Energy heat treat news
Roller Hearth Furnaces Crafted for Top Tier Automotive Supplier & Energy Companies
Three endeavors are underway to deliver advanced roller hearth furnace technology, featuring large-scale atmosphere quench and temper, annealing, and solution treatment systems to support the automotive and energy industries.
CAN-ENG Furnaces International, Ltd. is engaged in providing three separate systems amounting to over 450 feet of roller hearth furnace capacity.
Tim Donofrio
Vice President of Sales
Can-Eng Furnaces International, Ltd.
Source: Can-Eng Furnaces International, Ltd.
The first of the three undertakings is a high capacity, roller hearth lamination annealing system. Produced for the transformer manufacturing industry, it will be supplied to one of North America’s largest transformer core manufacturers with operations in the USA, Canada, Mexico and China. The lamination annealing process is applied to transformer cores to enhance their magnetic properties and reduce core loss, ultimately improving efficiency and performance. The system integrates a pre-heat system, high temperature annealing furnace with integrated protected atmosphere-controlled cooling and accelerated cooling chamber. It is more than 300ft long and is capable of producing over 14,000 lbs/hr of atmosphere protected electrical steel core laminations used to manufacture high voltage transformer stations needed in the development of North America’s electrical distribution infrastructure.
“This project is being carried out largely to satisfy the demand for improving America’s aging and overburden power distribution network. As part of improving the nation’s power distribution network, consideration is being made to increase access to electric vehicle charging stations of which transformer cores are a critical part,” shared Tim Donofrio, Vice President of Sales, Can-Eng Furnaces International, Ltd.
The second endeavor is a roller hearth solution treatment furnace system for a tier one supplier of cast aluminum automotive components. The furnace will be used as part of a continuous T-6 heat treatment system for the manufacturing of cast aluminum, safety critical suspension components, and will serve to supply for one of America’s largest Japanese-based automotive manufacturers. These suspension components are to be integrated into future hybrid and electric automobiles produced in America by the manufacturer.
The third project is a roller hearth atmosphere mesh belt furnace system for a tier one supplier of safety critical, high value fasteners. This system is used to atmosphere, quench and temper high value, safety critical fasteners used in automotive manufacturing. The system is rated for processing over 6000 lbs/hr, and is being supplied to an existing customer with four similar roller hearth furnaces. The system supports the ongoing demands for domestic-supplied, high volume, heat treatment capacity.
Roller Hearth Furnaces Crafted for Top Tier Automotive Supplier & Energy Companies Read More »
Walk-In Batch Ovens Shipped To Energy Industry
A shipment of six (6) heavy-duty walk-in batch ovens was delivered to a manufacturer of products for the energy industry. These industrial ovens will be used for baking glue onto products.
Mark Schahczinski, Senior Sales Engineer, Wisconsin Oven Corporation
The batch ovens, from Wisconsin Oven Corporation, have a maximum operating temperature of 500°F and guaranteed temperature uniformity of ±5°F at 285°F. A combination airflow configuration ensures even heat distribution throughout the chambers to optimize heating rates and temperature uniformity. Nine (9) point profile tests were conducted in each empty chamber under static operating conditions to verify temperature uniformity.
“We are proud to continue our partnership with this valued customer who has purchased multiple ovens from Wisconsin Oven over the years. Their trust in our products is a testament to our commitment to providing high quality equipment and building long term relationships with our customers,” said Mark Schahczinski, Senior Sales Engineer, Wisconsin Oven Corporation.
Walk-In Batch Ovens Shipped To Energy Industry Read More »
Manufacturer Expands Aluminum Heat Treat Capabilities
A provider in the power solutions industry has enhanced its operations with a heat treat drop-bottom furnace for the solution heat treatment of aluminum castings. This installation will increase the company’s production capabilities, with the furnace having a load setting of 48 in (123 cm) wide x 36 in (91 cm) high x 141 in (358 cm) long.
The furnace, the fifth designed and manufactured by NUTEC Bickley, has a single temperature control zone, typically operating at 1000°F (573°C), with a maximum of 1075°F (580°C). The load setting will accommodate up to three baskets, equivalent to around 3600 lb (1635 kg) of aluminum parts per cycle. The furnace has been customized to be indirect gas-fired using radiant tube burners. Additionally, the project incorporates a motorized quench tank, rails, movement system, and load/unload platform with elevator device.
Arturo Arechavaleta
Vice President, Metal Furnaces
NUTEC Bickley
“Efficient and effective solution heat treatment is a vital part of the aluminum casting process,” said Arturo Arechavaleta, vice-president of Metal Furnaces at NUTEC Bickley. “Without the sort of advanced system that we have custom-designed, volume production of high-quality aluminum parts is not feasible. We’re proud to have played an important role in this technology partnership.”
