VACUUM FURNACES NEWS
Vacuum Brazing, Quench and Temper Furnaces Part of Heat Treat Expansion
A Polish heat treatment provider recently announced the startup of vacuum brazing processes at its newest plant in Kalisz for the power generation and aerospace industry. The new facility houses vacuum furnaces as well as borescopes, spectrometer, welding systems, hardness testers, selective plating equipment and a sandblasting cabinet.
In addition, Hauck Heat Treatment has invested in the installation of new heat treatment equipment at their Dzierżoniów location, including new sealed quench furnaces (batch size 910mm x 760mm x 1220mm), one tempering furnace and one endogas generator.
The company also reported that its services to the Eastern European market have expanded with the addition of thermo-chemical treatment, carbonitriding.
Vacuum Brazing, Quench and Temper Furnaces Part of Heat Treat Expansion Read More »
Aeronautic Supplier Purchases Sintering Ovens
A new sintering line suitable for PTFE insulation has been designed and installed by a manufacturer for a producer of aeronautic cables. This machine is suitable for the thermal treatment of the insulation on conductors with diameter 1-7 inches.
In order to guarantee the uniformity of the process, WTM, which specializes in the application of materials for aircraft and aerospace cables and devices particular attention, focused on the definition of the temperature profile to be applied to the cable passing through the sintering ovens. Considering the maximum cable dimension, WTM, which is located in Austria and Italy opted for the induction preheating in the first part of the equipment. The sintering process occurs successively by means of three infrared ovens, equipped with independent control zones, each of them with a maximum temperature of 1022°F.
Aeronautic Supplier Purchases Sintering Ovens Read More »
Twin Vacuum Furnaces for Energy-Optimized Heat Treating
The first set of twin furnaces working on a single pumping station have recently been developed and commissioned to a leading designer and manufacturer of vacuum furnaces for the heat treatment of metal parts.
BMI, a Tenova company, headquartered in Lyon, France, commissioned the B54R-TWIN – vacuum furnaces for tempering – to meet the customer’s specific request for equipment that optimizes energy consumption.
During a heat treatment cycle of the B54R-TWIN, the pumping phase lasts only 30 minutes. Therefore, it is more efficient to use only one pumping group for two furnaces, working alternatively on one furnace or the other. This not only reduces electricity consumption but also minimizes the maintenance costs of the pumps.
Earlier in this quarter, Tenova announced key contracts from Chinese steel producers for six electrical arc furnaces (EAF) Consteel® Evolution in response to Chinese steelmaking industries converting their steel shops plants with EAF technology. In order to improve the reduction rate of CO2 emissions promoted by Chinese government, Chinese steelmakers are starting to increase the share of electrical steel production in comparison to manufacturing using blast or basic oxygen furnaces.
Twin Vacuum Furnaces for Energy-Optimized Heat Treating Read More »
Canadian Auto Parts Manufacturer Adds Chain Conveyor Oven
A Canadian automotive parts manufacturer recently contracted a chain conveyor oven to preheat aluminum billets prior to forging into automotive suspension components under high pressure. This forging process produces high-strength parts that are ideal for applications where performance and safety are critical, but a lighter-weight metal is needed for speed or energy efficiency.
The natural gas-fired indexing conveyor oven, constructed and shipped by Wisconsin Oven Corporation, has a maximum operating temperature of 1,100°F (593° C) and work chamber dimensions of 6’6” W x 23’6” L x 1’0” H. The oven is designed with the capability to heat 1,995 pounds of aluminum per hour and a production rate of 360 parts per hour. The equipment achieved temperature uniformity of +/-10°F (5.6° C) at 1,050° F (565° C) for the last 90 index positions. The patented Expandable Surface™ design includes 2 inches of high-temperature block insulation backed with 4 inches of semi-rigid batt type insulation.
Canadian Auto Parts Manufacturer Adds Chain Conveyor Oven Read More »
Aluminum Aging Oven Shipped to Aerospace Parts Manufacturer
An aerospace parts manufacturer recently acquired an electrically heated aluminum aging oven as part of an upgrade of its line. The SWH series batch oven was ordered to replace antiquated equipment in order to facilitate compliance with AMS 2750E Class 2 specifications. Wisconsin Ovens, a Thermal Product Solutions (“TPS”) brand, completed the shipment in August 2017.
Aluminum Aging Oven Shipped to Aerospace Parts Manufacturer Read More »
Vacuum Furnace Hot Zone Improvement Patent Awarded for Streamlined Manufacture Configuration
An innovation in vacuum furnace hot zone design has landed a new U.S. Patent, No. 9,702,627, for a Souderton, Pennsylvania, vacuum heat treating and brazing furnaces supplier. This hot zone improvement centers on the configuration of heating element supports, providing for simpler, streamlined manufacture of the support assembly. The new design further provides for easy assembly and disassembly of heating elements, a significant improvement over prior designs.
