HARDENING NEWS
Steel Hardening/Heat Treating Firm Relocates, Relaunches Manufacturing
Source: Sudbury.com
A Canadian steel hardening firm recently relocated its operations to a 54,000-sq ft complex as part of a business relaunch that includes hiring new staff and the startup of active manufacturing.
Northern Heat Treat Ltd , based in Sudbury, Ontario, is in the early stages of full operational capacity since the upgrade and moving of equipment, which will include the purchase of larger heat treating furnaces.
Read more: “Steel Hardening Business Breathes Life Into Capreol Industrial Shops”
Photo caption: George Sidun Jr. and George Sidun Sr. standing in front of Northern Heat Treat Ltd in Sudbury, Ontario/The delivery of a new furnace.
Photo credit: Sudbury.com
Steel Hardening/Heat Treating Firm Relocates, Relaunches Manufacturing Read More »
Hardening and Tempering Line Receives Upgrade
The Ohio-based Engineering Division of Conrad Kacsik Instrument Systems completed a full system upgrade of an automated hardening and tempering line for Nelson Fastening Systems, also located in Ohio. The project involved the removal of the existing control system, VFD drives, limits, and control wiring for Nelson, and included the installation of a new system that features safety controls.
A Honeywell HC900 with a 15-inch operator interface terminal integrated with a computer running Specview HMI software controls a 2-zone hardening furnace, generator, quench tank, water cooling tank, washer, 2-zone tempering furnace, and a blackening unit. The equipment was linked with six conveyors and wired into the four control panels completed by Kacsik’s engineering team.
The old conveyor system had VFD drives that did not communicate with a PLC. The new system was programmed with safety features: in the event of a chain break or a conveyor jam, the system will alarm and automatically shut other conveyors off.
Hardening and Tempering Line Receives Upgrade Read More »
Analysis of Heat Treat on Carburized Ring Gear and Multivariate Regression Model Development
Like most other heat treatments, the carburizing and hardening process is known to introduce dimensional changes and gear distortion [4]. If these size and shape changes can be anticipated and controlled, it is possible to eliminate post–heat treatment machining by designing ring gears that would allow for the heat treat change. Such gear manufacturing would significantly reduce cost and machining-to-assembly time, both of which are critical in a commercial environment and large-scale production.
Read More:  Analysis of Heat Treat Growth on Carburized Ring Gear and Multivariate Regression Model Development
Analysis of Heat Treat on Carburized Ring Gear and Multivariate Regression Model Development Read More »
