MANUFACTURING HEAT TREAT
The Role of Heat Treat in Binder Jetting AM for Metals
OC
Additive manufacturing (AM) at a commercial scale began about 30 years ago and has expanded well beyond its original scope. As AM becomes increasingly prominent across different industries, heat treaters need to know how to handle AM parts in their shops. Learn about the history of binder jetting AM, the alloys used in this technology that require heat treatment, and what heat treaters should expect for the future.
Read why Animesh Bose of Desktop Metal thinks that binder jetting AM is only going to be used more and more in several heat treating sectors.
This article first appeared in Heat Treat Today’s December 2022 Annual Medical and Energy print edition.
Binder Jetting of Metals: Origins
Animesh Bose
Vice President of Research & Development
Desktop Metal
Source: LinkedIn
Additive manufacturing (AM) at a commercial scale began about 30 years ago and has expanded well beyond its original scope. At the beginning, rapid prototyping (RP) was the name for the burgeoning technology; it emerged in the 1990s to bridge the gap between the need for quickly produced prototypes for manufacturers, not just plastic replicas. Rapid tooling (RT) of metal tooling parts joined RP R&D at this time as the research frontier for materials engineers. The current name for these technologies stands at “additive manufacturing,” or AM, though the popular terminology is simply “3D printing.”
Polymers
Developments in polymer AM also advanced rapidly with both extrusion-based technology as well as through advancements in Digital Light Processing of photopolymers. Stratasys Ltd., an American-Israeli manufacturer of 3D printers, software, and materials for polymer additive manufacturing as well as 3D-printed parts on-demand, began using a material extrusion-based process with their FFF (fused filament fabrication) technology to print parts, patented in 1989. This worked by feeding coils of polymeric materials though a printer, which would extrude the material through a small, heated chamber where the material would pass through a small orifice to extrude – or print – in a three dimensional design. This method allowed for very fine, hair-like material to print in a precise X ,Y, and Z motion, building layer by layer. Vat polymerization was another polymer AM technology that gained traction and involved photopolymer processing. Both technologies are currently used for polymeric materials. Interestingly, both processes have been adapted and are being used for metal 3D printing.
Metal AM
In 1993, an MIT engineering professor named Emanuel “Ely” M. Sachs – a man who could be considered the father of metal binder jetting technique – along with his colleagues from MIT patented the process of laying fluent, porous materials in layers between 50- to 100-micron thickness to form 3D parts. They were able to do this by spraying an organic binder on each layer of material where they wanted to increase the height of the part to produce a bonded layer in the selected area. This layering is repeated several times before the unbonded powder is removed immediately or after further processing.
One of the biggest advancements in metal AM happened in 2014 when GE Aviation combined multiple parts into one huge, complex design using a laser-based additive manufacturing method called direct metal laser melting. The end result was an airplane fuel nozzle made of 20 parts for the LEAP™ engine. All of AM came into the limelight, and direct metal laser melting – a melt-based technology – just took off.
But there were limitations to this laser process, the main one being cost and special powder requirements to layer and melt to form the part. The process was also technologically intensive and not fast enough for high volume production (as would be necessary for automotive or consumer good-type application).
Binder Jetting Technology
Binder jetting that had been developing in the early 2000s started to gain traction as a non-melt-based process for high volume mass production. Instead of melting the powder material, a binder is used to adhere the powder metal layers where needed. This method of printing results in a more uniform final part microstructure compared to the melt-based processes. ExOne, a binder jet 3D printing company, pursued the binder jetting technology using a license from MIT. In 2015, Desktop Metal was formed, and they focused on high volume mass production by binder jet using their Single Pass Jetting (SPJ™) technology. As binder jet gained traction, other companies entered the market (HP, GE, and Digital Metal). Desktop Metal recently acquired ExOne and efforts at developing standards for the technology are in full swing.
Heat Treating of AM Metals
Stainless Steels
There are two popular types of stainless steel for AM. The first is 17-4 PH, a precipitation-hardened stainless steel, which I like to call an “all purpose” stainless steel. When heat treated, one can achieve varying levels of strength, hardness, and elongation; and since it’s stainless steel it has a reasonable corrosion resistance. The aging treatments are already well-established – for example, H900, H1100, etc. The other popular grade is 316L, a non-heat treatable grade used in the food industry among others. Now, most stainless steels have chromium and nickel in decent amounts, so companies have developed a grade which is called “nickel-free stainless steel” for applications where people might be allergic to nickel. This class of alloy is also heat treatable. There are many more stainless steel grades that are being developed by the binder jet process.
Low Alloy Steels
Many low alloy steels are used in AM. For example, 4140 and 4340 have various, small amounts of alloying elements. These low alloy steels also need to be heat treated.
Tool Steels
Again, most tool steels are heat treatable. One of the most popular grades is H13; it is a tool steel that is heat treatable and can achieve fairly high hardness. It’s used for dies and other types of tooling.
Then, there is a category of tool steels known as A2 and D2; those are steels in which the strength can be changed through heat treatment.
Metal Alloys with Binder Jetting
There are also non-steel alloys that are used in binder jetting and require heat treatment. One example is nickel-based alloys, which fall in the broad category of super alloys. With some of these alloys, a heat treater would solutionize the part by taking it to a high temperature (950-1000°C), hold it for 60 minutes, and then quench in water, high pressure gas, or (in some instances) in air. The part then undergoes an aging treatment for several hours, depending on part thickness.
Additionally, there is a class of copper alloys with small amounts of zirconium and chromium that is heat treatable. These alloys have lower thermal and electrical conductivity compared to pure copper but have an advantage of higher strength and hardness over pure copper, which is very soft and malleable. For example, in applications that require additional strength and hardness compared to copper, the copper zirconium-chromium-based alloys may be appropriate since their strength and hardness can be increased by heat treatment.
