Piotr Skarbinski
Continuous CAB Line Production Boosts Capacity
A manufacturer specializing in advanced thermal management solutions has expanded its production capabilities with the delivery of a new continuous controlled atmosphere brazing (CAB) line. The system will support increased output of high-performance cooling components such as heat dissipation plates for data centers and cold plates for electric vehicles, while also serving demand across aviation, photovoltaics, and rail transport.
The company, a Chinese manufacturer focused on temperature control platforms and cooling systems, is investing in the continuous CAB line to strengthen production capacity and support growing demand for compact, high-efficiency thermal management technologies.
The CAB line, supplied by SECO/WARICK — a global thermal processing equipment manufacturer with operations in North America — features a 1,000mm (39.2 in) belt width and is designed to process multiple product types, including 3D vapor chambers and cold plates. The system includes a dry-off oven for part preparation, a radiation brazing furnace operating in a controlled atmosphere, a clean-out chamber to stabilize internal conditions, an air-jacketed cooling chamber, and a final cooling chamber. An integrated control system enables centralized operation and process management across all stages.
Piotr Skarbiński
SECO/WARWICK
“What makes this project unique is the ability to braze two distinct product groups — 3D-VC (3d vapor chambers) and cold plates — on a single line,” said Piotr Skarbiński, vice president of the Aluminum and CAB Products Segment at SECO/WARWICK. Through tailored throughput calculations and a customized cooling configuration, the system is engineered to deliver temperature uniformity and repeatable process control — factors essential to producing high-quality components for modern electronics and power systems, he adds.
As AI servers, EV systems, and advanced electronics generate increasing heat on compact surfaces, reliable aluminum brazing technologies remain essential to delivering performance, durability, and efficiency in next-generation thermal management systems.
Continuous CAB Line Production Boosts Capacity Read More »
Tube Annealing Furnace for Stainless Steel and Special Alloys Manufacturer
Alleima, a manufacturer of steel components and special alloys, will receive a new tube annealing furnace. The electric atmospheric furnace line is intended for bright annealing of high-alloy tubes and will be used in the production of nuclear applications components.
SECO/WARWICK is providing the furnace as their 5,000th device.
The tube annealing system
Source: SECO/WARWICK
Piotr Skarbiński
SECO/WARWICK
Magnus Mellberg
Production Unit Manager
Alleima
Source: LinkedIn
“Our partnership with SECO/WARWICK has lasted for many years. We are delighted that we could celebrate it in a special way, as our impressively large tube annealing line (over 140 meters long – 460 ft) happens to be the 5,000th SECO/WARWICK device. We feel that together we are creating not only a remarkable history, but also the future as this solution will help us spread our wings,” said Magnus Mellberg, production unit manager at Alleima.
“The furnace was created specifically for this partner’s needs. It will allow them to increase production capacity…This is important as the demand for high-alloy components in this market has increased. It is an unusual construction, verified through analysis and simulations, and implemented in reality. It offers very good technological results after the annealing process,” explained Piotr Skarbiński, vice president of the Aluminum and CAB Business Segments at the SECO/WARWICK Group.
Tube Annealing Furnace for Stainless Steel and Special Alloys Manufacturer Read More »
2 CAB Furnaces Commissioned for Auto Manufacturer
Two EV/CAB lines will be installed for a major manufacturer of heat exchangers for trucks, passenger cars, and new energy technologies. The furnaces are designed to meet the stringent requirements of the automotive industry for the production of components for commercial vehicles and to ensure long-lasting and reliable operation in demanding industrial conditions.
SECO/WARWICK, a supplier of controlled atmosphere brazing technology and more with North American locations, will deliver the two EV/CAB lines: one installation will occur in Mexico and the other in China for the Chinese manufacturer’s in-house heat treat operations.
Piotr Skarbiński
SECO/WARWICK
Both lines are modern aluminum brazing solutions dedicated to the production of key cooling system components for electromobility and classic automotive applications. One line has a belt width of 1900 mm, destined for the Chinese location, and was designed for battery cooling plate production, while the Mexican line is 1800 mm wide and will be dedicated to the production of automotive heat exchangers.
