FEATURED NEWS
Radiant Tube Manufacturer Completes 3-Phase Expansion
Holland, NY:  One of North America’s leading high-temperature radiant tube manufacturers, INEX Incorporated, recently completed a three-phase building expansion nearly doubling the companies footprint in Holland, New York, 30 miles southeast of Buffalo. According to Mike Kasprzyk, president and owner of INEX, “we’re now able to meet the growing needs of our expanding customer base.”
The expansion included additional production, engineering, and shipping/receiving floor space as well as the addition of new manufacturing equipment and technologies to meet consistently increasing demand. The company’s high-temperature silicon/silicon-carbide (Si/SiC) radiant tubes are one alternative to conventional all-metal radiant tubes and tend to have long life cycles and a higher BTU output per square inch than traditional all-metal radiant tubes.
For more on this expansion, listen to an audio interview with Mike Kasprzyk conducted by Heat Treat Today publisher DougGlenn by clicking here.
Radiant Tube Manufacturer Completes 3-Phase Expansion Read More »
Cost Effective Heat Treatment for Automotive Components made of Aluminium
BOTW-50w  Source:  Heat Processing Online
Automotive Heat Treating, Helmut Egger, Aluminium
The heat treatment of automotive components, made of aluminium alloys, has become a main focus point over the past years within the automotive industry. Increased strength and overall improved properties are ever more frequently targeted, so that material- and weight saving requirements can be accomplished. A fully automated – high capacity T6 – heat treatment line, which is in full compliance with today’s requirements of the automotive industry, will be introduced in the following.
Helmut Egger
Cost Effective Heat Treatment for Automotive Components made of Aluminium Read More »
Schafer Gear Works Transfers its Fort Wayne, Ind., Commercial Aviation Shafts and Small Gear Capabilities to South Bend, Ind.
Shafer Gear Works, Aerospace Heat Treat, Automotive Heat Treat, Medical Heat Treat, Manufacturing Heat TreatTo meet Schafer Gear Works’ growing demand for high-precision commercial aviation shafts and gears, the company recently moved its Fort Wayne, Ind., operations to its larger production facility in South Bend, Ind. “Acquisition of new, state-of-the-art equipment at our South Bend plant and the ability to better leverage our gear manufacturing expertise led to the transfer,” said Paresh Shah, operations manager for the South Bend facility. The transition was seamless and the plant now produces precision-critical shafts and small-diameter gears with tolerances to 0.0004” and microfinishes to 16 RMS.
Shah said moving the small-diameter gear production 90 miles west to Schafer Gear Works South Bend will improve design and manufacturing efficiencies as well as customer support. By centralizing the facility’s small- and medium-diameter gear engineering, production and quality control expertise, the company is expanding its presence in the aerospace and automotive industries as well as with medical instruments, light and heavy industrial products, recreation vehicles, and material handling companies. Its efforts to reduce tool costs and downtime keep pricing competitive and delivery among the fastest in the gear-making industry. Because of the South Bend facility’s continuous equipment improvements and stringent quality standards, it has earned ISO 9001-2008 and AS9100 certification.
Schafer Gear Works manufactures one of the widest ranges of custom-engineered, precision-cut gears for off-highway markets. In addition to the small-diameter gears and precision components, the South Bend plant produces 1.5- to 10-inch diameter spur, internal and helical gears as well as shafts.
Schafer Gear Works Transfers its Fort Wayne, Ind., Commercial Aviation Shafts and Small Gear Capabilities to South Bend, Ind. Read More »
Majority of Heat Treatment Done In-House at SKF — New Equipment Purchased
Ipsen recently installed both atmosphere and vacuum heat-treating systems at SKF’s state-of-the-art manufacturing facility in St. Louis, Missouri. With the relocation of their existing facility to a new location, SKF continues to focus on enhancing the quality, efficiency and overall effectiveness of their heat-treating equipment. Among this new Ipsen equipment was a complete ATLAS atmosphere heat-treating system, including two ATLAS integral quench batch furnaces and ancillary equipment – washer, temper, endo generator, loader/unloader and a feed-in/feed-out station. SKF also purchased a TITAN® vacuum heat-treating system to round out their production capabilities.
