MANUFACTURING HEAT TREAT NEWS
BAE Systems Begins Production on First Royal Navy Type 26 Global Combat Ship
Production on the first of the new Type 26 Global Combat Ships for the UK Royal Navy began with the push of a button last month at the BAE Systems shipyard in Glasgow, Scotland.
BAE Systems welcomed Sir Michael Fallon MP, Secretary of State for Defense, to its Glasgow facility to signal the start of production following the UK Government’s recent award of a contract for the first three ships to be built in this series. This advances the work already underway to construct five River Class Offshore Patrol Vessels and provides a strong foundation for the next two decades of shipbuilding in Scotland. During his speech, the Defense Secretary unveiled the name of the first ship as Glasgow.
The Type 26 Global Combat Ship will be a world-class anti-submarine warfare vessel, replacing the Type 23 anti-submarine variant frigates, with the premier ship due to be delivered to the Royal Navy in the mid-2020s. Globally deployable, the flexible mission bay, aviation facilities, and combat systems ensure it will be capable of undertaking a wide range of roles from high-intensity warfare to humanitarian assistance, either operating independently or as part of a task group.
The ship benefits from the latest advances in digital technologies, including 3D and virtual reality, to ensure that the ship’s design is refined earlier in the process.  This has enabled BAE Systems to work in collaboration with the Ministry of Defense and the Royal Navy to ensure every zone of the ship has the requirements of its crew at the heart of the design.
BAE Systems Begins Production on First Royal Navy Type 26 Global Combat Ship Read More »
Dana to Supply Driveshaft Assemblies, Motion Systems for New York Wheel
Dana Incorporated, based in Maumee, Ohio, recently announced that it is providing driveshaft assemblies and gearboxes for the New York Wheel–which will be the world’s tallest observation wheel.  This attraction is currently under construction on the north shore of Staten Island in New York City and will stand 630 feet (192 meters) high when completed in early 2018.
The New York Wheel features 36 pods that will each hold 40 people, taking visitors on a leisurely ride with a view of the Statue of Liberty and Manhattan skyline.  Production automation company VDL Steelweld is manufacturing these capsules, and Dana is supplying driveshafts to support a leveling system that allows each pod to stay balanced as the wheel rotates.  Dana is also supplying custom-made adapters to convert the end of the shaft to fit the drive.
In addition, Dana is supplying its motion system products to engineering company Starneth for the New York Wheel project.  Thirty-two planetary gearboxes will be used to rotate the wheel.  These gearboxes are typically designed to move continuous chain-tread vehicles or other heavy machinery and feature a custom cylindrical input shaft to fit the needs of this specific application.
Dana gearboxes were also supplied for the 550-foot tall High Roller observation wheel in Las Vegas, which opened in 2014.
“When Dana was approached about the New York Wheel, we knew there would be very specific requirements for this distinctive project,” said Aziz Aghili, president of Dana Off-Highway Drive and Motion Technologies.  “Dana offers a competitive advantage with a truly global footprint that supplies specialized driveshaft solutions, power-transmission products, and support all over the world.”
The New York Wheel is expected to draw more than 3.5 million visitors annually and will be visible from the New York Harbor.
Dana to Supply Driveshaft Assemblies, Motion Systems for New York Wheel Read More »
Austal Delivers Aluminum EPF Catamaran to U.S. Navy
  Source: Light Metal Age
Austal USA recently delivered the USNS Yuma, the eighth Expeditionary Fast Transport (EPF) vessel, an aluminum catamaran, to the U.S. Navy. The 338-foot long Yuma is capable of transporting 600 tons 1,200 nautical miles at an average speed of 35 knots and is designed to operate in austere ports and waterways, providing added flexibility to U.S. warfighters worldwide.
