FEATURED NEWS
Manufacturing Plant Adds In-House Nitriding for Power Generation Parts
HTD Size-PR LogoA manufacturer in Poland turns to in-house heat treating capabilities rather than outsourcing its nitriding for stainless steel power generation parts. Steam turbine components will now be processed at the facility in Elbląg as a result of funding help from a government program part of the European Union.
Marcin Stokłosa
Project Manager
Nitrex Poland
LinkedIn.com
P.W.P.T. POSTEOR Sp. z o. o made the decision to stop outsourcing to commercial heat treaters its steam turbine pieces to bring the nitriding in house. The NX series furnace, model NX-620 will streamline production of these parts with its automated capabilities. The pit type furnace from NITREX meets requirement for nitriding, nitrocarburizing,  and in-process oxidation. “The turnkey system also includes remote access software, an INS neutralizer for a clean and environment-friendly process, and a custom HMI for the end-user," describes Marcin Stokłosa, project manager at NITREX. "It is entirely automated, requiring little operator attendance or involvement."
POSTEOR hopes to reduce the challenges it was facing in outsourcing the components.  With the nitriding furnace the company will have more positive control of the end results.
Manufacturing Plant Adds In-House Nitriding for Power Generation Parts Read More »
Dig into the Archives: 5 Technical Articles for Fresh Heat Treaters in Auto
OCAre you a relatively new reader in automotive heat treat? Welcome. Enjoy this archive of articles from the automotive industry, which provides years of technical knowledge to fill any information gaps. Even the "OG" readers with Heat Treat Today will want to investigate this Technical Tuesday original content compilation that plumbs the depths of the archives.
1. What Heat Treatment To Use for Truck Gear Boxes?
Fig. 2. Schematic depiction of pusher furnace (l.) and 3D batch of helical gears (r.)This paper reveals the investigation and conclusions of distortion potentials for case hardening processes. Mainly, the focus was on how the SyncroTherm® concept method compared to conventional case-hardening processes for gears and sliding sleeves.
Read about how the results effected the bottom line: reduced costs, quicker processes, and less distortion. Also, be sure to examine each of the charts and figures for further understanding of each test.
This article entered the Automotive Heat Treat archive in 2016, and was written by Andreas Schüler, Dr.-Ing. Jörg Kleff, Dr. Volker Heuer, Gunther Schmitt, and Dr. Thorsten Leist.
Read about here: "Distortion of Gears and Sliding Sleeves for Truck Gear Boxes – a Systematical Analysis of Different Heat Treatment Concepts"
2. Cracking the Case
In this article, we follow a case study from the automotive industry to understand how to pinpoint a heat treating problem. This article specifically looks at what was causing cracking in variable valve timing (VVT) plates.
Read the 2018 article, "Part Failure Investigation & Resolution — A Case Study," by Rob Simons.
3. Carburizing: The Importance of Temperature Monitoring and Surveying
Temperature Monitoring and Surveying Solutions for Carburizing Auto Components: IntroductionLow pressure carburizing (LPC) furnaces play an important role in the automotive heat treating industry. During LPC, it is essential that processing temperature stays consistent and critical that the processing time frame is monitored.
This article discusses the importance of collecting temperature data and what to do with the data when it's been collected.
Throughout 2019, Dr. Steve Offley wrote for this series, beginning with this part 1, "Temperature Monitoring and Surveying Solutions for Carburizing Auto Components: Introduction." When you're through, enjoy part 2, part 3, and part 4.
4. Vacuum Brazing --- Back to the (Automotive) Basics
Vacuum Brazing for Automotive ApplicationsTime to brush up on a vacuum brazing furnace, but automotive industry style. Review the terms, parts, function, and more that are involved in a successful vacuum braze for automotive parts.
This study covers a semi-automatic TAV vacuum brazing furnaces, details the makeup of the furnace, and gives an idea of what happens with a load from start to finish.
Read this 2019 article by Alessandro Fiorese here: "Vacuum Brazing for Automotive Applications."
5. Saving Time --- Automation Versus Manual Hardness Tests
Evaluate for yourself the comparisons between an experienced operator manually entering data to Wilson VH3100 series Vickers Microhardness Tester and a DiaMet software entry. Some additional findings show that the crank pins could be examined by the Wilson tester with far less manipulation in the vice as well as reduction in data recording mistakes.
When you read this 2020 article by Buehler, "Manual Versus Automated Hardness Testing", learn exactly how much time, exactly, is saved with automation.
Dig into the Archives: 5 Technical Articles for Fresh Heat Treaters in Auto Read More »
Robotic Laser Heat Treating Expands at Grand Rapids
A commercial heat treater in Grand Rapids, MI is expanding its capabilities with robotic laser heat treating systems. This announcement was given with an open house invitation for the manufacturing community to witness this technology in action.
