Upfront Planning: What To Expect with Induction Design and Fabrication
OC
This Technical Tuesday article was composed by John Chesna, general manager at Induction Tooling, Inc. and honoree in Heat Treat Today's 40 Under 40Class of 2022. It appears in Heat Treat Today's May 2023 Sustainable Heat Treat Technologies print edition.
John Chesna
General Manager at Induction Tooling
#1 Plan for Inductor Wear
#2 Types of Inductor Designs
  • Pancake: used for heating flat surfaces
  • Single turn or multi-turn: commonly shown as copper tubing wrapped around cylindrically around the workpiece
  • Hairpin: typically, a simple back and forth loop used to heat long lengths internally or externally on the workpiece
  • Split return: used to focus the energy in particular areas of the workpiece
  • MIQ (machined integral quench) paddle: the most commonly used design for scanning applications
#3 Power and Frequency
#4 Part Details
#5 Material Handler
Contact John at jchesna@inductiontooling.com.
Upfront Planning: What To Expect with Induction Design and Fabrication Read More »
