Two vacuum induction melting (VIM) casting systems are being deployed to support the production of components used in power generation turbine manufacturing. The systems are designed to produce advanced alloys with controlled microstructures for components operating under demanding thermal and mechanical conditions.
The equipment, engineered to support both equiaxed (EQ) and directionally solidified (DS) casting processes, will be used in the production of high-performance, nickel-based alloy turbine components. These casting technologies are critical for achieving the structural integrity, thermal resistance, and performance consistency required in modern power generation turbines operating under extreme conditions.
Retech
Retech, a U.S.-based company and part of the SECO/WARWICK Group, supplied the two VIM systems. “These systems were designed to build on prior installations while incorporating specific changes requested by the [client] to support their current and future production goals,” said Earl Good, president of Retech. The systems are based on Retech’s core designs but incorporate client-specific modifications, tailoring feeder configurations to align with the client’s established production practices. This enables repeatable casting while maintaining precise thermal and atmospheric control throughout the process.
The order continues a relationship between Retech and the client that dates back to the 1980s, with several legacy systems still in operation at the facility. The client has indicated plans to expand capacity in the coming years, including potential additional system purchases and replacement of older equipment.
Press release is available in its original formĀ here.
