FEATURED NEWS
Heat Treating with Pumpkins?
OCHappy Halloween! Instead of the spook, we wanted to give you something to celebrate this weekend the way YOU know how to: through heat treating. Whether you know a heat treater on a tight budget or your shop is ready to "try something new", we want to show you TWO uses of pumpkins for your shop this Fall.
Pumpkins as Furnaces
Pumpkins make great ovens. The orange gourds, commonly converted into jack-o-lanterns this late-October, have a proven degree of structural integrity that can maintain heat for one cycle.
This process works best for heat treating parts that need to be introduced to gaseous H2O during the cycle time.
As you can clearly see below, the pumpkin can serve as a "furnace" for special parts.
  • Dimensions: 11.5" outer diameter x 11" total height; heating chamber is 10.75" diameter x 10.25" height; wall thickness is 3/4"
  • Temperature: range from 0-450 degrees Fahrenheit lasting 1 cycle (max)
  • Materials: organic matter derived from Cucurbita pepo
Cycle times may vary depending on the size and quality of vessel. For the example used in this article, the cycle ranged from roughly 0.75-1.25 hours. Controls are not included.
Find more pumpkin furnaces from this Texas supplier.
Find more traditional atmosphere furnaces here.
Pumpkins as Heat Treated Parts
Pumpkins don’t just make great furnaces, they are also parts to be heat treated. If it's slow on the shop floor this Fall, just take a lousy pumpkin from your doorstep and get to work!
While a pumpkin does have more prep involved, word has it this “part” is edible, too. Follow these steps when these parts come to your shop:
  1. Be sure that the coating used for the part is of highest quality. Cinnamon, allspice, and a hint of salt with olive oil have the right chemical composition for this part.
  2. When applying the coating, it is imperative to evenly distribute it across all parts in order to achieve consistent, predictable results.
  3. I'll leave the heat treating to you, but I recommend an open flame furnace for these parts. In this instance, discoloration is to be expected, but this is typically what customers want to see. Bonus: No quenching or cleaning required.
  4. Transfer parts to a cooling location.
For best results, heat treat parts in small batches.
Videos in this feature:
Cooking Inside A Pumpkin!
Grilled Pumpkin Recipe For Halloween
Continuous atmosphere protection sintering heat treatment furnace
Heat Treating with Pumpkins? Read More »
Heat Treat Radio #65: The Future of Heat Treat, a Conversation with Piotr Zawistowski
Heat Treat Today publisher, Doug Glenn, sat down with heat treating specialist, Piotr Zawistowski, the managing director at SECO/VACUUM, to hear what he believes the future of heat treat holds. Karen Gantzer and Bethany Leone from Heat Treat Today also joined the conversation, recorded at the ASM Heat Treat Show 2021. In this episode, you’ll learn why Piotr believes LPC, automation, and predictive maintenance are the future of heat treat and  how to get there.
Bethany Leone (BL): Peter first shared how SECO/WARWICK was on a mission to actualize the future of heat treat.
Piotr Zawistowski (PZ):  I think we are on a mission, that is, SECO/WARWICK and I.  I think the future of heat treatment will be LPC for carburizing, and gas quenching for quenching instead of oil.  I think the future is LPC and hydrogen quenching, to be honest.  Right now, most of carburizing is done in a carburizing atmosphere, and most of the quenching, as I know it.  I think that everything is moving in the vacuum direction, if you will, but we're not there yet.  So, that's our mission, in general.
Members of Heat Treat Today sat down with Piotr Zawistowski, managing director of SECO/VACUUM, at the ASM Heat Treat Show 2021.
I think I showed you a graph with what is the difference in quenching between oil and gas.  Right now, with 25 bar quenching, we are on the level of slow oil.  To get there, we have to use helium, but it's expensive, it's not economical.  We can go to hydrogen, which is the speed of oil and it's everywhere, it's cheap.  I think this is the future.
BL: This idea that the future of heat treat will be LPC and gas quenching – specifically with hydrogen – means moving in the vacuum direction, as Peter noted. But how fast will this transition come, especially given safety concerns with the use of hydrogen as a quenchant?
PZ: Exactly, that is the concern right now.  I think it will come, but we are far away from it.  Anyway, we don't have to go to hydrogen immediately, but I think we should go to nitrogen for now.  We have some solutions for that, and on top of that, I think we will go from regular carburizing to LPC.  It's not easy for people to switch, so our mission is for us to try to convince people to switch to LPC.  We would like to make it as easy as possible for them so that's why—maybe 20 years ago—we thought about starting.  Because we had quenching and carburizing, we thought, let's maybe leave quenching the same and start with carburizing.  So, we developed vacuum oil quench furnaces just to make it easier so they only have to change one thing at a time.  But then, we thought, it's a leap for them anyway because those are different oils and it's a vacuum oil.  So, right now, we're introducing a furnace with vacuum carburizing with the regular atmosphere is a quenching chamber in regular oils that all the heat treaters have known for years.
DG:  This is the SuperIQ?
PZ:  This is the SuperIQ.  I don't want to make it commercial, but this is another step.  If you look at our wall here, we have six different products and five of them are for carburizing.  It starts with Vector.  It can have carburizing but it doesn't have to be, but anyway, they all are connected with carburizing.  I think the mission is to convince people and to switch, in the industry, from all the messy dangerous, open-fire furnaces to new, clean, better technology.
Piotr sharing SECO/WARWICK vision for the future of heat treating.
BL: As we just heard, these are big transitions. So, if the first step towards heat treat with LPC is for heat treaters to use atmosphere carburizing with oil quench, what are the next steps to move to a fully vacuum-based future?
PZ:  Step number two is vacuum oil quench and step number three is vacuum carburizing or LPC and high pressure gas quench.  That is the future, in my opinion, and with hydrogen.
BL: As a review, moving to LPC could look like, first, using a traditional vacuum furnace with atmosphere capabilities, then, heat treating with vacuum oil quench, and finally, heat treating with LPC and high pressure gas quench. If such a transition is appealing, it would be good know what the productivity improvements of LPC are. . .
