Heat Treater of Military and Aerospace Ceramic Parts Expands with Box Furnace
Source: L&L Special Furnace Company, Inc.
A U.S. manufacturer with a plant in the Midwest received and commissioned a large high-temperature box furnace for processing ceramic matrix parts that will be used in military and aerospace applications.
L&L Special Furnace Company, Inc.'s GHH3350 has an effective work zone of 32” wide x 30” high x 50” deep. The furnace is capable of reaching temperatures up to 3100°F/1700°C under partial atmospheric pressure. A vacuum pump helps to remove oxygen prior to beginning the thermal cycle. The case is sealed for use with inert atmosphere.
Heat Treater of Military and Aerospace Ceramic Parts Expands with Box Furnace Read More »