Heat-treating is considered a core competency at SKF, and this new equipment will allow them to bring the majority of heat treatment in-house and efficiently handle the increase they’ve seen in production demands and volume of parts. Reflecting on the equipment purchased and what appealed to SKF, Bryan Stanford said, “Initially, I would say it was the general purposefulness of these Ipsen products that appealed to us. We run a very large variety of parts and batch quantities here. A custom solution designed to run tens of thousands of the same parts was not going to work for us. We wanted a low-cost, off-the-shelf-type solution that would allow us the flexibility we required – which is what the ATLAS and TITAN delivered. Now after having performed some pre-training, I would say what stands out the most is the ease of use and control of the equipment.”
The ATLAS batch furnaces feature a 24″ W x 36″ D x 30″ H (610 mm x 910 mm x 760 mm) load size with an 1,100-pound (500 kg) load capacity. They also operate at temperatures of 1,400 °F to 1,800 °F (750 °C to 980 °C) and have a quench oil capacity of 1,030 gallons (3,900 L). The TITAN vacuum furnace features an 18″ W x 24″ D x 18″ H (455 mm x 610 mm x 455 mm) load size with a 1,000-pound (454 kg) load capacity. It operates at temperatures of 1,000 °F to 2,400 °F (538 °C to 1,316 °C). Overall, this Ipsen equipment will be used for carburizing, carbonitriding, brazing and annealing and will process a wide variety of parts that support SKF’s Lubrication Business Unit.
Majority of Heat Treatment Done In-House at SKF — New Equipment Purchased Read More »
Checking Up on Your Heat Treater
BOTW-50w  Source:  GearTechnology.com
Over the years, I’ve toured many a gear manufacturing facility where the heat treat department stole the
show. Maybe it’s the massively deep pit furnaces, the Star Trek-esque control rooms and the large overhead cranes moving components around the facility. Perhaps it’s simply all the pyrotechnics
remind me of a really great rock concert. Regardless, heat treating is such a critical step in the gear manufacturing process it’s no surprise several manufacturers have brought it in-house.
Checking Up on Your Heat Treater Read More »
Aleris To Be Acquired By Zhongwang USA LLC
Aleris Corporation, a global aluminum rolled products producer, announced today that it has entered into a definitive agreement to be acquired by Zhongwang USA LLC, a company majority-owned and led by Mr. Liu Zhongtian, founder of China Zhongwang Holdings Limited (“China Zhongwang”, HKEX code: 01333).  The aggregate value of Aleris amounts to $2.33 billion, comprising $1.11 billion in cash for the equity to be paid by Zhongwang USA, plus $1.22 billion in net debt.
Aleris will continue to be headquartered in Cleveland, Ohio, and will be operated as an independent entity. The Aleris management team will remain in place, providing continuity for Aleris employees and customers and supporting the continued implementation of the Aleris strategy.
Aleris will retain its name and continue to serve its customers with no changes to current operations, contracts or commitments.  It will continue with the implementation of all strategic growth projects, including its major expansion project in Lewisport, Kentucky, which will enable Aleris to meet the North American automotive industry’s growing demand for aluminum auto body sheet.
“We are excited about this transition to strategic ownership as it will allow us to accelerate our strategy to expand our capabilities to support the production of high-value advanced materials for the global automotive and aerospace markets, while maintaining our position as a leading supplier to critical regional markets like building and construction,” said Sean Stack, President and CEO of Aleris.  “We expect the transition to be seamless for our employees and customers, and that the new strategic shareholder will provide us with greater financial flexibility to continue to anticipate and meet the needs of our customers well into the future.”
The acquisition of Aleris reflects Mr. Liu’s commitment to disciplined operating investments over the long-term in an industry to which he has been committed for two decades.  In addition to his role at Zhongwang USA, Mr. Liu is also the chairman and founder of China Zhongwang, the second largest aluminum extrusions product developer and manufacturer in the world and the largest in Asia.  With the acquisition of Aleris, Mr. Liu will now oversee companies that have complementary geographic footprints and capabilities.
“This acquisition is an international expansion to establish a complementary business foothold, as I strongly believe in the potential and prospects of Aleris and the aluminum industry as a whole,” Mr. Liu said.  “Aleris has a strong management team, talented employees and industry-leading capabilities with a complementary geographic footprint.  As the company enters the final phase of its Lewisport automotive project, I believe Aleris is well-positioned to capitalize on the positive demand trends we see globally, and I look forward to supporting the Aleris management team in implementing their growth strategies and pursuing continued success with expanded resources and financial and operational flexibility.”
Since 2010, Aleris has been owned and controlled by a group led by certain investment funds of Oaktree Capital Management, L.P., with affiliates of Apollo Management, L.P., and Sankaty Advisors, LLC owning minority interests.
