VACUUM FURNACES
Hot Zone Insulation Materials Critical in Preventing Heat Loss
With electricity costs increasing, heat treat facilities are looking for ways to harness energy and minimize heat loss through a variety of insulating methods and applications. Heat Treat Today‘s Technical Tuesday feature comes from Reál J. Fradette of Solar Atmospheres Inc of Souderton, PA (with Nicholas R. Cordisco of Solar Manufacturing Inc. contributing), analyzing the different types of furnace hot zone insulation materials with the following points taken into consideration:
A) Hot Zone Designs
  • All-Metal Designs
  • Ceramic Fiber Included Designs
  • Graphite Type Insulated Hot Zones
B) Defining Hot Zone Losses For Different Hot Zone Configurations
  • Calculating Power Losses For A Given Size Furnace
  • Effect Of Hot Zone Losses On Heating Rates and Peak Power
C) Effect on Power Losses With Various Insulation Layers and Thicknesses
  • Projecting Relative Losses Versus Felt Thicknesses
D) Equating Insulation Designs To Actual Power Usage
  • Projecting Cycle Costs For Different Areas Of Operation
  • Impact of Hot Zone Type on Total Cycle Cost
E) Summary And Conclusions
The heating rate of a load will dictate the total energy required to heat that load at that heating rate. Heating as fast as possible is not often the best solution to the application.
Read more: “Understanding Power Losses In Vacuum Furnaces”
Hot Zone Insulation Materials Critical in Preventing Heat Loss Read More »
Component Repair Technologies Featured in Crain’s Cleveland Business Article: Heat Treat Furnace Highlighted
A recently article in Crain’s Cleveland Business news (click here for full article) featured Component Repair Technologies (CRT), an aerospace heat treating company that performs a wide variety of in-house aircraft engine repair processes including machining, flame spray applications, welding, heat treat, chrome and nickel plating, shot peening, nondestructive testing, visual and dimensional inspection, and acid and alkaline cleaning . The company works on a wide variety of parts from several different engine models.
The Crain’s article featured a photo of a large vertical vacuum furnace manufactured by Solar Manufacturing, Inc. The furnace was designed and built specifically to CRT requirements.
The furnace is critical for CRT’s daily operations and has logged more than four thousand cycles since being commissioned over five years ago. The unit is in use virtually 24 hours a day, seven days a week.  The furnace pictured has a working hot zone 84″ in diameter by 60″ high and will operate to 2400ºF in high vacuum conditions.  The furnace has a hearth capacity of 5,000 lbs. and includes a 300 HP motor fan and heat exchanger for rapid argon gas quenching at up to two atmospheres overpressure.  Under heating and in the vacuum mode, the furnace operates to the mid-10-5 Torr vacuum range — approximately the same vacuum level found on the surface of the moon.
Elevator hearth vacuum furnace at Component Repair Technologies, Mentor, Ohio
(Photo courtesy: Component Repair Technologies, Inc. )
Component Repair Technologies Featured in Crain’s Cleveland Business Article: Heat Treat Furnace Highlighted Read More »
Largest Commercial Vacuum Furnace Nearing Completion
Solar Atmospheres of Western Pennsylvania and Solar Manufacturing, Inc. have been very busy these days building the largest vacuum furnace anywhere in the world.  The working hot zone of this high vacuum (three 35 inch Varian diffusion pumps) furnace is 80 inch diameter X 48 feet long with a maximum operating temperature of 2400°F.  Thirty five points of temperature will be surveyed to within +/- 10°F per the stringent AMS 2750E specification. The robust US Patented dual load car design will have the capacity to transfer up to 150,000 pounds of material in and out of the furnace.  For dimensionally critical, near net shaped jobs, the dual load car design will also have the capability to maintain the critical support needed at elevated temperatures to keep parts flat to within .030 inches.
All of the major components have been delivered and installed.  The gas and water systems are in place.  The remaining installation of all the electrical components and wiring will occur over the next several weeks.  This multi-million dollar project is expected to be completed in June with the commissioning of the furnace into production in July of 2016.  This unique piece of equipment will not only open up new production opportunities within the North American vacuum heat treating markets, but also internationally.
Largest Commercial Vacuum Furnace Nearing Completion Read More »
Solar Manufacturing’s Vacuum Furnace Reference Series
BOTW-50w Source:  Solar Manufacturing’s Vacuum Furnace Reference Series
This series includes eight releases with the following titles.
Release 1:  Critical Melting Points and Reference Data for Vacuum Heat Treating
Release 2:  Optimizing Procedures for Temperature Uniformity Surveying of Vacuum Furnaces
Release 3:  Operating a Vacuum Furnace Under Humid Conditions
Release 4:  Understanding PID Temperature Control as Applied to Vacuum Furnace     Performance
Release 5:  Understanding Power Losses in Vacuum Furnaces
Release 6:  Important Considerations when Purchasing a Vacuum Furnace
Release 7:  Important Considerations when Selecting a Vacuum Furnace Water Cooling System
Release 9:  Understanding Vacuum and Vacuum Measurement
Read More:  Solar Manufacturing’s Resources for Vacuum Heat Treating Releases 1 – 9
Solar Manufacturing’s Vacuum Furnace Reference Series Read More »