“We are proud that one of the leaders in automotive thermal management consistently chooses SECO/WARWICK technology. Our CAB lines…[fulfill] future requirements regarding automation, efficiency and ecology,” commented Piotr Skarbiński, vice president of the Aluminum and CAB Product Segments at SECO/WARWICK.
The two CAB lines ensure temperature distribution uniformity in the brazing process of wide components. The furnace designs involved a convection preheating chamber, radiant brazing furnace, and cooling zones with air jacket and final cooling.
2 CAB Furnaces Commissioned for Auto Manufacturer Read More »
Aluminum Brazing Furnace Supports Automotive Industry
Weifang Hengtong Radiator is increasing their efficiency and quality of their aluminum plate and bar heat exchangers with a semi-continuous controlled atmosphere brazing (CAB) furnace at their in-house heat treat operations.
Piotr Skarbiński
SECO/WARWICK
The SECO/WARWICK furnace was specifically designed for the production of plate & bar heat exchangers. The semi-continuous CAB system is based on a multi-stage cycle division. The line includes: a drying furnace, an entry washing chamber, a convection preheating and brazing chamber, an intermediate air seal cooling chamber, and a final direct cooling chamber. The semi-continuous mode ensures that even large-sized components are evenly heated during the proper process time.
“The semi-continuous Universal CAB System ensures shorter cycle time, lower investment costs, and higher process efficiency of each batch. These are the main advantages of the CAB system compared to vacuum brazing furnaces,” says Piotr Skarbiński, vice president of the Aluminum and CAB Products Segment at SECO/WARWICK Group.
The furnace is characterized by high flexibility, allowing the brazing of exchangers of various masses and dimensions in subsequent cycles while maintaining process parameters.
Aluminum Brazing Furnace Supports Automotive Industry Read More »
15th CAB Line Ventures to Mexico
After 15 years of collaboration, a new CAB furnace designed for production of heat exchangers for delivery vehicles, trucks, and cars is set to begin operating in Monterrey Mexico.
This 15-year collaboration between SECO/WARWICK and their Asian partner began in 2010 when the two began working together on solutions for heat exchanger production for trucks, passenger cars, and new energy technologies. The new CAB line that will operate in Mexico is equipped with a thermal degreasing furnace, preheating chambers, a radiation furnace, a deicing furnace, a final cooling chamber, and an advanced control system. These features are designed to meet the requirements of the automotive industry, as well as ensure long-term and reliable operation.
Liu Yedong
Managing Director
SECO/WARWICK China.
Piotr Skarbiński
SECO/WARWICK
“We can say that this is the jubilee 15th order, exactly on the 15th anniversary of our cooperation beginning,” said Piotr Skarbiński, vice president of the Aluminum and CAB Products Segment at SECO/WARWICK Group.
The CAB line with a 1,400 mm wide belt ensures excellent temperature uniformity across the entire width, which translate into the final product quality,” Liu Yedong, managing director of SECO/WARWICK China added.
15th CAB Line Ventures to Mexico Read More »
CAB Capabilities Expanded for Heat Exchanger Manufacturer
An aluminum heat exchanger manufacturer specializing in the production of heat exchangers recently expanded its production capabilities with a semi-continuous furnace for controlled atmosphere brazing (CAB) aluminum components. The system for semi-continuous operation, based on the cycle multi-stage division, is designed to increase the efficiency and quality of the heat exchangers with ribbed plate construction.
Piotr Skarbiński
SECO/WARWICK
SECO/WARWICK provided this CAB system, often chosen by the HVAC industry and manufacturers of car parts, for the industrial production of heat exchangers. The semi-continuous operation mode ensures uniform heating of elements even with above-average dimensions.