The transaction is expected to close in the first quarter of 2017 following the customary regulatory approvals and closing conditions.
Credit Suisse acted as financial advisor to Aleris.  Fried, Frank, Harris, Shriver and Jacobson, LLP acted as legal advisors.  Moelis & Co. advised the Aleris Board on certain aspects of this transaction. Paul, Weiss, Wharton & Garrison LLP acted as legal advisors to Oaktree Capital Management.
Aleris To Be Acquired By Zhongwang USA LLC Read More »
Should You Replace Your Aging Heat Treat Technology?
Consideration #1:  Sometimes, Hardware and Technology Forces You to Change Your Software.
Nothing is more frustrating than having to change your software systems because of unexpected developments that have occurred in the underlying and supporting technology.  For example, think about the enormous amount of software applications that ran fine on Windows XP, but now need to be replaced, or undergo a complete remake, because Windows XP is not supported by Microsoft anymore and has now become a risk to the continuity of your business.
Is your heat treat department running an outdated system, a customized software application, or a conglomerate of pieced-together, homegrown apps still limping along? If so, now is the time to look at making that much needed transition and move to a more flexible environment, preferably one that remains on the cutting edge of technology advancements with continuous monthly updates and new software releases.
Consideration #2: Benefits of Using Browser-based Software
A browser-based application is any application that uses a website application as the “front end”, or interface.  A browser-based application can be run in the cloud (SaaS), OR it could be run on your own internal (intranet) server(s). Users access the application from any computer (or mobile device if the software can handle it) connected to the Internet using a modern standard browser, instead of using an application that must be installed on each individual local computer or device.  As an example, Microsoft Word is a common word-processing application.  Google Docs is also a word-processing application, but all the functions are performed using any web browser instead of using software that has been installed directly onto their computer.
Web applications are easier to upgrade and do not require to be completely re-installed if you replace your computer system.  They still need to be kept up-to-date in order to cater to any new internet web browser technologies and information security threats.  With browser-based applications, users access the system via a uniform environment—the web browser; however, the user interaction with the application needs to be thoroughly tested on different web browsers so the system will function properly using any of the popular modern browsers.
Unlike traditional applications, web systems are accessible anytime, anywhere, via a computer or handheld device that has an Internet connection, putting the end user in charge of where and when they access the application.  Someone on vacation can quickly log into the system from anywhere in the world to see what is happening back at the shop.
Using Internet technologies based on industry-wide standards, it’s possible to achieve a far greater level of interoperability between applications than with isolated desktop systems. For example, it is much easier to integrate two browser-based systems than it is to get two proprietary systems to talk to each other. Browser-based architecture makes it possible to rapidly integrate enterprise systems, improving workflow and other business processes. Installation and maintenance becomes less complicated. Once a new version or upgrade is installed on the host server, all users can access it immediately. There is no need to upgrade each device with the new version of the application.
Speaking of data security and confidentiality of business-sensitive information, browser-based applications are typically deployed on dedicated servers, which are monitored and maintained by experienced server administrators. This is far more effective than monitoring many client computers or handheld devices, as is the case with new desktop applications that requires each device to be ‘touched’ every time there is a software change or new upgrade release.
Consideration #3: Most Businesses Know They Need to Update Their System
Various surveys and studies that have been done, and found that the majority of organizations polled know they need to, or should, update their enterprise software systems.  However, they have no plans to do so in the near future, mainly because of cost. This reason is conveniently used a lot, but it just doesn’t add up to be a legitimate reason.  Many businesses have no problem spending millions of dollars on new equipment, but don’t want to spend a few thousand dollars on new software that will get them the information they desperately need to make better decisions in the management of the business, and to help their employees be more efficient with fewer errors.  They are swimming in data, but starving for the information they need, usually because the data is held in disjointed silos across the enterprise…and it isn’t consolidated for better business metrics and knowledge-based reporting.
The problem with not wanting to spend money on software is that it will eventually lead to higher costs, both now and down the road, because the current system(s) require work-arounds, duplication of effort, data redundancy, etc.  There is also the possibility of decreased revenue and business income because the competition is better prepared, and has more to offer their customers. Budgets are important, but they shouldn’t be the only consideration when evaluating the need to modernize your software systems. These considerations should play a large part in the decision-making process.
Nothing Stays the Same:  One thing about technology is that it is always changing.  Your business is always changing too, and your software needs to keep up with your business…not be a hindrance to it. It is essential for nearly all organizations to stay in competition, but aged software applications can be as dangerous as not having an application at all. Not only do older systems not have the functionality that newer systems do, they become a competitive disadvantage and are a detrimental hindrance to achieving the goals/objectives of the business.
