September 28th and 29th, engineers and business advocates gathered at the ALUMINUM Business Summit to discuss mobility, digitization, sustainability, and the market development of steel. This article, written by Dr. Gerd Götz, Director General at European Aluminium, is a preview to the discussions that took place.
"Aluminium is a sustainable material essential to Europe’s green transition. It is used in solar panels, wind turbines, electric vehicles, transmission cables for renewable electricity, etc. The endless recyclability of aluminium further contributes to decarbonization and the circular economy."
Read this article and others in the magazine at: The FREE Edition of heatprocessing's 2-3 2021
Where is Aluminum Headed? Read More »
Extend Your Life: Hot Zone Replacement
Source: Ipsen
Where is all of the action happening? In the "hot zone". More than just a catchy name, you always want to make sure this high-impact area is working the best it can.
This best of the web article will show you how to maintain your hot zone with three key tips, and then give you a 5-point run-down on how you know you it’s time to replace it.
"Depending on your process and parts, hot zones can last for many years (5-8 years on average) or may need to be replaced more frequently. Several factors that affect the lifespan of a hot zone include:"
Read more: "A Look Inside the Furnace: Hot Zone Maintenance for Extending Lifespan"
Extend Your Life: Hot Zone Replacement Read More »