This is just an introduction to the many alloys that have been used in binder jetting that need heat treatment.
Future of Binder Jet and Heat Treat
While heat treaters know about AM in the medical and aerospace industries, AM will likely gain more traction in the automotive industry. Presently, these are relatively small parts, but you will begin to see larger components coming from AM; one of the things to be aware of is that AM can create organic shapes, including all kinds of twisted and complex metal geometries. To ensure that these organic shapes do not distort or droop, larger parts must be well-supported. The development of a software known as Live Sinter™ by Desktop Metal offers the possibility of negatively distorting a complex shaped part (in the green state) so that after sintering, the part shrinks and distorts to eventually provide the desired complex shape at the end. This allows for the possibility of sintering parts either with minimal or without any support structures.
Heat treaters can also anticipate high volume AM production. This is one of the major focuses for binder jet engineers – to reduce costs for most automotive parts – as it will make AM very appealing to this cost-conscious industry.
Finally, optimizing sintering processes and related equipment for AM parts will result in meeting the production demands of the industry, and this will lead to AM parts being seen in heat treat shops more regularly. It would not be a stretch to consider (since there are heat treatments where gas atmosphere quenching at high pressures is possible), that the complete heat treatment cycle may be performed in the same furnace.
About the Author: Animesh Bose is the vice president of Research & Development at Desktop Metal, where he is responsible for building out the company’s palette of materials that can be used to print quality parts. He has been involved in the area of powder metallurgy and particulate materials (PM) for more than thirty years.
For more information: Contact Animesh at animeshbose53@gmail.com
The Role of Heat Treat in Binder Jetting AM for Metals Read More »
Pennsylvania Heat Treat Furnace Manufacturer Announces Ownership Change
L&L Special Furnace Co, Inc. announced that they are under new ownership, Specialized Thermal Solutions, Inc. beginning with the new year. The manufacturing company will maintain their operations using L&L's name, with David Cunningham serving as both owner and president.
Gregory Lewicki (pictured above on the left) moved the furnace business to Aston, PA, in 1979. David Cunningham (pictured above on the right) has been with the company since December 2005. Aside from the name change, everything else about L&L Special Furnace Co, Inc., including contact info and email addresses, will remain the same. Specialized Thermal Solutions, Inc. will be absorbing all of L&L Special Furnace Co., Inc.’s order history and will continue to service any of its products.
The company will continue focusing on high-end, specialty industrial furnaces.
Pennsylvania Heat Treat Furnace Manufacturer Announces Ownership Change Read More »
This Week in Heat Treat Social Media: Christmas Edition
Welcome to Heat Treat Today's This Week in Heat Treat Social Media: Christmas Edition. So much content is available on the web, and it’s next to impossible to sift through all of the articles and posts that flood our inboxes and notifications on a daily basis. Heat Treat Today can help you filter the flood to bring you a peak at holiday happenings for heat treaters. Find some gift ideas and ways to relax over the Christmas break; Heat Treat Today is thankful for you!
1. Gifts That Warm the Heart
Don't underestimate heat treaters' creativity. A handmade knife or a piece of jewelry with heat treated sapphires will be a welcome addition under the tree.
2. Holiday Experiences
This time of year, spending time together is a great way to share the joy.
Heat treaters know that spending time with each other means good food and fellowship and ways to help others!
3.  Christmas Vacation Relaxation
How fitting that there is a recording artist with the name Heat Treat (of particular interest are tunes "Heat", "Condensers", and "Refinery Surveillance")? Kick back and relax over the break while listening to some tunes. Add some TV (ahem, Heat Treat TV) watching in the mix too, and you'll never have to go out!
4. A Few More Snippets To Extend the Christmas Cheer
"Tempering" and "Brazing" can be used at any time of year, but they seem to hold special places at Christmas! Enjoy some experiments and repairs to make the holidays bright.
"It's not Christmas until we use the brazing torch!" Need we say more?
Have a great Christmas!
This Week in Heat Treat Social Media: Christmas Edition Read More »
Cybersecurity Desk: The DFARS Interim Rule and What It Means for Heat Treaters
op-edAs the next installment in this series on cybersecurity, this third article will give you a better understanding of the Department of Defense’s DFARS interim rule and its requirements.
Today's read is a Cybersecurity Desk feature written by Joe Coleman, cybersecurity officer at Bluestreak Consulting™. This column is in Heat Treat Today's November 2022 Vacuum print edition. Refresh with part 1 and part 2 in earlier editions.
Joe Coleman
Cybersecurity Officer
Source: Bluestreak Consulting™
DFARS Interim Rule
On September 29, 2020, the Department of Defense (DoD) published the DFARS (Defense Federal Acquisition Regulation Supplement) interim rule 2019-D041, Assessing Contractor Implementation of Cybersecurity Requirements, with an effective date of November 30, 2020. These new clauses are an extension of the original DFARS 252.204-7012 clause that has been required in DoD contracts since 2018.
The interim rule implements the NIST SP 800-171 DoD Assessment Methodology and the CMMC (Cybersecurity Maturity Model Certification) framework. The interim rule requires contracting officers to take specific action prior to awarding contracts, giving task or delivery orders, or extending an optional period of performance on existing contracts on or after November 30, 2020.