Laser Hard, Inc.'s technology is gaining momentum in automotive, mining, power generation, medical, aerospace and firearms industries, among others. Due to its low heat input and accuracy, companies request this process in place of other conventional methods that introduce a greater risk of cracking and distortion. The robot has built-in pyrometry for consistent heat at the work piece, reducing the risk of melting edges or overheating in an area that may have a thin cross section.
The open house will be on Thursday, October 13th, at 2766 3 Mile Road, Grand Rapids, MI 49534. There will be laser hardening demonstrations every hour from 2pm-6pm. Food and beverages from Pork Fat Slim's food truck will be available.
Robotic Laser Heat Treating Expands at Grand Rapids Read More »
Welcome to Heat Treat Today's This Week in Heat Treat Social Media. You know and we know that there is too much content available on the web, so it’s next to impossible to sift through all of the articles and posts that flood our inboxes and notifications on a daily basis. Today, Heat Treat Today brings you another hot take of the latest compelling, inspiring, and entertaining heat treat chatter from the world of social media. We're looking at FNA chatter, some sweet technical (and not so technical) heat treat content, and a video of some hot steps.
1. Gas Nitriding vs. Plasma Nitriding
Typically, we have some sick video of a racecar jumping off a building to shock you into your Friday. This time, since many of us are getting off the hype of being at FNA, listen to this breakdown on the differences between gas nitriding and plasma nitriding.
2. All That Chatter
Check out some of the chatter that everyone has been posting on heat treat topics over the last few months.
Did someone say "Jominy"?
Simmering Springs
"One of these cooling fans is not like the other?!"
Screen Capture from Daniel Dudar via LinkedIn
3.  Bumping Shoulders with Heat Treaters
It's great to connect with other folks in the industry. This past week has been an amazing opportunity to forge new relationships and strengthen old ones at MTI events, the Furnaces North America trade show, and student-professional meet-ups.
MTI Moments
FNA Interactions
FNA Conversations
Peter Sherwin gives the best technical session highlights on his LinkedIn page.
ASM Chapter Professional-Student Mixer
4. The Reading (and Podcast) Corner
Time to take your afternoon coffee and read a few technical articles from around the industry. Got too many things to do? Put on an episode of Heat Treat Radio to enjoy as you commute home; they're so interesting, you may even get your family to start watching these videos instead of TV this weekend!
Stay Safe Out There
Where are you at in your cybersecurity know-how? Mike Harrison from Gasbarre is one of the sharp heat treaters out there who get's it. If you need an introduction into the world of cybersecurity, check out this article written on cybersecurity by Joe Coleman, cybersecurity officer at Bluestreak Consulting™.
Mesh Belts: A Report
Heat Treat Radio #82: Gun Part Treatments, Turning Up the Heat with Steve Kowalski
Heat Treat Radio #82: Gun Part Treatments, Turning Up the Heat with Steve Kowalski. Click to –> Watch | Listen | Learn
5. Hot Feet
Have you ever had a moment like this at the end of a long week? Check out these fancy footsteps as you dance from the shop or plant floor into your weekend!
Have a great weekend!
Jim Oakes Recognized with First Ever FNA Industry Award
Jim Oakes, president of Super Systems, has been awarded the first ever Furnaces North America (FNA) Industry Award at the trade show's opening night kickoff reception.
This award is given to an individual in recognition of their contribution(s) and current/ongoing commitment to the betterment of the heat treating industry with one or more significant accomplishments in the last five years in the area of innovation, leadership, academia, or research.
The Metal Treating Institute’s 2018 President, Pete Hushek, who gave the award to Jim stated, "[No] one has been more deserving of this award than Jim Oakes. Having served as the President of ASM for two years and immediately being elected as president, serving two years during the pandemic, along with his service in a host of other technical standards groups, Jim’s leadership shined as he led two of the major associations the last five years."
Jim Oakes (pictured above in the center) stated upon receiving the award, "This is truly an incredible honor to be recognized by my peers. We don’t do what we do for awards. We do it to make a difference. It is through that difference that we make a better future for everyone. It has always been a pleasure to serve this great industry."
The FNA trade show is produced by the Metal Treating Institute in partnership with its media partner, Heat Treat Today.
Jim Oakes Recognized with First Ever FNA Industry Award Read More »
It’s Over, It Was Great, Thank You!
Furnaces North America 2022, the premier trade show and technical conference in the North American heat treating industry, attracted over 1,200 attendees from around the world. The show is produced by the Metal Treating Institute in partnership with its media partner, Heat Treat Today.
While attendees were in Indiana at the Indianapolis Convention Center, they experienced connection with 125+ top suppliers in the heat treating industry, 35 educational sessions in 10 tracks, and two packed social networking events.
