Heat Treat Radio #96: Making the Leap to Laser Heat Treat with Nic Willis
If you are considering making the leap to laser heat treat, buckle up. Nic Willis, metallurgist/heat treat supervisor of Emerson Professional Tools — RIDGID® TOOLS, and recipient of Heat Treat Today's 40 Under 40 recognition in 2020, shares how he led the company to look at laser hardening for some of their induction heat treated projects. It’s a fascinating story that includes the decision-making process, the transition itself, and the continued implementation of this technology.
Source: Heat Treat Today
We had also seen some quality issues with cracking of these components. I just happened to listen to an episode of Heat Treat Radio that had to do with laser hardening. After I got done listening to the podcast, I reached out to Laser Hard, Inc. We started a conversation about learning more about laser hardening and if it was a fit for this particular product line.
Doug Glenn: So, you heard the podcast episode Heat Treat Radio #11: Laser Heat Treating with Laser Hard and decided to check it out.
The Cost (08:34)
Source: Unsplash.com/Alexander Mills
Nic Willis: Correct.
Source: Laser Hard
Nic Willis: Exactly.
About the expert:
Contact:
Email: Nicolas.Willis@Emerson.com
To find other Heat Treat Radio episodes, go to www.heattreattoday.com/radio.
Heat Treat Radio #96: Making the Leap to Laser Heat Treat with Nic Willis Read More »
