FEATURED NEWS
First Titanium Wheel Created with 3D Unveiled in California
The first titanium wheel created using EBM technology was recently unveiled during the official announcement of a partnership agreement between the two companies responsible for its design and manufacture.
HRE Wheels, headquartered in Vista, California, and GE Additive launched the new technology, which is a type of 3D printing to test the capabilities of additive manufacturing in a practical application and to create a highly-sophisticated wheel design with an elusive material like titanium. The new prototype wheel is known as “HRE3D+”.
With a traditional aluminum Monoblok wheel, 80% of material is removed from a 100-pound forged block of aluminum to create the final product. With additive manufacturing, only 5% of the material is removed and recycled, making the process far more efficient. Titanium also has a much higher specific strength than aluminum and is corrosion resistant, allowing it to be extremely lightweight and to be shown in its raw finish.
There was an intensive design collaboration between the Vista, California-based, team at HRE and the GE AddWorks team out of Ohio. Using design queues from two existing models of HRE wheels, the two companies worked together to create a stunning example of what is possible with additive manufacturing.
HRE President Alan Peltier
The wheel was produced on two Arcam EBM machines – Q20 and a Q10 in five separate sections, then combined using a custom center section and titanium fasteners.
“This is an incredibly exciting and important project for us as we get a glimpse into what the future of wheel design holds,” said HRE President Alan Peltier. “Working with GE Additive’s AddWorks team gave us access to the latest additive technology and an amazing team of engineers, allowing us to push the boundaries of wheel design beyond anything possible with current methods. To HRE, this partnership with GE Additive moves us into the future.”
Robert Hanet, senior design engineer, GE Additive AddWorks
“HRE prides itself on its commitment to excellence and superior quality in the marketplace. It was a natural fit for AddWorks to work on this project with them and really revolutionize the way wheels can be designed and manufactured,” said Robert Hanet, senior design engineer, GE Additive AddWorks.
First Titanium Wheel Created with 3D Unveiled in California Read More »
Heat Treat Tips: Induction Heating — Stuff You Should Know
During the day-to-day operation of heat treat departments, many habits are formed and procedures followed that sometimes are done simply because that’s the way they’ve always been done. One of the great benefits of having a community of heat treaters is to challenge those habits and look at new ways of doing things. Heat Treat Today‘s 101 Heat Treat Tips, tips and tricks that come from some of the industry’s foremost experts, were initially published in the FNA 2018 Special Print Edition, as a way to make the benefits of that community available to as many people as possible. This special edition is available in a digital format here.
In today’s Technical Tuesday, we continue an intermittent series of posts drawn from the 101 tips. The category for this post is Induction Heating, and today’s tips–#29, #73, and #83–are from Dr. Valery Rudnev, FASM, Fellow of IFHTSE, “Professor Induction”, Director of Science & Technology at Inductoheat Inc., an Inductotherm Group company. Dr. Rudnev is a regular contributor to Heat Treat Today.
Heat Treat Tip #29
Induction Heating Non-Ferrous Metals & Alloys
Dr. Valery Rudnev, FASM, Fellow IFHTSE, Professor Induction, Director Science & Technology, Inductoheat Inc., an Inductotherm Group company
Steel components by far represent the majority of hot worked and heat-treated parts for which electromagnetic induction is used as a source of heat generation. At the same time, many other non-ferrous metals and alloys are also inductively heated for a number of com­mercial applications. Induction heating of low electrically resistive metals such as Al, Mg, Cu, and others typically require using lower electrical frequencies compared to carbon steels, cast irons, or high resistive non-magnetic metals (such as Ti or W, for example) and metallic alloys. The lower value of electrical resistivity results in smaller current penetration depth (depth of heat source gen­eration), making it possible to apply much lower frequencies without facing the danger of eddy current cancellation.
