MANUFACTURING HEAT TREAT
Silica and Quartz Product Manufacturer Receives Box Furnace
L&L Special Furnace Company ben-mounted box furnace
Worldwide manufacturer of high-purity fused silica and high-end ceramic products is set to receive another bench-mounted box furnace from North American furnace supplier. These materials are used in the semiconductor and photonics industry as well as many other ceramic and composite industries worldwide.
The L&L Special Furnace Co. furnaces are part of the research and development department and are an important component of the testing and quality control department. The Model GS1714 has internal dimensions of 17” wide by 12” high by 14-1/2” deep and the operating voltage of 208, 220, 240 volts single phase, 60 or 50 hertz. It is also equipped for adjustable PID logic and finer temperature control around setpoint.
The furnace is constructed from 3” lightweight IFB firebrick, backed up with 2” of board insulation. The elements are oriented in the furnace to have long life and easy replacement as well as deliver consistent heat distribution with a uniformity gradient of ±7.5°F.
Silica and Quartz Product Manufacturer Receives Box Furnace Read More »
Nuts and Bolts of Combustion Systems – Safety Shutoff Valve
op-edSafety shutoff valves are the last line of defense against a potentially catastrophic incident. When conditions require, they interrupt the flow of fuel to the burner(s) and oven. There are many options when selecting fuel safety shutoff valves for your application. The construction and application of these devices is highly regulated by interlocking standards created by many different organizations. The goal of this article is to clarify how to comply with the most common standard affecting the reader: NFPA 86.
This column appeared in Heat Treat Today’s 2021 Trade Show September print edition. John Clarke is the technical director at  Helios Electric Corporation and is writing about combustion related topics throughout 2021 for Heat Treat Today.
John B. Clarke
Technical Director
To start, we must define our terms. The 2019 edition of NFPA 86* defines a safety shutoff valve as a “normally closed valve installed in the piping that closes automatically to shut off the fuel, atmosphere gas, or oxygen in the event of abnormal conditions or during shutdown.”1 A valve is “normally closed” (NC) if it closes automatically when power is removed. A furnace or oven typically has as few as two or more safety shutoff valves. [Author’s note: If the system uses radiant tubes for heating, and all the criteria are met, it may be acceptable to use only one valve in series, but this exception is not recommended by the author and will not be covered in this article.] There are two common arrangements for safety shutoff valve arrays—the Simple Double Block (Illustration 1) and the Double Block and Vent (Illustration 2). While both arrangements are compliant with the current version of NFPA 86, the vent is NOT required. In other words, Illustration 1 and Illustration 2 below are both acceptable.
The simple double block arrangement consists of two automatic, normally closed (NC) valves piped in series. It provides redundancy—both valves must leak for fuel gas to pass to the burner system. A double block and vent has two automatic, NC valves piped in series with a third automatic normally open (NO) valve installed between the NC valves. The purpose of the NO valve is to provide a path for any fuel gas leaking past the first NC valve to move to a safe location. Whether one should deploy a double block and vent approach depends on several considerations: Is the NO valve supervised? Is the selected vent location safe? And how will the system be inspected?
Illustration 1
Illustration 2
To start with, if the NO vent valve’s coil or wiring fails, it will remain open even when the system is operating—venting fuel gas. This is not only expensive, but high concentrations of vented fuel gas are an environmental and safety hazard. The solution to this concern is installing a monitored vent valve that only opens the NC valves after the vent valve is proven to be closed. This is typically accomplished with a proof-of-closure position switch that only closes after the vent valve is fully closed.
The next concern is the location and maintenance of the vent. The vent must terminate at a safe location that can accept the entire flow of fuel gas in the event of a failure. Therefore, hazards such as fresh air intakes and sources of ignition must be avoided at all costs. It is also important to periodically inspect the vent piping to ensure it remains unobstructed—insects and rodents may find the vent line a comfortable place to nest and bring up their young.
The last challenge is the periodic inspection of the vent valve and the vent piping—it is generally a challenge to test whether a vent line meets the design criteria, and leaking fuel gas can be vented without excessive backpressure.
A simple double block provides redundancy without the complexity of the vent. Good design practice, with proper valve selection, combined with proper fuel filtration greatly improves the reliability and longevity of both systems.
Valves used for safety shutoff valve applications must be listed by an approval agency for the service intended.2 Furthermore, depending on the flow rate, the valves must be equipped with either a local indicator showing the valve position and a means to prove the valve is closed.
