QUENCHING NEWS
Austenitizing, Salt Quenching Processes Enhance Auto Supplier’s Heat Treating Capabilities
A Mexico-based automotive supplier recently awarded a contract for the design and manufacture of a 1,500 lb/hr mesh belt furnace system for the austenitizing and molten salt quenching of unique components used in the manufacture of its drivetrain systems.
This contract was awarded to Can-Eng Furnaces International Ltd, which has scheduled the project to be commissioned early 2018 in Mexico’s centralized automotive manufacturing corridor. Incorporating several technological advancements for continuous atmosphere processing of products requiring carbon diffusion and quenching via a molten salt system, known as austempering, the new system includes: automated bin-dumping loading, mesh belt atmosphere hardening furnace, salt quench, post-quench wash and rinse system, mesh belt temper oven, and endothermic gas generator.
Austenitizing, Salt Quenching Processes Enhance Auto Supplier’s Heat Treating Capabilities Read More »
No Cal Heat Treat Services Supplier Adds Austempering, Marquenching Capabilities
A brazing and heat treating services supplier based in Northern California has announced the expansion of process services to their heat treating line. ThermoFusion now offers marquenching and austempering, in addition to their annealing, hardening, vacuum, and hydrogen services, for clients in the aerospace, automotive, medical, energy and general manufacturing industries.
Marquenching and austempering use a less aggressive quenchant, reducing the cooling rate slightly, and reducing distortion caused by rapid temperature change (thermal shock).  In high carbon material, these alternative processes allow for the formation of bainite instead of martensite, which allows spring steels to remain “springy” as they get hard.
No Cal Heat Treat Services Supplier Adds Austempering, Marquenching Capabilities Read More »
360 Degree Part Design: Listen to Your Heat Treat Department
Publisher’s Note: Joe Powell, President of Akron Steel Treating Company and IQ Technologies, raises a very compelling point that part designers should work closely with heat treaters to achieve the lowest possible cost of production. In his introduction, he lists out some lofty goals that were set by an ASM Committee back in 1999…a meeting I was fortunate to attend. The goals were lofty then, and they continue to be lofty now. Mr. Powell offers a road map for getting closer to these goals.
Enjoy the read.
Doug Glenn, Publisher
By Joe Powell, President, Akron Steal Treating & IQ Technologies
It’s now 2017, almost 18 years since the ASM R+D committee set forth its Vision 2020, a list of goals for the heat treating industry by the year 2020:
BACKGROUND AND INDUSTRY NEEDS
Industry needs have been determined from the information brought forth by various
committee efforts and surveys over the last five years. Heat treating industry executives identified many of these needs, and prepared a view of the ideal future. This view has been named Vision 2020, and the established performance targets, based in energy, environment, productivity and quality, and industry performance are:
  • Reduce energy consumption by 80%
  • Improve insulation
  • Achieve zero emissions
  • Reduce production costs by 75%
  • Increase furnace life ten-fold
  • Reduce the price of furnaces by 50%
  • Achieve zero distortion and maximum uniformity in heat treated parts
  • Return 25% on assets
  • Create 10-year partnerships with customers.”
It appears our industry has a way to go before meeting the Vision 2020 goals.  Whether you work for a captive heat treating division of a part manufacturer or do heat treating at a commercial heat treating shop for many different part manufacturers, the goals set forth in 1999 are still worth pursuing.
What can we do to speed up the process of achieving these goals?
The above goals can be summarized as making “better parts” at a total lower cost of manufacture.   Heat treating is a crosscutting technology.  To become more efficient in the heat treating process we must look at not only our heat treating processes, but also look concurrently “upstream” and “downstream” from the heat treating process.  All the parties in the part making value stream must collaborate to eliminate waste in each of their own processes as well as the waste that occurs from the interaction between each process.  Doing the proper processes in the right order is also key to eliminating waste.  For example, create a “near net shape” part before carburizing so the carburize layer that took so long to diffuse into the part is not removed in the post-hardening grinding operation.
[blocktext align=”left”]Heat treating considerations must become part of the design and engineering processes from their inception. Heat treaters must give their input for what material is best for the part application, considering not only the desired part fit and function, but the needed physical and mechanical properties. [/blocktext]
Two of the above goals: “reduce production costs by 75%” and “achieve zero distortion and maximum uniformity in heat treated parts” will require innovations in not only heat treating processes, but also heat treating equipment.   The modeling of the heat treating process must become an integral part of the FEA modeling of the part design.  The designer should focus on fit and function as well as achieving the needed mechanical properties, all at the lowest overall cost of manufacture.   Part design engineers cannot meet these goals employing the same heat treating processes and using the same alloys of material that have been used for the last 100 years.   Innovations in heat treatment must be developed collaboratively, crosscutting the many silos of expertise that are needed for making the part.
Part distortion after heat treatment costs part makers billions of dollars each year in post-heat treat operations.  Achieving predictable part distortion after quenching with optimal grain refinement for a given alloy of steel depends on selecting the proper heat treat methods, e.g., proper racking, uniform heating, uniform atmosphere protection and most importantly the proper quenching process.  However, the selection of the optimal quenching method is only enabled by a coordinated choice of the type of alloy used.  Although higher alloy steel allows the use of gas quenching, air hardening steels usually mean higher cost.  In addition, a higher hardenability steel does not always equate to the optimal hardness, ductility and part compressive surface stress state.  The part designer must work with both the steel maker and the heat treater to optimize all three dimensions of hardened part properties.