Winning Is About Staying in the Fight: “If it ain’t broke, don’t fix it.” This common phrase is used in reference to many things, even software applications. However, consider this: how detrimental can a ‘not-broke’ system be that is not efficient and causes additional time and effort from the workforce to do their day-to-day jobs?  Although modernizing your existing software application system might seem costly, if it is inefficient, you need to answer the question: How much is the existing system costing me?
It is costing you. Inefficiencies are expensive. That is the reason so many manufacturing organizations are working to become lean organizations. That is the reason that technology exists—to improve inefficiencies. Don’t be fooled. Just because the system was the most efficient thing on the market 10 to 15 years ago doesn’t guarantee that it’s the most efficient solution for your organization today. Take the time to study how much efficiency a new system could create before making the decision to modernize. If you still think modernization is too expensive, add the cost of that inefficiency to your operating budget and look again.
Agedness = Feebleness:  One last consideration when determining whether modernizing your software is the right option for the business, is the security of that system. You want your business data and confidential customer information to be secure and readily accessible at the same time. Just as the human body becomes feeble over time, so does the security of your application systems.
In an age when security is paramount to survival, your software applications could actually be putting your organization at risk. There have been multiple companies that have had their corporate servers hacked, sensitive data was breached, and in some cases they lost many months of valuable company data, not to mention the public humiliation, loss of customers’ trust, legal ramifications, and very expensive recovery efforts.  There’s a new data breach or malicious hack identified in the news almost weekly.
With that said, can you really afford to ignore that your older application systems and databases might be less secure than a new system?
Consideration #4: The Secluded Silo Syndrome
Many companies have purchased various software products over the years to meet some type of business or operational need. These purchases inevitably resulted in creating silos in different parts of the organization where it is hard to keep information (some/much of it duplicated) synchronized. Old software and old technology also means that newly hired employees have no experience in that technology and require extensive training just to use the technology to carry out their duties. Also, reporting is simply so much work that the business doesn’t get the information they want when they need it.
Some businesses have considered whether to spend money to develop something like a business intelligence layer over the top of the existing systems, or whether to spend their dollars to upgrade to a modern software system where all the data is stored in one place.  Past Chairman and CEO of General Electric, Jack Welch, once said that “If the rate of change on the outside exceeds the rate of change on the inside, the end is near.”
A key consideration that is faced by companies who find themselves in this position, is whether their existing software systems can effectively scale up to accommodate the planned growth of the business, or will the limitations of these old systems hinder their growth? Given the rate of change in business today, there will come a point at which the existing collection of systems just can’t accommodate the organization’s needs.
For example, can those applications support new governmental regulations, or any necessary certification/accreditation requirements? With natural attrition, there is a growing gap between new and existing employees. Does a viable business really want to invest in training new employees on obsolete applications?  Usually, this is a negative…therefore, the question becomes not “Should we change?”, but “When should we change?”
Everyone understands that there is a cost of replacing outdated systems and software tools, and this is usually the main reason that management gives to delay any upgrades.  But, remember this; you’re also paying a daily price by continuing to rely on those clunkers, and possibly putting the business at undue risk.
Consideration #5: Acknowledge the Objections
Because old software or hardware is still in use, senior management personnel often see no need to replace it.  They think, “If it ain’t broke, don’t fix it.” There are many phrases that management teams have used over the years when defending the continuing use of old software and continuing to delay what they know in their heart really needs to be done, based on the feedback (and sometimes complaints) they are getting from their ‘down in the trenches folks’.  Some of these include:
  • The old system works fine.
  • We’ve always done it that way.
  • New technology costs lots of money.
  • New software will require a big investment in training time as well as money.
  • New software may require some customizations.
  • We’re busy; we don’t have time for this.
  • We’re slow; we don’t have the money for this (please ignore the new Escalade in the parking lot).
Everyone understands that management is simply trying to limit spending in any way it can. However, think about this; if you never swapped out your old equipment, and upgraded to better, faster, more efficient, cost cutting machines, think about the problems you’d still be trying to solve!  The use of software is a very critical component of your business; so, it’s really not a question of if you should switch to better, faster, more efficient software, but when.