DFARS 252.204-7019 Clause: Notice of NIST SP 800-171 DoD Assessment Requirements
All DoD contractors in the Defense Industrial Base (DIB) must complete a self-assessment using the DoD’s NIST 800-171 Assessment Methodology and generate a points-based score. If the self assessment score falls below 110, contractors are required to create a POAM (Plan of Action and Milestones) and indicate by what date the security gaps will be remediated and a score of 110 will be achieved as part of the Supplier Performance Risk System (SPRS). At the time of a DoD contract award containing the new 7019 clause, a DoD contracting officer will verify that a score has been uploaded to the SPRS.
DFARS 252.204-7020 Clause: NIST 800-171 DoD Assessment Requirements
Along with the 252.204-7012 and 7019 clauses, the 7020 clause is approved for use in all DoD contracts. This new clause requires that contractors provide the government with access to its facilities, systems, and personnel when it is necessary for the DoD to conduct or renew a higher-level Assessment. The higher level Assessments are the Medium and High Assessments. The self assessment conducted as part of the 7019 clause is called a Basic Assessment.
Photo Source: Bluestreak Consulting™
A Medium Assessment is conducted by DoD personnel and will include a review of your System Security Plan (SSP) and how each of the requirements are met and to identify any language that may not adequately address the security requirements.
A High Assessment is conducted by DoD personnel onsite at the contractor’s location and will leverage the full NIST SP 800-171A (Assessing Security Requirements for Controlled Unclassified Information) to determine if the implementation meets the requirements by reviewing evidence and/or demonstration such as recent scanning results, system inventories, baseline configurations and demonstration of multi-factor authentication and/or two-factor authentication.
Along with that, this rule also requires that contractors flow down their requirements from 7019 to their subcontractors and suppliers. Just as the DoD may choose not to award a contract due to noncompliance, you may not be able to use a subcontractor or supplier due to their noncompliance.
DFARS 252.204-7021 Clause: Cybersecurity Maturity Model Certification (CMMC) Requirements
Heat treaters willing to move forward with these cybersecurity initiatives by the DoD will have an overwhelming impact on the DoD supply chain and your business. If many heat treaters in the U.S. choose to not embrace the mandatory requirements, the DoD and DoD contractors will award contracts solely to the few heat treaters who do choose to become compliant. Poor cybersecurity practices can result in hacking, loss of company data and critical customer data, and attacks by malware, viruses, and ransomware. All of this can result in major damage to the business and loss of customers, not to mention being liable for all losses and paying significant fines.
Complying with DFARS 7012 and NIST 800-171 is a requirement for all DoD contractors, subcontractors, vendors, and suppliers. The DoD has now begun confirming that contractors and subcontractors are compliant before awarding additional contracts. Navigating NIST 800-171 and DFARS is a complex and challenging — but necessary — step in this process.
This DFARS clause establishes CMMC into the federal regulatory framework. This requires that CMMC is to be included in all contracts, tasks or orders, and solicitations, with very few exceptions. The level of CMMC that is required will be determined by the DoD and added into the Request for Proposal. Contractors must maintain the appropriate CMMC level for the duration of any contract and the requirements must be trickled down to your subcontractors and suppliers. The CMMC certification is required at the time of contract award.
Watch For the Next Cybersecurity Desk Installment
My next article, number four in the series, will be: “General Cybersecurity Best Practices and What You Should and Should Not Do.
Joe Coleman is the cybersecurity officer at Bluestreak Consulting™, which is a division of Bluestreak | Bright AM™. Joe has over 35 years of diverse manufacturing and engineering experience. His background includes extensive training in cybersecurity, a career as a machinist, machining manager, and an early additive manufacturing (AM) pioneer.'; Contact Joe at joe.coleman@go-throughput.com.
Cybersecurity Desk: The DFARS Interim Rule and What It Means for Heat Treaters Read More »
Heads or Tails, Philadelphia Mint Wins by Upgrading Heat Treat Furnaces
HTD Size-PR LogoThe Philadelphia Mint recently began a round of upgrades for its heat treat furnaces. Their function in the minting process is to anneal, clean, and dry the coin blanks to soften the metal prior to striking into coins, extending the service life of the striking dies.
SECO/WARWICK Group’s American subsidiary, located in Meadville, PA, recently began upgrades, a refurbishment of all five of the Philadelphia Mint’s heat-treating furnaces, one furnace per year. The heat-treating furnaces were originally installed there by SECO/WARWICK USA from 1994 through 2000.
All five furnaces are 4000 pound per hour rotary retort furnaces outfitted with a quench system, as well as a hopper feeder, a batch burnish barrel, and a batch/continuous drum drier. The furnaces are showing their age after a quarter century, so rather than nickel and dime the maintenance, the mint opted for a comprehensive refurbishment.
“Our Partner has plenty of coin to heat-treat, but they don’t have any to burn," commented Marcus Lord, managing director at SECO/WARWICK USA. "These waste-heat recovery and combustion efficiency upgrades are going to save them a mint while cutting carbon and NOx emissions nearly in half."
The small letter at the nape of Washington’s neck in the coin image above is a mint mark.  The “P” indicates that the coin was struck at the Philadelphia Mint.
Source: SECO/WARWICK Group
To reduce energy consumption, the Mint is replacing insulation, roof panels, and radiant tubes as well as upgrading the loading systems. More energy efficient burners are being installed, along with recuperators to preheat the combustion air, to improve energy efficiency and use less natural gas. Mechanical improvements include replacing drive motors and two-speed gear boxes. The retort can over-heat and warp if the rotary retort unexpectedly stops before the cool-down cycle. As a failsafe, SECO/WARWICK added a pneumatic backup motor that can run the gear box off the Mint’s compressed air reservoir during a power outage.
The mint was established by the Coinage Act of 1792, when Philadelphia was the nation’s capital. It was the first public building constructed under the direction of the recently formed United States government. The machinery was powered by a horse walking circles in the basement.