Technical sessions and many exhibitors and attendees
Source: MTI
Exhibitors and attendees alike contributed to the energy and quality of attendance on the show floor, with robust networking and connections flowing over the course of the three days. Topics that were top-of-mind included automation, labor shortages, and the current challenges with supply chain issues.
“When the show doors opened up, it was so exciting the see the reconnection of supplier and customer,” stated Tom Morrison, FNA show producer. “FNA is a big success because of a lot of people, including the Metal Treating Institute volunteers, sponsors, and management, who put their heart and soul into delivering a world class event. It was exciting to see that hard work payoff this week.”
FNA Show Management announced it will host FNA 2024 in Columbus, OH on October 14-16 at the Columbus Convention Center with the Hilton Columbus serving as the host hotel.
(Pictured above is the Heat Treat Today team left to right: Michelle Ritenour, Ellen Porter, Sarah Maffet, Bethany Leone, Lauren Porter, and Alyssa Bootsma; Karen Gantzer, Doug Glenn, and Mary Glenn)
It’s Over, It Was Great, Thank You! Read More »
OCModern industry trends and expectations pose new challenges to heat treating equipment; in addition to the expected requirements (e.g., safety, quality, economy, reliability, and efficiency), factors like availability, flexibility, energy efficiency, environmental, and the surrounding carbon neutrality are becoming increasingly important.
Maciej Korecki, vice president of Business Development and R&D at SECO/WARWICK, presents this special Technical Wednesday case study for the last day of FNA 2022 to focus on an equipment solution that meets these modern industry demands: a semi-continuous vacuum furnace for low-pressure carburizing (LPC) and high-pressure gas quenching (HPGQ).
Maciej Korecki
SECO/WARWICK
At least 60 years ago, vacuum furnaces first appeared in the most demanding industries (i.e., space and aerospace), then spread to other industrial branches, and are now widely implemented in both mass production and service plants. Use of vacuum technology does not look like it is slowing down anytime soon.
The driving forces behind this growth in vacuum technology are two-fold: first, the increasing heat treatment requirements that result from the directions of industrial development and production systems, and second, environmental protection, where the advantages of vacuum technologies are undeniable.
Traditional Atmospheric Technology
Case hardening by carburizing is one of the most widely used heat treatment technologies. It consists in carburizing (introducing carbon to the surface) followed by quenching of the carburized layer. Typically, the work is carburized in a mixture of flammable gases (CO, H2), and quenched in oil in an atmosphere furnace, using methods developed in the 1960s.
These methods have a history of development, though the question remains if the technological developments can keep up with the requirements of modern industry. Safety is an issue with this method due to the use of flammable (and poisonous) gases and flammable oil, as well as open flame, which in the absence of complete separation from the air can lead to fire, or poisoning.
In addition, they affect their environment by releasing significant amounts of heat, polluting the surroundings with quenching oil and its vapors. They require the use of washers and cleaning chemicals, emit annually tens or even hundreds of tons of CO2 (greenhouse gas, the main culprit of global warming and dynamic climate change) coming from the carburizing atmosphere, and for these reasons, they need to be installed in dedicated so-called “dirty halls” separated from other production departments.
The resulting requirement to limit the temperature of the processes to 1688-1706 oF (920-930oC) is also not without importance, as it blocks the possibility of accelerating carburization and increasing production efficiency (due to the use of metal alloys in the construction, the service life of which drops dramatically at higher temperatures) and the formation of unfavorable intergranular oxidation (IGO), which is a characteristic feature of the atmospheric carburizing method.
Quenching in oil is effective, but it does not have precise controllable, repeatable, and ecological features that heat treaters may need. Due to the multiphase nature of oil quenching (steam, bubble, and convection phase) and the associated extremely different cooling rates, it is characterized by large and unpredictable deformations within a single part and the entire load. Furthermore, there is no practical method to influence and control the quench process.
Modern Vacuum Technology with LPC and HPGQ
Vacuum carburizing appeared as early as the 1970s, but it could not break through for a long time due to the inability to control and predict the results of the process, and heavy contamination of the furnaces with reaction products.
The breakthrough came in the 1990s, when acetylene began to be used as a carbon-bearing gas and computers were employed to control and simulate the process. Since the beginning of the 21st century, there has been a rapid development of the low pressure carburizing (LPC) technology and an increase in its industrial demand, which continues today with an upturn.
Vacuum carburizing occurs with the aid of hydrocarbons (usually acetylene), which catalytically decompose at the surface, providing carbon that diffuses into the material. The process is carried out under negative pressure (hundreds of times less than atmospheric pressure) and is very precise, efficient, and uniform due to the very high velocity and penetration capacity of the gas molecules, allowing the carburizing of large and densely packed loads and hard-to-reach surfaces such as holes.