Consideration #6: Dangers of the Do-nothing Approach
For the sake of argument, let’s say that your company decides to change nothing, and continues to use the old software or hardware forever. Take a moment to think about what would happen…
At some point in time, your software will not work on newer machines and modern operating systems and browsers, because they are constantly changing.  Here’s something on a more personal note for you to consider; if you oversee your company’s technology investment you need to understand that when the old computer equipment and/or old software systems fail, and the business is ‘dead in the water’ without it, management is going to blame you.  So, why wait for it to fail when you can be proactive, rather than reactive; start planning now and mitigate the risk.  Assistance is available to help you develop a strategy for reporting on the risk of the situation, and help senior management begin to study the possibility of replacing old technology based on effective risk management techniques.
At some point — and you never know when — some sort of system update or service pack may cause your old software to simply stop working.  Also, we have heard from other companies that their customers started complaining because they couldn’t get them the right data that they needed in a timely fashion in order to continue to do business with them. Why risk losing a good customer?  Even if time stands still at your company, it’s still moving right along for your customers (and your competitors).
Summing Up
The challenge now falls upon us, as business owners, to estimate the financial risk that each of our companies are taking when we choose to work with outdated computers, peripherals, operating systems, and the software we use to collect the day-to-day data that we need to run the business and stay competitive. By explaining the cost of doing nothing to the rest of your management team, you may be able to persuade them to start doing something instead.
Author
Ron Beltz
Director of Sales – Strategic Accounts
THROUGHPUT I BLUESTREAK
Should You Replace Your Aging Heat Treat Technology? Read More »
Broadwind Energy Announces Expansion of Abilene, TX Tower Facility
Broadwind Energy, Inc. (NASDAQ:BWEN) announced its Board of Directors has approved a $4 million expansion of the Company’s Abilene, TX tower facility. The expansion plan will increase tower production capacity in this plant to approximately 200 towers annually, a 30% increase. The Company expects the expansion project to be complete in mid-2017. Broadwind President and CEO Stephanie Kushner stated, “The strong demand for wind energy in the Texas region supports this expansion of our
Abilene facility. We are moving forward aggressively to bring this additional 30% capacity on line which should support incremental annual revenues of approximately $15-20 million, while adding
some important operating flexibility.”
Broadwind Energy Announces Expansion of Abilene, TX Tower Facility Read More »
Advanced Heat Treat Receives Nadcap Merit Status
Advanced Heat Treat Corp. announces that it has been awarded Nadcap Merit status for Heat Treating (Ion Nitriding) at the MidPort location in Waterloo, IA.
“Achieving Merit status for the second time in a row is a huge accomplishment for us. Our team works hard each day to ensure the highest quality is given not only to our aerospace and defense customers, but every customer that sends parts to AHT! We are proud to offer the Nadcap certification for our ion (or plasma) nitriding services and hope our customers take pride in the fact they send their parts to AHT.” Stated John Ludeman, Director of Metallurgy and Quality Excellence.
Advanced Heat Treat Corp. has held Nadcap accreditation since 2013. Having demonstrated their ongoing commitment to quality by satisfying customer requirements and industry specifications, the Nadcap Task Group has determined that Advanced Heat Treat Corp. has earned special recognition. This means that, instead of having their next Nadcap audit in twelve months, Advanced Heat Treat Corp. has been granted an accreditation that lasts 18 months!
“Achieving Nadcap accreditation is not easy: it is one of the ways in which the aerospace industry identifies those who excel at manufacturing quality product through superior special processes. Companies such as Advanced Heat Treat Corp. go above and beyond achieving Nadcap accreditation to obtain Merit status and they should be justifiably proud of it,” said Joe Pinto, Executive Vice President and Chief Operating Officer at the Performance Review Institute. “Benefitting from a less frequent audit schedule reduces audit costs and associated pressures and demonstrates the trust that the aerospace industry has in Advanced Heat Treat Corp., based on their past performance in Nadcap audits. PRI is proud to support continual improvement in the aerospace industry by helping companies such as Advanced Heat Treat Corp. be successful and we look forward to continuing to assist the industry moving forward.”
Advanced Heat Treat Receives Nadcap Merit Status Read More »
Distortion Engineering of Gears
BOTW-50w  Source:  Gearsolutions.com
THE CAUSES FOR DISTORTION OF GEARS are complex and the heat treatment process has been named as a main contributing factor. However, the truth is, all the manufacturing steps prior to and after heat treating also make a contribution to distortion. Nevertheless, any thermal operations carried out on gears may trigger and reveal the hidden distortion potential induced by manufacturing. An interesting approach of “distortion engineering” was established by the Collaborative Research Center (CRC) at Bremen University.
Distortion Engineering of Gears Read More »