Heads or Tails, Philadelphia Mint Wins by Upgrading Heat Treat Furnaces Read More »
Heat Treat Radio #86: Looking Ahead to Thermprocess 2023 with Timo Würz
As 2022 comes to an end, we’re taking this episode to look forward to what North American heat treaters can expect in the largest trade show for heat treaters anywhere: THERMPROCESS 2023. Doug Glenn, publisher of Heat Treat Today and Timo Würz, managing director at VDMA Metallurgy and General Secretary of The European Committee of Industrial Furnace, Heating and Metallurgical Equipment Associations (CECOF) talk about what attendees and exhibitors should expect and several of the hot topics in manufacturing that will be guiding this event.
Heat Treat Today is cancelling the North American Exhibitor Group. Please disregard the comments in podcast above or transcript below referencing this.
Doug Glenn (DG):  Welcome to another episode of Heat Treat Radio.
DG:  Let’s talk about this. I know you are involved, in your capacity, with VDMA and CECOF and things of that sort with the THERMPROCESS event which is coming up in June. For people who might not know what THERMPROCESS is, can you give us a 30,000-foot view of the event?
Timo Würz
Managing Director at VDMA Metallurgy
General Secretary of CECOF
Source: LinkedIn
Timo Würz (TW):  THERMPROCESS is the world-leading tradeshow for the thermal processing industries. And it’s not just one show -- THERMPROCESS is part of a tradeshow quartet. It’s four shows, and they are all about metallurgical equipment, metallurgical processes, thermal processing, foundry equipment, foundry applications. All of these topics are very much connected one to the other, and that makes it a really big show. It’s not just this little part of industrial furnaces and burners, but it’s imbedded in a huge metallurgical environment. That’s the reason they call this exhibition “the bright world of metals.” You’ll find there any kind of thermal applications. If you want to process glass or ceramics, you'll find the respective equipment there. This is the larger context of this show.
It's really huge. The 2019 edition that was more than 73,000 visitors in Düsseldorf, more than 2,300-something exhibitors on all the four tradeshows. For the THERMPROCESS alone I think it was about 340-350 exhibitors and about 6,000 visitors only for the show, not taking into account all the others coming from GIFA show or the METEC show which are the other shows. So, there are a lot of symmetries between these shows, and you see really everything that has something to do with thermal processing -- with equipment, with applications- it’s really a big thing.
DG:  You and I both have probably been to the THERMPROCESS since early on, maybe its beginning. I’m not sure when the first show was, but I know the first one I attended was in 1999. It was quite an event, even then.
I want to give our listeners and viewers a sense of the enormity of it. You’ve been to some of the North American shows. I don’t know if you’ve been to one of the larger shows in Chicago like the IMTS. It’s probably one of the larger metal shows in the United States. My contention is, and I wonder if you’d agree with this -- McCormick Place, where the IMTS is held, the campus on which the quartet of shows, as you say, is being held, is probably four to five times the size of an IMTS show. I don’t know if you’ve got that comparison or not, but it’s much larger than any other North American show I know of.
TW:  I know IMTS quite well because I’ve been there many years ago when I was working for the machine/tool industry. That is really a big show in the United States. I think the FABTECH is about the same size or even a little bit bigger than IMTS. I would say, maybe THERMPROCESS and the other three tradeshows are even a little bigger. I don’t know if your readers know the exhibition crowds in Düsseldorf, but they are quite huge. I think it’s the second or third largest exhibition area in Germany. The four trade shows, they really occupy all halls at the exhibition center. So, 73,000 square meters -- that is about 150,000 cross square meters, so 33,000 is only the net square meters. If you take all of the other areas together, it’s really a huge exhibition area. Still, the comparison is not too bad -- it compares to the big shows in the United States in other industries.
DG:  Yes, I think so. I tell people, when I try to give them a sense of the size of the campus that the Düsseldorf Messe. If you were to start on one end and just walk at a normal rate, it would probably take you 15-20 minutes to walk from one side to the other which, fortunately, we don’t have to do too much.
The dates of the show?
TW:  It’s June 12-16, 2023, in Düsseldorf.
Düsseldorf, Germany
Source: Unsplash.com
DG:  Which is a great time of year in Düsseldorf. It’s a lovely, lovely place, so I would encourage people to go.
Let’s talk about some of the trends, the international trends in thermal processing. From your perspective, what are some of those international trends, international things that are happening now that people will be able to learn about and hear about if they do come to THERMPROCESS?
TW:  There are a lot of things going on at the moment: there is the whole sustainability greenhouse gas reduction discussion going on. That is certainly going to be reflected at the show. There is digitization which is a very important issue for all industries but also for the metallurgical industries and the thermal processing industries. It gives you some new benefits you can offer to your customers, or you can benefit from in your product development. So, that’s a huge topic.
There is additive manufacturing that gives you completely new opportunities on how to produce certain parts for your equipment or how to replace a traditional technology. Think about replacing a casting by a part that is produced with additive manufacturing. Finally, the part is the same but the production process is completely different. There is a very interesting competition now between different production technologies coming out. That will be shown there and many, many others.
We could go into very specific details like new types of communication between machines and management systems or between different kinds of machines, and really a lot of interesting developments -- artificial intelligence, machine learning -- that all helps to optimize your process and your equipment, so that’s really an amazing development going on.
DG:  I’ve got a question for you:  I know you are kind of on the inside track with the whole Bright World Metals and Messe Düsseldorf, the organization that puts this on. Do you think that some day in the future they will add a fifth show on 3-D printing? There are a lot of metals going on here, right?