PZ:  So, it depends; there are a couple factors.  First, we have to take into account what kind of a case that we're talking about.  But, in general, I can tell you that the productivity increase should be 50%, or even 100%, or more.
DG:  You can double the amount of product through in the same amount of time?
Piotr walks through challenges to overcome to achieve an LPC and hydrogen heat treat future.
PZ:  Yes.  And, it's just as simple with increasing the temperature, so we are not limited with low pressure carburizing with the temperature, whereas there is a limit that atmosphere carburizing can be done. So, we have a lot of possibilities here.
BL: So, a 50-100% increase in productivity and an increased temperature range comes along with low pressure carburizing, LPC. When considering LPC, there is the question of how traditional specification, which clearly state the necessity of atmosphere carburizing, can be compatible with this newer technology.
PZ:  Yes, and those specs are changing.
DG:  Is that going to be a hindrance?
PZ:  Yes, it is right now, especially in aerospace.  The automotive industry, they moved already to LPC, but aerospace we are trying to help to change those specs, and they are changing as we speak.  A lot of those specs are still from the '80s, and there was no LPC back then.  As you know, in aerospace, it is not easy to change a spec, but this is happening right now, as we speak.
DG:  Are you guys involved with changes from Nadcap and all?
PZ:  Yes, and we are involved in major aerospace players.  We are doing tests for them and we are delivering them LPC furnaces.  Some of them are still doing R&D, but this is a first step.  With some of them, we are starting to see real production with LPC in aerospace, so we are getting there.
BL: To be sure, integrating the technical creation of specs by bringing heat treaters in touch with key end-users in the industry is necessary to have standards reflect effective heat treating techniques. Aside from standards, is there any resistance to adopting low pressure carburizing?
PZ:  I think, people are afraid of what is new: atmospheric carburizing is very simple and it is well known, vacuum carburizing is something different.  So, for atmosphere carburizing, it's only to control the potential in the furnace and time of carburizing.  In vacuum carburizing, it's not that easy- you have to have a special simulator to create a recipe.  People are afraid of it, but they shouldn't be because there is software.  We have software that can make that recipe really easy and pretty quick.  People are just afraid of something new.
SECO/WARWICK's SimVac
We have it [simulator] to create a recipe for LPC for the purpose of carburizing and we actually provide it.  This is our own simulator and we provide it with the equipment so it's very, very easy.
BL: In addition to an aversion to the new and the changes that may be involved, folks have a real concern with distortion. Peter then addressed this concern. . .
PZ:  High pressure gas quenching, in general, is better, but there are other methods.  It is not only us, but we are all trying to limit the distortions; we cannot say “eliminate” because that is impossible, but we can try to limit the distortion and control the distortions.  What we introduced to the market is our 4D quench technology, “fourth” dimension is that we rotate the part during quenching.
BL: While there is resistance that may be from outdated industry specs, a suspicion of the new, or technical concerns which the industry is continually addressing, Peter was sure note that there are, in fact, drivers that are encouraging heat treaters to move towards LPC.
PZ:  I think, the driver is both productivity and safety.  As an example, the [US] Biden administration just committed to reduce CO2 emission by 50% by the end of the decade.  This is good technology and there is a lot of fuel to emission out of atmosphere carburizing, internal and external.  But, there will be a push for climate change and CO2 emission.  I think, it's not only mandates, but, I think, in Europe, for example, they have a lot of grant; there is a lot of government money you can get if you are reducing the CO2 emission.  I think, for the heat treaters, it should be easy to capitalize on it.  As I said, no CO2 emission on LPC.  There is no emission at all.  That is the beauty of the technology.
Kanthal notes the electric shift that is predominantly occurring in Europe
Find this article in the August 2021 digital edition
BL: Certainly, financial incentives to adopt “greener” technologies as well as personal desire to do so would be motivating. Is there anything about the heat treated parts cosmetically that would make LPC attractive?
PZ:  Of course.  And, you don't have to wash it after, which is great.  It depends, as we still can have LPC and oil quench, you have to wash it, but if you can get to the gas quench, you've eliminated the wash part.  They just look nice and shiny and bright.  The color is better and you can eliminate washing.
BL: It is clear that LPC, one of the factors that plays into the future of heat treat as Peter envisions, has challenges and benefits for heat treaters to consider. Peter then talked about two additional factors for the future of heat treat: automation and predictive maintenance.
PZ:  There are two other factors.  One is automation, which is something big and it's more and more especially nowadays with the labor issue.  But, it is to eliminate the human error part of it.  On top of that, it is the traceability of the parts.  More and more customers would like no operators and the machine has to run by itself.  We have that—a full system of equipment.  You just place the basket with parts, or several baskets, and then the robot takes it to the furnace, carburizes, quenches, tempers, washes and then it comes out, completely untouched.  Robots are the automated loader. That is the direction.
Another is predictive maintenance, which is a big deal right now.  By predictive maintenance, I mean that the system has to predict the failures or the downtimes.  A lot of systems, which are available on the market are called “predictive maintenance”, but they are reactive.  For example, they have sensors on the machine and if something breaks, it sends you an email message, or whatever.  Our SECO/PREDICTIVE, which is our predictive maintenance, is based on an algorithm.  The algorithm is written in such a way that the system learns on failures and the more equipment we have connected to it, the more data we have, like everything we have around us right now, all the Googles and Amazons and so on.  I think this is the future, as well.  So, everything has to be connected to one database to predict what will happen before it happens.
DG:  Can you give me an example?  Let's say you've got a high temperature fan inside a vacuum furnace.  How would the SECO/PREDICTIVE or predictive maintenance work on that?
PZ:  I think we would control the vibration on it.  I think that's one way to do it.  And, at a certain level, it would send a signal – "Watch out! - you are about to have a problem".  It is better to do it that way because, then, there is time to order a replacement or schedule something so it will not break.  But, the goal is to predict the failure before it happens.
BL: With thoughts of LPC, automation, and predictive maintenance on our minds, we then walked over to a display of various furnaces to see how SECO/VACUUM applied these insights to their own furnaces. Peter began with the Vector, a versatile high pressure gas quench furnace.