Heat Treat Tip #73
Induction Hardening Powder Metal
When induction hardening powder metallurgy (P/M) materials, it is good practice to have a minimum density of at least 7.0 g/cm3 (0.25 lb/in.3). This will help obtain consistent induction hardening results. When hardening surfaces that have cuts, shoulders, teeth, holes, splines, slots, sharp corners, and other geometrical discontinuities and stress risers, it is preferable to have a minimum density of 7.2 g/cm3 (0.26 lb/in.3). Low-density P/M parts are prone to cracking due to a penetration of the gases into the subsurface areas of the part through the interconnected pores. Interconnected pores contribute to decreased part strength and rigidity compared with wrought materials. In addition, the poor thermal conductivity of porous P/M parts encourages the development of localized hot spots and excessive thermal gradients and also requires the use of quenchants with intensified cooling rates to obtain the required hardness and case depths. This is so because an increase in pore fraction and a reduction in density negatively affect the hardenability of P/M materials compared to their wrought equivalents.
Heat Treat Tip #83
Induction Hardening Cast Iron
These tips were submitted by Dr. Valery Rudnev, FASM, Fellow IFHTSE, Professor Induction, Director Science & Technology, Inductoheat Inc, an Inductotherm Group company.
If you have any questions, feel free to contact the expert who submitted the Tip or contact Heat Treat Today directly. If you have a heat treat tip that you’d like to share, please send to the editor, and we’ll put it in the queue for our next Heat Treat Tips issue.
Heat Treat Tips: Induction Heating — Stuff You Should Know Read More »
Neutron Researchers Looking for Ways to Improve Vehicle Safety and Fuel Efficiency
Source: Phys.org
Researchers working with a major U.S. steelmaker are responding to the increased demand for vehicles that are made safer and more fuel efficient by using neutrons “to better understand the properties of hydroformed advanced high-strength steel and how it responds to residual stress introduced during manufacturing,” according to Phys.org.
United States Steel Corporation (USS) industrial research engineers used neutrons at Oak Ridge National Laboratory’s Spallation Neutron Source to analyze materials exposed to different manufacturing processes.
“Because this is a new material containing retained austenite, we need to have a better understanding of its performance. A better understanding of how this material responds to different manufacturing processes like stamping or hydroforming will help us validate engineering models that will in turn make it easier to design and produce auto components that are lighter, stronger, and more durable.” ~ Lu Huang, USS industrial research engineer
Read more: “Neutrons Analyze Advanced High-Strength Steels To Improve Vehicle Safety and Efficiency”
Photo Credit: ORNL/Genevieve Martin. Photo caption: Lu Huang, USS industrial research engineer prepares a lightweighted advanced high strength steel component for neutron research at the Spallation Neutron Source’s VULCAN instrument. Data from this study may make it faster and easier for companies to design automotive components that are lighter, more durable, and safer. Credit: ORNL/Genevieve Martin
Neutron Researchers Looking for Ways to Improve Vehicle Safety and Fuel Efficiency Read More »
Steelmaker Invests in Q&T Production at Alabama Plant
A Swedish steelmaker is responding to the increase in demand for quenched and tempered (Q&T) steels in the U.S. by investing the equivalent of approximately $110 million in its Mobile, Alabama, steel mill.
Martin Lindqvist, SSAB’s President and CEO
SSAB’s investment is targeted to increase annual production capacity of Q&T in Mobile from 330,000 tons (U.S.) to 440,000 tons (U.S.) and to reduce costs.
“SSAB is a global leader in Q&T steels and we have largely driven market growth through application development together with customers,” said Martin Lindqvist, SSAB’s President and CEO. “Over the past 20 years, we have increased Q&T volumes by an average of 7 percent a year. There is great market potential as Q&T penetration is still relatively low in, for example, North and South America, where we now plan to increase capacity.”
The investment of around SEK 1 billion is scheduled to take place 2019-2021 and is targeted at three areas: formatting, blasting & painting, as well as shipping capacity.
In parallel, a new, accelerated cooling system will also be installed and this will improve the potential to grow volumes of more advanced premium products while reducing the need for alloys. The investment has been designed to include the potential to build additional Q&T capacity through direct quenching similar to the technology currently used at SSAB’s production facilities in Finland and Sweden.
