Thomas Johann Seebeck
Thermocouple Trivia by the Dozen
OC
Thermocouples are ubiquitous. Whether you are 20 days or 20 years into the industry, you know the essential role they play in making sure heat treat processes are running efficiently, accurately, and dependably. This quick trivia questionnaire will test your thermocouple knowledge on a dozen either obscure or obvious facts about thermocouples.
Los termopares son ubicuos. Sin importar que tu experiencia en la industria sea de 20 días o 20 años, conoces bien el papel esencial que juegan en asegurar que los procesos de tratamiento térmico avancen de manera eficiente, precisa y confiable...
Take the English version of the quiz below, or find the Spanish translation when you click the flag above right!
This Technical Tuesday article, first published in English and Spanish translations, is found in Heat Treat Today's November 2022 Vacuum print edition
Thermocouple Trivia
1. What thermocouple type potentially has the longest life (but is also the most expensive)?
(a) Type K (Chromel-Alumel)
(b) Type N (Nicrosil-Nisil)
(c) Type R (Platinum-13% Rhodium)
(d) Type J (Iron-Constantan)
2. What is something you might find at home that uses a thermocouple to control its temperature?
(a) Your oven
(b) Your toaster
(c) Your water heater
(d) All of the above
3. What do you need to know when purchasing thermocouples for your heat treat furnace or oven?
(a) The length of the thermocouple
(b) The process application you are running
(c) The type of thermocouple best suited for the
4. Who was Thomas Johann Seebeck?
(a) The person credited with describing the scientific theory behind thermocouples
(b) An advocate for the elimination of thermocouples in furnaces and ovens
(c) A German physicist who was responsible for helping develop rockets for the United States
(d) None of the above
5. What would be the best thermocouple to use to control the temperature of an oil quench tank?
(a) Type R (platinum — 13% rhodium)
(b) Type S (platinum — 10% rhodium)
(c) Type K (chromel-alumel)
(d) Type J (iron-constantan)
6. Why use an over temperature (aka "excess temperature") device on your furnace or oven?
(a) For better process control, it is always helpful to have more than one thermocouple in the furnace/oven
(b) To prevent the furnace temperature from running away and damaging the equipment
(c) An obsolete device no longer required by NFPA 86
(d) A method of ensuring the process being run in the furnace stays close to the set point temperature
7. How are thermocouples used in the heat treat industry?
(a)temperature control devices
(b) As part of a safety system designed to prevent the furnace/oven from running away and damaging itself
(c) To ensure that temperature, the most important process parameter, is maintained within limits necessary to successfully run a heat treat process
8. Why use type K versus type N thermocouples?
(a) Because type K has better accuracy
(b) Because type K has better temperature limits
(c) Because type K is more expensive
9. Thermocouples produce what type of voltage?
(a) PPM (parts per million)
(b) EMF (electromotive force)
(c) EMP (electromagnetic pulse)
(d) mV (millivolt)
10. What are some of the most common reasons why a thermocouple “drifts” or fails in a heat treat furnace or oven?
(a) Age
(b) Running at temperatures higher than its rated use temperature
(c) The wrong thermocouple type is used
11. What is a common problem seen in thermocouples that fail in service?
(a) Green rot (oxidation of chromium)
(b) Metal dusting (aka "catastrophic carburization")
(c) Grain growth
12. Complete the sentence: Types S, R, and B noble metal thermocouples are generally specified for use . . .
(a) . . . when temperatures exceed the upper recommended operating temperatures of base metal thermocouples.
(b) . . . after failing compliance on three SATs .
(c) . . . if the furnace only processes automotive parts.
(d) . . . to safeguard against low temperature readings in large loads.
Trivia Key
Compare your answers with the key on page 26 . How did you stack up in thermocouple knowledge? See where your skills measure up in the scale below.
Learn more about thermocouples in the interview between Doug Glenn and Eric Yeager on page 16 or check out the reference list below.
Alexander, Colleen Stroud, et al. “Application of Ribbon Burners to the Flame Treatment of Polypropylene Films.” Platinum Thermocouple - an Overview | ScienceDirect Topics, 20 June 2008, https://www.sciencedirect.com/topics/engineering/platinum-thermocouple.