In addition, the use of non-oxygen-containing hydrocarbon atoms eliminates the qualitative problem of intergranular oxidation (IGO). The process is completely safe, there is no flammable or poisonous atmosphere in the furnace and no open flame, and the furnace can work unattended and is fully available and flexible, i.e., it can be turned on and off on demand, which does not require any preparation. Similarly, changing the carburizing parameters takes place efficiently.
Due to the design of the vacuum furnace and the use of materials with high resistance to temperature, i.e., graphite — the only limitation for the temperature of the carburizing process is the steel from which the parts are made — it is possible to carburize at higher temperatures than traditional methods allow. The result is a significantly shorter carburizing time and increased furnace efficiency versus what can be achieved in an atmosphere furnace.
Neutral gas cooling was included with the vacuum furnaces. Initially, engineers used a cooling gas (nitrogen or argon) at near ambient pressure and natural convection. Subsequent solutions introduced fan-forced gas flow in a closed circuit. The cooling efficiency under such conditions was hundreds of times lower compared to that of oil, allowing only high-alloy steels and parts with very limited cross-sections to be hardened. Over the following decades, the development of HPGQ was focused on improving cooling efficiency by increasing pressure and velocity and using different types of gas and their mixtures. Current systems have cooling efficiencies on a par with oil-based systems and enable the same types of steel and parts to be hardened, with the advantage that deformation can be greatly reduced and reproducible, and the process is completely controllable (through pressure and gas velocity) allowing any cooling curve to be executed.
Vacuum technologies have an ecological edge. Because of their design and processes, vacuum furnaces do not interfere with the immediate surroundings and are environmentally friendly, so they can be installed in clean halls, directly in the production chain (in-line). They emit negligible amounts of heat and post-process gases which are not poisonous and contain no CO 2 at all. Gas quenching eliminates harmful quenching oil and the associated risk of fire and contamination of the immediate environment, as well as the need for equipment and chemicals for its removal and neutralization. Nitrogen used for cooling is obtained from the air and returned to it in a clean state, creating an ideal environmentally friendly solution.
The presented advantages of vacuum technologies influence its dynamic development and increase the demand of modern industry, and the gradual replacement of atmospheric technologies.
Vacuum furnaces are available in virtually any configuration: horizontal, vertical, single, double, or multi-chambered, tailored to the process and production requirements. In light of recent global changes, requirements, and industrial trends, special attention should be paid to disposable, flexible, and rapidly variable production and process systems, as well as independent and autonomous systems, which include a three-chamber vacuum furnace for semi- continuous heat treatment, equipped with LPC and HPGQ.
Three-Chamber Vacuum Furnace — CaseMaster Evolution Type CMe-T6810-25
This is a compact, versatile, and flexible system designed for vacuum heat treatment processes for in-house and commercial plants, dedicated to fast-changing and demanding conditions in large-scale and individual production (Fig. 1). It enables the implementation of case hardening by LPC and HPGQ processes and quenching of typical types of oil and gas hardened steels and allows for annealing and brazing. It is characterized by the following data:
  • working space 610x750x1000 mm (WxHxL)
  • load capacity 1000 kg gross
  • temperature 2282oF (1250oC)
  • vacuum range 10-2 mbar
  • cooling pressure 25 bar abs
  • LPC acetylene gas
  • Installation area 8x7m
The furnace is built with three thermally and pressure-separated chambers (Fig. 2.), and operates in a pass-through mode, loaded on one side and unloaded on the other, simultaneously processing three loads, hence its high efficiency. The load is put into the pre-heating chamber, where it is pre-heated to the temperature of 1382oF (750oC), depending on the requirements: in air (pre-oxidation), nitrogen or vacuum atmosphere. It is then transferred to the main heating chamber, where it reaches process temperature and where the process is carried out (e.g., LPC).
In the next step, the charge is transported to the quenching chamber, where it is quenched in nitrogen under high pressure. All operations are automatic and synchronized without the need for operator intervention or supervision.
Fig. 2. Construction and schematic furnace cross-section CMe-T6810-25.
Source: SECO/WARWICK
Particularly noteworthy is the gas cooling chamber, which in nitrogen (rather than helium) achieves cooling efficiencies comparable to oil (heat transfer coefficient >> 1000 W/m2K), thanks to the use of 25 bar abs pressure and hurricane gas velocities in a highly efficient closed loop system. The cooling system is based on two side-mounted fans with a capacity of 220 kW each, forcing with nozzles an intensive cooling nitrogen flow from above onto the load, then through the heat exchanger (gas-water), where the nitrogen is cooled and further sucked in by the fan (Fig. 3). The cooling process is controllable, repeatable, and programmable by gas pressure, fan speed and time. An intense and even cooling is achieved. The result is the achievement of appropriate mechanical properties of parts with minimal hardening deformations, without the use of environmentally unfriendly oil or very expensive helium.
