AM/3D Trivia
- What was the original name for additive manufacturing (AM), circa 1980s?
A) 3D printing
B) Rapid prototyping (RP)
D) Rapid tooling (RT) - What grade of stainless steel is most commonly used for AM to achieve varying levels of strength, hardness, and elongation when heat treated?
A) 17-4 PH
B) 316L
C) 304
D) 430 - Who is Emanuel “Ely” M. Sachs?
D) An MIT engineering professor who patented the process of metal binder jetting technique in 1993 - What do cast parts made from powder metallurgy methods and AM parts have in common?
C) Parts exhibit porosity
D) None of the above - What are the most commonly adjusted parameters to achieve higher yield strength when heat treating AM parts?
A) Cooling and heating rate
B) Temperature and time
C) Time and pressure
D) Temperature and pressure - Why is HIP known as the “gold standard” for processing AM parts for space?
D) All of the above - What is NOT a potential benefit of additive manufacturing?
A) Immediate cost savings
B) Fast part production
C) Rapid prototyping
D) Opportunity for increased automation and use of robotics - What are the two main categories for most 3D printing methods?
C) Both A and B
D) Neither A nor B - Which alloy was originally developed for aerospace applications but became one of the most common biomedical alloys?
A) Inconel 718
B) Inconel 625
C) Ti-6Al-4V
D) Hastelloy C22 - What was the first rapid prototyping method to produce metal parts in a single process (and is one of the most widely used AM technologies to manufacture Ti-6Al-4V parts)?
A) Powder-bed fusion (PBF)
C) Sheet lamination (SL)
D) Direct metal laser sintering (DMLS) - In what way does high temperature processing — specifically HIP below the annealing temperature (1470°F/799°C) — improve DMLS Ti-6Al-4V parts?
C) Both A and B
D) Neither A nor B - What is the ideal way to process 3D printed parts made using liquid binder polymers?
How Did You Do?