PZ:  This is a single chamber, multipurpose furnace.  It is for LPC carburizing and high pressure gas quenching.  This is the main furnace and, I think, 70% of what we sell. Maybe this is, like 50%.
Then 20% are the vacuum oil quench furnaces.  The vacuum oil quench furnaces heat processing chambers are the same as the Vector but then we can quench it in oil or we can have three chambers that can be continuous production or you can have oil quench on one side and high pressure gas quench on the other side.  We call it CaseMaster Evolution.  This is our middle step.  As I said, our goal is to go for LPC.
But, then, there is another one, the new baby in the family. [Peter then gestures to, what they call, the Super IQ vacuum furnace.]
For people, it was not easy to make a switch, so this is like a hybrid.  The processing chamber is vacuum carburizing but the quenching chamber is like a traditional atmosphere quench.  It is like a pure replacement: you can take one out and put this guy in.  You have all the benefits from low pressure carburizing but you operate mainly like an old and traditional furnace.  This is to make it easier in the transition.
BL: After learning how certain furnace designs can be helpful to heat treaters who have different processing needs or who are trying to convert to LPC, we then moved to see how LPC is being brought to pit-furnace size loads.
PZ:  This is another one, another tool in our mission, I would say.  This is a pit carburizing furnace but with LPC.  Right now, for big, heavy parts, they are carburizing atmosphere in pit furnaces and then they open the furnace and they just transfer it with a crane to an oil tank.  This is basically the same, but the pit furnace is with LPC.  There is nothing like this on the market right now.
We are trying to bring the LPC advantages to big parts and pit-style carburizers, as well.
BL: From LPC for large loads, we ended our tour with an LPC furnace with an interesting way to maintain traceability.​
PZ:  This is a single-piece carburizing furnace which we talked about.
So “CaseMaster”, which was the name of our traditional integral quench carburizing furnace in the past, we no longer do. Right now, if we have an RFQ for atmosphere carburizer, we go with LPC.
Thank yous from the group.
Publisher
Heat Treat Radio #65: The Future of Heat Treat, a Conversation with Piotr Zawistowski Read More »
Upton Industries Acquired by Kolene Corporation
HTD Size-PR LogoHeat treat solution manufacturer in Roseville, MI has been acquired by Kolene Corporation, a global leader of custom-designed and engineered molten salt bath equipment and specialty chemical formulations.
Upton Industries, Inc.
"We are proud to carry on Upton's strong brand and legacy as a part of Kolene Corporation as we move forward," commented Roger L. Shoemaker, chairman & CEO of the company.
Founded in 1937, Upton Industries, Inc. design and manufacture thermal processing systems in the metal heat treating industry. They apply their Engineered Thermal Solutions methodology to heat treat equipment including box type, car bottom, lift-off and specialty furnaces that utilize either electric heating or gas-fired systems.
Kolene will maintain both its Detroit headquarters location and the Upton Roseville location, which will be home to all Kolene’s manufacturing and fabrication. Bringing the two companies together will give the new company 50,000 sq. ft. of manufacturing, fabrication, and commercial processing capabilities.
W. Scott Schilling
Kolene Corporation
"After thoroughly evaluating Upton’s capabilities," said W. Scott Schilling, president of Kolene, "it was apparent that there are tremendous synergies between the two companies. Capitalizing on these synergies will allow [the company] to expand into applications and revenue segments where we have not historically been. [We] will also have the ability to become more vertically integrated due to Upton’s manufacturing and fabrications capabilities, which will allow us to strengthen our overall margins."
In its 82nd year, Detroit-based Kolene Corporation provides custom-designed and engineered equipment, specialized chemical formulations, and processes for cleaning and conditioning metal surfaces. Currently, their products are used worldwide for casting cleaning, alloy descaling, coatings removal, engine rebuild and other demanding automotive, industrial, and military applications.
Upton Industries Acquired by Kolene Corporation Read More »
Improving High-Temp Testing of Composites
OCDesigning ultra-efficient aircraft, lightweight automobiles, and modern power generation systems requires new materials with higher strength-to-weight ratios that can withstand higher operating temperatures for longer periods of time. These lighter weight, heat-tolerant materials help increase fuel efficiency and save energy, but characterizing these materials poses several challenges.
In this Technical Tuesday article, Dr. Erik Schwarzkopf, staff scientist at MTS Systems, will help you discover solutions to these challenges that will improve high-temperature testing of composites. This is the special focus article that appears in the Heat Treat Today November 2021 Vacuum Heat Treat Systems print edition. Return to our digital editions archive on Monday November 15, 2021 to access the entire print edition online!
Staff Scientist at MTS Systems
Testing at high temperatures can be complicated because “elevated temperature” means different things to different researchers. In general, there are three distinct temperature ranges for materials that have the highest strength-to-weight ratios. The first is for polymer matrix composites, or PMCs, from 392°F to 932°F (200°C to 500°C). The second is for metals, from 1472°F to 1832°F (800°C to 1000°C). The third is for ceramic matrix composites, or CMCs, which are tested up to 2732°F (1500°C). In each range, there are tradeoffs that test engineers need to consider in order to measure material properties at elevated temperatures and acquire high-quality results.
Problems arise when dealing with objects that need to touch the specimen or be near the specimen, such as grips, extensometers, furnaces, and chambers. The problems tend to be systemic, so solving an issue with one component tends to raise issues with another component.
In many cases, these issues start with specimen geometry. For example, PMC and CMC specimens are flat, and they cannot be grabbed in the same way as a round, threaded, or button-head metallic specimen. For gripping PMCs, cost-effective and easy-to-use hydraulic wedge grips are a good choice. Hydraulic wedges can apply consistent pressure to protect the fragile PMC specimen fibers from crushing and are able to maintain the correct pressure even as the chamber and wedge head heat up. These grips are relatively large, so they are often paired with a larger environmental chamber. The environmental chamber is typically larger than the furnaces required for higher temperature tests, but the thermal mass of the grips and chamber leads to very stable temperatures.