“Introduction to Thermocouples.” A Perfect Alliance Between Expertise and Know-How, RDC Control, 16 Dec. 2017, https://rdccontrol.com/thermocouples/thermocouples-101/introduction-to-thermocouples/.
Nash, William, and Eric Yeager. “Industrial Heating Magazine: How Long Should My Thermocouple Last?” Cleveland Electric Laboratories, 13 Sept. 2021, https://clevelandelectriclabs.com/industrial-heating-magazine-how-long-should-my-thermocouple-last/.
REOTemp Instruments. Thermocouple, 2011, https://www.thermocoupleinfo.com/.
Staff, Editorial. “Thermocouples Green Rot Effect.” Inst Tools, 20 Nov. 2019, https://instrumentationtools.com/thermocouples-green-rot-effect/.
“Thomas Johann Seebeck.” Editors of Encyclopaedia, Encyclopaedia Britannica, Encyclopaedia Britannica, Inc., 5 Apr. 2022, https://www.britannica.com/biography/Thomas-Johann-Seebeck.
“What Are Thermocouples Used for?” Enercorp Instruments What Are Thermocouples Used for Comments, 2020, https://enercorp.com/what-are-thermocouples-used-for/.
Heat Treat Today would also like to thank the following for their expert input: Dan Herring, The Heat Treat Doctor® at The HERRING GROUP, Inc.; Hank Prusinski, Summit Aerospace Products Corp.; and Andrew Bassett, Aerospace Testing and Pyrometry.
Thermocouple Trivia by the Dozen Read More »
Termopares: Doce datos menudos
OCLos termopares son ubicuos. Sin importar que tu experiencia en la industria sea de 20 días o 20 años, conoces bien el papel esencial que juegan en asegurar que los procesos de tratamiento térmico avancen de manera eficiente, precisa y confiable. Este breve cuestionario evaluará tu conocimiento de los termopares en una docena de datos entre obvios y triviales.
Take the Spanish translation of this quiz in the version below, or see both the Spanish and the English translation of the quiz where it was originally published: Heat Treat Today's November 2022 Vacuum Furnace print edition.
Traducido por: Shawna Blair
Datos varios de los termopares
1. ¿Cuál es el tipo de termopar que más larga vida puede llegar a tener (aunque también es el más costoso)?
(a) Tipo K (chromel-alumel)
(b) N (nicrosil-nisil)
(c) Tipo R (platino-13% rodio)
(d) Tipo J (hierro-constantan)
2. ¿Cuál de estos electrodomésticos que podrías tener en casa utiliza un termopar para controlar la temperatura?
(a)  El horno
(b)  La tostadora
(c)  El calentador de agua
(d) Todas las anteriores
3. ¿Qué debes saber a la hora de comprar termopares para tu horno de tratamiento térmico?
(a) La longitud del termopar
(b) La aplicación propuesta del proceso a realizar
(c) El tipo de termopar que mejor se adapta a la aplicación
4. ¿Quién fue Thomas Johann Seebeck?
(a) La persona a la que se le atribuye la teoría científica en la que se fundamentan los termopares
(b) La persona que abogó por la eliminación de los termopares en hornos
(c) Un físico alemán responsable de apoyar en el desarrollo de cohetes para los Estados Unidos
(d) Ninguna de las anteriores
5. ¿Cuál termopar sería el más indicado para controlar la temperatura de un tanque para temple en aceite?
(a) Tipo R (platino-13% rodio)
(b) Tipo S (platino-10% rodio)
(c) Tipo  K (chromel-alumel)
6. ¿Por qué motivo se  implementaría en un horno un dispositivo de protección contra temperatura en exceso, o ¨sobre¨ temperatura?
(a)  Para lograr un mejor control del proceso es favorable utilizar en el horno o caldera más de un termopar
(b)  Serviría para  impedir que la temperatura del horno se disparara ocasionando daños al equipo
(c) Un dispositivo obsoleto que la norma NFPA 86 ya no exige
(d)  Permitiría asegurar que el proceso que se adelante en el horno se mantenga cercano al punto de temperatura establecido
7. ¿Cómo se utilizan hoy en día los termopares en la industria del tratamiento térmico?
(a)  Como dispositivos de control de temperatura
(b)  Como parte de un sistema de seguridad diseñado para evitar que la temperatura del horno se dispare ocasionando que el horno se destruya
(c)  Como mecanismo que asegura que la temperatura, el parámetro más importante de un proceso de tratamiento térmico, no se salga de los límites indicados para lograr un resultado exitoso
8. ¿Por qué motivo se utilizaría un termopar tipo K en lugar de uno tipo N?