TW:  That is a very good question. I don’t know because there are still other exhibitions for 3-D printing and additive manufacturing. Maybe not necessarily a new show, but it is certainly becoming a permanent part of the existing show. One or the other place will really highlight that additive manufacturing maybe without having a fifth show to do it.
DG:  I think it would be interesting! We’d have to figure out instead of being a quartet, it would have to be a quintet, or something.
Let’s talk a little bit about the electrification. Let’s dig a little bit deeper into the electrification. What are you seeing there? I know, right now, you’re sitting in Florida, with tropical storm Nicole in your background. Is that the name?
TW:  It’s Nicole.
DG:  You’re sitting there in Florida, but I know you’re typically out of Germany. What are you seeing, Timo, there in Germany, regarding electrification and the move away from greenhouse gas, let’s say?
TW:  That is a good question but difficult to answer question. Electrification is not really new. There are well-established processes which are already electrified. Think about induction heating or melting or electric arc furnace. That is all electrified heating equipment, so that is not really new.
The important question is, how many other processes could be replaced by electrified processes? Now, I mean such processes where you burn fossil fuel, for example, natural gas. That is really the point when it comes to greenhouse gas mitigation -- you want to get rid of greenhouse gases, and usually they are emitted when you burn something. From a physics point of view or an engineering point of view, electrification is great because it has a very high efficiency. Turning electricity into heat has a very high efficiency, much better than burning something and generating heat from burning fossil fuels.
The problem is -- think of a reheating furnace in a steelworks. In terms of energy consumption, which has to be called a monster because a reheating furnace in a steelworks consumes per hour as much energy as a jumbo-jet flying from Europe to the U.S., each hour. And now, try to imagine how to electrify such an application. At the moment it’s hardly conceivable that you can really replace that existing equipment by something that is electrified. You have the same energy density that is needed to get the process done. That is very difficult. You really come to technological limits.
I don’t say you can’t overcome them in the future; but at the moment, it is just not possible. But you have to see which processes are possible, and those which possible should be electrified. And for others, you have to accept maybe you need a hybrid concept -- electrical heating and conventional burner, or you have to accept that you have to burn something. In the future, maybe that will be green hydrogen. So, there are different roots.
Finally, green hydrogen is another form of electrification because you need electricity to produce green hydrogen. When you bring that all down to one point, it’s only a question of -- are you able to generate a sufficient amount of renewable energy? It’s not a question about the thermprocess aspect, it’s more or less a question about the generation of enough renewable energy so that it’s about wind energy, it’s about solar power, etc. If there’s enough renewable energy, I would say everything can be electrified or everything could be supplied with green hydrogen. That is not the main problem. The main problem is the availability of enough renewable energy.
DG:  I think our listeners would be interested in your perspective just on this one little issue: I know one of the drivers in Germany for electrification is the fact that you’re getting your gas supply cut off by friends to the East. I’m curious, how is it there in Germany with the lines being cut? The pipes being cut?
TW:  It’s really challenging. To be honest, we were used to having a cheap energy supply from Russia, cheap gas from Russia that was the fuel for a lot of parts of our life -- for industry, for private heating, and everything. So, that’s gone now. Now, we have a completely different situation. At the moment, fortunately, all our gas storage is full so we were able to fill them very quickly at very high cost because we had to buy all the gas, wherever we got it, and had to pay really insane prices.
So, maybe that might not really push electrification because, at the moment, a good part of our electrification strategy was based on burning natural gas as a kind of transition technology. Now that’s gone and we have to reactivate all the power plants which are already phased out. Now we reactivate the coal-fired power plants in order to have enough electricity. So, we have a big discussion about nuclear power because we phased out already most of our nuclear power plants. There are only three running. How long they can run to maybe support energy production?
On the other hand, we’ve seen friends that more than 50% of their nuclear power plants, at the moment, are not working either because they have technical problems or because the French rivers don’t have enough water due to the drought. You need the cooling water for the nuclear power plant. At the moment, we have to export electricity to France; usually it’s the other way around.
DG:  That is very interesting. I didn’t realize that. I knew there was quite the drought, but I didn’t realize that that had an impact on their nuclear power production.
TW:  Yes. At least in France, it is very bad. The whole situation is somewhat strange, at the moment. My personal opinion is that it will help us to transform our energy system much faster than we already tried to do. That is really something pushing us in a completely new direction. I think the renewable power generation will really get a boost because we don’t have that many alternatives. We have to rely on I don’t know how many ships from the U.S. bringing LNG or from Qatar or some of these places. It is a challenging situation but I think it will help to transform the whole system much faster.
DG:  We have a saying, and you may have something similar in Germany, but they say, “necessity is the mother of invention,” meaning, if you’ve got to do something, you figure out how to do it, right? You invent something to be able to do it. Such is the case with the power situation there in western Europe, for sure.
Well, we wish you luck on that.
Let’s talk a bit about digitization or the internet of things and things of that sort. Tell me what people will possibly see, if they go to THERMPROCESS in regard to digitization and IIoT.
Source: Thermprocess-online.com
TW:  I think digitization is not a trend anymore. It’s a reality and it’s a necessity for all companies. You can’t do any business without thinking about how to digitize certain aspects of your business. It helps on different levels. First of all, it is, of course, a great help to optimize processes. Think of using, for example, machine learning or artificial intelligence or whatever you might want to call it. You can generate optimized furnace recipes for heat treating processes, for example, which were then based on the knowledge of people, in the past. And they were quite good, but now you reach new levels of optimization just using these digital solutions or the transformation of data communication. You get a complete new level of transparency of what is going on in your system because every part has an IP address and can tell you what its stage is, what it’s doing, and what is maybe a problem. So, you have a complete new transparency of your processes of your equipment that you can transfer easily to management systems. You can base decisions on such data which then becomes information and that is something that really improves the overall equipment efficiency very much. That is a really big benefit for the customers.