However, the larger chamber makes it difficult to use contacting extensometers, which test engineers would normally use in these applications. With a smaller chamber, you can situate the sensing technology outside the chamber and allow it to translate motion from the contact arm; but with a larger chamber, you cannot effectively translate that motion outside the chamber because the arm gets too long. The extensometer needs to be inside the chamber — but the elevated temperature damages the sensitive electronics.
"One of the best ways to increase high-temperature testing success is to work with a solution provider who understands the entire test."
One way to solve this issue with contacting extensometers is to use video extensometry and digital image correlation. These non-contacting strain measurement devices can be located outside the chamber, away from the heat that would damage other extensometers. A chamber with a window will let you look inside and measure motion in real-time. But this solution is not without its complications, either. You need a light inside the chamber to illuminate the specimen for the camera, and at some temperatures, the specimen’s illumination (or blackbody radiation) reduces the contrast and accuracy of video extensometry. You can mitigate these problems by using blue LEDs to illuminate the chamber and optical filtering to minimize blackbody effects and enhance contrast.
PMCs and CMCs are typically engineered as flat structural components, but given the gripping challenges presented by flat specimens, some people have wondered why we cannot just use round specimens instead. Even with metals, it is often not possible to obtain a large enough portion of the material to make a round specimen, especially if the goal is to test material that has been in service. Sometimes, a small specimen is extracted from a larger component — specifically, turbine blades from jet engines. The blades that see the hottest application temperatures are grown from single crystal seeds with cooling holes to let air through. These intricately shaped blades do not have enough bulk to create a round specimen. Also, when the interdendritic spacing of a single crystal is similar to the specimen dimensions, the specimen might act quite differently than a bulk, round specimen.
Gripping specimens in high-temperature applications remains a challenge. A test engineer would normally use high-temperature grips for most high-temperature applications. But the CMC testing temperature range exceeds 1832°F (1000°C) and these grips would start to lose strength. Ideally, the grip should be as hot as possible to minimize the gradient, just not so hot that the grip itself starts to get soft. If a specimen is long enough, cold grips could be used. But some specimens cannot be made long enough, for the same reasons they cannot be made round. Even if cold grips are used, larger gradients are then introduced, which means more tests need to be run due to the variations in those gradients, and that adds expense.
To address these challenges in the highest temperature ranges, look for a grip that can be actively cooled in two different ways, depending on what temperature range is required. These versatile grips can be placed in an area of the furnace that is relatively less hot than the center zone. If the center zone is 2192°F (1200°C), the top and bottom portions are closer to 1832°F (1000°C). With active cooling, the grip can stay in the cooler part of the chamber and still hold the specimen in place with an acceptable gradient. For testing metals up to 1832°F (1000°C), you can use a grip that is moderately cooled. For testing CMCs up to 2732°F (1500°C), look for a grip that is aggressively cooled.
One of the best ways to increase high-temperature testing success is to work with a solution provider who understands the entire test. Many labs attempt to build high-temperature testing solutions by assembling components from different providers. Unfortunately, the interdependencies and tradeoff s are too entangled. The extensometry expert may not understand how to make their offering work through a window or inside of a chamber. Grip experts may be able to make cold grips work, but the gradient is so large that it calls the test results into question. Find a provider that can offer the systems integration expertise you need to reduce testing variability, allowing you to run fewer tests and get accurate results.
About the Author: With more than 30 years of experience in materials testing, metallurgy, and system engineering, MTS Systems staff scientist Dr. Erik Schwarzkopf frequently shares his testing expertise in technical articles and conference presentations.
For more information: Contact Dr. Schwarzkopf at erik.schwarzkopf@mts.com
Improving High-Temp Testing of Composites Read More »
Heat Treat Grab Bag of 10 Tips to Keep Your Costs Down
OCWant a free tip? Check out this read of some of the top 101 Heat Treat Tips that heat treating professionals submitted over the last three years. These handy technical words of wisdom will keep your furnaces in optimum operation and keep you in compliance. If you want more, search for “101 heat treat tips” on the website! This grab bag of 10 tips focuses on how to keep your heat treating costs down, either by maintenance strategies or product and process decisions.
By the way, Heat Treat Today introduced Heat Treat Resources this year; this is a feature you can use when you’re at the plant or on the road. Check out the digital edition of the September Tradeshow magazine to check it out yourself!
(Super Systems, Inc.)
New Diffusion Pump Technology Increases Production Output
Gain immediate positive net cash flow with a lease to own finance option by upgrading your diffusion pumps with the new immersion heater technology. The new style heater will extend oil life and reduce energy consumption. New heater technology can increase production by eliminating the need of dropping your pump every time you change oil for faster maintenance turn around. Drop in place pump design with improved performance.
(Leybold Vacuum USA)
(Grammer Vacuum Technologies)
How Much Lost Money Flows Through the Walls of Your Furnace
In a strict sense, heat flows through the insulating lining of your furnace wall: the lower the outside temperature in the furnace shell, the less heat is lost and, consequently, less money.
For example, an outside temperature on the oven shell of 160°F (71°C) equals a heat loss of approximately 190 BTU/hr ft2, just multiply this number by the square footage of the entire outside surface of the oven. A well-designed and well-maintained insulation can reduce the outside temperature of the shell, say 120°F (49°C), and heat losses would be close to 100 BTU/hr ft2, that’s 90% more heat lost and therefore fuel.
So, my Tip for today is: “Let’s go for the basics that don’t change, and it will always give good results.” By the way, how many furnaces are there in your plant and how many square feet do their surfaces add up to?
(Carrasco Hornos)
There are 2 things in life you should never go cheap on: Toilet paper and combustion equipment! When upgrading or looking at new systems, spend the money to do it right. Designing on the cheap will only lead to operational and maintenance headaches. And trying to reuse the ancient artifacts when upgrading just to save a buck will cost you 10x that down the road. You don’t have to break your budget to do a quality job!
(Bloom Engineering Co., Inc.)