Solar Manufacturing, Inc., recognizes inventors Robert Wilson, Solar Manufacturing’s VP of Engineering, and Mark Hughes, Senior Design Engineer.
Copies of U.S. Patent No. 9,702,627 B2 may be obtained by visiting www.uspto.gov or click here for a pdf of the patent.
Vacuum Furnace Hot Zone Improvement Patent Awarded for Streamlined Manufacture Configuration Read More »
15 Atmosphere and Vacuum Furnaces Shipped to Aerospace, Commercial, MIM Industry Customers
Fifteen atmosphere and vacuum furnaces were shipped to customers in aerospace, commercial heat treating and MIM industries around the world during the second quarter of 2017, including China, Hong Kong, India, Japan, Saudi Arabia, and the United States.
The shipments included:
*   Two large, vertical (bottom-loading) MetalMaster® vacuum furnaces, each with a 120″ (3 m) diameter work zone and 10,000-pound (4,500 kg) load capacity
*   Five standard TITAN® vacuum furnaces complete with PdMetrics®
*   Debind and sinter vacuum furnaces for the MIM industry
*   ATLAS integral quench atmosphere furnace, which was delivered six weeks after order placement
In addition to these transactions, Ipsen USA of Cherry Valley, Illinois, delivered several custom-built vacuum furnaces that will process parts for the aerospace industry.
15 Atmosphere and Vacuum Furnaces Shipped to Aerospace, Commercial, MIM Industry Customers Read More »
Diamond Heat Treat Acquires Vacuum Furnace to Support IGT and Aerospace Industries
Diamond Heat Treat recently purchased a TITAN® H6 vacuum furnace with 6-bar gas quenching to expand their capabilities and serve additional market sectors, including IGT and Aerospace.
While Diamond Heat Treat – acquired by Calvert Street Capital Partners – already has three vacuum furnaces at their Rockford, Illinois, facility, the new furnace’s range of process capabilities allows them to better address key needs for different markets. According to Mike Sobieski, CEO of the thermal processing strategy, “This addition of technical capabilities is in line with our strategy of partnering with family-owned thermal processing companies and then investing in both people and equipment to enable profitable growth.”
One of Ipsen’s modular heat-treating systems, the furnace features a 36” x 48” x 36” (915 mm x 1,220 mm x 915 mm) work zone with a 3,000-pound (1,361 kg) load capacity. This furnace is also capable of operating at temperatures of 1,000 °F to 2,400 °F (538 °C to 1,316 °C) with ±10 °F (±6 °C) temperature uniformity.
Diamond’s purchase is consistent with Calvert Street Capital Partner’s strategy to partner with, support, and develop commercial heat treating manufacturers as described in a March 2017 interview with John Hubbard produced by Heat Treat Radio.
Diamond Heat Treat Acquires Vacuum Furnace to Support IGT and Aerospace Industries Read More »
Aerospace, Medical, and Tooling Industries Benefit from Eight Vacuum Furnaces
Eight vacuum heat treating systems were shipped to customers in Costa Rica, India, Germany and the United States. Ipsen USA recently shipped this equipment and it will be used to support the additive manufacturing, aerospace, medical, MIM and tooling industries.
The vacuum furnaces shipped included a vertical MetalMaster® furnace with a 5,000-pound (2,268 kg) capacity; a custom-built furnace for debinding and sintering; horizontal MetalMaster and TurboTreater®furnaces; a TITAN® DS (debinding and sintering) furnace; and several H2- and H6-sized TITAN vacuum furnaces equipped with the PdMetrics® software platform for predictive maintenance. This software platform securely connects to a network of integrated sensors on the furnace to gather and analyze data, run algorithms and provide real-time diagnostic that improve the health and integrity of the equipment.
Aerospace, Medical, and Tooling Industries Benefit from Eight Vacuum Furnaces Read More »
Medical Manufacturer Chooses Vacuum Furnace System
A vacuum heat-treating system with 2-bar gas quenching was shipped to Costa Rica and will be used to manufacture surgical components. The TITAN® H2, manufactured by Ipsen, helps companies accelerate the pace of innovation while satisfying the strict legal requirements of the medical industry.
The standardized vacuum furnace features an 18″ x 24″ x 18″ (455 mm x 610 mm x 455 mm) all-metal hot zone with a 1,000-pound (450 kg) load capacity. It is capable of operating at temperatures of 1,000 °F to 2,400 °F (538 °C to 1,316 °C) with ±10 °F (±6 °C) temperature uniformity. Equipped with the PdMetrics® platform for predictive maintenance – which securely connects to a network of integrated sensors on the furnace to gather and analyze data, run algorithms and provide real-time diagnostics – the furnace provides sophisticated monitoring of critical systems and key parameters that improve the health and integrity of the equipment. The company also received a gas backfill reservoir, a loader with a 2,000-pound (907 kg) load capacity and a complete air-cooled, closed-loop water system.
Medical Manufacturer Chooses Vacuum Furnace System Read More »