For fuel gas flows below or equal to 150,000 BTU/hour, two safety shutoff valves in series will suffice. See Illustration 3 below. This is very typical for pilot lines.
Illustration 3
For fuel gas flows greater than 150,000 BTU/hour and less than or equal to 400,000 BTU/hour, two safety shutoff valves in series with local position indication are required. Local indication is generally a window where an operator can see the actual position of the valve—open or closed—without relying on any electrical circuit or pilot light. See Illustration 4 below.
Illustration 4
For fuel gas flows greater than 400,000 BTU/hour, NFPA 86 requires two safety shutoff valves in series with local position indication. One valve must be equipped with a valve closed switch (VCS) that closes after the valve is fully closed, or a valve proving system (VPS) that runs a tightness check which must be utilized. The signal from either this VCS or VPS must be included in the burner management system’s (BMS) purge permissive string to ensure no fuel gas is flowing during the system preignition purge. The VCS must not actuate before the valve is fully closed. This is typically accomplished by using valve overtravel, where the valve closes first, then the mechanism continues to move until the VCS is actuated. This arrangement is depicted in Illustration 5 below.
Illustration 5
For the arrangement depicted in Illustration 5, NFPA only requires one valve be supervised with a VCS—the additional costs of supervising both valves are very low and will enhance safety.
Whatever the method used to shut off the fuel to burners or pilots, the array of valves must be inspected and tested annually or per the manufacturer’s recommendations, whichever period is the shortest. All systems must be designed to be tested—with provision provided to cycle valves in test mode and the ability to measure any potential leakage. We will explore how a fuel train should be “designed to be tested” in an upcoming article.
The one thing to always remember—safety shutoff valves are always deployed to provide redundancy, so that any one component failure will not prevent a safe interruption of fuel gas; but, as with all systems, there may be unforeseen events that can lead to complete failure. Only qualified people should design, operate, and maintain combustion systems.
[1] National Fire Protection Association – NFPA 86 Standard for Ovens and Furnaces 2019 Edition (NFPA, Quincy, Massachusetts, May 24, 2018) 3.3.82.2 pp 86-14.
[2] National Fire Protection Association – NFPA 86 Standard for Ovens and Furnaces 2019 Edition (NFPA, Quincy, Massachusetts, May 24, 2018) 13.5.11.1 pp 86-49.
John Clarke, with over 30 years in the heat processing area, is currently the technical director of Helios Electric Corporation. John’s work includes system efficiency analysis, burner design as well as burner management systems. John was a former president of the Industrial Heating Equipment Association and vice president at Maxon Corporation.
Nuts and Bolts of Combustion Systems – Safety Shutoff Valve Read More »
Vacuum Furnace Retrofit with New Binder Consolidation Technology
William (Bill) Jones
Owner and CEO
Solar Manufacturing
HTD Size-PR LogoRecently, a North American heat treater acquired a used VFS HL50 external quench vacuum furnace at an auction in the Philadelphia area. The main objective of this purchase was to retrofit this older furnace with a newer hot zone and pumping technology that will help minimize and target the condensation of detrimental binders evaporating out of MIM injection molded parts.
Solar Atmospheres of Western PA's maintenance team was responsible for refurbishing the furnace to its current standard. Solar Manufacturing, led by owner and CEO William Jones, designed the technology and the apparatus needed to consolidate the binders into one central location, thus minimizing the cleaning downtime the staff was experiencing. This includes a completely new hot zone, a binder pumping port, and a second vacuum pump. The collaborative effort ensured both projects came together seamlessly.
By mid-October, the high production MIM sinter job will be fully transferred from current Solar vacuum furnaces to this dedicated and refurbished vacuum furnace. After multiple sintering runs, the company will then have the data to compare the downtime of a traditional vacuum furnace versus the newly designed debind/sinter furnace. Solar looks forward to providing the MIM world with this new, critical processing information.
Vacuum Furnace Retrofit with New Binder Consolidation Technology Read More »
Heat Treat Radio #63 (Special Video Edition): Heat Treat Tomorrow – Hydrogen Combustion: Our Future or Hot Air?
Doug Glenn, publisher of Heat Treat Today, moderates a panel of 6 industry experts who address questions about the growing popularity of hydrogen combustion and what heat treaters need to do to prepare. Experts include Joe Wuenning, WS Thermal; Jeff Rafter, Selas Heat Technologies; Brian Kelly, Honeywell Thermal Solutions; John Clarke, Helios Electric Corporation; and Perry Stephens, EPRI.