(Combustion Innovations)
  1. It can cost you money: Operating with more air than needed will reduce your furnaces efficiency and require you to burn more fuel. Conversely, operating air deficient, unless necessary for the process, results in unburned fuel being released with the exhaust gasses. In most cases the unburned fuel going up your stack is energy that you paid for.
  2. It can decrease product quality and yield:  For many ferrous metals too much excess air will result in excess scale formation at high processing temperatures. On the contrary other materials such as titanium need to be processed with excess air to prevent Hydrogen pickup.
  3.  It can reduce your furnace’s reliability:  The burners on your direct fired furnace will have a defined range of acceptable air to fuel ratios for proper operation. If your system wanders outside of this range, which can be fairly tight with today’s ultra-low NOx burners, you could start to see flame failures that result in unplanned shutdowns.
  4. It can be a safety hazard: Apart from the possibility of causing burner instability, running with too little air will increase CO emissions. Unless your furnace is designed to safety exhaust CO you could end up exposing personnel working near your furnace to this deadly gas.
Inspection Mistakes That Cost
  • A certified Rc 54.3 +/- 1 test block was tested three times and the average of the readings was Rc 54 utilizing a flat anvil.  Water was put on the anvil under the test block and the next three readings averaged Rc 52.1.
  • Why is it so important that samples are clean, dry, and properly prepared?
  • If your process test samples are actually one point above the high spec limit but you are reading two points lower, you will ship hard parts that your customer can reject.
  • If your process test samples are one point above the low spec limit but you are reading two points lower, you may reprocess parts that are actually within specification.
  • It is imperative that your personnel are trained in proper sample preparation and hardness testing procedures to maximize your quality results and minimize reprocessing.
(Debbie Aliya)
The Right Furnace Atmospheres Will Pay Dividends
Save money on your furnace atmospheres by employing the driest and leanest furnace atmosphere blends possible. Furnace atmospheres are a compromise between keeping it simple and supplying exactly the atmosphere to meet the unique requirements of each material processed. Organizations have different priorities when it comes to atmospheres—heat treat specialists may want to be able to run as many different materials as possible using a limited array of atmosphere types, while captive heat treating operations often want exactly the atmosphere approach to maximize the benefits for their specific processes/products.
The dewpoint (water content) of the atmosphere in the furnace is a key factor in its performance. At high temperatures, water in the atmosphere can break down, releasing oxygen that can cause oxidation. You must maintain a high degree of reducing potential to achieve the surface finish and processing results desired. If the furnace atmosphere gas is wet, you’ll need a gas blend richer with hydrogen than you would if your atmosphere blend had a lower dewpoint (less water vapor content). Since hydrogen costs 10 times more than nitrogen, it is more economical to run a leaner atmosphere than a richer atmosphere. By running the driest atmosphere blend possible, you may find that you can lean down your atmosphere (consistent with the metallurgical needs of your product/process) by reducing the proportion of hydrogen and increasing the nitrogen. In doing so, you may recognize meaningful savings.
Check your furnace atmosphere raw materials and process and obtain the driest atmosphere possible. Control your atmosphere dewpoint by adding humidity as needed to the driest starting blend possible rather than accepting a wet atmosphere and trying to process your parts. You’ll achieve the best compromise of excellent results at the lowest cost.
(Nel Hydrogen)
Heat Treat Grab Bag of 10 Tips to Keep Your Costs Down Read More »
Fringe Friday: Manufacturing for the Future
Source: IndustryWeek
Sometimes our editors find items that are not exactly "heat treat" but do deal with interesting developments in one of our key markets: aerospace, automotive, medical, energy, or general manufacturing. To celebrate getting to the "fringe" of the weekend, Heat Treat Today presents today’s Heat Treat Fringe Friday best of the web article evaluating how your jobs may look a little different as general manufacturing adopts Industry 4.0 trends.
A question this article asks -- and you should, too -- is "What talent and skills do manufacturers need in order to succeed in the factory of the future?" With interconnected digital and physical developments through internet technology, heat treaters may fear that a "robot" will replace them. Armed with this article, you'll be able to identify what skills are needed for the future of five manufacturing roles: production planner, industrial engineer, operator, line leader, and quality engineer.
[blockquote author="" style="1"]The smart factory of the future will perfectly blend human capabilities with technology. Manufacturers can get ahead now by understanding how critical manufacturing roles will evolve and how to hire, train and upskill for these roles. Getting it right in talent development will ultimately separate the leaders from the laggards.[/blockquote]
Read more at "5 Manufacturing Roles that Will Soon Look Very Different"
"State of Industry 4.0 in the North American Heat Treat Market"
If you are interested in how the heat treating industry is affected by artificial intelligence (AI), the industrial internet of things (IIoT), and other subjects related to Industry 4.0, check out this article. Here's an excerpt:
"According to Aymeric Goldsteinas, project development manager at Ipsen, customers are becoming more willing to implement Ipsen’s Industry 4.0 endeavors, even cloud-based solutions, a willingness that was not present just one decade ago. So how is the heat treat market responding? We asked suppliers how they implemented Industry 4.0. . ."
Fringe Friday: Manufacturing for the Future Read More »
Encouraging Careers in Heat Treat
OCA new resource created and run by the Metal Treating Institute (MTI) offers tools to those seeking a career in the heat treat industry. Review some of these insightful videos, resources for young professionals, and a network to further your heat treating capabilities below!
There’s a new kid on the block trying to get young people to join the heat treat “club”. A product of the Metal Treating Institute (MTI), this new website called HeatTreatCareers.com features site tours, first-hand testimonials, and orientation videos for anyone seeking to understand the world of heat treat. These handy videos and brief articles also include resources for heat treaters who are looking to outsource some of their processes or for equipment solutions as they update and expand their offerings.
Calling All Young Industry Professionals
If you know someone who is new to heat treat – maybe a potential hire, a new hire, or a colleague who is looking into joining the field – they must check out this website. For young professionals, this website provides specific direction, explains what heat treating is, and how to pursue a career in it.
Three resources that HeatTreatCareers.com offers are:
  1. “What is Heat Treating?” video (see below)
  2. Searchable directory for heat treaters in your state (or by name)
  3. MTI YES Management Training Program
There are more training opportunities available here to increase professional management and/or technical knowledge pertinent for the heat treating industry.
