A global aerospace supplier is the recipient of a newly designed, state of the art furnace—the first of its type in the world—boasting an entire side-
At 1.75m high, the furnace enables two components to be loaded at one time by way of a trolley, with a gap of half a meter between the external tracks and the internal fixturing. This gap was required to enable the doors to close. The trolley then cantilevers across the gap, thanks in part to the unique design of its axels.
An additional challenge was the temperature conformity and accuracy needed by the customer. The maximum temperature difference across the part was specified to be no greater than +/-
The furnace was designed, delivered and installed by U.K.-based AeroThermal, which designs and manufactures thermal processing equipment for clients in the aerospace, motorsport, military, electronics and tobacco sectors. Accuracy of better than +/-
The furnace is made of a steel structural frame and steel paneling. It is also highly insulated, to the extent that it is possible to touch the vast majority of the oven wall at a temperature marginally above that of ambient whilst the furnace is in operation, minimizing energy usage.
Aerothermal also designed and built in-