Steelmaker Invests in Q&T Production at Alabama Plant Read More »
Sacrificial Lambs: Hardness Testing and Heat Treating
Source: Gear Technology
Charles D. Schultz, president of Beyta Gear Service
In a recent blog post at Gear Technology, Charles D. Schultz, president of Beyta Gear Service, addressed the importance of accuracy when describing hardness test location and the reason why “sacrificial lambs” are needed during production.
“I cannot emphasize enough that if you are not cutting up parts or coupons you do not know what is really happening during your thermal processing.” ~ Charles D. Schulz
Read more: “Gear Materials: More Inside Heat Treating Trivia”
Photo Credit: Gear Technology
Sacrificial Lambs: Hardness Testing and Heat Treating Read More »
PA Metals Manufacturer Begins Production at Expanded Aerospace Parts Facility
Source: Light Metal Age
Jeremy Halford, president of Arconic Engineered Structures
A lightweight metals engineering and manufacturing company located in Pittsburgh, Pennsylvania, recently opened its expanded aluminum and titanium aerospace parts facility in Bestwig, Germany, almost doubling its titanium parts production capacity and adding state-of-the-art equipment.
Arconic’s expansion will allow the company to meet the demand for lightweight titanium investment castings.
“Combined with our previous investments in Bestwig, this latest expansion is providing additional capacity to deliver even more of the titanium components our customers need to build aircraft at high volumes,” said Jeremy Halford, president of Arconic Engineered Structures.
Read more: “Arconic Opens Expanded Aerospace Parts Facility in Germany”
Photo credit: Arconic
PA Metals Manufacturer Begins Production at Expanded Aerospace Parts Facility Read More »
CAB Technology Commissioned by Auto Parts Manufacturer
A manufacturer of automotive heat exchangers recently partnered with a leading heat treat furnace manufacturing company with a formidable U.S. presence to produce parts using a complete Controlled Atmosphere Brazing (CAB) line for its greenfield project in Gujrat, India.
Karnavati Car Air Conditioners Pvt. Ltd, Ahmedabad, (KCPL), which produces a wide variety of high-quality radiators, condensers, cooling coils, and fan assemblies, will utilize SECO/WARWICK’s CAB line and related equipment in the manufacturing process, including thermal degreaser, fluxer, dry-off oven, air quality and cleaning. The system will be utilized for aluminum heat exchangers of all types for the automotive market.
“KCPL is one of the fastest growing companies in India,” said Kartik Jethwa – Chief Engineer, KCPL, “dealing in automotive radiators, condensers, cooling coils and fan assemblies. We have selected the complete SECO/WARWICK’s CAB brazing line because the system versatility will enable our company to produce a wide variety of high-quality products with the lowest possible cost – our goal is to continue our rapid pace of growth and improve profitability by modernizing our brazing operation.”
“We are proud technology partners with KCPL and look forward to their continued success. Since 1984, SECO/WARWICK has been the leader in the evolution and innovations in CAB technologies ensuring our customers that they will receive the finest system value and professional technical services to keep their equipment online and operating efficiently for many years in the future,” said Piotr Skarbinski, VP, Aluminum Process and CAB Technology, SECO/WARWICK.
CAB Technology Commissioned by Auto Parts Manufacturer Read More »
Nevada, Wisconsin Construction Equipment Manufacturer Expansion Includes Heat Treat
A manufacturer and supplier of earth-moving equipment recently announced expansion plans that include two of its brands building new facilities in Nevada and Wisconsin, one to host a new heat treat shop.
Jeff Dawes, President and CEO of Milwaukee-based Komatsu Mining Corp
Komatsu Equipment Company will a build state-of-the-art, $47 million customer support and service center in Elko, Nevada. This announcement comes not long after Komatsu Mining Corp reported intentions to construct a new headquarters and manufacturing campus near the location of the company’s original machine shop off South First Street in Milwaukee, Wisconsin.
Komatsu’s investment of nearly $300 million at the Milwaukee site will include the design and construction of advanced machine, heat treat, and fabrication shops; state-of-the-art technology, R&D, and robotics labs; as well as new office and training facilities. Komatsu Mining Corp. aims to reduce energy consumption with green initiatives, including solar panels, wind spires, a remotely operated closed-loop heat treat system, green spaces, LED lighting and other sustainable solutions. Project completion is expected in 2022.