Around 700 tonnes of aluminum in the form of plate, extrusions, and forgings is used in the construction of the Yuma. Custom panels created by friction stir welding are joined with custom extrusions using a combination of TIG and gas metal arc welding. Although no surface treatment is used above the waterline, the hull is painted below the waterline. Aluminum provides a strong weight ratio and enables Austal to produce a ship that can efficiently achieve high speeds with a shallow draft. The structure weight of an aluminum ship is approximately half that of a steel ship and is comparable to fiberglass. Other benefits of using aluminum in marine applications are that it is also easy to form, resistant to corrosion, doesn’t require paint to protect the surface, can be welded with well-established commercial processes, and is easy to repair.
Read more: Austal Delivers Aluminum EPF Catamaran to U.S. Navy
Austal Delivers Aluminum EPF Catamaran to U.S. Navy Read More »
Atmosphere Box Furnace Shipped to the Steel and Mining Industry
Lindberg/MPH announced the shipment of an electrically heated, rod over-bend atmosphere box furnace to the steel and mining industry. This is the second heat treating furnace of this kind that the customer has ordered from Lindberg/MPH. It is designed to meet the customer’s specific process based on the previous existing model they had ordered.
The atmosphere box furnace has work chamber dimensions of 15”W x 30”D x 12” H and a maximum temperature rating of 2000°F. Constructed with a gas tight steel shell made from continuous welded steel plate reinforced with structural steel members, the furnace door lifts up to provide access to the work chamber and is sealed by metal to metal contact to eliminate gasket wear and maintenance. A natural gas flame curtain is provided for the door area and is activated when the front door is opened to ignite exiting combustible atmosphere and minimize air infiltration back into the purge chamber.
“At Lindberg/MPH we pride ourselves on having the experience to design our equipment to meet the most stringent requirements. This customer’s process required the furnace to provide six different gas atmospheres. This is the second system we have shipped to them with this advanced atmosphere system.”– Kelley Shreve, Sales Representative
Lindberg/MPH atmosphere box furnaces feature:
  • Maximum gross load capacity is 465 lbs. at 2000°F
  • Six (6) different gas atmospheres including: nitrogen, hydrogen, endothermic, argon, CO and CO2
  • 460 volts, 3 phase, 3-wire, 60 Hertz
  • Door limit switch
  • HC900 Advanced Furnace Control System
  • Honeywell UDC 2500 Series Excess Temperature Controller
  • Electrical solenoid valves
  • Electronic flow control valves and moisture transducer
  • Immersion water heater
Atmosphere Box Furnace Shipped to the Steel and Mining Industry Read More »
Electro-Spec Expansion to Include Heat Treating Services
Source: SC Department of Commerce
Electro-Spec, Inc., a specialty plating manufacturer headquartered in Franklin, Indiana, announced plans to locate a new 10,000 square foot production operations in Lexington, South Carolina. The facility will be outfitted to serve the medical, telecommunications, aerospace, and automotive industries with electroplating and passivating processes, including heat treating, annealing, and stress relieving services suitable for a range of gold, silver, copper alloy, nickel alloy materials.
Process annealing capabilities go up to 1,000 °F, carried out in a protective nitrogen environment to eliminate heat scale. Parts are prepared in a specialized pre-treating process, which includes vacuum vapor degreasing and thorough cleaning.
With a customer base in North America, Asia, and Europe, Electro-Spec projects the new development will bring $3.1 million of capital investment and create 53 new jobs at the facility located at 307 Industrial Drive in Lexington. Hiring is expected to begin in Fall 2017.
“South Carolina’s reputation as a manufacturing powerhouse continues to help us attract companies from around the world. We’re proud that Electro-Spec has selected Lexington County to establish its new operations, and we look forward to watching this partnership grow in the years to come,” Secretary of Commerce Bobby Hitt said.
