nitrex turnkey system
Aerospace Manufacturer Expands with 7th Vacuum Furnace
A major North American aerospace manufacturer has placed an order for a seventh vacuum furnace to expand capacity. This furnace is specifically designed for the heat treatment of high-performance engine components and is built to support rigorous production schedules.
Mark Hemsath
Nitrex Turnkey Systems
The vertical, large-precision vacuum furnace, built by G-M Enterprises, a Nitrex Vacuum company, is engineered to meet the aerospace company’s growing production needs and its demand for critical engine components. Six VVF series vacuum furnaces have previously been installed for the manufacturer to produce aircraft engine parts across a range of aerospace applications. The latest furnace order includes a 60” x 60” (1,524 mm x 1,524 mm) chamber with bottom loading, capable of handling loads up to 3,000 lbs (1,360 kg).
“The customer’s decision to expand with Nitrex reflects G-M Enterprises’ proven track record in furnace reliability,” said Mark Hemsath, president of Nitrex Turnkey Systems. “Our commitment to quality has anchored this partnership for over three decades.”
Jay Jefsen
Regional Sales Manager
Nitrex Vacuum
“Our long-standing relationship with this aerospace customer underscores Nitrex’s commitment to providing durable equipment backed by robust technical support,” said Jay Jefsen, regional sales manager for Nitrex Vacuum. “We are proud to contribute to their ongoing success and look forward to supporting their production goals with this latest addition.”
The furnace is scheduled for commissioning in April 2025.
Aerospace Manufacturer Expands with 7th Vacuum Furnace Read More »
Heat Treat Capabilities Increase for Tooling and Machinery Component Manufacturer
Marcin Stokłosa
Project Manager
Nitrex Poland
LinkedIn.com
The YAZICI TRANSFER MAKINA company decided to increase its heat treat capacity in Istanbul with a second turnkey nitrocarburizing system from a Canadian furnace manufacturer. This decision specifically increases the manufacturing capacity of tooling and machinery components for the company’s precision CNC machines. It started production with the new system in the fall of 2021, and is used for Nitreg®-C nitrocarburizing and ONC® in-process oxidation treatments.
This second NITREX furnace is the same type as the first installation, a compact size NXK series furnace that became operational in 2019, simply bigger. Marcin Stokłosa, project manager at NITREX Poland, describes the turnkey system as a "solution that improves the company’s bottom line and reaffirms its commitment to sustainable manufacturing."
For the manufacturer, the Nitreg®-C nitrocarburizing and ONC® in-process oxidation will give a combined ability to improve the wear and corrosion properties of alloy and carbon steel parts.
"In the beginning, YAZICI TRANSFER MAKINA was relying on a very well-known commercial heat treater from the Turkish market to nitrocarburize the parts it needed," says Utku Inan, Nitrex representative in Turkey. "Now, the company has moved heat treating operations in-house, purchasing its own systems to nitrocarburize metal parts, which saves the company on lead time and transportation costs."
Heat Treat Capabilities Increase for Tooling and Machinery Component Manufacturer Read More »