But perhaps the most import aspect of this website is we get to hear from real heat treaters how this industry is more than a job. Be it the relationships or the day-to-day challenges that inspire creative thinking, it can be hard to locate one specific reason why anyone would enter our obscure industry. The video below makes a great case for this.
More Resources to Increase Heat Treat Capacity
For the young-at-heart and those who are ALWAYS looking to try something new, there are several resources for you, too. The first is a RFP form that allows you to propose a wild heat treat project to a network of commercial heat treaters to help you complete the project. This feature is part of the CallMTI.com resource, which connects you with MTI members from 40 states and eight countries, who are open for consultation.
Another resource is the “Why Outsource” tab that you can navigate to after clicking the Featured Plant Tours page. This resource helps you identify which heat treating challenges you’d prefer to overcome via outsourcing. Those challenges could include:
  • finding qualified good-workers
  • meeting OSHA safety requirements
  • funding needed equipment
  • continuing on-going maintenance
Of course, feel free to use that career finder that we mentioned above. Who doesn’t like a new challenge?
Bottom line: The website has something to offer everyone, especially if you are looking for a change or a challenge. And, by the way, who can visit the site and leave feeling unimpressed. . .?
Head over to www.heattreatcareers.com to find out more for yourself?
Encouraging Careers in Heat Treat Read More »
Automotive Heat Treater To Receive Vacuum Aluminum Brazing Furnace
HTD Size-PR LogoA manufacturer in the automotive industry has placed an order for a large-capacity, high vacuum furnace, equipped with a cooling station to increase the performance of the system. This furnace will complete their new production plant and aid in vacuum aluminum brazing various components.
Maciej Korecki
Vice President, Business Segment Vacuum Heat Treatment Furnaces
SECO/WARWICK
(source: SECO/WARWICK)
SECO/WARWICK, the sister company of North American manufacturer SECO/VACUUM, provided the furnace to the automotive manufacturer of engines, filters, electric equipment, and cooling systems. For this project, the client required that the vacuum furnace have automatic loading and transportation of parts, as well as an increase in precise control of temperature uniformity and distribution.
"The equipment [. . .] has been installed in a new production plant that will significantly improve the capacity of the entire group," explains Maciej Korecki, vice president of the Business Segment of Vacuum Heat Treatment Furnaces at SECO/WARWICK. "A key to success in this project was the huge trust displayed by our partner and close cooperation at the design stage."
heat treat buyers guideLooking for vacuum aluminum brazing furnaces? See listings for services and products in the Heat Treat Buyers Guide
Automotive Heat Treater To Receive Vacuum Aluminum Brazing Furnace Read More »
Message from the Editor: Inspiring Young People in Heat Treat
OCYoung people today get a bad rap. Karen Gantzer, managing editor at Heat Treat Today, disagrees! The leadership, initiative, and problem-solving skills of the 40 Under 40 Class of 2021 are truly inspiring. In the heat treat industry, it appears youth isn't such a bad thing after all. In this article, read what Karen has to say about some of the young people on the team at Heat Treat Today.
This article was originally published in Heat Treat Today's August 2021 Automotive print edition.
Karen Gantzer
Managing Editor
I find it very inspiring to work with young people in this industry. Contrary to what is sometimes heard in the world at large, many of the young people I’ve had the privilege of working with in the North American heat treat market are intelligent, conscientious, respectful, hard-working adults worth their weight in gold. They’re a real pleasure to be around. As this column is being typed, Heat Treat Today is working on selecting 40 young leaders in the North American heat treat market to be inducted into the 40 Under 40 Class of 2021, a great honor for each person, and a great honor for the 120 previous inductees, the 40 Under 40 Classes of 2018, 2019, and 2020. It’s amazing how difficult it is to pick 40 each year from those nominated. Nearly all of them are more than qualified, but only 40 can be selected. The judges invariably struggle each year. That is a GREAT problem to have, and it speaks to the quality of the young people in this industry. Although these young people will probably never make it into one of the 40 Under 40 classes, I would like to mention several under-40 individuals who contribute substantially to the North American heat treat market each and every day – the young people of Heat Treat Today – all of whom are less than 40 years old and all of whom are simply stellar people.
Bethany Funk-Leone is the Heat Treat Daily editor as well as the Heat Treat Radio editor and resident idea person along with Doug. We sometimes have to pivot at the last minute and Bethany flexes with grace, determination, and wit, as she juggles multiple responsibilities and stays ahead of the game.
Brandon Glenn is our art and web design expert. When we need a logo or image, a tweak on the website, or a last-minute edit on the Heat Treat Daily, Brandon is our man; and he always comes through with precision, kindness and often a comment that makes us laugh.
Ellen Glenn-Porter wears several hats—billing/accounting/audience development—and makes sure that important admin is completed on time. She faithfully connects with you in the industry and is always diligent to make sure the rest of the team is aware of needs, encouragement, or concerns that are sent to her.
Lauren Porter, Heat Treat Today production manager, is our newest team member. She has been Doug’s right hand person and done yeoman’s work in getting the print magazines, e-blasts, and other media out to you all as well as working with advertisers.
Alyssa Bootsma is our social media editor. She has taken excellent initiative on the various platforms and has grown our presence significantly. It has been exciting to see her grow and succeed in an area that had been unfamiliar to her, but one which she has embraced.
Jonathan Lloyd, Heat Treat Today's talented audio/podcast editor, ensures the excellence of Heat Treat Radio and other multimedia endeavors. His expertise and creativity in the audio and visual world is a huge asset as he helps us maintain a cutting edge.
The old-timers, Doug Glenn and I, couldn’t be happier to be working with this youthful group, who keeps us sharp and current! And, while they might never be in Heat Treat Today's 40 Under 40, they are our "Top 6" list of great people serving the North American heat treat market.
Thanks, team for the incredible work you do!
Message from the Editor: Inspiring Young People in Heat Treat Read More »
Looking to a Future with FNC or Nitriding?