Get IMMEDIATE access to this 60-minute, highly-informative discussion.
Heat Treat Radio #63 (Special Video Edition): Heat Treat Tomorrow – Hydrogen Combustion: Our Future or Hot Air? Read More »
International Cutting Tool Manufacturer Increases Capabilities with Vacuum Tempering Furnace
Piotr Zawistowski
Managing Director
SECO/VACUUM TECHNOLOGIES, USA
Source: secowarwick.com
HTD Size-PR LogoAn international manufacturer of cutting tools purchased a vacuum tempering furnace. This North American-made, horizontal, front-loading furnace is purpose-built to accommodate the client's needs with an all-metal hot zone for clean vacuum processing. As with the earlier furnaces from the same supplier, one of which was installed at a different facility, the new furnace includes a convection fan and a pressurized gas quench for quick cooling.
This is the fourth Vector furnace solution provided to the client. "There is no stronger statement," states Piotr Zawistowski, president of SECO/VACUUM, "[. . . ] than the customer who continues to order more of the same technology from us year after year as they expand. We are privileged to be a part of their growth."
Maciej Korecki
Vice President of the Vacuum Furnace Segment
SECO/WARWICK
(source: SECO/WARWICK)
"This customer demands – and has come to expect from us – a complete range of benefits, including precision heat treat uniformity, consistency from one workload to the next, and fast processing speeds along with low energy consumption," noted Maciej Korecki, vice president of the Vacuum Furnace Segment at SECO/WARWICK Group.
This single-chamber vacuum heat treating furnace is a good solution for machine tool manufacturers and is available with curved graphite elements or an all-metal hot zone. Additionally, it can be used for most standard hardening, tempering, annealing, solution heat treating, brazing and sintering applications.
International Cutting Tool Manufacturer Increases Capabilities with Vacuum Tempering Furnace Read More »
Navigating the 39 Top Heat Treat Resources
OCWelcome to another Technical Tuesday with Heat Treat Today! Heat Treat Today is always on the hunt for cutting-edge heat treat technology, trends, and resources that will help our audience become better informed to make wiser decisions.
To find the top resources being used in the industry, we asked your colleagues. But how to navigate the thirty-nine resources? In this quick guide, we'll show you how to navigate the resources provided by your colleagues in Heat Treat Today's 2021 Trade Show September print edition. And, after you've browsed these resources, you may want to send your own top picks to Karen@HeatTreatToday.com for next year!
Resource Categories
You'll notice an icon in each resource bubble that indicates which of the five sections you are reading about. The resources appear in this order:
  1. Apps & Tools
  2. Teaching/Learning
  3. Networking
  4. At-Your-Fingertips
  5. Unconventional Ideas and Resources
Who Contributed?
Heat treating vice presidents of sales and operations, authors, and in-house experts at heat treat facilities all contributed. Some offered more than one resource, so be on the look-out for those overachievers! Several contributors were:
  • Tom Morrison at the Metal Treating Institute
  • Dan Herring, The Heat Treat Doctor at The HERRING Group, Inc.
  • Mike Coburn at AFC-Holcroft
  • Mark Rhoa, Jr at Chiz Bros
Sneak Peak?
Since you asked, here are a few pages from the digital edition of the September 2021 magazine. To see all of the resources, click here.
Navigating the 39 Top Heat Treat Resources Read More »
Division of Global Manufacturer of Steel Acquired by Italian Company
Martina Merz
CEO
thyssenkrupp AG
Global manufacturer in steel products announced the sale of Acciai Speciali Terni (AST), including the associated sales organization in Germany, Italy and Turkey, to the Italian company Arvedi. The parties have agreed not to disclose the purchase price.
The transaction is subject to approval by the supervisory board of thyssenkrupp AG and merger control clearance. The closing of the transaction is expected in the first half of 2022. thyssenkrupp is also examining a possible minority shareholding in the AST group. Details of this will be negotiated up to the closing.
"This fourth transaction shows once again clearly that we are working through our priorities and making decisive progress in the transformation of thyssenkrupp," Martina Merz, CEO of thyssenkrupp AG commented. “Speed in focusing the portfolio is crucial for a successful change process. At the same time, improving performance remains our most urgent task. Here too we are well on track and will not let up."