Digitization is also the way towards new business models. So, having all your equipment, all your processes as a part of, let’s say, a digital or data ecosystem, it allows you to offer completely new products. For example, apps that help your customer to do the scheduling of the production or to allow you to have paper production concept or maybe helps you to do predictive maintenance and all those things. I think you will see all of this at the THERMPROCESS and the other three trade shows next year because, I would say, most of the companies, be it small or be it big, they  have such digital solutions now and they will show it in all different aspects and types of application.
DG:  Along that line, shifting gears just a little bit on this, one of the issues that we’re experiencing here in the United States is labor shortages and things of that sort. I don’t know if that’s exactly the same in Germany, but let’s assume that it is. How about automization and the use of robotics? Are you seeing anything along that line there, and do you anticipate that people would see some solutions or some ideas along that line if they were to come to THERMPROCESS?
TW:  Yes, we do have the very same problem. Finding young people, finding skilled people who are able to do their jobs in a highly sophisticated, industrial environment is terribly difficult. We have many, many jobs where we can’t find people for. Not the low wages jobs, but highly qualified jobs that require a lot of training. It’s exactly the same problem you have in the United States. And automization is maybe one aspect of overcoming that problem. Of course, a lot of companies do invest in automization, they do invest in robotics. Maybe not in the thermal processing industry. Robotics there is maybe different from what we maybe think of when we hear robotics like in automotive assembly, when you see maybe 2,000 robots working in a coordinated way, assembling a car structure. But any kind of automization that helps to overcome labor shortages being manipulating heavy pieces.
DG:  I think of fixturing and racking, right? I mean, that’s a heavily labor-intensive process, even if it’s small parts? Taking 100 parts and putting them in a rack so that they can be heat treated -- I think automization.
TW:  Yes. So, if you don’t find the people to do that, you certainly will have automization. You find all the big robotic companies and the automization suppliers on the four trade shows, especially in the foundry environment -- there is a lot of robotics. So, robotics manufacturers like KUKA, ABP and Fanuc, they are all there. They will show their special applications for the metallurgical sector. There is certainly a lot to see at the THERMPROCESS and the other three shows.
DG:  So, you and I both know that at THERMPROCESS and GIFA and METEC and NEWCAST, that it’s not all business. There is a little bit of enjoyment beyond business that goes on there. It’s also a little bit of fun on the show floor, but I would like your personal opinion: What do you enjoy about Düsseldorf? What is there for those people who would want to come over and do more than just work? What is there to see?
TW:  First of all, it’s taking place in summer and usually, at least the last two or three editions, we had really  nice weather. That helps a lot to get people in a good mood. Düsseldorf is a particularly nice city. It has an old part, Düsseldorf Altstadt, where you’ll find these typical restaurants and these typical Düsseldorf pubs where you get this special beer. That is really a place where people just meet and have fun. So, after the show you can go there and just have fun. You can talk business of course, if you like, but you can just have fun, drink a beer, sit at the banks of the Rhine river. The people are nice people. The people from the Rhineland, they are known as nice people. They have a good sense of humor so it is really a good place to come, do business, but also do anything else but business. It is a good place to be in June. There is plenty to do, and it’s a good place to have a lot of fun.
DG:  And it’s easy to get around, I must say. At the Messe or the fairgrounds, where the show is, the trains pull right in. They’re more like trolley trains, not necessarily subway trains, but it’s kind of what we think of in the United States as subway cars- they pull right into the Messe there. It’s easy to get on, it’s easy to get off. It’s 10-15 minutes to downtown. There is some great shopping for any of you ladies, or men if you’re a shopper, that you can easily take a walk down Königsallee which is a beautiful shopping place there and the Altstadt as you mentioned- all pretty much, which I think is nice, depending on where you stay in Düsseldorf . If you’re in the downtown area, it’s all relatively, if you’re in decent shape, in walking distance. You can walk it. I walked from the Bahnhof all the way over to Altstadt. You can do it; it’s not undoable.
TW:  That is all within walking distance, yes. And, if not, you can take the tram or the subway and it takes you 15-20 minutes, and you’re right in the center. Even if you want to go a little further- all the other large cities around are very well connected by this public transportation system. Never use a car in this area -- that is bad. In terms of traffic, if you are in a car, it’s a mess. Use the public transportation, and it’s wonderful because it connects all cities. You can easily go to Cologne, you can go to all the other cities around. It’s very easy.
DG:  In the past, they’ve had a bit of a technical program associated. Are they having that this time?
TW:  Yes, of course.
DG:  If you don’t mind, tell us a  bit about what you know about that technical program.
Be a Part of the Show!
TW:  At THERMPROCESS, there is going to be the THERMPROCESS forum -- what was the THERMPROCESS symposium, in the past. It’s a kind of 2-day presentation program right in, I think, Exhibition Hall #9, so where the THERMPROCESS really is, where we have a two days with program presentations from exhibiting companies showing their innovations or showing new solutions, new applications.
We’re going to have at the first day, a special program that will try to dive a little bit deeper into the energy transition -- how the energy system will transform in the future. That is more from a scientific point of view, a political point of view, but nevertheless very interesting. Then we have the company presentations, and we are going to have the ‘tech talks.’ On Thursday, we are going to have the ‘tech talks.’ Originally, it was an online forum, but there we transfer it to the exhibition. So, three companies are giving presentations in a frame of a specific topic. They all build thematically on the other presentations so you see a whole picture of one specific topic. That is going to happen.
