Heat Treat Radio #97: Lunch & Learn, Ovens vs. Atmosphere Furnaces
Are you trying to figure out what heat treat equipment investments you need to make in-house and what is better being outsourced? This conversation marks the continuation of Lunch & Learn, a Heat Treat Radio podcast series where an expert in the industry breaks down a heat treat fundamental with Doug Glenn, publisher of Heat Treat Today and host of the podcast, and the Heat Treat Today team. This conversation with Dan Herring, The Heat Treat Doctor®, zeros in on heat treat ovens versus atmosphere furnaces.
All About Ovens (01:42)
Source: Grieve
Source: Dan Herring
Source: Dan Herring
Source: Dan Herring
Source: Dan Herring
Source: Dan Herring
Source: Dan Herring
Q&A on Ovens (16:58)
Source: Dan Herring
Source: Dan Herring
Source: Dan Herring
Source: Dan Herring
Source: Dan Herring
Dan Herring: Well thank you, my pleasure.
For more information:
dherring@heat-treat-doctor.com
To find other Heat Treat Radio episodes, go to www.heattreattoday.com/radio.
Heat Treat Radio #97: Lunch & Learn, Ovens vs. Atmosphere Furnaces Read More »