Fig. 3. Cross-section of the furnace CMe-T6810-25 cooling chamber.
An integral part of the furnace system is the SimVaC carburizing process simulator, which enables the design of furnace recipes without conducting proof tests.
Distinctive Features of the CMe-T6810-25 Furnace
The advantages of this type of furnace — versus more traditional or past forms — can be demonstrated in a number of usability and functional aspects, the most important of which are the following:
Safety:
  • Safe, no flammable and poisonous atmosphere
  • No open fire
Production and installation:
  • Intended for high volume production (two to three times higher output when compared to single- and double-chamber furnaces)
  • Effective and efficient LPC (even five times faster than traditional carburizing)
  • Total process automation & integration
  • Clean room installation
  • Operator-free
  • Compact footprint
Quality:
  • High precision and repeatability of results
  • Uniform carburizing of densely pack loads and difficult shapes (holes)
  • No decarburization or oxidation
  • Elimination of IGO
  • Ideal protection and cleanliness of part surfaces
  • Accurate and precise LPC process simulator (SimVaC)
Quenching:
  • Powerful nitrogen quenching (neither oil nor helium is needed)
  • Reduction of distortion
  • Elimination of quenching oil and contamination
  • Elimination of washing and cleaning chemicals
Operational:
  • Flexible, on-demand operation
  • No conditioning time
  • No human involvement and impact
  • High lifespan of hot zone components — i.e., graphite
  • No moving components in the process chamber
Ecology:
  • Safe and environmentally friendly processes and equipment
  • No emission of harmful gases (CO, NOx, SOx)
  • No emission of climate-warming gas CO2
Based on the CMe-T6810-25 furnace performance, it is rational and reasonable to build heat treatment systems for high-efficiency and developmental production in a distributed system by multiplying and integrating further autonomous and independent units. The reasons for doing so are because the furnace design affords:
  • No risk of production total breakdown
  • Unlimited operational flexibility
  • Less initial investment cost
  • Unlimited multiplication
  • No downtime while expansion
  • Independent quenching chamber
  • Independent transportation
  • Independent control system
The characteristics, capabilities and functionalities of the CMe-T6810-25 furnace fit very well with the current and developmental expectations of modern industry and ecological requirements, which is confirmed by specific implementation cases.
Case Study
The three-chamber CaseMaster Evolution CMe-T6810-25 vacuum furnace was installed and implemented for production at the commercial heat treatment plant at the Polish branch of the renowned Aalberts surface technologies Group in 2020.
Fig. 4. Gearwheel used in the case hardening process.
The CMe furnace, together with the washer and tempering furnace, forms the core of the department's production, which is why the furnace is operated continuously. Last year, the furnace performed over 2000 processes and showed very high quality (100%) and reliability (> 99%) indicators. The very high efficiency of the furnace was also confirmed, which, with relatively low production costs, contributes to a very good economic result.
The case hardening process on gearwheels used in industrial gearboxes was taken as an example. The wheel had an outer diameter of about 80 mm and a mass of 0.52 kg (Fig. 4), and the load consisted of 1344 pieces densely packed in the working space (Fig. 5) with a total net weight of 700 kg (920 kg gross) and 25 m2 surface to be carburized. The aim of the process was to obtain an effective layer thickness from 0.4 – 0.6 mm with the criterion of 550 HV, surface hardness from 58 – 62 HRC (Rockwell Hardness C), core hardness at the gear tooth base above 300 HV10 and the correct structure with retained austenite below 15%.
Fig. 5. A photograph of the arrangement of gearwheels in the load.
The LPC process was designed using the SimVaC® simulator at a temperature of 1724oF (940oC) and a time of 45 min, with 3 stages of introducing carburizing gas (acetylene), obtaining the appropriate profile of carbon concentration in the carburized layer, with a content of 0.76% C on the surface (Fig. 6).
The process was carried out in the CMe-T6810-25 furnace and had the following course from the perspective of a single load (Fig. 7):
  1. Loading into a pre-heating chamber, heating and temperature equalization in 1382oF (750oC) (100 min in total).
  2. Reloading to the main heating chamber, heating and temperature equalization in 1724oF (940oC), LPC, lowering and equalizing the temperature before quenching in 1580oF (860oC), reloading to the cooling chamber (total 180 min).
  3. Gradual quenching at a pressure of 24, then 12 and 5 bar, discharge of the load from a quenching chamber (total of 25 min).
The load stayed the longest in the main heating chamber – for 180 minutes. This means that with the continuous operation of the furnace in this process, the cycle will be just 180 minutes, i.e., once every three hours the raw load will be loaded, and the processed load will be removed from the furnace.