And there will be, of course, the foundry related events. There is going to be the ESTA that is the European steel technology application day. That is a very big event with seven hundred sessions over the whole exhibition. That is for the metallurgical people, so for the steel producers.
DG:  Good. That’s great. I thought that was going on but I wasn’t sure and I just wanted to confirm.
Timo, I thank you very much. I appreciate you taking the time to help us understand what might be going on at THERMPROCESS. Thanks very much for joining us.
TW:  It was my pleasure, thank you.
Publisher
Heat Treat Radio #86: Looking Ahead to Thermprocess 2023 with Timo Würz Read More »
Steel Sustains
OCThe American steel industry is the cleanest of the leading steel industries in the world. Of the major steel-producing countries, the U.S. has the lowest CO2 emissions per ton of steel produced. By contrast, Chinese steel production creates carbon emissions that are nearly twice that of the U.S. per ton of steel produced. The global steel industry contributes 8% of total world greenhouse gas (GHG) emissions, whereas the U.S. steel industry only accounts for 1–2% of total U.S. GHG emissions.
Read why  Kevin Dempsey of American Iron and Steel Institute thinks that America is doing so well with decarbonization.
This article first appeared in Heat Treat Today’s November 2022 Annual Vacuum print edition.
Kevin Dempsey
President and CEO
Source: steel.org
There are several reasons for the American steel industry’s leadership in decarbonization. A key factor is that the American steel industry has adopted electric arc furnace (EAF) technology at a much more accelerated rate than the global industry. Nearly 71% of the steel produced in the U.S. in 2020 was from EAFs, compared to only 26% globally.
In addition, the American steel industry operates blast furnaces that are among the most carbon efficient in the world. Integrated steel mills in the U.S. are almost entirely fed by domestically sourced iron ore pellets compared to CO2 -intensive sintered ore used in China and elsewhere. This results in significantly lower emissions of CO2, as well as lower emissions of NOx, SO2, and particulate matter.
Also, the emissions factors associated with the energy mix used for steelmaking in the United States are lower than in other steel-producing locations in the world, with much more reliance on natural gas and renewable energy. This cleaner energy mix helps produce steel with the lowest CO2 emissions. The American steel industry is continuing to invest in clean energy to provide the electricity needed to run our mills — a number of steel producers in the U.S. have announced several projects that employ renewable energy to supply all or most of specific facilities’ energy requirements.
The steel industry in the U.S. also continues to make other key investments to further decrease its carbon emissions and advance its leadership position on sustainability. For example, American steelmakers have made investments to increase the use of direct reduced iron (DRI) and hot briquetted iron (HBI), which can lower emissions for both integrated blast furnace-basic oxygen furnace steel mills and EAF steel mills. Additionally, new DRI and HBI facilities are being designed and have recently been built to be hydrogen-ready once clean hydrogen is available on an industrial scale and commercially viable.
Steel is a critical component in the continued development of all clean energy technologies to reduce America’s carbon footprint. According to a recent study by McKinsey & Co1, steel is the only material critical to all low-carbon technologies. Wind, solar, and tidal renewable energy systems, zero emission electric vehicles, electric grid transmission, hydrogen production, and carbon capture systems all highly depend on steel. For example, steel comprises over 70% of the weight of a typical wind turbine. Grain oriented electrical steel (GOES) is a critical and irreplaceable material used in the production of power and distribution transformers that will be necessary for the greening and modernization of the domestic electric grid. American non oriented electrical steel (NOES) is used for electric motors, including those that will power the growing electric vehicle market.
The American steel industry and  its construction partners have also proactively and voluntarily published verified Environmental Product Declarations, which report the carbon footprint and other potential environmental impacts for nearly every steel construction product available in the marketplace today. Furthermore, when steel construction products have outlived their current intended use, they can be recycled into new steel to be used for any variety of new products. Today’s steel beam can become tomorrow’s refrigerator, soup can, or car door.
Sustainable steelmaking is the American steel industry’s number one commitment — for our customers and all Americans. Our entire industry is continuing to make key investments and innovations to further decrease carbon emissions and advance our leadership position on sustainability.
About the Author: Kevin Dempsey is the president and chief executive officer of the American Iron and Steel Institute, a leading advocacy group representing electric arc furnace and integrated American steel producers. He previously served as senior vice president of public policy and general counsel to the Institute, during which AISI achieved landmark policy successes on trade, tax, and infrastructure, and successfully showcased the steel industry’s sustainability accomplishments and steel innovations in the automotive and construction markets.
For more information: www.steel.org
References:
[1] Marcelo Azevedo, Magdalena Baczynska, Patricia Bingoto, Greg Callaway, Ken Hoffman, “The raw materials challenge: How the metals and mining sector will be at the core of enabling the energy transition,” McKinsey & Company, January 10, 2022, www.mckinsey.com/industries/ metals-and-mining/our-insights/the-raw-materials-challenge-how-the- metals-and-mining-sector-will-be- at-the-core-of-enabling-the-energy- transition.
Steel Sustains Read More »
Improving Your Use of Radiant Tubes, Part 2
op-edLast month, we introduced the importance of radiant tubes in the heat treat industry. We explored the “why” of radiant tubes and skimmed the surface, exploring materials, sizing, shapes, longevity, and installation — all topics we’ll deep dive into in future posts. This month, let’s explore what typically occurs inside a radiant tube.
This column is a Combustion Corner feature written by John Clarke, technical director at Helios Electric Corporation, and appeared in Heat Treat Today's December 2022 Medical and Energy print edition.
