Vacuum Furnace for 3D Printed Aerospace Components
A vacuum furnace is being supplied for the heat treatment of 3D printed metal components used in the aviation and energy industries. The furnace will meet the requirements of stress-relieving processes for large components produced using additive technology and highly controlled hardening processes.
Maciej Korecki
SECO/WARWICK
SECO/WARWICK, a furnace provider with North American locations, will provide the new equipment. The furnace has a working space of 900 x 900 x 1200 mm and an advanced vacuum system which enables clean processes.
“The new investments of our partner in 3D printing are among the most dynamic undertakings in the field of precision metalworking … Our device is a key element in the chain of post-processing technology and has been designed to perfectly respond to the needs related to annealing and stress removal in additively manufactured elements,” commented Maciej Korecki, vice president of the Vacuum Segment at SECO/WARWICK.
The vacuum furnace is equipped with an efficient high vacuum system (HPGQ) based on two SV300 Leybold pumps, a Roots WH2500 pump, and an HS-32 AGILENT diffusion pump, allowing for vacuum in the 10⁻⁴ mbar range. The device also features a partial pressure system for technical gases, which counteracts the sublimation of alloying elements and contamination of the hot zone. An important addition is the dew point sensor, which protects against moisture condensation in the heating chamber and minimizes the risk of oxidation of the batch surface.
SECO/WARWICK Vector furnace produced image
Source: SECO/WARWICK
The recipient plans to use the device primarily for post-3D printing stress-relief processes, but also for hardening turbine and engine system components.
