NITRIDING TECHNICAL CONTENT
Heat Treat Basics: Nitriding and Carburizing
Pattern Energy, Siemens Determine Cause Of Ocotillo Wind Collapse, Energy Heat Treating  Source:  Metlab
Nitriding and carburizing are the two most common heat treatment practices for surface hardening functional components. The main difference is that in nitriding, nitrogen atoms are made to diffuse into the surface of the parts being processed, whereas in carburizing, carbon is used. There are advantages and disadvantages to both processes.
This excellent blog post by Metlab in the Philadelphia area is a great primer for both processes.
Read More:  Nitriding and Carburizing
Heat Treat Basics: Nitriding and Carburizing Read More »
Carburizing vs Nitriding: Treatment Modeling
BOTW-50w  Source:  Thermal Processing Magazine
The finite element method can provide insights needed by engineers to calibrate thermal processes, whether it’s carburizing or nitriding, and maximize the benefits of the heat treatment.
Carburizing and nitriding treatments have the same goal: increase hardness on the surface while keeping the core ductility. Carburizing is a process where the part is placed in a confined environment regulated by its carbon content. By adjusting the parameters such as temperature and time, the carbon will diffuse into the part to a certain thickness. While the carbon content (%C) is fairly known at the locations where the carbon has diffused, it is harder to anticipate how far the carbon has diffused. The nitriding process uses the same concept but with nitrogen instead of carbon. The simulation of this process is helpful for the engineer to optimize the process. This article presents two examples to illustrate the carburizing and nitriding heat treatment processes.
Read more: Carburizing and Nitriding Treatment Modeling by Nicolas Poulain
Carburizing vs Nitriding: Treatment Modeling Read More »
Ion Nitriding of Titanium Alloys for Gear Applications
The advantages of ion nitriding heat treatments in many low-alloy steels and titanium alloy gears used in high-performance applications include resisting wear and fatigue.
Thermochemical surface engineer heat treatments are effective in improving the performance of various gears made of ferrous alloys. The cost of machining typical gears during the manufacturing process often exceeds 55 percent of total cost, especially when there is significant grinding after carburizing the gears. Therefore, improvements in the manufacturing of gears that can lead to a reduction in machining are valuable.
Nitriding produces high hardness and compressive stresses in many low-alloy steels used for gears. It is a nearly distortion-free process, which allows for the treating of finished components, thus minimizing costs. The complex nature of the stresses at the contact area of rotating gears leads to contact fatigue and sliding friction. Nitriding is superior to other surface engineering techniques in resisting wear at gear f lanks. When a high-strength alloy steel suitable for nitriding is used, a nitrided surface layer withstands high contact Herztian stress (contact stress) at gear flanks better than a deeper carburized layer in many instances.
Ion Nitriding of Titanium Alloys for Gear Applications Read More »
Quality Counts: Gas Nitriding
In general, nitriding of parts involves a thermal process that provides a tough, corrosion-resistant, and wear-resistant surface with less distortion compared to other case hardening processes due to processing temperature and no need for quenching. There are different methods of nitriding, including gas nitriding, plasma/ion nitriding, and salt-bath nitriding. This article focuses on gas nitriding.
Read More:  Quality Counts:  Gas Nitriding by Jim Oakes
Quality Counts: Gas Nitriding Read More »
