Induction Coils
Anatomy of Induction Coils
Consider the numerous systems in your heat treat operations. What makes up the anatomy of each furnace or system? In this “Anatomy of a . . .” series, industry experts indicate the main features of a specific heat treat system. In this feature, the full-page spread identifies main features of induction coils.
The mark-ups for these reference images are provided by John Gadus, design and sales specialist, Induction Tooling, Inc.
View the full graphics by clicking the image below.
This Technical Tuesday article is drawn from Heat Treat Today’s April/May 2024 Sustainable Heat Treat Technologies print edition, that had a special focus on green heat treat technologies.
Search www.heattreatbuyersguide.com for a list of induction equipment providers to the North American market. If you are an induction equipment supplier and are not listed here, please let us know at editor@heattreattoday.com.
This series will continue in subsequent editions of Heat Treat Today’s print publications. Stay tuned!
Anatomy of Induction Coils Read More »
Induction and Sustainability Tips Part 1: Cleaning and Maintenance
OC
Discover expert tips, tricks, and resources for sustainable heat treating methods Heat Treat Today's recent series.  And, if you're looking for tips on combustion, controls systems, or induction in general, you'll find that too! Part 1, today's tips, digs into cleaning and maintenance
This Technical Tuesday article is compiled from tips in Heat Treat Today's May Focus on Sustainable Heat Treat Technologies print edition. If you have any tips of your own about induction and sustainability, our editors would be interested in sharing them online at www.heattreattoday.com. Email Bethany Leone at bethany@heattreattoday.com with your own ideas!
1. Maintenance of Induction Coils Used in Hardening Applications
Soap and hot water will remove sticky quench and debris.
How should you maintain induction coils used in hardening applications? Elbow grease — a little goes a long way. After each use, a simple solution of soap and hot water will remove sticky quench and debris. Scrub hardened dirt with a Scotch-Brite pad. Check for pitting, arcing, and insulator damage. If all is good, use a hot water rinse, and it’s ready for use. If the inductor is to remain on the machine for an extended period, it is advised to wash it and the associated bus daily. Check for damage. Following this simple procedure will reduce business waste.
Source: William Stuehr, President/CEO, Induction Tooling, Inc.
#partscleaning #inductorcoil #hardening
2. Maintaining Tooling Fixtures for Induction Hardening
Tooling fixtures are usually maintained simply by storing them inside a mandrel and a box. This system will prevent coils from getting distorted.
Most tooling should be rinsed in hot water to wash off the polymer and then dried and stored away for future use.
It is a good practice to use deionized water for cooling the power supplies.
Source: Madhu Chatterjee, President, AAT Metallurgical Services LLC
#partscleaning #toolingfixtures
3. Switch to Aqueous
As industry tries to become more “green,” a number of companies are switching from lubricants that are petroleum or mineral oil-based to water-based (“aqueous”) lubricants instead. However, some of these companies then make the mistake of not changing their degreasing fluids that they use to remove these lubricants prior to their next processing operations, and stay with their standard degreasing fluids, such as acetone or alcohol, which are not effective at fully removing water-based lubricants. Instead, they need to run tests to find an appropriate alkaline-based degreasing fluid for such water-based lubricants, since alkaline-based degreasers will be effective at removing such lubricants. Commonly available dish-detergents (alkaline-based) have been shown to be highly effective for such use.
Source: Dan Kay, Owner, Kay & Associates
#aqueouscleaner #gogreen #lubricants
Induction and Sustainability Tips Part 1: Cleaning and Maintenance Read More »
