MANUFACTURING HEAT TREAT
2200°F Conveyor Oven Supplied for Aquatic Heating Systems
Baker Furnace, Inc. shipped a custom-built, high-temperature conveyor oven designed to heat treat rods used to manufacture commercial heating elements.  The process also requires a nitrogen purge to create a specific atmosphere.
At 35 ft long with an operating temperature of 1900°F, the engineering challenges for this unique application were a combination of the size and high temperature coupled with the fact that the application required four different heating zones with a nitrogen injection in every zone.
The electrically-powered conveyor oven was constructed as a modular system which allowed Baker Furnace to conduct a complete test on site and then break it down to ship and install in the most cost-effective manner.   The first two zones for heating measure 24”w x 16”h x 12’L while the two cooling sections measure 24”w x 16”h x 20’L, both with nitrogen injection supply lines to create an inert atmosphere. The oven is equipped with a 24” wide inconel wire woven belt supported by an internal inconel slider bed, which is driven with a gear reduction motor (speed controlled by Allen Bradley drives).  Using formed rod-style, Kanthal elements rated at 60kW for heating, the entire system is controlled with an Allen Bradley touch screen HMI and Allen Bradley PLC software.
“Designing a conveyor oven of this size and temperature is a challenge in itself, but our biggest hurdle came when we had to achieve a plus or minus 25°F heat uniformity within the multiple zones.  Each zone required different temperatures with a nitrogen injection.  We leaned on our past experience as well as testing several scenarios to come up with a design that the customer loves.”   Tim Bacon, Lead Project Manager at Baker Furnace.
2200°F Conveyor Oven Supplied for Aquatic Heating Systems Read More »
CT Scanners for Industrial Jobs
BOTW-50w Source:  Today’s Energy Solutions
“These 3D imaging devices and long-range scanners serve a wide range of industries, and help assure that they are performing the highest level of testing and accuracy possible. A few of the diverse industries currently using this technology and the goals sought are:
Manufacturing – for internal inspection of components and to ensure that a part meets specifications; this includes injection molded, cast, forged or fabricated parts made from metal, plastic, polymers, composites and even 3D printed products.”
Read more: CT Scanners for Industrial Jobs
CT Scanners for Industrial Jobs Read More »
Alcoa Awarded up to $50 Million Contract from U.S. Army to Advance Combat Vehicles
Lightweight metals leader Alcoa (NYSE:AA) has been awarded a five-year contract from the U.S. Army worth up to $50 million for R&D projects focused on developing innovative, lightweighting solutions for ground combat vehicles. The U.S. Army Tank Automotive Research, Development and Engineering Center (TARDEC) awarded Alcoa Defense a “Ground Vehicle Light-Weighting” contract to support efforts to accelerate technology research and development and provide engineering solutions for Department of Defense ground vehicles and intelligent ground systems.
“This agreement with TARDEC builds on Alcoa Defense’s decades-long partnership with the U.S. Army to advance military ground vehicles,” said Eric Roegner, President of Alcoa Defense. “Alcoa’s lightweight solutions have improved troop protection while reducing vehicle weight and assembly time. We look forward to building on our successful track record to help develop the next generation combat vehicle.”
Alcoa’s first “work directive,” or project funded under the contract, is an initiative to advance Alcoa-developed aluminum weld wire alloys. These alloys have already been proven to increase the strength of welded joints—typically the weakest point on a vehicle—as well as reduce corrosion of those welded joints on combat vehicles. Under potential future work directives, Alcoa will provide material research, development, engineering, testing, and evaluation efforts related to ground vehicle lightweighting. These research and development efforts will address various technologies associated with lightweighting such as aluminum forming technology, fastening and joining, modeling and simulation, armor development, material development, material fabrication, energy conservation, and coating and corrosion technology.
A Strong Track Record
Alcoa has built a strong track record of partnering with the U.S. Army to develop solutions that advance the performance of ground combat vehicles. In 2013, Alcoa announced a joint Alcoa-U.S. Army Research Laboratory (ARL) initiative to manufacture the world’s biggest single-piece forged aluminum hull for combat vehicles—the largest closed die forging ever made. This game-changing forging replaces the lower hull of a combat vehicle, significantly improving survivability over traditional welded hulls. In Army testing, the monohull has performed exceptionally well in mitigating the effects of blast events, such as those caused by Improvised Explosive Devices.
In 2005, the U.S. Army Tank-Automotive and Armaments Command (TACOM) awarded Alcoa a research, development and engineering contract to develop aluminum structures for ground combat and tactical vehicles under the Army Lightweight Structures Initiative. Alcoa delivered structural solutions that provided on average 30 to 50 percent weight savings over baseline designs.
About Alcoa
A global leader in lightweight metals technology, engineering and manufacturing, Alcoa innovates multi-material solutions that advance our world. Our technologies enhance transportation, from automotive and commercial transport to air and space travel, and improve industrial and consumer electronics products. We enable smart buildings, sustainable food and beverage packaging, high-performance defense vehicles across air, land and sea, deeper oil and gas drilling and more efficient power generation. We pioneered the aluminum industry over 125 years ago, and today, our more than 60,000 people in 30 countries deliver value-add products made of titanium, nickel and aluminum, and produce best-in-class bauxite, alumina and primary aluminum products. For more information, visit www.alcoa.com, follow @Alcoa on Twitter at www.twitter.com/Alcoa and follow us on Facebook at www.facebook.com/Alcoa.
