solution heat treatment
Gray drop bottom furnace bg with headshot male, dark hair, white shirt
Aerospace Heat Treating Upgrades Capacity with Drop Bottom Furnace
An electrically heated drop bottom furnace with a traveling quench tank and a maintenance platform has been shipped to an aerospace company for the solution heat treatment
Mike Grande
Vice President of Sales
Wisconsin Oven Corporation
Source: Wisconsin Oven Corporation
of aluminum parts.
Wisconsin Oven designed the drop bottom furnace with sufficient capacity to heat 600 pounds of aluminum per load and provide a quench delay that does not exceed 5 seconds. The system also includes a slow drop speed program to be used for heating applications that do not require a quench.
“This drop bottom furnace was designed with a 5 second quench delay, and a temperature uniformity of +/- 5°F at the set points 850°F and 1,100°F. In addition, the system was tested to be in compliance with AMS2750F, Class 1 furnaces and instrumentation Type C prior to shipment from our manufacturing facility,” said Mike Grande, vice president of sales at Wisconsin Oven.
Aerospace Heat Treating Upgrades Capacity with Drop Bottom Furnace Read More »
temperature: 1300°C (2400°F)
Universal High Pressure Quench Delivers Wide Range of Process Capabilities to Slovenia Commercial Heat Treater, MIHEU Read More »
