Spheroidize Annealing
How to Know Which Softening Process to Use in Your Heat Treatment
Source: Metlab Heat Treat
When steel needs to be softened to alter ductility, toughness, or properties, or to produce a specific microstructure, a heat treater can turn to any one or combination of processes to suit the material or the application.
Metlab Heat Treat’s primer series includes a short explanation of the options available, whether it is
  • annealing, which “removes the internal stresses, which build up as a result of cold working and other fabrication processes;”
  • protective atmosphere normalizing, which “refines the grain size and enhances the uniformity of the microstructure;” or
  • spheroidize annealing, which “is generally done on parts which have been work hardened, to allow them to be further worked, either rolled in the case of coils, or drawn for wire.”
Read more: “Annealing, Protective Atmosphere Normalizing, Spheroidize Annealing”
Photo credit: Metlab Heat Treat
How to Know Which Softening Process to Use in Your Heat Treatment Read More »
Seven Types of Annealing, and Why Bearing Manufacturers Should Turn to Spheroidization
Sources: Machine Manufacturing; Knergize.com
Heat treating more often than not includes the process of annealing in order to induce precise softness; to alter ductility, strength, or properties; or to produce a definite microstructure. Because of the wide variety of steels and metal alloys, it is important for heat treaters to match the correct annealing process with the steel grade and to the application of the parts being treated.
Machine Manufacturing has provided a summary of the annealing process and listed seven types of annealing, describing the process and the objectives for each. Included in the list are:
  1. Complete Annealing
  2. Isothermal Annealing
  3. Incomplete Annealing
  4. Spherification Annealing
  5. Diffusion, or Uniform, Annealing
  6. Stress Relief Annealing
  7. Recrystalization Annealing
Read more: "What Is Annealing and 7 Types of Annealing Process"
Dr. S.B. Sarkar
And to take the analysis into more specific types of annealing, over at Knergize.com, Dr. S.B. Sarkar discusses Spheroidized Annealing and its benefit to bearing manufacturers, describing the metallurgical science behind the process, noting the need to adhere to international standards and specifications, and addressing equipment management and quality control of the process.
Read more: "Why Spheroidised Annealing of Bearing Steel Is Important for Manufacturing Good Quality Bearings"
Photo credit
Seven Types of Annealing, and Why Bearing Manufacturers Should Turn to Spheroidization Read More »