“The key advantages of this solution includes higher hourly efficiency — modern brazing technology ensures shorter production cycle time; stable and repeatable quality — the advanced brazing atmosphere control system minimizes the risk of defects, guarantees faster maintenance as well as no production downtime. . . . The semi-continuous CAB system is popular because it allows users to realize a reduction in costs while producing atmosphere brazing with exceptional quality control,” said Piotr Skarbiński, vice president of Aluminum Process and CAB Business Segment in the SECO/WARWICK Group. “We supply solutions to many companies in Asia, and a large part of the contracts are the result of recommendations we receive from our customers.”
The CAB line includes a drying furnace, an inlet purging chamber, a patented heating and brazing chamber, an intermediate cooling chamber with an air jacket and a direct final cooling chamber. The product moves between stages in a horizontal position based on a continuously adjustable cycle time, depending on the load’s type and configuration. The semi-continuous operation mode ensures that even large-sized heat exchangers will be heated evenly during the correct process time.
CAB Capabilities Expanded for Heat Exchanger Manufacturer Read More »
Aero/Auto Aluminum Manufacturer Expands Heat Treatment
Taiwan Hodaka Technology, an aerospace and automotive manufacturer, extends its market reach by adding an aluminum aging furnace to its heat treatment capabilities. The furnace, which is designed for aging using T77 technology, will allow the company to meet the highest safety and strength standards.
This is the first transaction between Taiwan Hodaka Technology, which is involved in the design and processing of parts made of aluminum alloys, and SECO/WARWICK. The furnace operates in the temperature range from 176° to 428°F (80° to 220°C) with a temperature uniformity in the last heating phase, of ±47.4°F (3°C) in accordance with the AMS 2750 standard.
“The solution supplied by SECO/WARWICK will allow us to enter a new market segment. We are a partner for many key players in the aviation industry. The T77 aluminum aging furnace will enable us to serve customer requirements even better. At the same time, the new technology will support our commitment to reducing our impact on the environment,” said Dr. Sam Chiang, vice president for R&D at Taiwan Hodaka Technology Co. Ltd.
Tomasz Kaczmarczyk, Sales Manager of the Aluminum Process and CAB Furnaces Teams, SECO/WARWICK
For heat treated alloys (2xxx, 6xxx and 7xxx series), the letter T and one or more digits are used after the alloy series symbol. The first digit is the most important, as it indicates the type of heat treatment applied to the alloy, while the remaining digits (if provided) indicate heat treatment variants or their modifications. The 7000 series of aluminum alloys have the highest strength of all other aluminum alloy series and are commonly used in aviation since they are held to the highest safety and strength standards.
“T7 denotes the process of solution heat treatment and artificial aging to an overaged state to obtain specific properties, e.g. increased corrosion resistance,” said Tomasz Kaczmarczyk, sales manager of the Aluminum Process and CAB Furnaces Team at SECO/WARWICK. “Sometimes, in addition to the digit denoting the standard heat treatment, an additional digit is used to denote modifications to the given treatment or stress relief procedures. For example, for 7xxx alloys, the symbol T77 denotes retrogression and re-aging. The use of this process improves the alloy’s corrosion resistance, which is so crucial in the production of aircraft parts. The applied technology will allow Taiwan Hodaka Technology to produce high-quality profiles used in the aviation industry in accordance with the AMS standard.”
Piotr Skarbiński
SECO/WARWICK
“The furnace on order equipped with electric heating will process 1500 kg of aluminum profiles with a maximum length of 5500 mm. This is a two-zone solution with a total heating power of 420 kW. The solution for aluminum aging, powered by electric heaters, eliminates the problem of CO2 emissions and is in line with the ecological trend increasingly common in heavy industry,” said Piotr Skarbiński, vice president of the CAB and aluminum products segment at SECO/WARWICK.
The furnace will be used at the company’s newly built plant in Taiwan.
The project partner was PEERENERGY, which offers thermal process consulting, project management, and equipment supply for the aerospace, military equipment, and semiconductor industries.