Cavaliere Giovanni Arvedi
Founder and President
Arvedi,
"[This] transaction has a compelling industrial rationale for Arvedi Group," said Cavaliere Giovanni Arvedi, founder and president of Arvedi, "which becomes stronger by successfully completing its product mix. Furthermore, this transaction is strategic for the whole Italian economy and represents an initial step towards new exciting developments. We are very pleased that [thyssenkrupp] is considering a potential minority shareholding in AST, guaranteeing continuity and showing trust in the know-how and capabilities of our Group."
"We are pleased to have found a new owner for AST in the Arvedi Group," adds Volkmar Dinstuhl, CEO of the Multi Tracks segment and Chairman of AST, "who will drive the development of the company with investments and innovations."
Progress has also been made with other portfolio companies in the Multi Tracks segment: The contract for the sale of the Mining business to the Danish company FLSmidth was signed at the end of July 2021, followed shortly afterwards by the signing of the contract for the sale of the Infrastructure business to FMC Beteiligungs KG. The sale of thyssenkrupp Carbon Components to Austrian Action Composites GmbH was completed on August 31. In addition, the closure of the heavy plate mill in Duisburg will be completed by the end of this month.
Division of Global Manufacturer of Steel Acquired by Italian Company Read More »
Thermcraft Acquired By Ohio-Based Fabricator
Lee Watson
President & CEO
Alloy Engineering
HTD Size-PR LogoThermcraft, Inc., a manufacturing company of thermal processing equipment, has recently been acquired. Nancy Crafton, widow of Thomas Crafton, the former president & CEO, shared details with the company family and introduced them to the new owner, saying, "Tom would be happy to know there is a bright future for Thermcraft."
Alloy Engineering, a diverse fabricator specializing in high-temperature & corrosion-resistant alloys, notes that the acquisition fits in the company's strategy to expand their high temperature product offering. Through the purchase, the company will be able to leverage their expertise in high temperature alloys along with Thermcraft's expertise in ceramics and heaters to deliver some innovative products to both existing and new customers and markets.
"I am excited and eager," said Lee Watson, president & CEO of Alloy Engineering, "to take the reputation built by the Crafton family along with the Thermcraft employees and grow it to the next level. By merging the core competencies of both companies and taking innovative solutions to market, we will provide a solid future for both of our companies."
Thermcraft Acquired By Ohio-Based Fabricator Read More »
Fusing the Heat Treat Practices with Human Creativity
OC Creation requires endurance and continued hard work. Find out what creative applications and research services your colleagues are committed to bringing from across the heat treat industry.
These innovations could bring the next level of innovation to your industrial plants. Enjoy!
Novel Mechanical Testing Systems Powered By Finite-Element Analysis, Optimization Algorithms, and Machine Learning
- An excerpt from a Heat Treat Radio episode with James Dean -
Doug Glenn:  You may have already stated this a little bit, but briefly: indentation plastometry is basically taking an indentation to be able to test, not just hardness or not even necessarily hardness, but the deformation or the strain of material.  Do you have to know the microstructure of the material when you’re doing these tests?
James Dean:  That’s a good question.  In principle, no.  If we were to dig deep into the mechanics of what’s going on within our system and our software package, you’d come to recognize that it’s, from a mathematical point of view at least, insensitive to microstructural features.  There is a numerical method underlying this – a finite-element analysis – therefore, treating this as a continuum system doesn’t take account explicitly of the microstructure.
When you’re doing the test, it’s actually helpful to know something about the microstructure simply because our technology is all about extracting bulk mechanical behavior engineering properties.  Therefore, when we do our indentation test, it is important that we are indenting a representative volume of the material.
It is important that we are capturing all of the microstructural features that give rise to the behavior you would measure in a microscopic stress strain test.  Otherwise, you can’t pull out those bulk, core engineering properties, and therefore, the scale on which you do the indent is important.  Your indenter has to be large relative to the scale of the microstructure.  So, it’s only at that level that you need to understand or know anything about the microstructure.
DG:  This test is a nondestructive test, right?  You said you can actually test live materials, correct?
JD:  Yes.
DG:  You don’t have to destroy them, you don’t have to machine them, you don’t have to make them into something you can rip apart, right?
JD:  Right.
Read/Listen to the full interview here.