OCWhat's the future of ferritic nitrocarburizing and how does it compare to other hardening processes? When it comes to metal hardening, there are many variations on central processes, including recent innovations in how to apply hardening processes.
This Technical Tuesday brings you a quick overview of how hardness technologies differ, specifically nitriding and FNC, and how certain heat treaters have developed these specific hardness technologies.
Understanding the Various Hardening Processes
If you want to know the future, the best you can do is understand the past and present. Let’s begin with looking at the most common hardening processing methods. Here are a few excerpts from “Elevate Your Knowledge: 5 Need-to-Know Case Hardening Processes” by Mike Harrison, engineering manager of Industrial Furnace Systems Division at Gasbarre Thermal Processing Systems:
Read more about these 5 processes in Mike Harrison's article. Click to read.
Carburizing: “Gas carburizing is a process where carbon is added to the material’s surface. The process is typically performed between 1550-1750°F, with carburizing times commonly between 2-8 hours [this spec is disputed, and times may run up to 24 hours]; of course, these values can vary depending on the material, process, and equipment. The most common atmosphere used for atmosphere gas carburizing is endothermic gas with additions of either natural gas or propane to increase the carbon potential of the furnace atmosphere.”
Nitriding: “Gas nitriding is a process where nitrogen is added to the material surface. The process is typically performed between 925-1050°F; cycle times can be quite long as the diffusion of the nitrogen is slow at these temperatures, with nitriding times typically ranging from 16 – 96 hours or more depending on the material and case depth required. Nitriding can be performed in either a single or two-stage process and has the potential to produce two types of case, the first being a nitrogen-rich compound layer (or “white layer”) at the surface that is extremely hard and wear-resistant but also very brittle.”
Carbonitriding: “Despite its name, carbonitriding is more closely related to carburizing than it is to nitriding. Carbonitriding is a process where both carbon and nitrogen are added to the material surface. This process is typically performed in a range of 1450-1600°F [this spec is disputed, and temperatures may go up to 1650°F] and generally produces a shallower case depth than carburizing.”
Ferritic Nitrocarburizing (FNC): “In the author’s opinion, just like with carbonitriding, ferritic nitrocarburizing (FNC) is named incorrectly as it is more closely related to nitriding than it is with carburizing. FNC is a process that is still mostly nitrogen-based but with a slight carbon addition as well. The added carbon helps promote compound layer formation, particularly in plain carbon and low alloy steels that do not contain significant nitride-forming alloys. This process is typically performed in a range of 1025-1125°F with cycle times much shorter than nitriding, typically 1-4 hours.”
Low Pressure Carburizing (LPC): “Low-pressure carburizing (LPC), or vacuum carburizing, is a variation of carburizing performed in a vacuum furnace. Instead of the atmospheres mentioned previously, a partial pressure of hydrocarbon gas (such as acetylene or propane) is used that directly dissociates at the part surface to provide carbon for diffusion. After LPC, the workload is transferred to a quench system that could use oil or high-pressure gas, typically nitrogen.”
Nitriding
Learn more about the basics of hardening at Heat Treat Radio. Click to listen,
Gas nitriding, a process over 100 years old, is a hardening process that involves diffusing nitrogen into the surface of steel to create a hard, wear-resistant case. Among many benefits, the part will have enhanced fatigue properties, anti-galling properties under load, and a resistance to softening at elevated temperature. This makes it an excellent choice for the aerospace industry.
There is some recent history regarding problems related to the “white layer”. In a typical microstructure, the “white layer” is a nitrogen-rich surface layer and the diffusion layer exists beneath it.1 It is essential that the surface layer be controlled to avoid an overly brittle part. Mark Hemsath the vice president of Sales – Americas for Nitrex Heat Treating Services, elaborated on this in a Heat Treat Radio episode:
"Doug Glenn: I assume, with all the modern day technology and whatnot, we're able to control that white layer and/or depth of nitriding layer through your process controls and things of that sort."
"Mark Hemsath: Yes. Nitriding has been around a long time, but one of the problems that they had was controlling the white layer. Because they basically would just subject it to ammonia and you kind of got what you got. Then they learned that if you diluted it, you could control it. That's with gas nitriding. Then plasma nitriding came around and plasma nitriding is a low nitriding potential process. What that means is it does not tend to want to create white layer as much. It's much easier to control when the process itself is not prone to creating a lot of white layer, unlike gas. Now, in the last 10 – 15 years, people have gotten really good at controlling ammonia concentrations. They've really learned to understand that."
Recently, SECO/WARWICK shared their nitriding technological developments in their product, ZeroFlow.
"ZeroFlow nitriding is ammonia-based gas nitriding," commented Dr. Maciej Korecki, PhD Eng., vice president of the Vacuum Furnace Segment at SECO/WARWICK Group. "It is distinguished by the fact that the nitrogen potential is controlled by introducing the right portion of ammonia at the right time and only ammonia, instead of a continuous flow of a mixture of ammonia and diluent gas."
"Consequently, the ZeroFlow method uses the minimum amount of ammonia needed to achieve the required nitrogen potential and replenish the nitrogen in the atmosphere, taking into account the situation where no ammonia is supplied to the furnace at all, no flow, hence the suggestive name of the solution," he continued. "Using ammonia alone in the nitriding process, we are dealing with a stoichiometric reaction (as opposed to some traditional methods), that is, one that is uniquely defined and predictable based on the monitoring of a single component of the atmosphere. Therefore, the ZeroFlow process controls very precisely through the analyzer only one gas, obtaining an improvement in the quality and repeatability of the results compared to various traditional methods."
According to Dr. Korecki, the process is about going back to the basics of nitriding: "The inventor of the method is Prof. Leszek Maldzinski of the Poznan University of Technology, who developed the theoretical basis and confirmed it with research. Then, more than 10 years ago, a partnership between SECO/WARWICK and the Poznan University of Technology initiated a project to develop and build the first industrial furnace designed to perform the ZeroFlow nitriding processes. The furnace was launched at SECO/WARWICK's research and development department (SECO/LAB®), where the method has been implemented and validated on dozens of industrial-scale processes."
