VACUUM FURNACES NEWS
Heat Treater To Sharpen Their In-House Operation
HTD Size-PR LogoA manufacturer of machining tools, industrial knives, mulching knives, and chippers has placed an order for a vacuum furnace with 10 bar high-pressure gas quenching. It will be used for tool steel hardening and tempering processes.
The furnace on order, the Vector® -- a furnace from North American SECO/VACUUM and the international SECO/WARWICK -- has been adapted to match the Czech manufacturer's needs: SECO/WARWICK engineers have designed a 600 x 600 x 1800mm work space. The device modification was implemented to fit the long and straight characteristic shape of the workpieces. The unit was also equipped with a directional cooling option to effectively cool down long and thin knives that, a shape that's prone to distortion during the hardening process.
The application for the device required an inverter that enables complete control over temperature at every stage of the hardening process to reduce distortion. Together with the additional option of directional cooling and the convection system, the system design helps to reduce the undesirable distortion significantly.
Heat Treater To Sharpen Their In-House Operation Read More »
Aerospace Industry Chooses Vacuum Heat Treat Solution
HTD Size-PR LogoA Chinese company has ordered a horizontal vacuum furnace which will help in producing highly specialized cast parts used in the aerospace industry. Delivery of the furnace is scheduled for June 2022.
The Vector® horizontal vacuum furnace with a graphite chamber and a gas quenching system comes from SECO/WARWICK. This type of furnace from the international manufacturer comes with a graphite hot zone and can be used for most standard hardening, tempering, annealing, solution heat treating, brazing, and sintering.
The furnace will be installed in a facility that specializes in the production of high-temperature alloys used in the aviation, shipbuilding, and power industries, offering a wide range of products, including but not limited to, bars, wires, bands, pipes, and specialized castings.
Find vacuum furnaces for brazing when you search the Heat Treat Buyers Guide.com
Aerospace Industry Chooses Vacuum Heat Treat Solution Read More »
Michelin Acquires New Vacuum Furnace
HTD Size-PR LogoMichelin, a European tire manufacturer with technology centers in the U.S., will receive a new vacuum furnace from a global supplier with locations in North America. Tire manufacturing requires specialized tools; tools and dies used in production are heat treated in vacuum furnaces. The furnace, with a 16" x 16" x 24" heating chamber, will be used for gas hardening and will remove the need for third-party hardening.
Maciej Korecki
SECO/WARWICK
Michelin will receive a SECO/WARWICK Vector® vacuum furnace, enabling efficient hardening processes with the use of high pressure and cooling gas. “With a relatively low expenditure," explains Maciej Korecki, vice president of Business, Vacuum Furnace Segment at SECO/WARWICK, "the compact Vector vacuum furnace makes it possible to become independent from third parties. It also provides better control over the quality of heat-treated components and reduces the risk of delays which, as a result of lack of deliveries, slow down or obstruct manufacturing processes (tire manufacturing in this case)."
Michelin Acquires New Vacuum Furnace Read More »
Solar Atmospheres of Souderton, PA Adds Furnace for Titanium Reclamation
HTD Size-PR LogoSolar Atmospheres Souderton, PA incorporated a high-production vacuum furnace with a work zone of 48″x48″x72″ and a weight capacity of up to 7,500 lbs/batch. The furnace doubles the facility’s hydriding and de-hydriding capacity in the reclamation of titanium and tantalum materials.
Solar Atmospheres Souderton, PA installed the furnace with Solar Manufacturing’s vacuum furnace technology. The technology is aimed at safety and efficiency and will help in the reclamation process.
Solar Atmospheres of Souderton, PA Adds Furnace for Titanium Reclamation Read More »
MIM and AM Client Pleased with Retrofit Sintering Vacuum Furnace
A retrofitted vacuum furnace will now produce more metal injected molded (MIM) components with considerably less downtime.
In 2021, a North American heat treater, Solar Atmospheres of Western PA, retrofitted a vacuum furnace for use in a new metal injection molding (MIM) and additive manufacturing (AM) binder removal technology application. The goal was to build a vacuum sintering furnace with a new innovative hot zone and pumping technology that would minimize and target the deposit of detrimental binders evaporating out of MIM and AM parts.
Source: Solar
Robert (Bob) Hill, FASM
The hot zone, after a month of repeated 2400°F sintering cycles, remains clean. The problematic binders coalesced at the targeted area within a separate heated pumping port while keeping the primary pump and booster uncontaminated. Most importantly, the client reported that their sintered parts processed in this new furnace never looked better. The MIM parts were extremely bright and met their critical density and dimensional requirements.
The heat treater anticipates considerable maintenance savings on this dedicated furnace versus processing sintering and AM work with binders in a traditional vacuum furnace. Working in a traditional furnace meant added labor and material costs coupled with the lost production time and degradation on the life of the hot zone, which cost the company more than $180,000 per year. The projected maintenance costs on this newly designed sintering furnace will be $10,000 per year.
"Knowing the effects," reported Bob Hill, president of Solar Atmospheres of Western PA, "of what MIM and certain AM processing had done to our equipment in the past, Bill Jones and the engineers at Solar Manufacturing developed an innovative solution for us. Having this newly designed vacuum furnace will be an asset for our future in MIM and AM processing."