The indirect gas firing is via single centrifugal recirculation that produces a vertical flow pattern. Heating is achieved with four radiant tube burners that have individual flame safety devices. The burner system incorporates a motorized control butterfly valve, and the gas flow is controlled by proportional ratio regulators. This design, with its baffle arrangement, delivers an even flow pattern, providing excellent temperature distribution and control in the furnace’s load chamber and high-efficiency heat recirculation (convection) horizontally across the aluminum castings. Excellent temperature uniformity was always considered an important parameter, and this has been shown to be ±5.4°F (±3°C) under full test in the provider’s manufacturing facility.
In order to maintain excellent thermal efficiency in operation, the furnace walls are fully lined using ultra large proprietary ceramic fiber modules. Their configuration and fixing provide for excellent insulation and long life coupled with low maintenance. The insulation layer is 6 in (150 mm) thick and has a density of 12 lb/ft3 (192 kg/m3).
The installation will see the drop-bottom furnace itself stationary — in a fixed elevated position — with the quench tank and loading car moving to accommodate baskets at the selected position. The furnace has a single, pneumatically operated horizontal slide door. For these particular aluminum castings, the company will employ a motorized water quench system provided by NUTEC Bickley, as well as its rails included leveling and installation. The tank has been designed to accept a full load of pieces within the work basket when the furnace is positioned vertically above it.
Press releases are available in their original form here.
Manufacturer Expands Aluminum Heat Treat Capabilities Read More »
Green Energy Equipment Manufacturer Adds VIM System
A green energy equipment manufacturer has expanded its vacuum induction melting capacity with another VIM furnace for melting and casting refractory alloys. The new VIM system will be used to cast directionally solidified parts for the next generation of green energy technologies.
Earl Good
Managing Director
Retech
Retech, a SECO/WARWICK Group company, designed this system with directional solidification, a casting process used to control the crystalline structure formation in cast parts. This process precisely controls the rate and direction from which heat dissipates from a part as it cools in the mold.
Similarly equipped VIM systems melt ultra-high-purity alloys used in a diverse array of applications, including single-crystal jet engine blade casting, super alloys, shape memory alloys, and silicon for semiconductor wafers.
“This is going to help this industry partner accomplish both their production and R&D metallurgy goals,” said Earl Good, managing director of Retech, “They also appreciate that buying from us again means that their staff is already trained on this equipment.”
Green Energy Equipment Manufacturer Adds VIM System Read More »
Loy Instrument Partners To Expand Capabilities
Loy Instrument, Inc., which supplies process control and combustion solutions for heat treaters in multiple industries, has been acquired by Relevant Industrial, LLC (Relevant), a leading provider of industrial equipment and engineered solutions. This partnership enhances the company’s ability to serve clients in industries such as aerospace, metals, refining, petrochemical, manufacturing and power generation.
John Carte
CEO
Relevant Industrial LLC
Loy, headquartered in Indianapolis, Indiana, has over 80 years of industry knowledge and a team with more than 900 years of combined experience. This acquisition marks a significant milestone for Relevant, strengthening its position as an industry leader and expanding its geographic footprint into Indiana, Ohio, Kentucky and Michigan.
“Joining Relevant Industrial is an exciting step for Loy Instrument, our employees, and our customers,” said Ken Bradway, president of Loy Instrument, Inc. “Together, we’ll leverage our combined expertise and resources to expand our capabilities and continue delivering exceptional solutions to the industries we serve.”
“The addition of Loy Instrument’s expertise strengthens our ability to tackle complex challenges in combustion and process control, providing even greater value to our customers,” said John Carte, CEO of Relevant Industrial. “We’re excited to welcome this exceptional team into the Relevant family and look forward to driving innovation together.”
Loy Instrument Partners To Expand Capabilities Read More »
Aalberts Acquires Paulo, Expands Heat Treat Reach in N.A.
Aalberts N.V. has reached an agreement to acquire 100% of shares of Paulo Products Company (Paulo), expanding the company’s geographical footprint in the U.S. The acquisition will bolster the Dutch company’s capabilities to provide heat treating, brazing, and metal finishing operations for the North American automotive, aerospace, defense, and energy sectors.
Stéphane Simonetta
CEO
Aalberts N.V.
Pending regulatory approval, the management team of Paulo, which operates five heat treatment facilities in the USA and one in Mexico, will work with the management of Aalberts Surface Technologies in North America. The transaction is expected to be finalized in the second quarter of 2025 and generate an annual revenue of approximately USD 105 million with 522 employees.
“We are excited about the growth potential in the different end markets and are looking forward to welcoming Paulo’s employees to Aalberts,” said Stéphane Simonetta, CEO of Aalberts N.V. “This strategic acquisition will further enhance our proximity in North America and Mexico as per our ‘thrive 2030’ strategy. Together, our leadership position will enable us to serve our customers with short lead times, high quality and full-service capabilities.”
