3DPrint.com
Heat Treatment of FDM Parts to Determine Effect on 3D Printing: UT-Arlington Study
Source: 3DPrint.com
A University of Texas at Arlington thesis student recently investigated thermal annealing to determine how to increase inter-bead bond strength overall in 3D printing processes.
Rhugdhrivya Rane tackled the dilemma of weak tensile strength in FDM parts and whether parameters chosen by the user — such as temperature ranges and pressure gradients — can affect an increase in inter-bead bond strength. The researcher used thermal annealing, and thermal annealing with unidirectional mechanical pressure in the Z direction, 3D printing a variety of specimens in ABS. The method of 3D printing was chosen due to its increased popularity in mainstream manufacturing.
“The parts were printed using two different sets of print parameters: high and low settings, to investigate the effect of heat treatment on both sets of print parameters. The values of temperature, time and applied pressure during heat treatment were varied to obtain a detailed comparative study and the correlation between the given variables and the increase in ultimate tensile strength.” ~ Rane
The discovery was that “higher temperatures and longer exposure to heat produced better tensile strength, along with increased ductility.”
“Though thermal annealing and uniaxial pressure cause an increase in the strength of the parts, the print parameters play a vital role in determining the initial mechanical properties of the parts. When the parts are fabricated with a higher value of flow rate and extrusion temperature, they exhibit significantly higher mechanical properties as compared to parts printed with substandard setting,” concluded the researchers. “Thus, by controlling the print parameters and using the right values of temperature and pressure we can see substantial increase in strength of FDM parts.”
Photo credit/caption: via UTA / “Tensile testing of dogbone specimens”
Heat Treatment of FDM Parts to Determine Effect on 3D Printing: UT-Arlington Study Read More »
Laser Sintering vs. Bulk Sintering in a Furnace: Both Have a Place in 3D Metal Printing Industry
Source: 3DPrint.com
Matt Sand, president of 3DEO
Matt Sand, president of 3DEO, discusses the pros and cons of laser sintering and bulk sintering as applied to the 3D printing industry with a particular emphasis on sustainability and low-cost technologies.
Read more: “Metal 3D Printing: Laser Sintering vs. Bulk Sintering in a Furnace – Pros and Cons”
Laser Sintering vs. Bulk Sintering in a Furnace: Both Have a Place in 3D Metal Printing Industry Read More »
Stryker’s Spine Division to Debut 3D Printed Tritanium Posterior Lumbar Cage Spinal Implant
BOTW-50w Source:  3D Print.com
“Stryker’s proprietary Tritanium technology has now been applied to spinal implants designed to encourage healthy regrowth of the bone tissue, and to reduce any strain or damage caused by being implanted. The Tritanium Posterior Lumbar (PL) Cage is a 3D printed intervertebral body fusion device that was developed to help patients dealing with lumbar spinal fixation due to ongoing back problems brought on by degenerative disc disease.”
Read More:  Stryker’s Spine Division to Debut 3D Printed Tritanium Posterior Lumbar Cage Spinal Implant
Stryker’s Spine Division to Debut 3D Printed Tritanium Posterior Lumbar Cage Spinal Implant Read More »