Aero/Auto Aluminum Manufacturer Expands Heat Treatment Read More »
3 Heat Treat Furnaces for Annealing Aluminum
Jupiter Aluminum Industries (JUPALCO), a newly established aluminum factory which will be part of the Jupiter Group in India, has ordered three furnaces for annealing aluminum coils from a heat treat furnace manufacturer with North American locations.
The equipment ordered by the Jupiter Group from SECO/WARWICK includes three Vortex® 2.0 furnaces for aluminum annealing, two cooling chambers, and one loader. A system configured in this way will ensure the optimal production volume of the Indian rolling mill.
The aim of JUPALCO’s new plant will be to achieve the highest level of domestic aluminum production in history and to create an ecosystem of comprehensive aluminum-based solutions. This is the first cooperation between SECO/WARWICK and the Jupiter Group.
The three Vortex furnaces are effective systems for annealing aluminum coils. In the Vortex 2.0 version, a system of straight nozzles has increased the heat transfer efficiency. The systems key feature is the increased heat transfer coefficient, achieved by directing high-velocity air to both sides of the coil. This allows air to flow over the coil edges, not just through its outer layer.
Piotr Skarbiński, Vice President of (Source: secowarwick.com)
With the use of patented air flow technology, the aluminum coil annealing systems operate with process cycles that are significantly shorter. This in turn ensures energy savings, increased efficiency, and improved surface quality of the finished coils.
“In the case of coil annealing,” commented Piotr Skarbiński, VP of the CAB and Aluminum Products Segment at the SECO/WARWICK Group, “the challenge is to optimize the process by reducing the cycle time as much as possible while maintaining the desired metallurgical properties throughout the entire load.”
The Jupiter Group plans to recycle over 50,000 tons of aluminum scrap every year once fully operational. This scrap will come from both in-house and customer scrap, purchased scrap, and recycled cans/foils etc. The new rolling mill in India will help the Group expand its footprint in the aluminum industry and produce Made in India products which will be known for its quality and reliable products and services.
“Since the 1990’s,” says Mr. Sandeep Bajaj, CMD of Jupiter Aluminum Industries, JUPALCO, “the Jupiter Group processes aluminum as a partner of the converting and packaging industries. Ecology is an important value for us. It is included in our mission, just like our Partner’s. The rolling mill in India will be one of the most modern facilities of this type in this region, which is why we are equipping it with the best solutions available on the market.”
3 Heat Treat Furnaces for Annealing Aluminum Read More »
EV/CAB Lines for Battery Cooler Production
Piotr Skarbiński
SECOWARWICK
Source: LinkedIn
EV/CAB lines for electric battery coolers' protective atmosphere brazing will be provided to manufacturers from Poland and the Czech Republic.
SECO/WARWICK Group's EV/CAB continuous lines are products dedicated to the automotive sector. EV/CAB solutions work for heat exchangers’ leading manufacturers and are used for mass production of large-size car battery coolers.
"Globally, the demand for electric cars and thus for battery coolers is increasing," commented Piotr Skarbiński, vice president of the Aluminum and CAB Products Segment, SECO/WARWICK Group. "It should be emphasized that the EV/CAB line is not a standard product, generally available on the market. Many years of experience have allowed us to create solutions optimally adapted to the production in this industry."
EV/CAB Lines for Battery Cooler Production Read More »
2 Companies Choose EV/CAB Lines for Battery Cooler Components
Piotr Skarbiński
SECOWARWICK
Source: LinkedIn
Two Chinese manufacturers choose EV/CAB lines to expand their heat exchanger production to better heat treat oversized battery cooler.
The furnace supplier, SECO/WARWICK, noted that this will be the fourteenth CAB line for one of the manufacturers in the China market.
“This year, CAB lines for brazing heat exchangers have been sold to several new customers on the Chinese market," said Piotr Skarbiński, vice president of the Aluminum and CAB Products at SECO/WARWICK. “The EV/CAB line . . . [has] temperature uniformity across the belt, suitable for the strict requirements of the automotive industry, as well as its reliability and quality."
2 Companies Choose EV/CAB Lines for Battery Cooler Components Read More »