Aalberts Acquires Paulo, Expands Heat Treat Reach in N.A. Read More »
Sandia National Laboratories Expands Production Capabilities with 2 Vacuum Furnaces
Sandia National Laboratories has acquired two horizontal vacuum furnaces for one of its production labs in Albuquerque, NM. The furnaces will meet the multimission laboratory’s goal to maintain process parameters and datalogging essential for analysis to coincide with the process payload run results. The facility’s applications target roughly 70 industry sectors, including nuclear deterrence, arms control, nonproliferation, hazardous waste disposal, and climate change.
In the tandem system designed and set up by AVS Incorporated, one furnace operates at a maximum of 1600°C (2912°F) and the other at 1300°C (2372°F). Both have a 100-lb load capacity. The systems integrate wet and dry hydrogen process gas along with all refractory metal hot zones. The HMI interface and controls allow for countless combinations of recipes and selectable functions.
Sandia National Laboratories is one of three research and development laboratories of the United States Department of Energy‘s National Nuclear Security Administration (NNSA) with the primary goal of advancing U.S. national security by developing various science-based technologies.
Sandia National Laboratories Expands Production Capabilities with 2 Vacuum Furnaces Read More »
Huake Casting Control Technology Expands Production with Vacuum Furnace
A manufacturer of components for the aviation and energy sectors is expanding its production capabilities with the acquisition of a horizontal vacuum heat treatment furnace. Huake Casting Control (Shanghai) Technology Co., Ltd., will use the equipment to manufacture precision gas turbine components and aircraft parts.
A Vector® horizontal vacuum heat treatment furnace
Source: SECO/WARWICK Group
The solution, a member of the Vector® family of furnaces provided by SECO/WARWICK Group, comes with a graphite heating chamber and a 15-bar absolute gas quenching system, can operate at temperatures up to 2550°F (1400°C), and has a maximum gross load weight of 1767 lb (800 kg).
“We were convinced to choose the Vector furnace because of its wide range of heat treatment processes and applications, fast cycles with high pressure gas quenching and low consumption of energy, process gases and other media. Another undoubted advantage is that Vector is environmentally friendly and has low process gas emissions,” said Li Naixu, chairman of Huake Casting Control (Shanghai) Technology Co., Ltd.
“Huake ​​Casting Control Technology has become our customer as the result of the SECO/WARWICK Group’s increasing reputation in Asia. . . . We want to provide partners with solutions which will allow them to grow and achieve their intended goals related to production, quality and profitability,” said Liu Yedong, managing director of SECO/WARWICK China.
Huake Casting Control Technology Expands Production with Vacuum Furnace Read More »
Turbine Manufacturer Expands Heat Treat Capabilities with Vacuum Furnace
A manufacturer of wind and gas turbines is bolstering its heat treatment capabilities with a vacuum furnace to process oversized gas turbine structural components.
Maciej Korecki
SECO/WARWICK
Source: SECO/WARWICK.com
The vacuum furnace provides a work zone that accommodates the company’s need to heat treat large-sized parts and uses three process gases, argon, nitrogen, and hydrogen, to increase the process purity and reduce gas consumption costs during the cooling process. This is the eighth vacuum furnace the company has purchased from SECO/WARWICK and will be installed at the manufacturer’s European location.
“The demand for gas and wind turbines is systematically growing all over the world, and renewable energy is currently the focus of attention in all industries. It plays an important role in mitigating climate change, which is why it is important for us to be able to support a Partner who focuses on sustainable, renewable, and unlimited green energy,” said Maciej Korecki, vice president of the vacuum segment, SECO/WARWICK Group.
Kamil Siedlecki
Sales Manager
SECO/WARWICK
Source: LinkedIn
“The furnace’s three-gas partial pressure system helps prevent evaporation and sublimation of alloying elements from the load surface during vacuum heat treatment or vacuum brazing. Partial pressure control is important when processing many materials to prevent the hot zone evaporation and contamination,” said Kamil Siedlecki, sales manager at SECO/WARWICK.
Turbine Manufacturer Expands Heat Treat Capabilities with Vacuum Furnace Read More »
2 Vacuum Furnaces Increase Heat Treat for Alternative Energy Company
A company developing advanced alternative renewable energy technologies large-scale industrial applications is expanding their heat treat capabilities with two identical vacuum furnaces.
The Research and Development team of Solar Manufacturing, Solar Atmospheres, assisted the client’s engineers to verify the process in the Mentor® Pro vacuum furnace prior to sending this furnace. Solar Manufacturing shipped the identical vacuum furnaces and assisted the company’s engineers to verify the molybdenum shielded hot zone operation of the new equipment at the developer’s facility. The furnace’s internal gas quenching system processes workloads to quench at 2 bar positive pressure in either nitrogen or argon gas, a flexibility that assists the company in achieving results across a wide range of metallurgical applications.
The client also finds benefit from the compact design of the Mentor® Pro features a molybdenum shielded hot zone measuring 18” wide x 18” high x 36” deep, capable of temperatures up to 2500°F, and a workload weight capacity of up to 1,000 lbs.
2 Vacuum Furnaces Increase Heat Treat for Alternative Energy Company Read More »