(a) Porque el tipo K es más exacto
(b) Porque el tipo K tiene mejores límites de temperatura
(c) Porque el tipo K es más costoso
9. ¿Qué tipo de voltaje generan los termopares?
(a) PPM (parte por millón)
(b) EMF (fuerza electromotriz)
(c) EMP (pulso electromagnético)
(d) mV (milivoltios)
10. ¿Cuáles son algunas de las causas más comunes de que la calibración del termopar de un  horno o caldera de tratamiento térmico se desvíe o falle?
(a) Edad
(b) Manejo a temperaturas superiores al límite recomendado
(c) Utilización del termopar equivocado
11. ¿Qué problema comúnmente se observa en los termopares que fallan en el uso?
(a) Moho verde (oxidación de cromo)
(b) Metal dusting (carburización catastrófica)
(c) Crecimiento de grano
12. Complete la frase: Los termopares de metales nobles Tipo S, R y B por lo general se especifican para uso…
(a) . . . en casos en los que las temperaturas superan la máxima recomendada para operar los termopares de metales base.
(b) . . . luego de caer en incumplimiento en tres pruebas SAT (prueba de exactitud del sistema, por sus siglas en inglés).
(c) . . . cuando la caldera solo se usa para procesos de piezas automovilísticas.
(d) . . . para prevenir que se baje demasiado la temperatura en cargas grandes.
Clave de Doce datos menudos
Compara tus respuestas de la página 27 con la clave a continuación. ¿Cómo te fue en conocimiento de termopares? Califi ca tushabilidades de acuerdo a la escala que encontrarás líneas abajo.
Para aprender más acerca de los termopares, lee la entrevista entre Doug Glenn y Eric Yeager en la página 16, o revisa la lista de obras referenciadas al fi nal de esta página.
Referencias
[1] Alexander, Colleen Stroud, et al. “Application of Ribbon Burners to the Flame Treatment of Polypropylene Films.” Platinum Thermocouple - An Overview [“Aplicación de quemadores de cinta al fl ameado de película de polipropileno.” Termopar de platino - un resumen.] | ScienceDirect Topics, 20 June 2008, https://www.sciencedirect.com/topics/engineering/platinum-thermocouple.
[2] “Introduction to Thermocouples.” A Perfect Alliance Between Expertise and Know-How [¨Introducción a Termopares. Una alianza perfecta entre la experticia y el conocimiento¨], RDC Control, 16 Dec. 2017, https://rdccontrol.com/thermocouples/thermocouples-101/introduction-to-thermocouples/.
[3] Nash, William, and Eric Yeager. “Industrial Heating Magazine: How Long Should My Thermocouple Last?” [¨Revista de Calentamiento Industrial: ¿Cuánto debería durar mi termopar?¨] Cleveland Electric Laboratories, 13 Sept. 2021, https://clevelandelectriclabs.com/industrial-heating-magazine-how-long-should-my-thermocouple-last/.
[4] Staff , Editorial. “Thermocouples Green Rot Eff ect.” [¨Efecto moho verde en termopares¨] Inst Tools, 20 Nov. 2019, https://instrumentationtools.com/thermocouples-green-rot-effect/.
[5] REOTemp Instruments. Thermocouple [Termopar], 2011, https://www.thermocoupleinfo.com/.
[6] “Thomas Johann Seebeck.” Editors of Encyclopaedia, Encyclopaedia Britannica, Encyclopaedia Britannica, Inc., 5 Apr. 2022, https://www.britannica.com/biography/Thomas-Johann-Seebeck.
[7] “What Are Thermocouples Used for?” [¨¿Para qué se utilizan los termopares?¨] Enercorp Instruments What Are Thermocouples Used for Comments, 2020, https://enercorp.com/what-are-thermocouples-used-for/.
Heat Treat Today agradece la colaboración de estos expertos: Dan Herring, The Heat Treat Doctor® del HERRING GROUP, Inc.; Hank Prusinski, Summit Aerospace Products Corp.; y Andrew Bassett, Aerospace Testing and Pyrometry.
Termopares: Doce datos menudos Read More »