MIM and AM Client Pleased with Retrofit Sintering Vacuum Furnace Read More »
Vacuum Nitriding Furnace for North American Captive Heat Treater
ZeroFlow® nitriding furnace
A North American-based manufacturer of helicopter masts, turbine shafts, engine thrust links, and nuclear components with in-house heat treating will receive a customized vacuum tempering/gas nitriding furnace. The furnace will be used for nitriding and nitrocarburizing loads up to 63" diameter x 175" deep and has a load capacity of 13,200-lb.
Peter Zawistowski Managing Director SECO/VACUUM TECHNOLOGIES, USA Source: secowarwick.com
The manufacturer ordered the custom-made pit nitriding furnace from SECO/VACUUM to increase load capacity. In addition to being able to process oversized workloads, the furnace, with an almost 80% increase in size from the standard, has a working temperature range of 300°F–1,300°F, a temperature uniformity of +/-5°, and low ammonia consumption.
"We are very pleased to collaborate with this precision manufacturer to enable new state-of-the-art nitriding and nitrocarburizing capabilities in their Canadian facility," commented Peter Zawistowski, managing director of SECO/VACUUM.
Vacuum Nitriding Furnace for North American Captive Heat Treater Read More »
Captive Extrusion Die Maker Levels Up With 11 New Furnaces
Peter Zawistowski
Managing Director
An international extrusion die maker with in-house heat treating is set to modernize its gas-fired combustion technology with eleven furnaces at three U.S., Canada, and Mexico locations. The upgrade: new vacuum, nitriding, and tempering furnaces that will increase consistency and precision nitriding potential and reduce gas emissions.
SECO/VACUUM will deliver four Vector® single-chamber gas quench vacuum furnaces, six tempering furnaces, and one ZeroFlow® pit-type gas nitriding furnace for use in the aluminum extrusion industry.
"This is a big deal for the customer," said Peter Zawistowski, managing director of SECO/VACUUM.  "They’ll benefit from a complete modernization of their heat treatment capabilities across all of North America with clean, efficient vacuum heat treatment technologies. It’s a bigger deal for vacuum heat treating as a whole. It proves we’ve made great strides in the industry to convert legacy atmosphere users into vacuum technology believers."
Captive Extrusion Die Maker Levels Up With 11 New Furnaces Read More »
R&D and Additive Manufacturing Heat Treater Adds Vacuum Furnace
Derek Dennis
Solar Atmospheres of California
To support R&D and additive manufacturing projects, Solar Atmospheres of California (SCA) has added some small vacuum furnace capacity to their equipment offerings.
The new vacuum furnace was acquired from SCA’s furnace manufacturing sister facility, Solar Manufacturing (SAMI) located in Sellersville, PA, and was specifically designed to process a variety of materials between 600°F – 2400°F (+/-10°F) in both vacuum and/or partial pressure environments. Precise cooling capability up to 2-Bar in argon, nitrogen or helium is available with a maximum operating temperature up to 2650°F. The furnace is also equipped with the SAMI’s state-of-the-art SolarVac® Polaris Control System for optimum performance and precise cycle control.
"We are pleased to add this needed piece of vacuum furnace equipment to service our valuable customers," said Derek Dennis, president of SCA. "The additive manufacturing industry continues to grow, and this new furnace will allow SCA to respond to small builds and R&D projects quickly and precisely."
R&D and Additive Manufacturing Heat Treater Adds Vacuum Furnace Read More »
Watlow Electric Manufacturing Company Acquires High-Vacuum Furnace
Karla Sarabia
Plant Manager
Watlow Electric Manufacturing Company, a North American manufacturer of industrial heaters, sensors, and controllers, will receive a high-vacuum furnace and auxiliaries for annealing thermocouple wires between every drawing stage.
SECO/VACUUM will design and deliver the Vector® HPGQ 6-bar furnace with a customized 40"x40"x48" working zone and a 1.5 ton load capacity. The furnace package includes a 20,000 l/s diffusion pump for high-vacuum operation and a closed loop water system, loading cart, and nitrogen reservoir.
"We wanted a furnace that aligned perfectly with the exceptional capabilities and operation at our Illinois facility to ensure uniform product quality among plants," Karla Sarabia, manager of Watlow Electric Manufacturing Company's Mexico project said. "It’s also a big advantage that SECO/VACUUM has local maintenance support to serve our needs in Mexico."
Watlow Electric Manufacturing Company Acquires High-Vacuum Furnace Read More »
New Vacuum Furnace for Expanding Cutting Tool Manufacturing Facility
Piotr Zawistowski
Managing Director
HTD Size-PR LogoAn international cutting tool manufacturer will augment the capacity of its heat treat vacuum temper furnaces with two more at their North Carolina manufacturing facility.
This expansion to the company's heat treat capabilities comes two months after ordering their fourth Vector®  from SECO/VACUUM. The two single chamber, horizontal, front-loading furnaces are designed with an all-metal hot zone for clean vacuum processing. This style will be able to keep up with most standard hardening, tempering, annealing, solution heat treating, brazing and sintering applications, as well as low pressure carburizing.
"We are thrilled to be an ongoing partner in this [client's] growth," said Piotr Zawistowski, managing director of SECO/VACUUM. "We know they have multiple competitive options for their vacuum heat treat equipment, so we take nothing for granted, and work hard to earn their business every step of the way."
New Vacuum Furnace for Expanding Cutting Tool Manufacturing Facility Read More »