Again, heat treating considerations must become part of the design and engineering processes from their inception. Heat treaters must give their input for what material is best for the part application, considering not only the desired part fit and function, but the needed physical and mechanical properties.  If we are to minimize waste in post-heat treat operations to achieve proper fit and function, at the lowest overall cost of manufacture, we need to collaborate with all the parties in the part making value chain.
Heat treating equipment in most heat treating departments is the same basic designs as decades ago.   The sunk costs in equipment the heat treater often dictates what heat treat processes will be done to the parts with little or no regard to the effect heat treatment has on total overall cost of manufacture.  Since heat treatment costs are typically between 5% to 10% of the total part cost, demonstrated cost savings from innovative heat treatments alone are rarely enough to justify a change to a new type of processing equipment even if demonstrated to be clearly better.
However, if the total cost of heat treatment includes an examination of the waste created “upstream” and “downstream” of the heat treatment process, often a change in heat treat processes can be shown to have a much larger effect on lowering he overall cost of parts making while making a better part for the end-user.  Achieving a proper balance of hardness and ductility in the part can be enhanced by also achieving a higher compressive surface stress state after quenching.   Higher compressive residual stresses can significantly increase part performance or yield higher power density at nominal cost.   Regardless of part hardness, compressive residual surface stress will usually enhance part wear and fatigue performance.   But to enable the optimal intensive quench that gives compressive residual surface stresses requires the part designer to collaborate with the heat treater.
A faster quench cooling rate usually will provide higher hardness to a deeper level in the part for a given alloy of steel.   Most heat treat metallurgists believe the higher cooling rate also means more part distortion or a higher probability of part cracking.  So many parts are designed around higher alloy air hardening grades of steel to get lower distortion after quenching.  However even gas quenching can cause unacceptable distortion in thin parts with complex shapes.
[blocktext align=”right”]Modern heat treat process modeling and intensive quenching practices have shown that the relationship between the probability of part cracking and rate of quench cooling is a bell curve. [/blocktext]
Modern heat treat process modeling and intensive quenching practices have shown that the relationship between the probability of part cracking and rate of quench cooling is a bell curve.  While it is true at very low cooling rates, such as gas quenching and molten salt quenching, there is a very low probability of part cracking, we also now know that at very high cooling rates which are uniformly applied to the part shell from the very beginning of the quench, the probability of part cracking is also very low.   The key is to eliminate the non-uniformity part cooling caused by film boiling at the very beginning of the quench process.
The benefit of “uniform + intensive” quench cooling is predictable part distortion and optimal grain refinement for a given alloy of steel.  In addition, intensive quench cooling develops “current” compressive surface stresses that hold the part like a die.  Even after tempering, high residual compressive surface stresses remain when designed into the part with the proper material alloy selection and the proper uniform and intensive quench process make for better parts at a total lower cost.   An added benefit is the elimination of the oil quenchants for increased safety, decreased environmental impact and cleaner parts without washing.
CONCLUSION:
As heat treaters today, we must find the optimal processes and apply them in the best available equipment that eliminates the pains of heat treating from distortion and non-uniform properties for not only our customers, but our customers’ customer.  Obviously, we heat treaters cannot do this in a vacuum.  (Pun intended!)  Heat treating is integral and crosscutting with many different process technologies in the part making value stream.
For the heat treating industry to achieve the goals set forth for us so long ago, we must collaborate with all the other members in the part making value chain to optimize the heat treating processes we have always used and in some cases find new ways.  The simple fact is everyone at each step of part design and manufacture must collaborate to eliminate waste for the benefit of all in the lean value stream.  The order of processing is also very important.  To get it all right, the part making value map cannot be done from the individual silos of expertise.
Therefore, the selection of the optimal heat treatment process for a better part at a lower overall cost of manufacture is only enabled by a collaboration of the part designers, material makers and manufacturing engineers all working with their heat treater.
360 Degree Part Design: Listen to Your Heat Treat Department Read More »
Majority of Heat Treatment Done In-House at SKF — New Equipment Purchased
Ipsen recently installed both atmosphere and vacuum heat-treating systems at SKF’s state-of-the-art manufacturing facility in St. Louis, Missouri. With the relocation of their existing facility to a new location, SKF continues to focus on enhancing the quality, efficiency and overall effectiveness of their heat-treating equipment. Among this new Ipsen equipment was a complete ATLAS atmosphere heat-treating system, including two ATLAS integral quench batch furnaces and ancillary equipment – washer, temper, endo generator, loader/unloader and a feed-in/feed-out station. SKF also purchased a TITAN® vacuum heat-treating system to round out their production capabilities.
