Melting Furnace
Aluminum Parts Manufacturer Increases Capacity with Melting Furnace
A melting and holding furnace with a preheat hearth and a maximum temperature rating of 1,450°F (788°C) has been shipped to a manufacturer to increase capacity for processing aluminum parts.
Lindberg/MPH announced the shipment of a gas-fired reverberatory aluminum melting and holding furnace with a total holding capacity of 85,000 lbs based on 155 lbs per cubic ft. of molten aluminum and a melt rate of 10,000 pounds per hour. A full width vertically rising air operated door provides access to load the preheat hearth and a full width cleanout door at the rear allows for unloading.
Kelley Shreve
General Manager
Lindberg/MPH
Source: Lindberg/MPH
This melting furnace is designed with an elevated base and bottom mounted magnetic stirring mechanism. An air pressure pump well for dispensing molten aluminum provides the operator with greater ease of use and allows the unit to stand idle over long periods of time such as weekends without having a large temperature differential between the pumper and the furnace.
“This aluminum melting furnace design provides maximum melting efficiency and large capacity. The customer supplied magnetic stirring mechanism helps reduce damaging oxide growth,” said Kelley Shreve, general manager at Lindberg/MPH.
Aluminum Parts Manufacturer Increases Capacity with Melting Furnace Read More »
Melting Furnaces and Twin Chamber Furnace to be Installed
Significant milestones have been obtained with the construction and installation of two 70 mt melting furnaces and the installation of a 105 mt twin chamber furnace. Air pollution control equipment is currently being installed and the pit is being prepared to accept all of the casting equipment which will be installed in 2017. This is all part of GARMCO’s remelt expansion project.
GARMCO designed the plant to meet stringent Bahraini safety and environmental regulations. The new plant will provide GARMCO with the capability to cast an additional 120,000 tonnes of aluminium slab products. Once the slabs are rolled, the finished products will exceed customer quality requirements, improve operational safety, and reduce production costs. The plant is to be fully operational by December 2017.
Fives, the turnkey construction contractor,achieved over 600,000 man hours without any lost time injuries. 2017 will be a challenging year for all personnel on this fast track project that commenced in March 2016 Commissioning of equipment is scheduled for April and the plant should be fully operational by December 2017.
Melting Furnaces and Twin Chamber Furnace to be Installed Read More »
