This original content article was first written by Alberto Ramirez, engineer of Power Supply and Automation at Contour Hardening, Inc. and an honoree from Heat Treat Today’s 40 Under 40 Class of 2021, for Heat Treat Today's May 2023 Sustainable Heat Treat Technologiesprint edition.
Alberto Ramirez Power Supply and Automation Engineer Contour Hardening, Inc.
Figure 1. Induction hardening process Source: Contour Hardening, Inc.
Figure 2. Induction system components Source: Contour Hardening, Inc.
Figure 3. Capacitors Source: Contour Hardening, Inc.
Oscilloscope
Function generator
Ammeter
Digital and analog multimeter
High voltage probes
Figure 4. Energy parameters example Source: Contour Hardening, Inc.
Figure 5. Before and after of an arc at the transmission line Source: Contour Hardening, Inc.
Figure 6. Flow diagram of the energy process at the power supply Source: Contour Hardening, Inc.
Figure 7. Coil damage Contour Hardening, Inc.
Figure 8. Possible examples of measurements Contour Hardening, Inc.
Temperature
Voltage
Current
Resistance and capacitance
Waveforms
Summary
About the Author: Alberto C. Ramirez graduated from the National Technical Institute of Mexico as a mechatronics engineer. He earned his master’s degree in information technology administration from Monterrey Institute of Technology. With more than eight years of experience in power supplies, project management, maintenance, and automation, he currently works as a Power Supply and Automation Engineer at Contour Indianapolis. Alberto began his career at the Contour subsidiary in Mexico and due to his dedication, he is part of the staff in the United States. He is also an honoree from Heat TreatToday's 40 Under 40 Class of 2021.
This seventh article in the series from the Cybersecurity Desk helps you determine if CMMC applies to your business, learn about what changes were made to CMMC 1.0., know what you should be doing NOW to prepare for CMMC 2.0., and more.
Today’s read is a feature written by Joe Coleman, cybersecurity officer at Bluestreak Consulting™. This column is in Heat Treat Today’sMay 2023 Focus on Sustainable Heat Treat Technologies print edition.
Joe Coleman Cybersecurity Officer Bluestreak Consulting™ Source: Bluestreak Consulting™
Along with determining if CMMC (Cybersecurity Maturity Model Certification) applies to your business, this 7th article in the series from Heat Treat Today’s Cybersecurity Desk will give you a better understanding of what the certification is all about and the requirements to become certified. Also, we will cover the changes that were made to CMMC 1.0, the current status of CMMC’s proposed rule, and what you should be doing NOW to prepare for when the CMMC 2.0 rule is finally released.
What Is Changing in CMMC 2.0
In November 2021, the Department of Defense (DoD) announced a major update to the CMMC program. To safeguard sensitive national security information, the DoD launched CMMC 2.0, a comprehensive framework to protect the Defense Industrial Base’s (DIB’s) sensitive unclassified information from frequent and increasingly complex cyberattacks. Manufacturers or suppliers that handle sensitive or Controlled Unclassified Information (CUI) in any way or those within the DIB need to pay attention. CMMC 2.0 condenses the original 5 CMMC maturity levels into 3 levels, eliminating levels 2 and 4, and removing CMMC unique practices and all maturity processes. They have also revised the number of controls required for each of the three new levels. Level 1 includes 17 controls, Level 2 has 110 controls, and the total number of controls in Level 3 is still to be determined. There are also several other changes made that somewhat relax the requirements from CMMC 1.0.
Who Does CMMC Impact?
Manufacturers in the DIB are going to be held accountable to safeguard sensitive information and must comply with CMMC 2.0. Any contractor, subcontractor, supplier, or manufacturer that provides parts or services to the DoD or anyone within the DIB (no matter how minuscule) will need to comply with one of the three levels of CMMC compliance.
What Should Heat Treaters Be Doing Now?
Although CMMC 2.0 is still in the rulemaking phase, the new CMMC proposed rule is expected to be released sometime in mid-2023. This will give some much needed clarity on how to move forward and will help streamline the implementation of CMMC. Warnings will be issued to the DIB through DoD primes and will be passed down through the supply chain. Manufacturers that do not comply will be at risk of losing contracts.
If you (or your clients) are doing work for any DoD primes (or NASA), such as Raytheon, Lockheed Martin, McDonnell Douglas, Northrup Grumman, or L3Harris (and many more), then this applies to your business. If you are unsure, check the fine print in your contracts, and/or ask your clients about their requirements.
If you handle CUI in any way, you need to be at a CMMC Level 2 or Level 3. The most common level is Level 2. If you don’t handle CUI in any way, but you do handle FCI (Federal Contract Information), you will need to be certified at a Level 1.
On average, it can take a company of up to 100 employees between 12 to 18 months for NIST 800-171 (CMMC Level 2) implementation. Meaning, even though CMMC 2.0 is not completed yet, don’t wait until it is. You’re already a year behind if you haven’t started your NIST 800-171 implementations and you want to be ready for when the CMMC 2.0 rule is released
CMMC certification requires government oversight whereas NIST 800-171 compliance can be self-attested. You should always hire a qualified CMMC consultant to ensure that you’re “audit-ready” for your certification audit.
