Heat Treater Expands Hardening Plant Capabilities
A heat treater with surface hardening capabilities recently expanded its operational line with a vacuum furnace. The new equipment offers a working space of 35.5 x 35.5 x 47 in (900 x 900 x 1200 mm), enabling the processing of larger elements.
This is the 14th vacuum furnace that SECO/WARWICK has provided to Aalberts surface technologies Group, which specializes in vacuum heat treatment, vacuum brazing, hardening of stainless steels, and coating systems for industry. It is the seventh Vector vacuum furnace to be installed at this location in Eindhoven, The Netherlands. It is equipped with high-pressure hardening of 15 bar abs., the option of installing liquid nitrogen, convection heating, directional cooling, and isothermal quenching.
“The solution design is based on the standard VP vacuum furnace Vector type solution. Vector has a round heating chamber and an efficient cooling system,” said Grzegorz Głuchowski, sales manager at SECO/WARWICK. “The additional option of installing liquid nitrogen allows for the load faster cooling after the hardening process. This translates into the furnace’s greater efficiency.”
“This will be the seventh SECO/WARWICK solution operating in Eindhoven. This time, delivery time was key. The solution we ordered is quite specific. We have specific requirements, which are the result of over 80 years of industry experience. The Vector vacuum furnace’s design from the customer’s perspective is very well thought out, as it allows for modifications and additional options. It is one of the most flexible metal heat treatment furnaces on the market,” said Steffen Schneiders, managing director of “The Netherlands & Nordic” from Aalberts surface technologies.
