allen-bradley plc
Mueller Brass Co. Soon to Heat Treat with New Sintering Furnace
A batch sintering furnace will be installed at Mueller Brass Co., a major supplier of brass rod and forgings in the United States. The 60" wide x 90" deep x 30" tall atmosphere box sintering furnace includes an accelerated gas cooling system to improve floor-to-floor cycle time and meet their demanding production needs.
This Gasbarre Thermal Processing Systems box furnace is designed with a maximum operating temperature of 1650°F, a capacity of 14,000 lbs., and utilizes a nitrogen atmosphere. The system incorporates an Allen-Bradley PLC with SSi 9130 control and 12.1" HMI display. Additionally, the indirect fired gas heating system incorporates parallel positioning control for efficiency and process flexibility, and an integrated oxygen analyzer gives Muller Brass Co. the proper furnace environment prior to heating.
Tall atmosphere box sintering from Gasbarre Thermal Processing Systems
Photo Credit: Gasbarre Thermal Processing Systems
Mueller Brass Co. Soon to Heat Treat with New Sintering Furnace Read More »
Heat Treater Upgrades with Annealing Furnace for Brass Parts
HTD Size-PR LogoA Midwest manufacturer of brass components is upgrading their heat treat capabilities with a new furnace. The 24″ wide, 3 zone mesh belt annealing furnace will provide improved energy efficiency, reduced atmosphere consumption, and consistent and reliable part quality, as compared to an older design.
The brass annealing furnace from Gasbarre Thermal Processing Systems is designed with a maximum operating temperature of 1650℉ with a capacity of 800 lbs/hr, and utilizes a blend of nitrogen and hydrogen atmospheres. The system incorporates an Allen-Bradley PLC and HMI with automated atmosphere and water temperature control and datalogging.
Heat Treater Upgrades with Annealing Furnace for Brass Parts Read More »
