Manufacturer To Expand Heat Treat Capabilities with Box Furnace
Business Development Manager
Lindberg/MPH
Source: Lindberg/MPH.com
A manufacturer is expanding their heat treat capacities with a new box furnace, designed for air atmosphere applications, from a North American furnace provider.
Lindberg/MPH's heat treat furnace has a maximum temperature rating of 1,250°F and a load capacity of 6,000 lbs and is designed to accept fixtures that are 48" wide by 84" deep by 48" high. A full-width roller hearth is located across the furnace chamber floor for manual loading and load support. Temperature is controlled by a Honeywell DC2500 Series controller with an adjustable alarm set-point and latching output relay; the controller disconnects the power to the heating elements and sounds an audible alarm in an event that temperature exceeds desired set-point.
“The high velocity forced heating system circulates heat evenly within the furnace chamber," commented Bill St. Thomas, business development manager at Lindberg/MPH. "[This] assures rapid and uniform heat transfer throughout the workload.”
Manufacturer To Expand Heat Treat Capabilities with Box Furnace Read More »
