TAV: The Vacuum Furnaces Blog
Binder Removal in Vacuum Sintering
Source: TAV: The Vacuum Furnaces Blog
Andrea Alborghetti, Technical Manager of TAV Vacuum Furnaces
Heat Treat Today previously posted Parts 1 and 2 of this series on vacuum sintering. Part 1 focused on the two processing steps of debinding and sintering. Part 2 addressed primarily the vacuum sintering furnace itself. This installment analyzes the process and variables involved with binder removal.
Andrea Alborghetti, technical manager of TAV Vacuum Furnaces and contributor to the company’s blog, provides an analysis of burning vs capturing binders, addressing advantages as well as problems that may arise and how to execute control in the process, as in this example:
“One thing that is worth clarifying is that the flames usually seen on the outlet of kilns that use combustible gases (hydrogen, for example) as the process gas, were not originally designed to burn the binder disassociation residues to reduce emissions to the legal limits. Rather, it is solely for disposing of the emitted hydrogen safely, thus avoiding hazardous, potentially explosive atmospheric concentrations being created outside of the kiln.”
Read more for further analysis of binder removal, including discerning the type of residue found with your process: “Perfect Vacuum Sintering Step by Step #3”
Binder Removal in Vacuum Sintering Read More »
The Vacuum Sintering Furnace Examined
Following up on the first installment of his series on “perfect vacuum sintering” (linked here), Andrea Alborghetti, technical manager of TAV Vacuum Furnaces and contributor to the company’s blog, provides an overview of the right insulation for a vacuum sintering furnace, an examination of hot zone design, the distribution of gas-flow, and the box for loading and unloading.
Read more: “Perfect Vacuum Sintering Step by Step #2”
The Vacuum Sintering Furnace Examined Read More »
Achieving Perfect Vacuum Sintering
Andrea Alborghetti, technical manager of TAV Vacuum Furnaces and contributor to the company’s blog, has provided a comprehensive, step-by-step overview of how to achieve “perfect vacuum sintering”, which includes an explanation of the metallurgic technologies involved; a review of debinding, “the first critical step of sintering”; and the factors to be taken into consideration when choosing what type of heat treatment process to use in order to obtain “a high quality of the end material in terms of density, porosity, and mechanical resistance.”
Read more: “Perfect Vacuum Sintering Step by Step #1”
Achieving Perfect Vacuum Sintering Read More »