What’s the Difference Between FCI and CUI?
FCI is information not intended for public release. FCI is provided by or generated for the Federal Government under a contract to develop or deliver a product or service. CUI and FCI share important similarities and a particularly important distinction. Both CUI and FCI include information created or collected by or for the government, as well as information received from the government. However, while FCI is any information that is “not intended for public release,” CUI is information that requires safeguarding and may also be subject to dissemination controls. In short: All CUI in possession of a government contractor is FCI, but not all FCI is CUI.
Joe Coleman is the cybersecurity officer at Bluestreak Consulting™, which is a division of Bluestreak | Bright AM™. Joe has over 35 years of diverse manufacturing and engineering experience. His background includes extensive training in cybersecurity, a career as a machinist, machining manager, and an early additive manufacturing (AM) pioneer. Contact Joe at joe.coleman@go-throughput.com.
Piotr Skarbiński Vice President of Aluminum and CAB Products Segment SECOWARWICK Source: LinkedIn
EV/CAB lines for electric battery coolers' protective atmosphere brazing will be provided to manufacturers from Poland and the Czech Republic.
SECO/WARWICK Group's EV/CAB continuous lines are products dedicated to the automotive sector. EV/CAB solutions work for heat exchangers’ leading manufacturers and are used for mass production of large-size car battery coolers.
"Globally, the demand for electric cars and thus for battery coolers is increasing," commented Piotr Skarbiński, vice president of the Aluminum and CAB Products Segment, SECO/WARWICK Group. "It should be emphasized that the EV/CAB line is not a standard product, generally available on the market. Many years of experience have allowed us to create solutions optimally adapted to the production in this industry."
A Pennsylvania company recently heat treated and quenched a fabricated 47,000-pound gear. In addition to this gear, about a month ago, its reverse image (with the helix in the opposite direction) was also heat treated. The halves will be matched when grinding is complete to make a complete gear to drive a rolling mill for a steel plant.
Mark Podob President Metlab Source: LinkedIn
Following a formal process, Sheffield Forgemasters have placed an order of over $25 million for seven new furnaces — 3 forging and 4 heat treat — for the company’s proposed 14,000+ ton forging line. The large, open die forge will replace the company’s existing forging press and will complement its smaller press to serve defense and commercial markets.
Andritz, a company with North American locations, will supply the furnaces which will have up to 1,102 tons of capacity and will have rail-mounted car-bottoms which can roll in and out for the loading of ultra-large components.
“The furnaces will be the mainstay of our new heavy forging line, delivering both heat-treatment and main forging heating cycles, using the latest burner technologies for optimum efficiency and heat control," commented Steve Marshall, manufacturing transformation director at Sheffield Forgemasters. “New innovation in furnace technologies includes dual-fuel burners which can switch to hydrogen if the technology to move away from natural gas becomes viable."
Main photo l to r: Roman Mueller-Huenervogt from Andritz Metals and Steve Marshall from Sheffield Forgemasters, sign the furnaces contract.
On site at heat treat operations, gas-fired furnaces can be a significant source of carbon emissions. But depending on the desired heat treatment, an alternative approach that combines induction through heating and intensive quenching could be the “green ticket.” Learn about the ITH + IQ technique and discover how certain steels may benefit from this approach.
This Technical Tuesday article was composed by Edward Rylicki, Vice President Technology, and Chris Pedder, Technical Manager Heat Treat Products and Services, at Ajax TOCCO Magnethermic Corp., and Michael Aronov, CEO, IQ Technologies, Inc.It appears in Heat Treat Today's May 2023 Sustainable Heat Treat Technologiesprint edition.
Chris Pedder, Technical Manager Heat Treat Products and Services, Ajax TOCCO Magnethermic Corp. Source: Ajax TOCCO Magnethermic Corp.
Dr. Michael Aronov, CEO, IQ Technologies, Inc. Source: Ajax TOCCO Magnethermic Corp.
Ed Rylicki, Vice President Technology, Ajax TOCCO Detroit Development & Support Center Source: Ajax TOCCO Magnethermic Corp.
Table 1. Assumptions for calculating of carbon emissions by integral quench furnace Source: Ajax TOCCO Magnethermic Corp.
(Equation 1) Ehard = k • Qhard
where:
■ k = the emission coefficient (equal to 0.050 • 10-3 kg per 1 kJ of released energy when burning natural gas (see Reference 2) ■ Qhard = thermal energy required for heating up the above load from ambient to the austenitizing temperature
■ M = load weight, kg ■ C = steel specific heat capacity (kJ/kg°C) ■ Ta = part austenitizing temperature (°C) ■ To = part initial temperature (°C) ■ Eff = furnace thermal efficiency (a ratio of the furnace thermal losses to the gross heat input)
Figure 1 Source: Ajax TOCCO Magnethermic Corp.
