TITAN Vacuum Furnace
Stack Metallurgical Group Adds Vacuum Furnace to its Capabilities
Stack Metallurgical Group, a Nadcap accredited and Northwestern U.S. commercial heat treater, recently installed  a TITAN® vacuum furnace at its location in Spokane Valley, Washington. Formerly known as Inland NW Metallurgical Services, Stack Spokane is one of the company’s four locations offering metal processing services such as vacuum heat treating, induction heat treating, aluminum chemical processing, and ion nitriding. Ipsen USA  completed the installation.
Ron Decker,
General Manager, Stack Metallurgical Services, Inc.
“It was an easy choice adding another Ipsen furnace to our offering,” said General Manager Ron Decker. “We count on Ipsen for a versatile product that delivers great results.”
Installation of the TITAN® H6 2-bar vacuum furnace was completed in late 2019 and will be used to process aerospace components. Stack operates four Ipsen furnaces in Spokane and a dozen more in Portland.
Stack Metallurgical Group Adds Vacuum Furnace to its Capabilities Read More »
Majority of Heat Treatment Done In-House at SKF — New Equipment Purchased
Ipsen recently installed both atmosphere and vacuum heat-treating systems at SKF’s state-of-the-art manufacturing facility in St. Louis, Missouri. With the relocation of their existing facility to a new location, SKF continues to focus on enhancing the quality, efficiency and overall effectiveness of their heat-treating equipment. Among this new Ipsen equipment was a complete ATLAS atmosphere heat-treating system, including two ATLAS integral quench batch furnaces and ancillary equipment – washer, temper, endo generator, loader/unloader and a feed-in/feed-out station. SKF also purchased a TITAN® vacuum heat-treating system to round out their production capabilities.
Heat-treating is considered a core competency at SKF, and this new equipment will allow them to bring the majority of heat treatment in-house and efficiently handle the increase they’ve seen in production demands and volume of parts. Reflecting on the equipment purchased and what appealed to SKF, Bryan Stanford said, “Initially, I would say it was the general purposefulness of these Ipsen products that appealed to us. We run a very large variety of parts and batch quantities here. A custom solution designed to run tens of thousands of the same parts was not going to work for us. We wanted a low-cost, off-the-shelf-type solution that would allow us the flexibility we required – which is what the ATLAS and TITAN delivered. Now after having performed some pre-training, I would say what stands out the most is the ease of use and control of the equipment.”
The ATLAS batch furnaces feature a 24″ W x 36″ D x 30″ H (610 mm x 910 mm x 760 mm) load size with an 1,100-pound (500 kg) load capacity. They also operate at temperatures of 1,400 °F to 1,800 °F (750 °C to 980 °C) and have a quench oil capacity of 1,030 gallons (3,900 L). The TITAN vacuum furnace features an 18″ W x 24″ D x 18″ H (455 mm x 610 mm x 455 mm) load size with a 1,000-pound (454 kg) load capacity. It operates at temperatures of 1,000 °F to 2,400 °F (538 °C to 1,316 °C). Overall, this Ipsen equipment will be used for carburizing, carbonitriding, brazing and annealing and will process a wide variety of parts that support SKF’s Lubrication Business Unit.
Majority of Heat Treatment Done In-House at SKF — New Equipment Purchased Read More »
