Ontario Furnace Maker To Expand, Increase Production
A North American furnace manufacturer recently announced plans to increase production capabilities by expanding its Ontario facility. The investment will consist of adding 45,000 square feet of modern manufacturing space as well as 18,000 square feet of office space. Construction is underway and is expected to be complete May of 2025.
CAN-ENG Furnaces International, Ltd., based in Niagara Falls, Ontario, CA, indicated the capacity expansion will be to their Plant #2 Operations in St. Catharines, Ontario. The manufacturing space will be outfitted with fabrication, assembly, and testing equipment to serve the changing needs of the industries they serve with thermal processing equipment, including stamping and fastener companies, electric vehicle and automotive component producers, the iron and steel industries, aluminum foundries, and agricultural, and construction manufacturers.
This expansion will double the current floor space and integrate enhanced overhead lifting capabilities to accommodate larger thermal processing systems being demanded by EV component and battery material processors. Upgrades include the addition of two 30-ton and two 20-ton overhead cranes to accompany the existing units presently in use. Future expansion plans that include foundation and utility upgrades have been considered during the design process.
Ontario Furnace Maker To Expand, Increase Production Read More »