Electro-Spec Expansion to Include Heat Treating Services Read More »
Using Heat Treatment and Thermal Shape Memory to Tailor Nitinol to Industry Applications
  Source: AZO Materials
Nitinol’s shape memory and superelastic properties allow it to be used in a wide range of applications in the aerospace, medical, consumer technology, telecommunications, and automotive industries. In particular, heat treatment and thermomechanical processes can change the parent shape of Nitinol wire, making it indispensable for use in medical devices.  Read more: Using Heat Treatment and Thermal Shape Memory to Tailor Nitinol to Your Application by AZO Materials
Using Heat Treatment and Thermal Shape Memory to Tailor Nitinol to Industry Applications Read More »
Novelis, Kobe Steel Join Forces with South Korea Heat-Treat Facility
Novelis Inc. announced in May that it has entered into a joint venture agreement with Kobe Steel, Ltd., a producer of aluminum rolled products in Japan. The joint venture, to be named Ulsan Aluminum, Ltd., will be formed by Novelis selling Kobe Steel 50 percent of its ownership interest in its Ulsan, South Korea facility for US $315 million. Through the venture, Novelis and Kobe Steel will jointly own and operate the Ulsan facility, with each company remaining responsible for its metal supply and commercial relationships.
Located in the industrial hub of Korea, Novelis’ Ulsan facility currently focuses on the production of rolled aluminum sheet for a variety of markets in Asia. The plant recently completed a major expansion, adding a new three-stand hot finishing mill as well as a pusher furnace and annealing furnaces.
Novelis, Kobe Steel Join Forces with South Korea Heat-Treat Facility Read More »
Suit of Armor Receives Heat Treatment
  Source: Metlab
Combining the ancient craft of blacksmithing with heat treating processes, artisan Robert (Mac) McPherson obtained the finish he wanted for a suit of armor designed after a late 15th-century statue of the patron saint of firefighters. The suit was fashioned with 125 hand-formed, then hardened and tempered metal plates.
Read more: Metlab Applies Black Oxide to a Suit of Armor by Metlab Blog
Suit of Armor Receives Heat Treatment Read More »
Melting Furnaces and Twin Chamber Furnace to be Installed
Significant milestones have been obtained with the construction and installation of two 70 mt melting furnaces and the installation of a 105 mt twin chamber furnace. Air pollution control equipment is currently being installed and the pit is being prepared to accept all of the casting equipment which will be installed in 2017. This is all part of GARMCO’s remelt expansion project.
GARMCO designed the plant to meet stringent Bahraini safety and environmental regulations. The new plant will provide GARMCO with the capability to cast an additional 120,000 tonnes of aluminium slab products. Once the slabs are rolled, the finished products will exceed customer quality requirements, improve operational safety, and reduce production costs. The plant is to be fully operational by December 2017.
Fives, the turnkey construction contractor,achieved over 600,000 man hours without any lost time injuries. 2017 will be a challenging year for all personnel on this fast track project that commenced in March 2016 Commissioning of equipment is scheduled for April and the plant should be fully operational by December 2017.
Melting Furnaces and Twin Chamber Furnace to be Installed Read More »
Heat Treat Radio #7: Former Bodycote CEO Re-Enters Heat Treat Market
Audio: Former Bodycote CEO Re-Enters Heat Treat Market
In this conversation, Heat Treat Radio host, Doug Glenn, interviews John Hubbard, longtime CEO of Bodycote who retired in 2009 and has recently re-entered the market with an aggressive capital investment company located in Baltimore, Maryland. This 20-minute Heat Treat Radio interview gives you all the important news about what Mr. Hubbard and the Calvert Street Capital Partners (CSCP) are planning. To date, CSCP, under the leadership of Mr. Hubbard, have snagged top talent from the industry, including Mike Sobieski and Don Longenette, and are actively pursuing the acquisition of well-established and profitable commercial heat treat across North America.
Our aerospace, automotive, medical, and energy manufacturers with in-house heat treats will find it encouraging to hear what John has to offer.
Heat Treat Radio #7: Former Bodycote CEO Re-Enters Heat Treat Market Read More »
