power supply
10 Steps To Troubleshoot Your Induction System
OC
This original content article was first written by Alberto Ramirez, engineer of Power Supply and Automation at Contour Hardening, Inc. and an honoree from Heat Treat Today’s 40 Under 40 Class of 2021, for Heat Treat Today's May 2023 Sustainable Heat Treat Technologies print edition.
Alberto Ramirez
Power Supply and Automation Engineer
Figure 1. Induction hardening process
Figure 2. Induction system components
Figure 3. Capacitors
  • Oscilloscope
  • Function generator
  • Ammeter
  • Digital and analog multimeter
  • High voltage probes
Figure 4. Energy parameters example
Figure 5. Before and after of an arc at the transmission line
Figure 6. Flow diagram of the energy process at the power supply
Figure 7. Coil damage
Figure 8. Possible examples of measurements
  • Temperature
  • Voltage
  • Current
  • Resistance and capacitance
  • Waveforms
Summary
About the Author: Alberto C. Ramirez graduated from the National Technical Institute of Mexico as a mechatronics engineer. He earned his master’s degree in information technology administration from Monterrey Institute of Technology. With more than eight years of experience in power supplies, project management, maintenance, and automation, he currently works as a Power Supply and Automation Engineer at Contour Indianapolis. Alberto began his career at the Contour subsidiary in Mexico and due to his dedication, he is part of the staff in the United States. He is also an honoree from Heat Treat Today's 40 Under 40 Class of 2021.
For more information:
Contact Alberto at Contact Alberto at aramirez@contourhardening.com.
10 Steps To Troubleshoot Your Induction System Read More »
Upfront Planning: What To Expect with Induction Design and Fabrication
OC
This Technical Tuesday article was composed by John Chesna, general manager at Induction Tooling, Inc. and honoree in Heat Treat Today's 40 Under 40Class of 2022. It appears in Heat Treat Today's May 2023 Sustainable Heat Treat Technologies print edition.
John Chesna
General Manager at Induction Tooling
#1 Plan for Inductor Wear
#2 Types of Inductor Designs
  • Pancake: used for heating flat surfaces
  • Single turn or multi-turn: commonly shown as copper tubing wrapped around cylindrically around the workpiece
  • Hairpin: typically, a simple back and forth loop used to heat long lengths internally or externally on the workpiece
  • Split return: used to focus the energy in particular areas of the workpiece
  • MIQ (machined integral quench) paddle: the most commonly used design for scanning applications
#3 Power and Frequency
#4 Part Details
#5 Material Handler
Contact John at jchesna@inductiontooling.com.
Upfront Planning: What To Expect with Induction Design and Fabrication Read More »