If you have suggestions for topics you’d like John to explore in future columns, please email Karen@heattreattoday.com.
John B. Clarke
Technical Director
The radiant tube burner combines fuel and an oxidizer (commonly air) in the presence of a source of ignition. Radiant tube burners differ from burners that are fired into an open furnace. They function to distribute heat as uniformly as possible within the interior of the tube to maximize its temperature and heat transfer uniformity. In some applications, a low rate of heat transfer is acceptable (for example, in the holding zone of a continuous furnace). In that same furnace, a much higher heat transfer rate may be required in the front of the furnace. In all cases, higher heat  transfer rates result in higher internal tube temperatures. In most cases, the higher the temperature, the greater the stress on the material.
Within the radiant tube in the visual flame region, the energy is transferred to the inner surface of the tube by convection and radiation. The rate of convective transfer has much to do with the mixing characteristics of the burner in question. Once combustion is complete, the heated products of combustion — CO2 , O2 , H2O, and N2 — continue to flow through the radiant tube. They impart heat to the interior surface of the radiant tube through convections and — in the case of the CO2 and H2 — radiation. The non-polar gases (O2 and N2) are effectively transparent to radiation: neither absorbing nor radiating heat. This transparency poses a problem for the performance of radiant tubes because the combustion process is ideally complete some distance before the end of the radiant tube.
There are a few ways to make use of the heat stored in the O2 and N2 . One way is to stir the mixtures to ensure these gases meet the inside walls of the tube and can convectively transfer their energy. Another way is to insert a “core buster” or other device into the exit end of the radiant tube. This device must be able to withstand the peak temperature of the products of combustion at this point, so it is typically constructed of some ceramic material or a composite of ceramics. As the heated gases pass over this “core buster,” the resistance forces higher flows around the perimeter of the tube, increasing convective transfer. The “core buster” also is convectively heated and can then radiate heat to the inner surface of the tube and, finally, the “core buster” increases mixing of the gases to ensure all remaining hydrocarbons and carbon monoxide are brought into contact with oxygen to complete the oxidation process.
The transfer of heat to the inner surface is dependent on the effective surface area. A tube with a nominal inside diameter of four inches may have a much greater effective surface area due to roughness, which resemble very small peaks and valleys. Anyone who has attempted to walk around a small Caribbean island can attest — it takes a lot longer than you would think by looking at the map and really scares your shipmates when they cannot find you. Cast and composite radiant tubes can be fabricated to increase this effective internal surface area. Tubing can also be equipped with internal fins.[blocktext align="left"]No matter what the construction, ultimately it does no good to transfer heat to the interior of the radiant tube if the tube cannot transfer the same quantity of heat through the exterior to the furnace and work being heated.[/blocktext]
Which mode of control is better? High/Low, proportional, or pulsed? Any method can achieve a uniform tube heat release given the correct burner radiant tube combination. The important thing is that the vigor of the mixing is matched to the length and roughness of the radiant tube. Burner X may be perfectly suited to a short radiant tube but lead to non-uniform heating as the tube length is extended. On the other hand, Burner Y, with a relatively lazy flame, may work perfectly on long tubes with lower heat transfer demands but be unsuitable for short tubes where high heat transfer rates are desired.
In the coming months, we will examine many of these areas in greater detail, and this author can make use of his experience of many failures to inform the readers of what not to do. Then, by extension, we’ll learn how to get more from the furnaces by thinking systematically about their radiant tubes, burners, and controls.
Improving Your Use of Radiant Tubes, Part 2 Read More »
Heat Treater Expands with Vacuum Furnace
HTD Size-PR LogoA Swiss commercial heat treater ordered a vacuum furnace. A system will increase the production capacity of their nickel and silver brazing processes.
Maciej Korecki
SECO/WARWICK
The SECO/WARWICK vacuum furnace helps with hardening larger size parts and significantly increases the efficiency of the current hardening plant. The furnace increases production. In the version ordered by the Swiss, a large working zone (36"X36"X48") with the potential to adjust to an oversized load utilizes the advantages of a round heating chamber.
“[With a] cooling capacity of 15 bar, it is possible to process parts that require very fast cooling . . . . Vector also allows the system to perform more difficult brazing processes with either nickel or silver," explains Maciej Korecki, vice president of the Vacuum Furnace Segment, at SECO/WARWICK Group. "This is our second installation with this partner. Previously, we delivered a solution from the SECO/WARWICK furnace family of a similar size, in a non-pressurized version."
Heat Treater Expands with Vacuum Furnace Read More »
Firearms Manufacturer To Receive Furnace To Heat Treat Aluminum
HTD Size-PR LogoA leading firearms manufacturer ordered a continuous conveyor furnace from a Wisconsin furnace supplier. The oven will be used for heat treating aluminum parts prior to quenching.
Industrial Conveyor Furnace
Source: Wisconsin Oven Corp.
Mike Grande
Vice President of Sales
Wisconsin Oven
This industrial conveyor furnace has a maximum temperature rating of 1,110°F and interior chamber dimensions of 4’2” W x 30’ L x 1’ H. The parts are manually loaded onto the flat wire belt conveyor and transported through both zones of the oven. The recirculation system utilizes two 56,000 CFM blowers, and the furnace is equipped with a performance monitoring system that collects information from predictive maintenance sensors.
“[W]e provide custom design solutions to meet each of our customer’s unique requirements," commented Mike Grande, vice president of sales at Wisconsin Oven Corporation. "This conveyor furnace was designed to sit at an incline which allows for the quench tank to fit under the conveyor discharge end.”
Firearms Manufacturer To Receive Furnace To Heat Treat Aluminum Read More »
