vacuum brazing
December 2015
Brazing to form strong metallurgical bond where the brazed joint becomes a sandwich of different layers, each linked at the grain level
The conversation explores various reasons why a vacuum furnace is well-suited to perform brazing because it provides:
  • a controlled, consistent atmosphere cycle after cycle
  • uniform heating throughout the hot zone
  • a controlled rate of heating
  • the elimination of air to prevent the formation of oxidation of the metal
Brazing applications from parts to rockets
February 2016
April 2016
Additional Notes on Titanium
February 2013
175,000 pounds of 6Al-4V titanium in Solar’s 48-foot-long vacuum furnace
Voices in Heat Treat: Vacuum Brazing Revisited Read More »
Dig into the Archives: 5 Technical Articles for Fresh Heat Treaters in Auto
OCAre you a relatively new reader in automotive heat treat? Welcome. Enjoy this archive of articles from the automotive industry, which provides years of technical knowledge to fill any information gaps. Even the "OG" readers with Heat Treat Today will want to investigate this Technical Tuesday original content compilation that plumbs the depths of the archives.
1. What Heat Treatment To Use for Truck Gear Boxes?
Fig. 2. Schematic depiction of pusher furnace (l.) and 3D batch of helical gears (r.)This paper reveals the investigation and conclusions of distortion potentials for case hardening processes. Mainly, the focus was on how the SyncroTherm® concept method compared to conventional case-hardening processes for gears and sliding sleeves.
Read about how the results effected the bottom line: reduced costs, quicker processes, and less distortion. Also, be sure to examine each of the charts and figures for further understanding of each test.
This article entered the Automotive Heat Treat archive in 2016, and was written by Andreas Schüler, Dr.-Ing. Jörg Kleff, Dr. Volker Heuer, Gunther Schmitt, and Dr. Thorsten Leist.
Read about here: "Distortion of Gears and Sliding Sleeves for Truck Gear Boxes – a Systematical Analysis of Different Heat Treatment Concepts"
2. Cracking the Case
In this article, we follow a case study from the automotive industry to understand how to pinpoint a heat treating problem. This article specifically looks at what was causing cracking in variable valve timing (VVT) plates.
Read the 2018 article, "Part Failure Investigation & Resolution — A Case Study," by Rob Simons.
3. Carburizing: The Importance of Temperature Monitoring and Surveying
Temperature Monitoring and Surveying Solutions for Carburizing Auto Components: IntroductionLow pressure carburizing (LPC) furnaces play an important role in the automotive heat treating industry. During LPC, it is essential that processing temperature stays consistent and critical that the processing time frame is monitored.
This article discusses the importance of collecting temperature data and what to do with the data when it's been collected.
Throughout 2019, Dr. Steve Offley wrote for this series, beginning with this part 1, "Temperature Monitoring and Surveying Solutions for Carburizing Auto Components: Introduction." When you're through, enjoy part 2, part 3, and part 4.
4. Vacuum Brazing --- Back to the (Automotive) Basics
Vacuum Brazing for Automotive ApplicationsTime to brush up on a vacuum brazing furnace, but automotive industry style. Review the terms, parts, function, and more that are involved in a successful vacuum braze for automotive parts.
This study covers a semi-automatic TAV vacuum brazing furnaces, details the makeup of the furnace, and gives an idea of what happens with a load from start to finish.
Read this 2019 article by Alessandro Fiorese here: "Vacuum Brazing for Automotive Applications."
5. Saving Time --- Automation Versus Manual Hardness Tests
Evaluate for yourself the comparisons between an experienced operator manually entering data to Wilson VH3100 series Vickers Microhardness Tester and a DiaMet software entry. Some additional findings show that the crank pins could be examined by the Wilson tester with far less manipulation in the vice as well as reduction in data recording mistakes.
When you read this 2020 article by Buehler, "Manual Versus Automated Hardness Testing", learn exactly how much time, exactly, is saved with automation.
Dig into the Archives: 5 Technical Articles for Fresh Heat Treaters in Auto Read More »
Don’t Vacuum-Braze Metals Containing Zinc
Source: Kay & Associates Brazing Consultants
Are you sure you should vacuum braze that? As the title of this best of the web article suggests, vacuum brazing materials containing zinc is not a good idea. Volatized zinc can contaminate, and maybe even ruin, your vacuum furnace. But what about cadmium, lead, chromium, and magnesium? Is vacuum brazing safe for those materials?
In this article by Dan Kay, examine the vapor pressure curves of common metallic elements to be sure you know exactly when you need to worry about vaporization. And remember, operating your furnace at partial pressure does not offset the effects of vaporization.
