The Chemistry Behind the Process: 6 Heat Treat Tips for Brazing, Induction, and Quenching
We’ve assembled some of the top 101 Heat Treat Tips that heat treating professionals submitted over the last three years into today’s original content. If you want more, search for “101 heat treat tips” on the website! Today’s tips will remind you of the importance of materials science and chemistry.
By the way, Heat Treat Today introduced Heat Treat Resources last year; this is a feature you can use when you’re at the plant or on the road. Check out the digital edition of the September Tradeshow magazine to check it out yourself!
Induction Hardening Cast Iron
(Dr. Valery Rudnev, FASM, Fellow IFHTSE, Professor Induction, Director Science & Technology, Inductoheat Inc.)
14 Quench Oil Selection Tips
- Part Material – chemistry & hardenability
- Part loading – fixturing, girds, baskets, part spacing, etc.
- Part geometry and mass – thin parts, thick parts, large changes in section size
- Distortion characteristics of the part (as a function of loading)
- Stress state from prior (manufacturing) operations
- Oil type – characteristics, cooling curve data
- Oil speed – fast, medium, slow, or marquench
- Oil temperature and maximum rate of rise
- Agitation – agitators (fixed or variable speed) or pumps
- Effective quench tank volume
- Quench tank design factors, including number of agitators or pumps, location of agitators, size of agitators, propellor size (diameter, clearance in draft tube), internal tank baffling (draft tubes, directional flow vanes, etc.), flow direction, quench elevator design (flow restrictions), volume of oil, type of agitator (fixed v. 2 speed v. variable speed), maximum (design) temperature rise, and heat exchanger type, size, heat removal rate in BTU/hr & instantaneous BTU/minute.
- Height of oil over the load
- Required flow velocity through the workload
- Post heat treat operations (if any)
(Dan Herring, “The Heat Treat Doctor®”, of The HERRING GROUP, Inc.)
How to Achieve a Good Braze
In vacuum brazing, be certain the faying surfaces are clean, close and parallel. This ensures the capillary action needed for a good braze.
A good brazing filler metal should:
- Be able to wet and make a strong bond on the base metal on which it’s to be applied.
- Have suitable melt and flow capabilities to permit the necessary capillary action.
- Have a well-blended stable chemistry, with minimal separation in the liquid state.
- Produce a good braze joint to meet the strength and corrosion requirements.
- Depending on the requirements, be able to produce or avoid base metal filler metal interactions.
(ECM USA)
(Dan Herring, The Heat Treat Doctor®)
Determine your quench: Induction or Immersion? Different aqueous quenchants will provide either faster or slower cooling depending upon induction or immersion quenching applications. It is important to select the proper quenchant to meet required metallurgical properties for the application.
- Part material: Chemistry and hardenability are important for the critical cooling rate for the application.
- Part material: Minimum and maximum section thickness is required to select the proper aqueous quenchant and concentration.
- Select the correct aqueous quenchant for the application as there are different chemistries. Choosing the correct aqueous quenchant will provide the required metallurgical properties.
- Review selected aqueous quenchant for physical characteristics and cooling curve data at respective concentrations.
- Filtration is important for aqueous quenchants to keep the solution as clean as possible.
- Check concentration of aqueous quenchant via kinematic viscosity, refractometer, or Greenlight Unit. Concentration should be monitored on a regular basis to ensure the quenchant’s heat extraction capabilities.
- Check for contamination (hydraulic oil, etc.) which can have an adverse effect on the products cooling curves and possibly affect metallurgical properties.
- Check pH to ensure proper corrosion protection on parts and equipment.
- Check microbiologicals which can foul the aqueous quenchant causing unpleasant odors in the quench tank and working environment. If necessary utilize a biostable aqueous quenchant.
- Implement a proactive maintenance program from your supplier.
(Quaker Houghton)
Container Clarity Counts!
(Rick Kaletsky)