In the next step, the parts underwent tempering at a temperature of 160oC.
The result of the process was tested on ten parts taken from the reference corners and from the inside of the load. The correct layer structure (Fig. 8) and hardness profile (Fig. 9) were achieved, and all the requirements of the technical specification were met (Tab. 1).
Tab. 1. Comparison of the parameters required and obtained in the process.
During the process, the consumption of the costliest energy factors was monitored and calculated, and the results per one load are as follows:
  • Electricity – 550 kWh
  • Liquid nitrogen – 160 kg
  • Acetylene – 1.5 kg
  • CO2 emissions – 0 kg
Cooling water and compressed air consumption have not been included as they have a negligible impact on process costs.
Summary: Efficiency and Economy
As a result of the process, all technological requirements have been met, obtaining the following indicators of efficiency and consumption of energy factors calculated for the entire load and per unit net weight of the load (700 kg):
  • Capacity: 3h/load; 233 kg/h; 5 thousand tons/year (6500 h)
  • Electricity: 550 kWh; 0.79 kWh/kg
  • Liquid nitrogen: 160 kg; 0,23 kg/kg
  • Acetylene: 1,5 kg; 2,1 g/kg
  • CO2 emissions : 0 kg; 0 kg/kg
On this basis, it is possible to estimate the total cost of energy factors in the amount of approximately EUR 100 per load or approximately EUR 0.14/kg of net load (assuming European unit costs of 2021). It is important that these costs are not burdened by CO2 emission penalties, as can happen with more traditional furnaces.
To sum up the economic aspect, based on an example process, a CMe furnace capacity of 1,500 net tons of parts per year was achieved for 6500 hours of annual furnace operation, at a cost of energy factors of about 100 EUR per load, or 0.14 EUR per kg of parts. The economic calculation is very attractive, and the return on investment (ROI) is estimated at just a few years.
While the advantages of this type of vacuum application are clear from this case study, the example discussed here does not represent the full capabilities of the CMe-T6810-25 furnace, even this process can be optimized and shortened, thereby increasing the furnace's efficiency, and reducing costs. It is possible to carry out carburizing processes (LPC) or hardening alone in a 1.5 h cycle, which would double the capacity of the furnace and similarly reduce the cost of energy factors and shorten the ROI time.
For more information:
Go to www.secowarwick.com
Case Study: Heat Treat Equipment Meets the Future Industry Today Read More »
Bundle Up for Fall with 4 Vacuum Heat Treat Articles
OCGetting excited for the November print edition? In 2021, Heat Treat Today released the inaugural Vacuum Heat Treating print edition. This edition is set to release every November to help heat treaters better work their vacuum furnaces and vacuum heat treat processes.
This Technical Tuesday original content round-up shares the hottest vacuum heat treating articles from this past year as you bundle up for the cool weather this fall. Enjoy!
Graphite in Vacuum Furnace Fixturing
The Use of Graphite for Vacuum Furnace Fixturing
Let's talk about carbon/carbon composite --- C/C.
Why is the vacuum furnace industry excited about its use in graphite vacuum furnace fixtures, grids, and leveling components? Because it can be readily machined for special shapes and applications. The lighter-weight material is mostly composed of carbon fibers and a carbon matrix (or binder).
As the authors of this article explain, "They are among the strongest and lightest high temperature engineered materials in the world compared to other materials such as basic graphite, ceramics, metal, or plastic. C/C composites are lightweight, strong, and can withstand temperatures of over 3632°F (2000°C) without any loss in performance." Intrigued, are you not?
Read the article by Solar Atmosphere's Roger Jones and Real J. Fradette, "The Use of Graphite for Vacuum Furnace Fixturing."
Step-by-Step Guide To Choose Heat Treating Equipment (English / Español)
If it's time to choose an industrial furnace, let's break it down step by step:
Step One: Quote Request
Step Two: Supplier Selection
Step Three: Study and Evaluation of Offers
Step Four: The Price
Follow this guide and avoid saying things like "The substation and/or the cooling tower did not have the capacity"; "The equipment is not what we expected"; or “They never told us that the furnace needed gas in those capabilities." If there are steps you take when selecting an industrial furnace, let us know in a Reader Feedback note here.
Read the article by Carrasco Hornos Industriales' Carlos Carrasco, "A Guide to Selecting Heat Treating Equipment" or "Guía para la Selección de Equipos para Tratamiento Térmico."
Pressure vs. Velocity and the Size of Your Furnace
If you like the R&D world of heat treat, but also like to be grounded in practical heat treat solutions, this is the article for you. Read about what this commercial heat treat found out about how size relates to the pressure and velocity of vacuum furnace cooling rates. Here are the facts you will learn:
  1. The greatest impact on the cooling performance in a vacuum furnace is to increase the___ ______ within ___ _____.
  2. This is achieved by ______ __ ______ of the ______ ____.
Read the article by Solar Atmosphere's Robert Hill and Gregory Scheuring, "Vacuum Gas Cooling: Pressure vs. Velocity, Part 1 of 2."
