Michigan Heat Treater Increases Gas Nitriding Capacity
Advanced Heat Treat Corp. (AHT) has increased operations at their Monroe, Michigan facility with additional gas nitriding equipment.
Chad Clark
Plant Manager
The new unit will be utilized in heat treatment for industries such as automotive, government and defense, plastics, power generation, and others. It will utilize UltraGlow® Gas Nitriding, which is a case-hardening process whereby nitrogen is diffused into the surface of a solid ferrous alloy by holding the metal at a suitable temperature in contact with a nitrogenous gas, usually ammonia.
AHT Michigan Plant Manager Chad Clark added, “Our mission statement is ‘Exceeding expectations with UltraGlowing results,’ so this is an example of us expanding capacity to provide our customers with great turnaround. We are pleased to offer additional capacity and look forward to the completion of our building expansion and additional equipment/services in the future.”
AHT can accommodate parts up to 400” inches in height, 160” in diameter and up to 60,000 lbs in weight. A few of the common materials used in gas nitriding processes are austenitic stainless steel; martensitic stainless steel; cast materials (gray/ductile/nodular iron); medium carbon steel; and low alloy/low carbon steel.
This equipment follows on the heels of a building expansion for AHT’s Monroe facility.
