A defense sector manufacturer has selected a vacuum furnace solution to support carburizing and heat treatment of steels used in firearm production. The equipment will be used to improve process efficiency and meet the technological requirements associated with modern weapons manufacturing.
The system will be supplied to a client in the European defense sector by SECO/WARWICK, a global manufacturer of industrial heat treatment equipment with operations in North America, and consists of a single-chamber vacuum furnace to maximize versatility across a range of heat treatment applications for firearm steels. The equipment enables the manufacturer to transition from traditional gas carburizing to low-pressure carburizing (LPC), improving process control, and reducing gas consumption.
Sales Manager
SECO/WARWICK
According to Lukasz Chwialkowski, sales manager at SECO/WARWICK, the furnace features a round heating chamber capable of processing oversized components, LPC technology, and a high-pressure gas quenching (HPGQ) system. High temperature uniformity throughout the working space supports repeatable results, while a convection heating system improves efficiency at lower temperatures. Directional cooling is designed to accommodate complex part geometries. A graphite chamber supports durability and multi-shift hardening operations.
This order is the first collaboration between the European defense sector manufacturer and SECO/WARWICK. The contract holds strategic and technological significance — both for the client, who is modernizing their infrastructure, and for SECO/WARWICK, who is strengthening its position as a key solutions provider for the defense sector.
