Aviation Industry Supplier Expands with HPGQ Furnace
A screws and fasteners manufacturer for the aviation industry is expanding its heat treating operations with a vacuum furnace with high-pressure gas quenching (HPGQ) and high vacuum for multipurpose and dedicated applications. The vacuum’s heating chamber is 16x16x24 in (400x400x600 mm), a compact design that accommodates the company’s small in-house hardening plant while still being large enough to enable efficient heat treatment of multiple components at once.
SECO/WARWICK
The SECO/WARWICK furnace is designed with the ability to work on both nitrogen and argon and includes a round heating chamber with a temperature uniformity of +/-9oF (+/-5oC), and convection heating up to 1590°F (850°C). The Vector HV (high vacuum) furnace meets standards required in the heat treatment of components intended for the aviation industry; material heating processes require cleanliness (which is why an additional argon-partial pressure system was used) and a high heating temperature of 2192oF (1200oC).
“The Client required very short cooling times, which are possible with the use of a 15 bar abs gas blower,” said Maciej Korecki, vice president of the vacuum segment, SECO/WARWICK Group. “Our advantage is that it is a proven solution (our standard but adapted to the partner’s specific requirements). Vector offers wide personalization possibilities, which significantly reduces project costs and ensures faster implementation time.”
Press release is available in its original from here.
Aviation Industry Supplier Expands with HPGQ Furnace Read More »