Heat-treating is considered a core competency at SKF, and this new equipment will allow them to bring the majority of heat treatment in-house and efficiently handle the increase they’ve seen in production demands and volume of parts. Reflecting on the equipment purchased and what appealed to SKF, Bryan Stanford said, “Initially, I would say it was the general purposefulness of these Ipsen products that appealed to us. We run a very large variety of parts and batch quantities here. A custom solution designed to run tens of thousands of the same parts was not going to work for us. We wanted a low-cost, off-the-shelf-type solution that would allow us the flexibility we required – which is what the ATLAS and TITAN delivered. Now after having performed some pre-training, I would say what stands out the most is the ease of use and control of the equipment.”
The ATLAS batch furnaces feature a 24″ W x 36″ D x 30″ H (610 mm x 910 mm x 760 mm) load size with an 1,100-pound (500 kg) load capacity. They also operate at temperatures of 1,400 °F to 1,800 °F (750 °C to 980 °C) and have a quench oil capacity of 1,030 gallons (3,900 L). The TITAN vacuum furnace features an 18″ W x 24″ D x 18″ H (455 mm x 610 mm x 455 mm) load size with a 1,000-pound (454 kg) load capacity. It operates at temperatures of 1,000 °F to 2,400 °F (538 °C to 1,316 °C). Overall, this Ipsen equipment will be used for carburizing, carbonitriding, brazing and annealing and will process a wide variety of parts that support SKF’s Lubrication Business Unit.
Majority of Heat Treatment Done In-House at SKF — New Equipment Purchased Read More »
SMS Supplies Heat Treatment Line to Axis Pipe and Tube
SMS group has supplied and successfully commissioned a heat treatment facility and pipe threading line, which includes two 4-axis CNC threading machines, at Axis Pipe and Tube, based in Houston, Texas, U.S.A.
The two new plants for the Bryan, TX, works enable the company to produce OCTG tubes (Oil Country Tubular Goods) used in natural gas and crude oil production. With the new state-of-the-art equipment, Axis Pipe and Tube will extend its product range opening up new customer segments.
SMS group supplied a heat treatment line, including a natural gas-fired walking-beam hardening and tempering furnace, a water quenching unit and a 10-roll hot straightener, to produce tube grades of up to HCP110. The supplied pipe threading line features two 4-axis CNC threading machines, which operate on the principle of stationary tool and rotating tube. A hydrostatic pipe tester with a maximum test pressure of 15,000 psi, a finishing section and all pipe handling equipment for the threading line were also part of SMS group’s scope of supply. The pipe handling equipment is designed to prevent pipe-to-pipe contact after threading. The tubes and pipes processed on the threading machines will conform to manufacturing standards as per API 5CT.
Thanks to this project, Axis Pipe and Tube is now even better prepared to fulfill the ever more exacting quality and productivity demands of the market at present and in the future.
SMS Supplies Heat Treatment Line to Axis Pipe and Tube Read More »
Coupling CFD and Oil Quench Hardening Analysis of a Gear Component
“The coupling of CFD and heat treatment analyses provides a more robust application of computer modeling to predict the latent heat release, distortion, and residual stresses during the quench hardening process.”
Read More:  Coupling CFD and Oil Quench Hardening Analysis of a Gear Component by B. Lynn Ferguson, Zhichao (Charlie) Li, David Greif, Zlatko Kovacic, Simon Urbas, Rok Kopun
Coupling CFD and Oil Quench Hardening Analysis of a Gear Component Read More »
Record Gas Quenching Speeds Achieved in Ipsen’s ARGOS Heat Treating System
KLEVE, GERMANY – Ipsen’s Global Development Team recently celebrated the first build and testing of the ARGOS heat-treating system. The ARGOS uses low-pressure carburizing (AvaC®) in combination with 20-bar nitrogen quenching to provide metallurgical properties never before seen in gas quenching systems – even those utilizing 20-bar helium quenching. One industry visitor who witnessed the test run commented, “The ARGOS is likely the fastest inert gas quench furnace in the world.”
This initial test was performed on one of the most difficult to quench vacuum carburized components: layshafts for large gears. Until now, helium gas, which is both expensive and declining in availability, was required to fully transform parts with very high cross-sectional thicknesses.
Test outcomes showed that the shafts processed in the ARGOS system with 20-bar nitrogen quenching achieved higher surface hardness and core hardness values than shafts processed in the existing vacuum heat-treating furnaces that use 20-bar helium quenching. The ARGOS heat-treating system also offers several benefits, including:
  • Flexible installation with a selectable number of carburizing, nitriding, subzero and high vacuum process chambers with a nitrogen gas and/or oil quench module
  • Excellent temperature uniformity during heating and cooling
  • Minimal and controllable distortion due to temperature homogeneity throughout the entire load and the reversible gas flow during cooling
  • Extremely high gas velocity and volume due to Ipsen’s unique cooling system design
Overall, the ARGOS furnace line represents a significant milestone in the growing trend to operate low-pressure carburizing (LPC) lines in combination with inert gas quenching.
Record Gas Quenching Speeds Achieved in Ipsen’s ARGOS Heat Treating System Read More »
temperature: 1300°C (2400°F)
Universal High Pressure Quench Delivers Wide Range of Process Capabilities to Slovenia Commercial Heat Treater, MIHEU Read More »