Many people braze stainless steels (which contains chromium) at vacuum levels approaching 10-5 Torr [. . . ] You can readily see that at 10-5 Torr the temperature at which Cr volatilizes has dropped down to only about 1800F (950°C). Since nickel-brazing of stainless typically takes place at about 2000-2100°F (1095-1150°C), please understand that you will indeed be volatilizing chromium during this brazing operation, which will condense on the furnace walls, giving them a greenish/bluish coloration.
Read more: Don't Vacuum-Braze Metals Containing Zinc
Don’t Vacuum-Braze Metals Containing Zinc Read More »
Heat Treat TV: Solar Atmospheres
Heat Treat TV pulls the best heat treat videos from the web for your viewing, and today Heat Treat TV highlights Solar Atmospheres.
As a commercial heat treater, Solar Atmospheres is dedicated to providing vacuum heat treating and brazing services of the highest possible quality and meeting the expectations of their customers. They seek to educate their customers and will design a heat treating process that fits their needs.
This video demonstrates what a commercial heat treater considers when processing parts, including explaining why a heat treater chooses some methods over others. Topics mentioned in the presentation are brazing, carburizing, and nitriding as well as post-heat treat processing, vacuum brazing, vacuum carburizing, and vacuum gas nitriding.
Click here for more information on Solar Atmospheres.
If you have a video you’d like included on Heat Treat TV, please send an email to editor@HeatTreatToday.com and include a link to the video.
Heat Treat TV: Solar Atmospheres Read More »
Welcome to Heat Treat Today's This Week in Heat Treat Social Media. As you know, there is so much content available on the web that it's next to impossible to sift through all of the articles and posts that flood our inboxes and notifications on a daily basis. So, Heat Treat Today is here to bring you the latest in compelling, inspiring, and entertaining heat treat news from the different social media venues that you've just got to see and read!
1. What do Quality Aerospace Bolts Look Like?
"Quality aerospace bolts are more rigorously tested, more carefully manufactured, and more carefully studied than almost any other component on an aircraft. The reason?" Read more here, and check out the video to see high-impact landing that is required of fighter jets. See 5:10-8:06 for a forced landing on a stool when the pilot's nose gear failed.
2. Hot Heat Treat Technologies
Walk through this CGI Animation of Vacuum Brazing process to see the breakdown of the heat treating process without getting burnt.
3. Advancing Technologies
Check out TWO uses of cutting edge digital systems when applied to heat treat, and industry related processes. See below for the videos.
Digital Transformation of Thermal Processes
Tracking All Processes with Digital
SMS Digital: BIG RIVER STEEL - THE FIRST LEARNING STEEL PLANT
4. The Podcast and Reading Corner
Ever wanted to have access to resources for on the job training? Read or listen to the sources below to learn a new technique, tip, or other aspect of the industry.
A NEW Metal? Check out what carburizing and hardening can do.
"...carburized A-21 exhibited superior corrosion resistance in salt fog testing versus the other stainless steels. It also maintained good core mechanical properties of..."
The "How" Behind Nitrex's Rebranding
Finding a Balance: Read Ipsen's Blog, The Herald, on additive manufacturing  and the thermal processing industry.
[blocktext align="center"]"Additive manufacturing is a disruptive technology with the potential to lower cost, increase speed and create parts once thought to be too complex and intricate to manufacture by conventional methods."[/blocktext]
"Balancing the Speed and Technology of Additive Manufacturing with the Mature and Methodical Thermal Processing Industry" (photo source: IpsenHarold.com)
5. Metal Music
Finally, here is some not-so-heavy metal music to start your weekend. Big thanks to Rosanne Brunello of Mountain Rep for the find! Have a great weekend, folks.
Choosing the Right Vacuum Furnace
Source: TAV, the Vacuum Furnaces Blog
It pays to carefully consider the key factors to buying a vacuum furnace (source: TAV, the Vacuum Furnaces Blog)
When and why is it a good idea to purchase a vacuum furnace? Does your company really need one? A company that wants to play its cards best, in terms of investment and yield, knows about the advantages offered by vacuum heat treatments in both the short and long term. But choosing the ideal furnace best suited to your company’s needs isn’t as easy as it might appear.
In this Heat Treat Today Best of the Web feature, TAV Vacuum Furnaces gives readers a handy guide over at its blog to consider the crucial factors in choosing a vacuum furnace for your company, including tips on who needs a vacuum oven, why comparing two or more systems is a bad idea, and the role of the heat exchanger, vessel performance, and the pumping unit.
An excerpt: “There are many fields, ranging from the vacuum sintering of metal powders or ceramics to the vacuum brazing of aluminum alloys to continue with high temperature brazing, in which technological avant-garde stands out. In these sectors, the decision to use a vacuum furnace is linked to the possibility of implementing an advanced development production process, for which the focus was on high-yield plants.”
Read more: “Do I Really Need a Vacuum Furnace?”
Choosing the Right Vacuum Furnace Read More »