This nitrogen-based process can produce a deeper compound layer than nitriding, which is great for industrial machinery applications where this deep layer is needed for increased wear resistance and the critical strengthening of a deep case depth is not essential.
FNC has gone through a technical evolution with different heat treaters in the industry developing their own unique applications with method in mind. We'll look at two recent examples: AHT's Super Ultra Ox and Bodycote's Corr-I-Dur.
Edward Rolinski
Senior Scientist
Advanced Heat Treat, Corp.
(Source: https://www.ahtcorp.com/)
According to experts at Advanced Heat Treat Corp. (AHT), Edward Rolinski (Dr. "Glow"), Jeff Machcinski, Vasko Popovski and Mikel Woods, "Thermochemical surface engineering of ferrous alloys has become a very important part of manufacturing. Specifically, nitriding and nitrocarburizing (FNC) processes are used since their low temperature allows for treatment of finished components. They are applied to enhance the tribological and corrosion properties of component surfaces.2 In many situations, nitriding replaces carburizing even if the nitrided layer is not as thick.3 A post-oxidizing step, applied at the end of FNC, leads to significant enhancement of corrosion properties by formation of a magnetite layer (Fe3O4).
"AHT’s newly developed process, UltraOx® Hyper, results in superior wear and corrosion resistance and allows for good control of the parts’ blackness. The latter is very important when the treatment is used for firearms. While the parts’ corrosion resistance improves with nitriding alone, the additional steps in UltraOx® Hyper significantly extend corrosion resistance. AHT is committed to achieving its customers’ desired metallurgical and cosmetic results through R&D and investing in state-of-the-art equipment. These innovations allow for flexibility in these areas."
In recent news, wave energy pioneer CorPower Ocean will be using Bodycote's thermochemical treatment, Corr-I-Dur®, for CorPower’s high-efficiency WECs.
Image Source: www.waterpowermagazine.com
From Bodycote, they say that their proprietary Bodycote thermochemical treatment “Corr-I-Dur® is a combination of various low temperature thermochemical process steps, mainly gaseous nitrocarburising and oxidising.”
They explain, "In the process, a boundary layer consisting of three zones is produced. The diffusion layer forms the transition to the substrate and consists of interstitially dissolved nitrogen and nitride precipitations which increase the hardness and the fatigue strength of the component. Towards the surface it is followed by the compound layer, a carbonitride mainly of the hexagonal epsilon phase. The Fe3O4 iron oxide (magnetite) in the outer zone takes the effect of a passive layer comparable to the chromium-oxides on corrosion resistant steels.
"Due to the less metallic character of oxide and compound layer and the high hardness abrasion, adhesion and seizing wear can be distinctly reduced. Corr-I-Dur® has very little effect on distortion and dimensional changes of components compared to higher temperature case hardening processes."
How to Implement?
We’ve seen a lot of development in way of nitriding and ferritic nitrocarburizing (FNC), but for many heat treaters, you inherit specific processes and traditions of accomplishing heat treatment and do not have the chance to understand how to implement each process. Read the full 21 point comparative resource at FNC vs. Nitriding
The more informed you are, the better decisions you can make. For example, knowing these recent developments in metal treating and hardening is sure to help you decide whether to shift directions in how you company process parts for electric vehicles, or if you are ready to expand your offerings for your aerospace clients. It is clear that each of these processes have a future all-their-own. It’s up to you to decide whether that future should be yours, too.
For more information on the basics of hardness, listen to the what, why, and how of hardening with Mark Hemsath, an expert on metal hardness and vice president of Sales – Americas for Nitrex Heat Treating Services, on this Heat Treat Radio episode with Doug Glenn, publisher of Heat Treat Today. You can also review the resources below that were referenced in today’s article.
1 Daniel H. Herring, “The Heat Treat Doctor”, “Case Hardening of Steel, Part Three: Gas Nitriding,” PowerPoint Presentation, © 2004 – 2010 The HERRING GROUP, Inc.
2 “Thermochemical Surface Engineering of Steels”, Woodhead Publishing Series in Metals and Surface Engineering: Number 62, Ed. Eric J. Mittemeijer and Marcel A. J. Somers, Elsevier, 2015, pp.1-769.
3 J. Senatorski, et. al, Tribology of Nitrided and Nitrocarburized Steels”, ASM Handbook Vol 18, Friction, Lubrication and Wear Technology, ed. G. Totten ASM International, 2017, pp. 638-652.
Resources
  1. Herring, “Case Hardening of Steel, Part Three: Gas Nitriding,” PowerPoint Presentation, © 2004 – 2010 The HERRING GROUP, Inc.
  2. Harrison, “Elevate Your Knowledge: 5 Need-to-Know Case Hardening Processes,” Heat Treat Today, https://www.heattreattoday.com/processes/hardening/hardening-technical-content/comparative-study-of-5-case-hardening-processes/.
  3. Hemsath and D. Glenn, “Heat Treat Radio: Metal Hardening 101, Part 2 of 3,” Podcast and Transcript, Heat Treat Today, https://www.heattreattoday.com/media-category/heat-treat-radio/heat-treat-radio-metal-hardening-101-with-mark-hemsath-part-2-of-3/.
  4. Orosz, T. Wingens, and D. Herring, “Nitriding vs. FNC,” Heat Treat Today, https://www.heattreattoday.com/processes/nitrocarburizing/nitrocarburizing-technical-content/integrated-nitriding-and-fnc/.
  5. Senatorski, J. Tacikowski, E. Rolinski and S. Lampman, “Tribology of Nitrided and Nitrocarburized Steels”, ASM Handbook Vol 18, Friction, Lubrication and Wear Technology, ed. G. Totten ASM International, 2017.
  6. “Thermochemical Surface Engineering of Steels”, Woodhead Publishing Series in Metals and Surface Engineering: Number 62, Ed. Eric J. Mittemeijer and Marcel A. J. Somers, Elsevier, 2015, pp.1-769.
Looking to a Future with FNC or Nitriding? Read More »
