Endothermic gas generator
Endo Gas Upgrades Heat Treat for Nordic Traction
Nordic Traction Group, a manufacturer of traction chains and tracks for forestry and agricultural machinery, recently upgraded their heat treatment operations by installing a new endothermic gas generator system.
Daniel Panny
Head of Sales
UPC-Marathon in Germany
Source: LinkedIn
To carburize its traction chains, Nordic Traction Group, with manufacturing locations in Finland and Scotland, added the EndoFlex™ S system. The system, from UPC-Marathon, a Nitrex company with North American locations, replaces an outdated generator. The new system improves process reliability and product quality and requires less preventative maintenance.
“Since the EndoFlex™ S produces only the amount of gas required by the carburizing furnace, there is zero waste in endogas production. This also allows Nordic Traction to save big by maximizing energy usage and gas consumption,” said Daniel Panny, Head of Sales at UPC-Marathon.
Endo Gas Upgrades Heat Treat for Nordic Traction Read More »
Elevate Your Knowledge: 5 Need-to-Know Case Hardening Processes
OCYour parts need heat treated to herculean surface hardness but with a soft, ductile core. That is to say, you are looking at case hardening processes, most likely one of these: gas carburizing, low-pressure carburizing, carbonitriding, gas nitriding, and ferritic nitrocarburizing.
Mike Harrison at Gasbarre Thermal Processing Systems brings us a Technical Tuesday article about what case hardening is and how five of the most common processes vary by (1) comparing the specific guidelines for each temp and time, (2) identifying equipment used to perform each process, and (3) providing a chart (at the end!) to understand different process considerations.
Mike Harrison
Engineering Manager of Industrial Furnace Systems Division
Atmosphere Gas Carburizing
Fig. 1 – Integral quench furnace: "The atmosphere gas carburizing process can be performed both in batch and continuous equipment."
Fig. 2 – Endothermic gas generator: "To achieve a carburizing atmosphere endothermic gas is typically used, which is produced by an endothermic gas generator that heats a combination of natural gas and air to create a mixture that is approximately 40% hydrogen, 40% nitrogen, and 20% carbon monoxide."
Low-Pressure Carburizing
Fig. 3 – Vacuum furnace with oil quench
Fig. 4 – Continuous vacuum furnace
Carbonitriding
Diffusion Only Processes
Gas Nitriding
Fig. 5 – Horizontal retort nitriding furnace: "Traditionally, pit furnaces have been used for nitriding as they can accommodate larger load sizes and can be easier to seal as gravity helps keep the lid sealed; however, horizontal designs have gained in popularity in recent years."
Ferritic Nitrocarburizing
Considerations
Screenshot 2023-12-27 at 1.19.41 PM
Elevate Your Knowledge: 5 Need-to-Know Case Hardening Processes Read More »
