“Gear Materials: More Inside Heat Treating Trivia”
Sacrificial Lambs: Hardness Testing and Heat Treating
Source: Gear Technology
Charles D. Schultz, president of Beyta Gear Service
In a recent blog post at Gear Technology, Charles D. Schultz, president of Beyta Gear Service, addressed the importance of accuracy when describing hardness test location and the reason why “sacrificial lambs” are needed during production.
“I cannot emphasize enough that if you are not cutting up parts or coupons you do not know what is really happening during your thermal processing.” ~ Charles D. Schulz
Read more: “Gear Materials: More Inside Heat Treating Trivia”
Photo Credit: Gear Technology
Sacrificial Lambs: Hardness Testing and Heat Treating Read More »
What’s Going on Inside Your Heat Treated Part?
It’s no secret to heat treaters that not all methods work well on all parts and specifications. It’s also a hard fact that false readings can result when applying hardness measuring systems, therefore, says Charles D. Schulz of Gear Technology, “critical service parts often require a few ‘sacrificial lambs’ to be processed along with the production parts.”
“I cannot emphasize enough that if you are not cutting up parts or coupons you do not know what is really happening during your thermal processing.” — Charles D. Schulz
Photo credit: Gear Technology
What’s Going on Inside Your Heat Treated Part? Read More »