Alcoa has been a partner and supplier to the military for decades, enabling high-performance defense vehicles across air, land and sea. It is part of the Company’s innovative value-add business. For more information on Alcoa Defense, please visit www.alcoa.com/defense.
About TARDEC
The U.S. Army Tank Automotive Research, Development and Engineering Center (TARDEC) develops, integrates and sustains the right technology solutions for all manned and unmanned Department of Defense ground vehicle systems and combat service support equipment to improve the effectiveness of our armed forces and provide superior capabilities for our future armed forces. Headquartered at the U.S. Army Detroit Arsenal in Warren, Mich., TARDEC is a major research, development and engineering center for the Army Materiel Command’s Research, Development and Engineering Command, and is an enterprise partner in the TACOM LCMC. For more information, please visit our website at http://tardec.army.mil, our Facebook page at www.facebook.com/TARDEC, or our Twitter page at www.army.mil/TARDEC
Disclaimer: Reference herein to any specific commercial company, product, process, or service by trade name, trademark, manufacturer, or otherwise, does not necessarily constitute or imply its endorsement, recommendation, or favoring by the United States Government or the Department of the Army (DoA). The opinions of the authors expressed herein do not necessarily state or reflect those of the United States Government or the DoA, and shall not be used for advertising or product endorsement purposes.
As the author(s) is(are) not a Government employee(s), this document was only reviewed for export controls, and improper Army association or emblem usage considerations. All other legal considerations are the responsibility of the author and his/her/their employer(s).
Alcoa Awarded up to $50 Million Contract from U.S. Army to Advance Combat Vehicles Read More »
Heat Treating Oven Part of Norsk Titanium’s Ultra Lean Manufacturing Line
Norsk Titanium AS, the world’s leading provider of aerospace-grade, titanium additive manufacturing technology, today announced the groundbreaking of a new European assembly and test center outside Oslo, Norway.
Norsk Titanium Chief Commercial Officer Chet Fuller, Chief Executive Officer Warren M. Boley Jr., and Senior Vice President of Operations Chris Bohlmann were on hand to kick off construction of the new facility, which is scheduled to be completed October 2016.
“Customer demand for our additive manufacturing technology is growing to the point where we need significantly more space to assemble and test our MERKE IV™ RPD™ machines prior to worldwide shipment,” said Senior Vice President of Operations Chris Bohlmann. “This new factory will enable us to better serve our manufacturing partners and aerospace customers while expanding our footprint in this innovative region of Norway.”
Norsk Titanium also plans to install the world’s first end-to-end aerospace Ultra Lean Manufacturing line in the facility. A MERKE IV™ Rapid Plasma Deposition™ machine paired with a heat treating oven and a multi-axis CNC machining center will demonstrate the conversion of titanium wire into finished aerospace parts in a production line length of approximately 30 meters.
“The new Ultra Lean Manufacturing line allows our customers to do hands-on development of new part programs on the same campus as our worldwide technology center,” said CEO Warren M. Boley Jr. “Titanium wire comes in one end, the CAD drawing is input, and finished aerospace parts that are fully tested, heat treated and ready for installation are produced in a matter of days. RPD™ truly is a game-changer in terms of cost reduction, speed to market and production line efficiency.”
About Norsk Titanium AS
Norsk Titanium AS is the world’s pioneering supplier of aerospace-grade, additive manufactured, structural titanium components. The company is distinguished in the aviation industry by its patented Rapid Plasma Deposition™ (RPD™) process that transforms titanium wire into complex components suitable for structural and safety-critical applications. The Norsk Titanium research and development team is committed to displacing the inefficient forging process with a precision wire deposition technology embodying substantial savings for aerospace, defense and commercial applications. www.norsktitanium.com
Heat Treating Oven Part of Norsk Titanium’s Ultra Lean Manufacturing Line Read More »
Economist: Manufacturing Revives in 2016’s Second Half
BOTW-50w Source:  SME Manufacturing Engineering
“We’re about out of the woods,” Alan Beaulieu, president of ITR Economics, said during a presentation at the MFG Meeting in Palm Desert, CA. “We are not looking at a recession in manufacturing in the United States.”
Read more:  Economist: Manufacturing Revives in 2016’s Second Half
Economist: Manufacturing Revives in 2016’s Second Half Read More »
temperature: 1300°C (2400°F)
Universal High Pressure Quench Delivers Wide Range of Process Capabilities to Slovenia Commercial Heat Treater, MIHEU Read More »
Apple’s Patent Pending 7000 Series Aluminum Invention Used in the New iPhone 6s Comes to Light
[Best of the Web] Source: PatentlyApple.com
When Apple introduced the iPhone 6s on September 9, 2015 they pointed out in their press release and on their iPhone design page that they had upgraded the aluminum to that of the 7000 series aluminum, the same alloy used in the aerospace industry. Apple further noted that “It’s created from a unique composition of elements that make it the strongest alloy we’ve ever used in an iPhone.
Read more about Apples’ use of this aerospace aluminum alloy.
Apple’s Patent Pending 7000 Series Aluminum Invention Used in the New iPhone 6s Comes to Light Read More »