Energy at Large: A Heat Treat Vacuum Furnace Case Study
Harnessing the Sun: A Heat Treat Case Study with General AtomicsIf you like to read about how heat treaters can be game changers in multinational science projects, this is the article for you. A specially designed vacuum heat treat furnace was commissioned to heat treat critical components in a large energy generator. The heat treating of these components takes 5 weeks to complete; talk about a long, uniform heat treat period.
Read about the energy experiment, the heat treat furnace, and the heat treating process in this technical feature.
Read the article by SECO/VACUUM's Rafal Walczak, "Harnessing the Sun: A Heat Treat Case Study with General Atomics."
Bundle Up for Fall with 4 Vacuum Heat Treat Articles Read More »
Excitement at Fever Pitch – Furnaces North America 2022 Happening Now!
OCHeat treaters travel for miles to attend Furnaces North America 2022, in Indianapolis, IN, for two days of learning and networking. This guide gives some necessary attendee information and can’t-miss highlights from the schedule.
Reach out to the Heat Treat Today team at Booth #622-624, or email us at editor@heattreattoday.com, to connect with us at the show. You can also follow us on social media for show updates.
Where and How?
The Indianapolis Convention Center (ICC), at 100 Capitol Avenue, is the place to be. Check out the parking maps to plan your route and incorporate access via skywalk when planning your arrival. Additionally, scan the QR code below (or click here) to log in to the FNA 2022 resources, including resources to navigate the show floor tomorrow and links to find things to do with colleagues, employees, and clients.
Monday
From 7:00 AM to 6:00 PM today, you can complete registration and pick up your badge at the ICC outside of hall B. You can do this on your way to the FNA 2022 Kickoff Welcome Reception, which begins at 6:00 PM at the Marriott Downtown 350 W Maryland Street.
Tuesday
Here’s a sample guide of how to maximize your time at the Indianapolis Convention Center on Tuesday, October 4th.
  • 7:00 AM – 5:00 PM: Pick up your badge and register outside hall B of the ICC if you haven’t already done so.
  • 8:30 AM – 11:15 AM: Head to any of the 20 technical sessions located within five meeting rooms.
  • 10:30 AM – 5:30 PM: Tour the FNA Business Exhibition in hall B.
  • 12:00 PM: Lunch at adjoining food court.
  • 4:00 PM – 5:30 PM: Trade Show Floor Reception
What?
Discover “New Equipment”, “Emerging Technology”, and “Changing Trends” at the technical sessions. The 5 topics that you can explore on Tuesday are Maintenance, Equipment, Energy, Compliance, and The Future.
The following is a sample of some of the technical classes we are looking forward to:
  1. “Heat Treat Robotics . . . .The Present, The Future” Room 124 (8:00 am — 8:35 am)
  2. “Improved Predictive Maintenance Using SCR Power Controllers” Room 120 (8:50 am — 9:25 am)
  3. “Saving Energy & Money in Your Heat Treat Plant” Room 122 (9:40 — 10:15am)
  4. “A Cleaner, Safer and Greener Vacuum Oil Quench Furnace”  Room 121 (9:40 — 10:15am)
  5. “Vacuum Furnace Leaks — What You Need to Know” Room 120 (10:30 am — 11:05 am)
Following these technical sessions, the entire exposition floor of Hall B holds over 135 booths, just waiting to share ideas and innovations. Find Heat Treat Today at Booth #622-624.
Who?
This full list of exhibitors will help you identify the heat treat industry players you want to visit. The time for in-person conversation is invaluable as you navigate new leads. This quick video (or watch below) gives the sense of what an opportunity this is: “You will not want to miss everything heat treating including a packed exhibit hall of the top suppliers in the industry, 35 technical sessions and the best minds in heat treating from both commercial and captive heat treaters.”
See you soon!
Excitement at Fever Pitch – Furnaces North America 2022 Happening Now! Read More »
Guía para el líder que quiere motivar
op-ed[Está] posicionado no solo para trabajar en conjunto con otros seres humanos sino también para liderarlos; si su potencial se ha de realizar, puede que ya haya entendido bien que en esas personas reposa la verdadera clave del éxito que a futuro pudiera conseguir.
Bill Munn, coach de liderazgo at Bill Munn Management Coaching, wrote this article for Heat Treat Today’s September 2022 Tradeshow print edition. Read the English translation when you click the flag to the right!