Bert demonstrates the benefits of working with a collaborative robot to induction harden steel parts. The robot gives the operator the ability to work directly next to it, as opposed to conventional robot arms where fencing and distance is required.
Robotic Revolution
- An excerpt from Metal Treating Institute Member Profiles with Penna Flame Industries -
The computerized robotic surface hardening systems have revolutionized the surface hardening industry. These advanced robots, coupled with programmable index tables, provide an automation system that helps decrease production time while maintaining the highest quality in precision surface hardening.
  • Increased wear resistance
  • Higher hardness and longer life
  • Less processing time
  • Higher efficiency and productivity
  • Maintain tensile strength
  • Quick turnaround of the project
  • Consistent, repeatable process
  • Less distortion when compared to furnace treatment
Read the full article here.
High Pressure Break Through For Additive Manufacturing
- An excerpt from a Heat Treat Radio episode with Johan Hjärne -
DG:  Doing it all- stress relief, HIP, age, or whatever. Just for clarity sake, you’ve got a typical HIP process, you’re going to heat it up, put it under very high pressure, then, normally, if you didn’t have the high pressure heat treatment capabilities, you would have to cool that part down which is typically cooled quite slowly in a conventional HIP unit, taking more time and whatnot.  It then comes down to ambient, or close to ambient, where it can be held, you take it out, you put it back in another furnace (a normal furnace, not a HIP furnace), take the temperature back up, get it to the point where you want it, quick cool it, quench it, to a certain extent, to get the characteristics that you’re looking for, and you’re done.  What we’re talking about here is the combination of those two processes plus potential other things like stress relief, and all that, in a single unit, correct?
JH:  Yes.  This has very beneficial effects on time.  Many of the HIP vendors do not have HIP and heat treatment in the same facility.  Now we have sold a couple of units to some new HIP vendors that have this capacity, but, historically, the HIP vendors didn’t have both HIP and heat treatment.  First, the customer had to send it to a service provider for HIPing, they got the part back, they had to send it to somebody that could do the heat treat step, and then got the part back, and so on.  The time, and specifically for additive manufacturing, is important.  Keep in mind they can do a part pretty fast, anywhere between a day to two days, worst case a week, but then having to wait week after week after week to get the part back for the HIPing or for the heat treating.
DG:  So there’s a substantial, potential time savings, for sure; not just process savings in between furnaces, but the fact that you can buy one furnace and do both of those things.
Let’s talk for just a second about what types of products are most effectively HIPed and/or, if we can, high pressure heat treated.
JH:  As I said before, we really started to realize the potential with this technology with the additive manufacturing world.  That is were we started to realized that we can actually make a difference here.  Not only does it have a beneficial effect for the total time, but having the components under elevated temperature for a shorter period of time is actually beneficial for the microstructure; the grain doesn’t grow as much.
Modernizing Tech
- An excerpt from Metal Treating Institute Member Profiles with Franklin Brazing and Metal Treating -
Fusing the Heat Treat Practices with Human Creativity Read More »
Redline Industries, Inc. Acquired by North American Refractory Solutions Provider
HTD Size-PR LogoA supplier of monolithic refractories and construction services announced that it has completed the acquisition of Redline Industries, Inc., solidifying its reputation for innovation and customer satisfaction.
Jim Host
Business Development Manager
Redline, Inc.
Based in Chicago, IL, Redline Industries, Inc. was founded in 1998 and today is recognized as a first-rate supplier of low-cement refractory castables and gun mixes, having earned industry recognition for the quality of its products and the integrity of its people and business practices. Redline™ refractories are engineered to safeguard furnaces in the high-temperature processing of non-ferrous metals, such as aluminum, as well as prevent furnace heat loss to promote greater energy efficiency.
Brad Taylor
President and CEO
Plibrico
The Plibrico Company, LLC will provide seamless consistency for Redline customers by continuing to manufacture Redline refractories to their current specifications, while promoting the Redline brand within Plibrico's broad portfolio. Dedicated Redline support experts will carry on serving customers with no interruptions.
"This acquisition enhances our ability to better serve our customers," said Jim Host, business development manager at Redline.
"We are thrilled to bring Redline into the Plibrico family," commented Brad Taylor, president and CEO at Plibrico. "We believe this acquisition will provide customers with more choices as we leverage our complementary technologies and our core competencies in customer care, product development and manufacturing."
Redline Industries, Inc. Acquired by North American Refractory Solutions Provider Read More »