“The new campus provides us opportunity for advancement in state-of-the-art facilities that expand our capabilities on a global scale,” said Jeff Dawes, President and CEO of Milwaukee-based Komatsu Mining Corp. “Our new facilities will be designed to enhance safety, efficiency and environmental sustainability – all top priorities of Komatsu worldwide, allowing us to better serve our customers and deliver innovative solutions.”
John Pfisterer, president of Komatsu Equipment Company
Of the new 189,000 sq-ft manufacturing space in Elko, Nevada, Komatsu Equipment Company John Pfisterer said: “The new building offers an exciting opportunity to bring together local employees of two major Komatsu subsidiaries: KEC and Komatsu Mining Corp. (KMC), into one integrated organization. Collaborating directly in a shared, state-of-the-art space, these combined teams will enhance customer support and operational efficiency.”
The new building will include a six-bay, full-service construction equipment and mechanical rebuild shop; a heavy welding and fabricating shop, large enough for rebuild and manufacturing of large shovel and truck structures and manufacturing of truck bodies; a heavy machine shop with large, horizontal milling and boring machine, plus vertical lathe capability; and a construction equipment and rental-machine yard. The Nevada project is planned for completion in early 2020.
Nevada, Wisconsin Construction Equipment Manufacturer Expansion Includes Heat Treat Read More »
Steelmaker Completes Acquisition of Rebar Facilities
A steel and metal manufacturer based in Irving, Texas, which includes heat treating in the processes it provides recently announced the company has completed the acquisition of 33 rebar fabrication facilities as well as steel mills in the United States.
Barbara Smith, Chairman of the Board, President, and Chief Executive Officer of Commercial Metals
Commercial Metals Company acquired the plants from Gerdau S.A., a producer of long and specialty steel products in the Americas. The steel mills are located in Knoxville, Tennessee; Jacksonville, Florida; Sayreville, New Jersey; and Rancho Cucamonga, California.
“I am thrilled to welcome the approximately 3,200 employees of these operations to Commercial Metals Company,” said Barbara Smith, Chairman of the Board, President, and Chief Executive Officer of Commercial Metals. “The successful completion of the transaction represents an important step in our strategy to be the leading concrete reinforcing specialist as well as a significant provider of merchant and wire rod products.  With our expanded geographic footprint and added operational flexibility, this transaction supports our vertically integrated steelmaking model and will leverage our existing rebar manufacturing technology and customer service core competencies.”
Photo credit: BizJournals.com
Steelmaker Completes Acquisition of Rebar Facilities Read More »
Heat Treat Tips: Burner Tuning & Calibration – It’s Not Your BBQ Grill . . .
In today’s Technical Tuesday, we continue an intermittent series of posts drawn from the 101 tips. The category for this post is Combustion, and today’s tip is #23.
Combustion
Heat Treat Tip #23
Burner adjustment to nominal gas and air ratios is a typical component of your combustion equipment maintenance. However, this process cannot be minimized in importance as any adjustment can affect operation, efficiency, exhaust emissions & equipment life. Factors to consider and address during any burner adjustment:
  • Burner adjustment should always be done when possible at normal furnace operating temperature under typical production to maintain best conditions for final calibration.
  • Provide clean combustion air: maintain blower filter & consider the source of any plant air.
  • An increase of gas may not increase power to the system due to heat transfer or throughput issues.
  • A decrease in combustion air will not create a hotter flame or add power to the system as this may only create a gas-rich operation resulting in reduced power and CO in the exhaust.
  • Verify gas & combustion supply pressures & consider creating a monthly log of incoming pressures.
  • While a visual inspection of flame can help to verify operation or proper combustion, burner gas /air adjustment can not accurately be performed by simply looking at color or size of a flame.
  • A working understanding of burner system is important to determine and verify values to gas/air and excess O² to a specific application.
This tip was submitted by WS Thermal.
Heat Treat Tips: Burner Tuning & Calibration – It’s Not Your BBQ Grill . . . Read More »