(Equation 3)
Ecarb = k • Qcarb
where:
(Equation 4)
Qcarb = Qcarb1 + Qcarb2
Figure 2 Source: Ajax TOCCO Magnethermic Corp.
Per Reference 1, the environmentally unfriendly carburizing process can be fully eliminated in most cases for automotive pinions when applying the ITH + IQ method and using limited hardenability (LH) steels that have a very low amount of alloy elements. A case study conducted for drive pinions with one of the major U.S. automotive parts suppliers demonstrates the intensively quenched drive pinions met all client’s metallurgical specifications and passed both the ultimate strength test and the fatigue test. It was shown that the part’s fatigue resistance improved by about 150% compared to that of standard carburized and quenched in oil drive pinions. In addition, distortion of the intensively quenched drive pinions is so low that no part straitening operations were required.
Full-service commercial heat treating solutions provider Akademi Metalurji incorporated a turnkey nitriding installation to save on process gases and production time, and also process wider-dimensioned parts.
The project includes a mid-sized pit-type furnace, advanced controls, three process technologies, and accelerated cooling. The latter add-on equipment will help reduce cycle times, optimize production between batches, and run more cycles.
This new system allows the company to overcome efficiency and quality challenges they faced at the Gebze, Turkey, facility; the prior system consumed excessive amounts of process gases and yielded inconsistent nitriding results. Nitrex, a Canada-based company with international locations, provided the NX-1015 pit furnace, which offers an effective work zone of 39” d x 59” h (1000 x 1500 mm) and a load capacity of 4400 lbs. (2000 kg). The supplied library of Nitreg®-based recipes is tailored to meet different application requirements, resulting in a hardened surface that is highly wear-resistant, particularly useful for applications like machinery components, tooling, dies, and molds, where Akademi Metalurji specializes.
The system was successfully installed and commenced operations in April 2023.
Peter Zawistowski Managing Director SECO/VACUUM Technologies, USA Source: SECO/WARWICK
A global developer of power generation systems is planning to expand heat treat capabilities with a 2-bar vacuum furnace.
SECO/VACUUMwas awarded this contract and will provide a Vector® single chamber high-pressure quench vacuum furnace to expand the company's processing capacity, including high vacuum sintering and annealing. The new furnace will provide deep vacuum levels needed for the global developer's highly specialized applications.
"Securing continued business with this [client] is about working with people as much as it is working with machines," commented, Peter Zawistowski, managing director of SECO/VACUUM. This order is for a nearly identical furnace to one the same heat treat client ordered last year, which "really validated not just our furnace quality but also the teamwork and customer service behind it."
Are you trying to figure out what heat treat equipment investments you need to make in-house and what is better being outsourced? This conversation marks the continuation of Lunch & Learn, aHeat TreatRadio podcast series where an expert in the industry breaks down a heat treat fundamental with Doug Glenn, publisher ofHeat TreatTodayand host of the podcast, and theHeat TreatTodayteam. This conversation with Dan Herring, The Heat Treat Doctor®, zeros in on heat treat ovens versus atmosphere furnaces.
All About Ovens (01:42)
Universal oven from Grieve Source: Grieve
"Metal lined oven" Source: Dan Herring
"Double door shelf oven" Source: Dan Herring
"A larger horizontal oven . . . . a fan system sitting at back" Source: Dan Herring
"Walk in oven" Source: Dan Herring
"Industrial oven . . . . typical oven in typical heat treat shop" Source: Dan Herring
"Monorail conveyor oven . . . . with u-shaped radiant tubes" Source: Dan Herring
Q&A on Ovens (16:58)
Heat Treat Today team enjoying a Lunch & Learn session
A 14-foot long car bottom furnace Source: Solar Atmospheres of Western PA
"A box furnace . . . . sometimes difficult by sight alone to tell an oven or box furnace" Source: Dan Herring
"A box furnace with retort" Source: Dan Herring
"A pit style furnace . . . . there is probably 4X as much furnace below the floor" Source: Dan Herring
"An integral quench furnace, an in-out furnace" Source: Dan Herring
"A humpback style furnace" Source: Dan Herring
SEW-EURODRIVE has commissioned a modular NANO vacuum furnace system completely integrated with advanced automation for their Lyman, SC, facility.
It is the third NANO system with integrated robotics from ECM USA within the last two years. This 6 chamber, 20 bar quench NANO vacuum furnace system has 16 tempering positions, advanced solvent based washer (both oil and water based contaminants), and robotic workload assembly/disassembly.
Dunnage management is also provided and fully automated within the robotics configuration.
The system was specifically designed to run multiple materials (including carburized grades and tool steels) and will increase production for various load scenarios and processes. SEW-EURODRIVE MOVITRANS® (SEW-EURODRIVE’s patented inductive energy power transfer supply system) will also be incorporated within the vacuum furnace transfer system.