Bill Munn
Leadership Coach
Source: Bill Munn Management Coaching
¡Felicitaciones a Los 40 sub-40 de Heat Treat Today Promoción 2022! (En inglés: Heat Treat Today’s 40 Under 40 Class of 2022, N. del T.) Este galardón constituye un honor que señala a quien lo recibe como portador de una muy importante  y singular responsabilidad.
Usted es un líder.
Por definición, de aquí se desprende que no se desempeña solo; es más, está posicionado no solo para trabajar en conjunto con otros seres humanos sino también para liderarlos; si su potencial se ha de realizar, puede que ya haya entendido bien que en esas personas reposa la verdadera clave del éxito que a futuro pudiera conseguir.
¿Cómo, pues, lograr su compromiso?
Primer paso: Afiance en sí mismo un espíritu enseñable, asumiendo su rol con la humildad sufi ciente como para buscar el consejo, la claridad y el aprendizaje continuo.
Segundo paso: Aprenda cómo motivar a las personas.
Los tres pilares para motivar a un equipo
Luego de más de cinco décadas de trabajar de cerca con centenares de líderes excelentes junto con sus equipos, he identifi cado y confi rmado vez tras vez que hay tres factores claves para motivar el compromiso y el desempeño de las personas: la visión, la autonomía y el crecimiento.
Visión
Las personas anhelan ser parte de algo importante.
Desean que su actividad tenga significado. Ansían no solo entender la visión del equipo y la empresa a la que pertenecen sino también creer en ella.
Para generar tal visión no hace falta que usted esté dedicado a salvar el mundo. Bastará con que dedique un tiempo a revisar los valores fundamentales de su organización preguntando: <<¿Qué hace que esto sea importante? ¿Qué es imprescindible para que estemos aquí haciendo lo que hacemos?>>, para luego comunicar ese mensaje a su equipo.
Este es un proceso tan poderoso como esencial, uno que demasiadas veces se ha pasado por alto.
Autonomía
Las personas rechazan fuertemente la microgestión. Corresponda o no a la realidad, la microgestión transmite dos mensajes fatales para la motivación: <<No confío en usted>> y <<Creo que usted es incompetente>>.
Por otro lado, el asignar tareas a los miembros del equipo invitándolos a formular preguntas y despejar dudas para luego entrar con fuerza a desempeñarse por sí solos comunica todo lo contrario dando a entender: <<Confío en usted>> y <<Creo lo puede hacer>>.
Motiva de manera increíble.
Ganancia adicional: Los miembros de su equipo aprenderán y crecerán de forma más ágil, logrando un mayor alcance, cuando se les permita el desarrollo autónomo; demostrarán mayor sentido de pertenencia a la organización y su visión.
En pocas palabras, serán más comprometidos y efi caces.
Crecimiento
Las personas anhelan que se les haga progresar; quieren sentir, a lo largo de sus vidas y sus carreras, que están en vías de mejora y crecimiento, perfeccionando cada vez más su quehacer.
El personal suyo desea recibir retroalimentación, asistir a seminarios, participar en programas de formación, leer revistas informativas de peso como esta, y tener acceso a la ayuda, la asesoría y el desarrollo en su esfera particular.
Son demasiados los líderes que se acercan al personal para decir: <<deberías ser mejor en X o te falta avanzar en Y>> sin brindarles el apoyo
para lograrlo, comunicando así el no querer invertir en el éxito a largo plazo de esa persona, lo que a su vez genera que la persona invierta menos de sí en la organización y sus metas.
Si busca un equipo conformado por personas valiosas, apoye a esas personas en su crecimiento demostrando así que son valoradas.
Los resultados de una motivación efectiva
Un equipo motivado se compromete, y un equipo comprometido logra lo propuesto. Como líder de alto potencial usted tiene una oportunidad singular para encender en el personal con el que trabaja una llama, proceso que revertirá en benefi cio de sus metas propias.
Establezca la visión. Libere la autonomía. Fomente el crecimiento. Hacerlo se ha convertido ahora en su responsabilidad y un alto honor, honor que tanto su personal como su carrera le habrá de agradecer.
Le deseamos lo mejor. HTT
Sobre el Autor: Acerca del autor: Mediante el desarrollo de la visión estratégica y la resolución de retos en tiempo real, Bill Munn asiste a los ejecutivos en potenciar al máximo sus equipos. Desde su experiencia como veterano de 32 años en coaching empresarial y otrora ejecutivo destacado del Dow 30, Bill viene aportando sabiduría práctica, perspicacia innovadora y herramientas para el actuar contemporáneo a centenares de líderes corporativos a nivel mundial. Magister en administración de empresas y en su momento profesor de fi nanzas y economía, Bill es un conferencista dinámico y autor de best-sellers en Amazon.
Para más información:
Póngase en contacto con Bill en: billmunncoaching.com
Guía para el líder que quiere motivar Read More »
